Implementing Resilient WebSocket Reconnection in Genesys Cloud Web Messaging Clients
You will build a TypeScript module that maintains a persistent Web Messaging connection to Genesys Cloud, automatically recovers from network partitions using exponential backoff with jitter, and guarantees message delivery by buffering unacknowledged payloads and resending them via the Guest API upon session restoration. This implementation uses the Genesys Cloud Web Messaging WebSocket endpoint and the /api/v2/webchat/guests REST API. The code is written in TypeScript and runs in Node.js 18+ or modern browsers.
  • OAuth 2.0 client with the webchat:guest:write scope, or a valid api_key header value
  • Genesys Cloud Web Messaging API v2
  • TypeScript 5.0+ with ES2022 target
  • Node.js 18+ runtime or a browser environment with native WebSocket and fetch support
  • Dependencies: uuid (for message ID generation), @types/uuid
Genesys Cloud Web Messaging requires a session token before establishing a WebSocket connection. You obtain this token by creating a guest session. The following function handles authentication and caches the token for reuse across reconnection cycles.
interface GuestSession {
  webchatInstanceId: string;
  token: string;
  expiresAt: number;
const ORG_HOSTNAME = process.env.GENESYS_ORG_HOSTNAME || 'your-org.mypurecloud.com';
const OAUTH_TOKEN = process.env.GENESYS_OAUTH_TOKEN || '';
async function authenticateGuest(): Promise<GuestSession> {
  const url = `https://${ORG_HOSTNAME}/api/v2/webchat/guests`;
  const response = await fetch(url, {
    method: 'POST',
    headers: {
      'Authorization': `Bearer ${OAUTH_TOKEN}`
    body: JSON.stringify({
      guest: {
        email: 'anonymous@local',
        firstName: 'Guest',
        lastName: 'User'
  if (!response.ok) {
    if (response.status === 401) throw new Error('Invalid OAuth token or missing webchat:guest:write scope');
    if (response.status === 403) throw new Error('Account lacks Web Messaging entitlement');
    if (response.status === 429) throw new Error('Rate limited on guest creation. Back off and retry.');
    if (response.status >= 500) throw new Error('Genesys Cloud service unavailable. Retry with exponential backoff.');
    throw new Error(`Guest creation failed with status ${response.status}`);
  const data = await response.json();
    webchatInstanceId: data.webchatInstanceId,
    token: data.token,
    expiresAt: Date.now() + (data.expiresIn * 1000)
The token field returned by the Guest API serves as a bearer token for all subsequent Web Messaging REST calls and WebSocket authentication. The module caches this session to avoid unnecessary guest creation during transient network drops.
Step 1: WebSocket Initialization and Health Monitoring
The Web Messaging WebSocket endpoint requires the instance ID and guest token. You must monitor connection health by tracking the last successful ping/pong exchange or message acknowledgment. The following class manages the WebSocket lifecycle and health state.
interface MessagePayload {
  type: 'message';
  content: string;
  messageId: string;
interface AckPayload {
  type: 'messageReceived';
  messageId: string;
class WebMessagingConnection {
  private ws: WebSocket | null = null;
  private isHealthy = false;
  private healthCheckInterval: ReturnType<typeof setInterval> | null = null;
  private lastAckTimestamp = 0;
  private readonly HEALTH_TIMEOUT_MS = 30000;
  constructor(
    private instanceId: string,
    private token: string,
    private onMessage: (msg: MessagePayload) => void,
    private onAck: (messageId: string) => void,
    private onDisconnect: () => void
  connect(): void {
    const wsUrl = `wss://${ORG_HOSTNAME}/api/v2/webchat/instances/${this.instanceId}/websocket`;
    this.ws = new WebSocket(wsUrl);
    this.ws.onopen = () => {
      console.log('WebSocket connected to Genesys Cloud');
      this.isHealthy = true;
      this.startHealthMonitor();
    this.ws.onmessage = (event: MessageEvent) => {
        const data = JSON.parse(event.data as string);
        if (data.type === 'message') {
          this.onMessage(data);
        } else if (data.type === 'messageReceived') {
          this.lastAckTimestamp = Date.now();
          this.onAck(data.messageId);
      } catch (err) {
        console.warn('Failed to parse WebSocket message:', err);
    this.ws.onclose = (event: CloseEvent) => {
      this.stopHealthMonitor();
      console.log(`WebSocket closed: code ${event.code}, reason ${event.reason}`);
      this.onDisconnect();
    this.ws.onerror = (error: Event) => {
      console.error('WebSocket error:', error);
      this.isHealthy = false;
  private startHealthMonitor(): void {
    this.healthCheckInterval = setInterval(() => {
      if (Date.now() - this.lastAckTimestamp > this.HEALTH_TIMEOUT_MS) {
    }, 10000);
  private stopHealthMonitor(): void {
    if (this.healthCheckInterval) {
      clearInterval(this.healthCheckInterval);
      this.healthCheckInterval = null;
  send(payload: MessagePayload): void {
    if (this.ws?.readyState === WebSocket.OPEN) {
      this.ws.send(JSON.stringify(payload));
    } else {
      throw new Error('WebSocket is not open');
  close(): void {
    this.ws?.close(1000, 'Client disconnect');
The health monitor tracks acknowledgment timestamps. If no acknowledgment arrives within thirty seconds, the connection is marked unhealthy and triggers the reconnection flow. This approach prevents silent failures where the WebSocket remains open but the underlying TCP connection is dead.
