Implementing Redaction of Sensitive Audio Segments in Genesys Cloud Recordings Using the Media API and Python FFmpeg
- Download a Genesys Cloud recording, programmatically mute specified time ranges using FFmpeg, and upload the sanitized file back to the platform for GDPR compliance.
- Uses the Genesys Cloud Media API and the
ffmpeg-pythonlibrary in Python. - Covers OAuth2 authentication, HTTP streaming download, audio filter construction, multipart upload, and exponential backoff retry logic.
- OAuth 2.0 Client Credentials flow configured in Genesys Cloud with a valid
client_idandclient_id - Required scopes:
media:read,media:write - Python 3.9+ runtime
- FFmpeg binary installed and accessible in the system
PATH - Dependencies:
requests>=2.31.0,ffmpeg-python>=0.2.0 - A valid Genesys Cloud recording ID (
recordingId) and a list of redaction windows in seconds[(start, end), ...]
Genesys Cloud uses OAuth 2.0 Client Credentials flow for server-to-server API access. The token expires after twenty minutes, so production code must cache the token and refresh it when expired. The following function handles token acquisition and basic TTL caching.
import requests
from typing import Optional
GENESYS_BASE_URL = "https://api.mypurecloud.com"
TOKEN_ENDPOINT = f"{GENESYS_BASE_URL}/oauth/token"
class TokenCache:
def __init__(self) -> None:
self._expires_at: float = 0.0
def get_token(self, client_id: str, client_secret: str) -> str:
if self._token and time.time() < self._expires_at - 60:
return self._token
payload = {
"client_id": client_id,
"client_secret": client_secret
response = requests.post(TOKEN_ENDPOINT, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expires_at = time.time() + data["expires_in"]
return self._token
The get_token method returns a bearer token valid for the media:read and media:write scopes. You will attach this token to the Authorization header for all subsequent Media API calls.
Step 1: Retrieve Recording Metadata and Secure Download URL
Genesys Cloud does not expose raw audio files directly in the recording metadata object. You must first fetch the recording entity to obtain a time-limited downloadUrl. The endpoint requires the media:read scope.
HTTP Request Cycle
GET /api/v2/recordings/{recordingId} HTTP/1.1
Host: api.mypurecloud.com
Accept: application/json
Realistic Response Body
"recordingType": "conversation",
"mediaType": "audio",
"downloadUrl": "https://media.mypurecloud.com/download/a1b2c3d4-e5f6-7890-abcd-ef1234567890?token=xyz",
"status": "completed",
"createdDate": "2024-05-10T14:30:00Z"
The following function fetches the metadata and validates that the recording is in a completed state before proceeding.
def get_recording_download_url(token: str, recording_id: str) -> str:
headers = {
"Accept": "application/json"
url = f"{GENESYS_BASE_URL}/api/v2/recordings/{recording_id}"
response = requests.get(url, headers=headers)
raise RuntimeError("Authentication failed. Verify OAuth token and scopes.")
if response.status_code == 403:
raise RuntimeError("Forbidden. The recording may be locked or the account lacks media:read scope.")
recording = response.json()
if recording.get("status") != "completed":
raise ValueError(f"Recording {recording_id} is not in 'completed' state. Current state: {recording.get('status')}")
return recording["downloadUrl"]
Step 2: Download Audio and Apply FFmpeg Redaction
The ffmpeg-python wrapper exposes a Pythonic interface to FFmpeg. To redact sensitive segments without dropping audio continuity, you use the volume filter with a conditional enable expression. The expression between(t,start,end) evaluates to 1 when the current timestamp falls within the range, and 0 otherwise. By summing multiple between() calls, you create a single filter that mutes all specified windows.
Filter Construction Logic
If you need to mute 10.0 to 15.0 seconds and 30.5 to 35.2 seconds, the FFmpeg expression becomes:
enable='between(t,10.0,15.0)+between(t,30.5,35.2)':volume=0.001
The following function streams the download to a temporary file, applies the filter, and returns the path to the redacted audio.
import tempfile
import ffmpeg
from typing import List, Tuple
def download_and_redact(
download_url: str,
redaction_windows: List[Tuple[float, float]],
output_format: str = "wav"
) -> str:
# Stream download to temporary input file
with tempfile.NamedTemporaryFile(suffix=".wav", delete=False) as tmp_in:
response = requests.get(download_url, stream=True)
for chunk in response.iter_content(chunk_size=8192):
tmp_in.write(chunk)
input_path = tmp_in.name
output_path = tempfile.mktemp(suffix=f".{output_format}")
# Build FFmpeg enable expression
if not redaction_windows:
raise ValueError("Redaction windows list cannot be empty.")
between_clauses = [f"between(t,{start},{end})" for start, end in redaction_windows]
enable_expr = f"'{'+'.join(between_clauses)}'"
ffmpeg
.input(input_path)
.output(output_path, af=f"volume=enable={enable_expr}:volume=0.001")
.overwrite_output()
.run(capture_stdout=True, capture_stderr=True)
except ffmpeg.Error as e:
raise RuntimeError(f"FFmpeg processing failed: {e.stderr.decode()}") from e
finally:
import os
os.unlink(input_path)
return output_path
The volume=0.001 parameter reduces audio to near silence while preserving the original waveform duration. This prevents downstream transcription services from misaligning timestamps.
