Implementing Retrieval-Augmented Generation (RAG) Pipelines with Guardrails for Agent Copilot
You are building a production-grade Retrieval-Augmented Generation (RAG) pipeline that powers an Agent Copilot sidebar in Genesys Cloud-giving agents real-time, grounded knowledge article suggestions and next-best-response recommendations during live interactions. When complete, your RAG system will retrieve the top-k most semantically relevant knowledge articles from a vector store based on the live conversation transcript, inject them as context into an LLM prompt, generate a suggested response, apply safety guardrails to prevent hallucination and policy violations, and deliver the suggestion to the agent’s desktop within 1.5 seconds of each customer utterance-fast enough to be genuinely useful during a live conversation.
- Genesys Cloud: CX 2 or 3 with Digital channels or Genesys Agent Assist.
- Infrastructure:
- A vector database (Pinecone, Weaviate, pgvector, or Qdrant).
- An embedding model (OpenAI
text-embedding-3-smallorsentence-transformers/all-MiniLM-L6-v2). - An LLM inference endpoint (OpenAI GPT-4o-mini, Anthropic Claude Haiku, or self-hosted Qwen via Ollama).
- A FastAPI service acting as the RAG backend.
- Genesys Cloud Notification API subscription for real-time conversation transcript events.
1. Why RAG Rather than Fine-Tuning?
| Approach | Update Frequency | Risk of Hallucination | Knowledge Freshness |
| Fine-tuning | Requires model retraining (weeks/monthly) | Medium - model may confabulate when off-domain | Stale between retraining cycles |
| RAG | Update vector store in real time | Low - answers are grounded in retrieved documents | Always fresh - new articles indexed immediately |
For a contact center knowledge base that changes frequently (product updates, policy changes, SLA adjustments), RAG is the correct architecture. Fine-tuning is reserved for teaching the model how to respond (tone, format, brand voice), not what to know.
2. Knowledge Base Indexing Pipeline
from sentence_transformers import SentenceTransformer
from qdrant_client import QdrantClient
from qdrant_client.models import Distance, VectorParams, PointStruct
import hashlib, uuid
embedding_model = SentenceTransformer('sentence-transformers/all-MiniLM-L6-v2')
qdrant = QdrantClient(url="http://localhost:6333")
COLLECTION_NAME = "contact_center_knowledge"
def setup_collection():
qdrant.recreate_collection(
collection_name=COLLECTION_NAME,
vectors_config=VectorParams(size=384, distance=Distance.COSINE)
def index_knowledge_article(article_id: str, title: str, content: str, category: str, tags: list):
Chunks and indexes a knowledge article into the vector store.
Articles are chunked into 400-token overlapping segments for better retrieval precision.
chunks = chunk_text(content, max_tokens=400, overlap=50)
points = []
for i, chunk in enumerate(chunks):
embedding = embedding_model.encode(chunk).tolist()
chunk_id = str(uuid.uuid4())
points.append(PointStruct(
id=chunk_id,
vector=embedding,
payload={
"article_id": article_id,
"title": title,
"category": category,
"tags": tags,
"chunk_index": i,
"chunk_text": chunk,
"total_chunks": len(chunks)
qdrant.upsert(collection_name=COLLECTION_NAME, points=points)
print(f"Indexed article '{title}' → {len(chunks)} chunks")
def chunk_text(text: str, max_tokens: int = 400, overlap: int = 50) -> list[str]:
"""Simple word-based chunker with overlap."""
words = text.split()
chunks = []
i = 0
while i < len(words):
chunk = ' '.join(words[i:i + max_tokens])
chunks.append(chunk)
i += (max_tokens - overlap)
return chunks
3. The RAG Retrieval and Generation Pipeline
import openai
from qdrant_client.models import SearchRequest
openai_client = openai.AsyncOpenAI()
async def generate_agent_suggestion(
conversation_transcript: str,
customer_last_utterance: str,
agent_context: dict # queue name, customer tier, interaction metadata
) -> dict:
Full RAG pipeline: retrieve → augment → generate → guardrail → return.
Target latency: < 1.5 seconds end-to-end.
# Step 1: Embed the customer's last utterance (not the full transcript)
# Using just the last utterance keeps retrieval focused on the immediate need
query_embedding = embedding_model.encode(customer_last_utterance).tolist()
# Step 2: Retrieve top-5 most relevant knowledge chunks
search_results = qdrant.search(
query_vector=query_embedding,
limit=5,
score_threshold=0.65 # Minimum relevance score - don't retrieve unrelated docs
if not search_results:
"suggestion": None,
"confidence": 0.0,
"reason": "No relevant knowledge articles found for this query.",
"sources": []
# Step 3: Build the augmented prompt
retrieved_context = "\n\n".join([
f"[Article: {r.payload['title']}]\n{r.payload['chunk_text']}"
for r in search_results
system_prompt = f"""You are an expert contact center agent assistant for {agent_context.get('company_name', 'our company')}.