Step 2: Exponential Backoff with Jitter
Network partitions require a deterministic reconnection strategy. Pure exponential backoff causes thundering herd problems when many clients reconnect simultaneously. Adding random jitter distributes reconnection attempts across time. The following utility implements the algorithm.
function calculateBackoffDelay(attempt: number, baseDelay: number = 1000, maxDelay: number = 30000, jitterRange: number = 1000): number {
  const exponential = baseDelay * Math.pow(2, attempt);
  const jitter = Math.random() * jitterRange;
  return Math.min(maxDelay, exponential + jitter);
function sleep(ms: number): Promise<void> {
  return new Promise(resolve => setTimeout(resolve, ms));
async function reconnectWithBackoff(
  attempt: number,
  maxAttempts: number,
  onReconnect: () => void,
  onError: (err: Error) => void
): Promise<void> {
  if (attempt >= maxAttempts) {
    onError(new Error('Maximum reconnection attempts reached'));
    return;
  const delay = calculateBackoffDelay(attempt);
  console.log(`Reconnection attempt ${attempt + 1} in ${Math.round(delay)}ms`);
  await sleep(delay);
    onReconnect();
  } catch (err) {
    await reconnectWithBackoff(attempt + 1, maxAttempts, onReconnect, onError);
The calculateBackoffDelay function caps the maximum delay to prevent indefinite wait times. The jitter range adds randomness to the exponential curve. This pattern aligns with Genesys Cloud’s rate limiting behavior and prevents cascading 429 responses during large-scale outages.
Step 3: Message Buffer and Resend Logic
Unacknowledged messages must survive connection drops. You track messages in a buffer keyed by their unique ID. Upon session restoration, the module resends buffered messages. If the WebSocket is not immediately ready, the module falls back to the Guest API REST endpoint to guarantee delivery.
interface BufferedMessage {
  payload: MessagePayload;
  timestamp: number;
  acknowledged: boolean;
  retryCount: number;
class MessageBuffer {
  private buffer = new Map<string, BufferedMessage>();
  private readonly MAX_RETRIES = 3;
  private readonly BUFFER_TTL_MS = 300000;
  add(payload: MessagePayload): void {
    const entry: BufferedMessage = {
      payload,
      timestamp: Date.now(),
      acknowledged: false,
      retryCount: 0
    this.buffer.set(payload.messageId, entry);
    this.cleanupExpired();
  acknowledge(messageId: string): void {
    const entry = this.buffer.get(messageId);
    if (entry) {
      entry.acknowledged = true;
      this.buffer.delete(messageId);
  getUnacknowledged(): BufferedMessage[] {
    return Array.from(this.buffer.values()).filter(m => !m.acknowledged);
  private cleanupExpired(): void {
    const now = Date.now();
    for (const [id, entry] of this.buffer) {
      if (now - entry.timestamp > this.BUFFER_TTL_MS || entry.retryCount >= this.MAX_RETRIES) {
        this.buffer.delete(id);
async function resendBufferViaRest(
  buffer: MessageBuffer,
  instanceId: string,
  token: string
): Promise<void> {
  const pending = buffer.getUnacknowledged();
  const url = `https://${ORG_HOSTNAME}/api/v2/webchat/instances/${instanceId}/messages`;
  for (const msg of pending) {
        method: 'POST',
        headers: {
          'Authorization': `Bearer ${token}`
          type: 'message',
          content: msg.payload.content,
          messageId: msg.payload.messageId
      if (response.status === 429) {
        const retryAfter = parseInt(response.headers.get('Retry-After') || '5', 10);
        console.warn(`Rate limited on message ${msg.id}. Waiting ${retryAfter}s`);
        await sleep(retryAfter * 1000);
        // Retry once after rate limit
        await fetch(url, {
          method: 'POST',
          headers: { 'Content-Type': 'application/json', 'Authorization': `Bearer ${token}` },
          body: JSON.stringify({ type: 'message', content: msg.payload.content, messageId: msg.payload.messageId })
      } else if (!response.ok) {
        throw new Error(`REST resend failed: ${response.status}`);
      buffer.acknowledge(msg.id);
      msg.retryCount++;
    } catch (err) {
      console.error(`Failed to resend message ${msg.id} via REST:`, err);
The MessageBuffer class tracks acknowledgment state and enforces time-to-live limits to prevent memory leaks. The resendBufferViaRest function handles 429 rate limits by reading the Retry-After header and implementing a single retry. This ensures compliance with Genesys Cloud’s rate limiting policies while preserving message order and delivery guarantees.
