Implementing Robust OAuth Token Refresh for Long-Running Genesys Cloud Batches
- You will build a resilient HTTP client wrapper that automatically detects expired access tokens and refreshes them without interrupting a batch processing job.
- This tutorial uses the Genesys Cloud CX REST API and the
requestslibrary in Python. - The solution handles
401 Unauthorizedresponses caused by token expiration and implements exponential backoff for rate limiting.
- OAuth Client Type: A Genesys Cloud CX OAuth Client with
client_credentialsgrant type enabled. - Required Scopes: Depending on your batch operation, you need specific scopes (e.g.,
analytics:report:readfor analytics,user:readfor user data). For this tutorial, we assume a genericuser:readscope. - SDK/Library: Python 3.8+ with
requestsandpython-dotenvinstalled. - Environment Variables: You must have
GENESYS_CLOUD_REGION,GENESYS_CLOUD_CLIENT_ID, andGENESYS_CLOUD_CLIENT_SECRETdefined in your environment or a.envfile.
Genesys Cloud CX access tokens have a default lifetime of 3600 seconds (1 hour). If your batch job processes data for longer than this window, or if the token was issued slightly earlier in your application lifecycle, the token will expire mid-execution.
The standard client_credentials flow does not provide a refresh token. You must re-request the access token using your client credentials when the old one fails.
Step 1: Secure Credential Management
Never hardcode credentials. Use environment variables.
import os
# Load environment variables from .env file
load_dotenv()
GENESYS_REGION = os.getenv("GENESYS_CLOUD_REGION", "my.genesys.cloud")
CLIENT_ID = os.getenv("GENESYS_CLOUD_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLOUD_CLIENT_SECRET")
if not all([CLIENT_ID, CLIENT_SECRET]):
raise ValueError("GENESYS_CLOUD_CLIENT_ID and GENESYS_CLOUD_CLIENT_SECRET are required.")
# Construct the token URL based on region
# Note: EU regions use eu.genesys.cloud, others use my.genesys.cloud
TOKEN_URL = f"https://{GENESYS_REGION}/oauth/token"
API_BASE_URL = f"https://{GENESYS_REGION}/api/v2"
Step 2: The Token Fetcher Function
This function requests a new access token. It must be robust because it will be called during error recovery.
import requests
import logging
from typing import Optional, Tuple
def fetch_access_token(client_id: str, client_secret: str, token_url: str) -> Tuple[Optional[str], Optional[int]]:
Fetches a new access token from Genesys Cloud OAuth endpoint.
Returns:
Tuple[Optional[str], Optional[int]]: (access_token, http_status_code)
payload = {
"client_id": client_id,
"client_secret": client_secret
response = requests.post(token_url, data=payload, timeout=10)
if response.status_code == 200:
data = response.json()
access_token = data.get("access_token")
if access_token:
logger.info("Successfully fetched new access token.")
return access_token, 200
else:
logger.error("Token response missing 'access_token' field.")
return None, 500
else:
logger.error(f"Failed to fetch token. Status: {response.status_code}, Body: {response.text}")
return None, response.status_code
logger.error(f"Network error while fetching token: {e}")
return None, 500
The core of this tutorial is the GenesysApiClient class. This class wraps the requests library to intercept HTTP errors. Specifically, it checks for 401 Unauthorized (indicating an expired or invalid token) and 429 Too Many Requests (rate limiting).
Step 1: Building the Resilient Client Class
This client maintains the current token and knows how to refresh it. It implements a retry mechanism specifically for authentication failures.
class GenesysApiClient:
def __init__(self, base_url: str, token_url: str, client_id: str, client_secret: str):
self.base_url = base_url
self.token_url = token_url
self.client_id = client_id
self.session = requests.Session()
# Initial token fetch
self._refresh_token()
def _refresh_token(self) -> bool:
Attempts to refresh the access token.
Returns True if successful, False otherwise.
token, status = fetch_access_token(self.client_id, self.client_secret, self.token_url)
if status == 200 and token:
self.access_token = token
return True
return False
def _get_headers(self) -> dict:
if not self.access_token:
raise RuntimeError("No access token available. Authentication failed.")
"Authorization": f"Bearer {self.access_token}",
def request(self, method: str, endpoint: str, params: Optional[dict] = None,
json_body: Optional[dict] = None, max_retries: int = 3) -> requests.Response:
Sends an HTTP request with automatic token refresh on 401 and backoff on 429.
Args:
method: HTTP method (GET, POST, etc.)
endpoint: API path (e.g., '/users')
params: Query parameters
json_body: JSON request body
max_retries: Maximum number of retries for 401 errors
retries = 0
last_exception = None
while retries <= max_retries:
# Construct the full URL
url = f"{self.base_url}{endpoint}"
# Make the request
response = self.session.request(
method=method,
url=url,
headers=self._get_headers(),
params=params,
json=json_body,
timeout=30
# Handle 401 Unauthorized: Token likely expired
if retries < max_retries:
logger.warning(f"Received 401. Attempting token refresh (retry {retries + 1}/{max_retries})...")
retries += 1
# Try to refresh the token
if self._refresh_token():
continue # Retry the request with the new token
# If refresh failed, break the loop to raise the error
logger.error("Token refresh failed. Giving up.")
break
else:
logger.error("Max retries reached for 401 error.")
break
# Handle 429 Too Many Requests: Rate Limiting
retry_after = int(response.headers.get("Retry-After", 5))
logger.warning(f"Rate limited (429). Waiting {retry_after} seconds...")
time.sleep(retry_after)
# Do not increment retries for 429, just wait and retry immediately
# If we get here, the request did not fail with 401 or 429
response.raise_for_status() # Raise exception for other 4xx/5xx
return response
last_exception = e
# If it's not 401 or 429, and we are out of retries, stop
if e.response.status_code not in (401, 429):
break
retries += 1
last_exception = e
retries += 1
if retries <= max_retries:
time.sleep(2 ** retries) # Exponential backoff for network errors
# If we exit the loop, raise the last error
if last_exception:
raise last_exception
raise RuntimeError("Request failed unexpectedly without a specific error.")