Your role is to provide brief, accurate response suggestions to agents handling customer inquiries.
RULES:
1. Base your suggestion ONLY on the provided knowledge articles - do not add information not found in the articles.
2. If the articles don't contain sufficient information to answer the customer's question, say so explicitly.
3. Keep suggestions under 3 sentences - agents need concise guidance, not essays.
4. Write in a professional, empathetic tone matching our brand voice.
5. Never suggest actions outside agent authority (e.g., issuing credits over $50 requires supervisor approval).
KNOWLEDGE ARTICLES:
{retrieved_context}
CUSTOMER TIER: {agent_context.get('customer_tier', 'standard')}
QUEUE: {agent_context.get('queue_name', 'General Support')}"""
user_prompt = f"""Recent conversation:
{conversation_transcript[-1500:]} # Last 1500 chars to stay within context window
Customer just said: "{customer_last_utterance}"
Provide a suggested response for the agent:"""
# Step 4: Generate (with timeout budget - 1 second max for LLM call)
response = await openai_client.chat.completions.create(
model="gpt-4o-mini",
messages=[
{"role": "system", "content": system_prompt},
{"role": "user", "content": user_prompt}
max_tokens=150,
temperature=0.3, # Low temperature for factual, consistent responses
timeout=1.0
suggestion = response.choices[0].message.content.strip()
# Step 5: Apply guardrails
guardrail_result = apply_guardrails(suggestion, agent_context)
if not guardrail_result["passed"]:
"suggestion": None,
"confidence": 0.0,
"reason": f"Guardrail blocked: {guardrail_result['reason']}",
"sources": []
"suggestion": suggestion,
"confidence": round(search_results[0].score, 3),
"sources": [{"title": r.payload["title"], "score": round(r.score, 3)} for r in search_results[:3]],
"reason": "Generated from knowledge base"
4. Guardrails - Preventing Hallucination and Policy Violations
import re
POLICY_VIOLATION_PATTERNS = [
(r'\$\d{3,}', "Suggests credit/refund over $100 - requires supervisor"),
(r'guarantee|guaranteed', "Absolute guarantees require manager approval"),
(r'sue|legal action|attorney', "Legal threat references require escalation to Legal"),
(r'confidential|internal only', "Potential internal data exposure"),
def apply_guardrails(suggestion: str, agent_context: dict) -> dict:
Applies safety guardrails to the generated suggestion.
Returns {"passed": bool, "reason": str}.
suggestion_lower = suggestion.lower()
# Check policy violation patterns
for pattern, reason in POLICY_VIOLATION_PATTERNS:
if re.search(pattern, suggestion, re.IGNORECASE):
return {"passed": False, "reason": reason}
# Check for explicit uncertainty indicators (good - model is being honest)
# Don't block these, but flag for transparency
has_uncertainty = any(phrase in suggestion_lower for phrase in [
"i'm not sure", "i don't have information", "you should consult",
"based on the information available"
# Minimum quality check - don't send empty or near-empty suggestions
if len(suggestion.strip()) < 20:
return {"passed": False, "reason": "Suggestion too short to be useful"}
return {"passed": True, "reason": "passed"}
Edge Case 1: Retrieval Returns High-Score but Wrong-Category Articles
The similarity search returns a high-scoring article about “billing dispute resolution” when the customer is asking about a “technical connectivity issue.” Both mention “account” and “resolve” heavily, causing false retrieval.
Solution: Add category filtering to the vector search. If the IVR/bot has already classified the interaction type (technical, billing, retention), apply a metadata filter to restrict retrieval to the relevant category: filter={"category": {"$in": ["technical", "general"]}}.
Edge Case 2: RAG Latency Exceeds 1.5 Seconds During High Traffic
Under load, the vector search + LLM call chain takes 2.5+ seconds. By the time the suggestion arrives, the agent has already responded.
Solution: Implement speculative generation: pre-generate suggestions for the 5 most common intents as soon as the interaction starts (predicted from IVR selections or opening message). Cache them. If the customer’s actual question matches a pre-generated suggestion, serve it instantly from cache.
Edge Case 3: Agent Receives Conflicting Suggestions from Multiple Knowledge Articles
Article A says the refund window is 30 days. Article B (an older version) says 14 days. The RAG system retrieves both and the LLM synthesizes an uncertain “between 14 and 30 days” response.
Solution: Implement knowledge article versioning with a last_updated metadata field. During retrieval, prefer more recently updated articles using a recency boost in the similarity score: final_score = cosine_score * 0.8 + recency_score * 0.2. Archive (don’t delete) old articles to preserve the index but suppress them from production retrieval.