The following module combines authentication, connection management, backoff logic, and buffer handling into a production-ready client. Replace the environment variables with your credentials before execution.
// Reuse types and utilities from previous sections
// (Assume all interfaces and functions are in the same file or imported)
class GenesysWebMessagingClient {
  private session: GuestSession | null = null;
  private connection: WebMessagingConnection | null = null;
  private buffer = new MessageBuffer();
  private reconnectAttempt = 0;
  private readonly MAX_RECONNECT_ATTEMPTS = 5;
  private isRunning = false;
  async initialize(): Promise<void> {
    this.session = await authenticateGuest();
    await this.setupConnection();
    this.isRunning = true;
  private async setupConnection(): Promise<void> {
    if (!this.session) throw new Error('Session not initialized');
    this.connection = new WebMessagingConnection(
      this.session.webchatInstanceId,
      this.session.token,
      (msg) => console.log('Received:', msg.content),
      (id) => this.buffer.acknowledge(id),
      async () => await this.handleDisconnect()
    this.connection.connect();
  private async handleDisconnect(): Promise<void> {
    if (!this.isRunning) return;
    console.log('Connection lost. Initiating reconnection flow...');
    this.reconnectAttempt++;
        this.reconnectAttempt - 1,
        this.MAX_RECONNECT_ATTEMPTS,
        async () => {
          // Refresh session if expired
          if (Date.now() > this.session!.expiresAt) {
          this.reconnectAttempt = 0;
          // Resend unacknowledged messages
          await resendBufferViaRest(this.buffer, this.session!.webchatInstanceId, this.session!.token);
          console.log('Session restored. Buffer cleared.');
        (err) => {
          console.error('Reconnection failed permanently:', err);
          this.isRunning = false;
    } catch (err) {
      console.error('Unexpected error during reconnection:', err);
  async sendMessage(content: string): Promise<void> {
    const messageId = uuidv4();
    const payload: MessagePayload = {
      type: 'message',
      content,
      messageId
    this.buffer.add(payload);
      this.connection?.send(payload);
      console.log(`Message ${messageId} sent to WebSocket`);
    } catch (err) {
      console.warn('WebSocket send failed. Message buffered for REST fallback.');
  shutdown(): void {
    this.connection?.close();
// Usage
const client = new GenesysWebMessagingClient();
client.initialize().then(() => {
  client.sendMessage('Hello Genesys Cloud');
  client.sendMessage('Testing resilient delivery');
The client initializes a guest session, establishes the WebSocket, and routes all outbound messages through the buffer. If the WebSocket drops, the backoff routine triggers, refreshes the session if necessary, restores the connection, and flushes the buffer via the REST endpoint. The shutdown method cleanly terminates intervals and sockets.
Error: 401 Unauthorized on Guest Creation
  • Cause: The OAuth token lacks the webchat:guest:write scope, or the token has expired.
  • Fix: Regenerate the OAuth token with the correct scope. Verify the token expiration timestamp before calling authenticateGuest.
  • Code: Add a pre-check before authentication:
if (!OAUTH_TOKEN || OAUTH_TOKEN.length < 10) {
  throw new Error('OAUTH_TOKEN environment variable is missing or malformed');
Error: 429 Too Many Requests on Message Resend
  • Cause: The client exceeds Genesys Cloud’s rate limits during buffer flush or rapid reconnection.
  • Fix: Implement strict adherence to the Retry-After header. Never retry faster than the server specifies.
  • Code: The resendBufferViaRest function already parses Retry-After. Ensure you do not parallelize buffer sends. Use sequential await loops as shown.
Error: WebSocket Close Code 1006 (Abnormal Closure)
  • Cause: Network partition, proxy timeout, or Genesys Cloud infrastructure restart.
  • Fix: The exponential backoff with jitter handles this automatically. Verify that your environment allows persistent WebSocket connections to *.mypurecloud.com. Corporate firewalls often terminate idle connections after sixty seconds.
  • Code: Adjust HEALTH_TIMEOUT_MS to match your network policy:
private readonly HEALTH_TIMEOUT_MS = 45000; // Match proxy idle timeout
Error: Message Buffer Memory Leak
  • Cause: Messages are never acknowledged and the buffer grows indefinitely.
  • Fix: The cleanupExpired method enforces a TTL and maximum retry count. Monitor buffer size in production using this.buffer.getUnacknowledged().length.
  • Code: Add a diagnostic interval:
setInterval(() => {
  console.log(`Buffer size: ${this.buffer.getUnacknowledged().length}`);
}, 60000);