Step 2: Implementing the Batch Logic with Pagination
Batch jobs often involve iterating through paginated results. If a token expires during the loop, the standard requests call would fail. Our GenesysApiClient handles this transparently.
We will query the /api/v2/users endpoint to fetch all users in the organization. This is a common batch operation that can exceed token lifetimes if the organization is large or if there are network delays.
def fetch_all_users(client: GenesysApiClient) -> list:
Fetches all users from Genesys Cloud using pagination.
Demonstrates token refresh mid-batch.
all_users = []
page = 1
page_size = 100
logger.info("Starting batch user fetch...")
while True:
# The client.request method handles 401/429 internally
response = client.request(
method="GET",
endpoint="/users",
params={
"page_size": page_size,
"page_number": page
entities = data.get("entities", [])
if not entities:
logger.info(f"No more users found at page {page}.")
break
all_users.extend(entities)
logger.info(f"Fetched {len(entities)} users from page {page}. Total so far: {len(all_users)}")
# Check if there are more pages
# Genesys Cloud returns 'nextPage' in the response if available
if "nextPage" not in data:
logger.info("Reached the last page.")
break
page += 1
# Simulate a long-running process to increase chance of token expiry in testing
# In production, remove this sleep. It is here to demonstrate resilience.
# time.sleep(10)
logger.error(f"HTTP Error during fetch: {e}")
# If the client exhausted retries, this exception bubbles up
break
logger.error(f"Unexpected error: {e}")
break
return all_users
Step 3: Processing Results
Once the data is fetched, you can process it. Note that the processing logic is separate from the fetching logic. This separation ensures that if a network issue occurs during processing (e.g., writing to a database), it does not corrupt the token state.
def process_users(users: list) -> None:
Example processing function.
for user in users:
# Example: Log user ID and name
logger.debug(f"Processing User: {user.get('id')} - {user.get('name')}")
# In a real scenario, you might update an external DB or send to a queue
# db.save(user)
logger.info(f"Successfully processed {len(users)} users.")
Below is the full, copy-pasteable script. Save this as genesys_batch_refresh.py.
import os
import requests
import logging
# Configure logging
level=logging.INFO,
format='%(asctime)s - %(levelname)s - %(message)s'
load_dotenv()
payload = {
if access_token:
else:
return None, 500
else:
return None, 500
if not self._refresh_token():
raise RuntimeError("Failed to obtain initial access token.")
return True
return False
retries = 0
method=method,
url=url,
params=params,
json=json_body,
timeout=30
retries += 1
break
else:
break
return response
last_exception = e
break
retries += 1
last_exception = e
retries += 1
if last_exception:
all_users = []
page = 1
page_size = 100
while True:
method="GET",
endpoint="/users",
params={
"page_number": page
if not entities:
break
break
page += 1
break
break
return all_users
for user in users:
# Initialize the resilient client
client = GenesysApiClient(
base_url=API_BASE_URL,
token_url=TOKEN_URL,
client_id=CLIENT_ID,
client_secret=CLIENT_SECRET
# Run the batch job
users = fetch_all_users(client)
# Process the results
process_users(users)
logger.info("Batch job completed successfully.")
logger.error(f"Batch job failed: {e}")
Error: 401 Unauthorized After Refresh
What causes it: The client_credentials grant failed, or the client ID/secret is invalid.
How to fix it:
- Verify
GENESYS_CLOUD_CLIENT_IDandGENESYS_CLOUD_CLIENT_SECRETare correct. - Ensure the OAuth Client in Genesys Cloud Admin is active.
- Check the logs for the specific error body from the
/oauth/tokenendpoint.
# In fetch_access_token, inspect response.text on non-200 status
if response.status_code != 200:
logger.error(f"OAuth Error: {response.text}")
What causes it: You are exceeding the rate limit for the API endpoint (e.g., 100 requests per minute for /users).
How to fix it:
- Implement exponential backoff (already included in the
GenesysApiClient). - Respect the
Retry-Afterheader. - Reduce
page_sizeif you are making too many requests due to small pages, or increase it to reduce total request count.
Error: Token Expires Mid-Request
What causes it: The token expired at the exact millisecond the request was sent.
How to fix it: The GenesysApiClient retries the request after refreshing the token. If this happens frequently, consider refreshing the token proactively before it expires (e.g., at 80% of its lifetime) rather than reactively on 401. However, reactive refresh is simpler and sufficient for most batch jobs.
Error: Missing Scopes
What causes it: The OAuth Client does not have the required scope for the endpoint.
How to fix it:
- Go to Genesys Cloud Admin > Security > OAuth Clients.
- Edit your client.
- Add the required scope (e.g.,
user:read). - Restart your application to force a new token fetch with the new scope.