Step 3: Upload Redacted Audio to Genesys Cloud
Genesys Cloud uses a three-step upload workflow for recordings. First, you create a recording object via POST /api/v2/recordings. The response returns a presigned uploadUrl. Second, you transfer the file to that URL using a PUT request. Third, you notify Genesys Cloud that the upload is complete via POST /api/v2/recordings/{id}/upload/complete. This workflow requires the media:write scope.
HTTP Request Cycle (Step 1: Create Recording Object)
POST /api/v2/recordings HTTP/1.1
Request Body
"conversationId": "original-conversation-id"
Response Body
"id": "new-recording-id-123",
"uploadUrl": "https://media.mypurecloud.com/upload/new-recording-id-123?token=abc"
HTTP Request Cycle (Step 2: Transfer File)
PUT https://media.mypurecloud.com/upload/new-recording-id-123?token=abc HTTP/1.1
Content-Type: audio/wav
Content-Length: 1048576
HTTP Request Cycle (Step 3: Finalize)
POST /api/v2/recordings/new-recording-id-123/upload/complete HTTP/1.1
The following function handles the complete upload cycle with built-in 429 retry logic.
import json
from typing import Dict, Any
def retry_on_429(func, max_retries: int = 3, base_delay: float = 1.0):
def wrapper(*args, **kwargs):
for attempt in range(max_retries + 1):
response = func(*args, **kwargs)
wait_time = base_delay * (2 ** attempt)
time.sleep(wait_time)
return response
raise RuntimeError("Max retries exceeded for 429 Too Many Requests")
return wrapper
def upload_redacted_recording(
token: str,
audio_path: str,
original_conversation_id: str,
media_type: str = "audio/wav"
) -> Dict[str, Any]:
headers_auth = {
# Step 1: Create recording object
create_payload = {
"conversationId": original_conversation_id
create_response = requests.post(
f"{GENESYS_BASE_URL}/api/v2/recordings",
headers=headers_auth,
json=create_payload
create_response.raise_for_status()
recording_data = create_response.json()
recording_id = recording_data["id"]
upload_url = recording_data["uploadUrl"]
# Step 2: Upload file with retry logic
def do_file_upload():
with open(audio_path, "rb") as f:
return requests.put(upload_url, data=f, headers={"Content-Type": media_type})
upload_response = retry_on_429(do_file_upload)()
upload_response.raise_for_status()
# Step 3: Finalize upload
complete_response = requests.post(
f"{GENESYS_BASE_URL}/api/v2/recordings/{recording_id}/upload/complete",
complete_response.raise_for_status()
"recordingId": recording_id,
"uploadUrl": upload_url
The retry_on_429 decorator implements exponential backoff. Genesys Cloud enforces rate limits per tenant and per endpoint. The decorator catches 429 responses, sleeps for 1.0 * 2^attempt seconds, and retries up to three times before raising an exception.
The following script combines authentication, download, redaction, and upload into a single executable module. Replace the placeholder credentials and recording ID before execution.
import os
import sys
import requests
import tempfile
import ffmpeg
from typing import List, Tuple, Dict, Any, Optional
class TokenCache:
return self._token
payload = {
return self._token
headers = {"Authorization": f"Bearer {token}", "Accept": "application/json"}
raise RuntimeError("Forbidden. Verify media:read scope.")
raise ValueError(f"Recording status is {recording.get('status')}, expected 'completed'.")
def download_and_redact(download_url: str, redaction_windows: List[Tuple[float, float]]) -> str:
tmp_in.write(chunk)
output_path = tempfile.mktemp(suffix=".wav")
raise ValueError("Redaction windows cannot be empty.")
ffmpeg
.input(input_path)
.overwrite_output()
raise RuntimeError(f"FFmpeg failed: {e.stderr.decode()}") from e
finally:
return output_path
time.sleep(base_delay * (2 ** attempt))
return response
raise RuntimeError("Max retries exceeded for 429")
return wrapper
def upload_redacted_recording(token: str, audio_path: str, conversation_id: str) -> Dict[str, Any]:
headers_auth = {"Authorization": f"Bearer {token}", "Content-Type": "application/json"}
create_payload = {
"conversationId": conversation_id
create_resp = requests.post(f"{GENESYS_BASE_URL}/api/v2/recordings", headers=headers_auth, json=create_payload)
create_resp.raise_for_status()
data = create_resp.json()
recording_id = data["id"]
upload_url = data["uploadUrl"]
def do_upload():
return requests.put(upload_url, data=f, headers={"Content-Type": "audio/wav"})
upload_resp = retry_on_429(do_upload)()
upload_resp.raise_for_status()
complete_resp = requests.post(f"{GENESYS_BASE_URL}/api/v2/recordings/{recording_id}/upload/complete", headers=headers_auth)
complete_resp.raise_for_status()
return {"recordingId": recording_id, "status": "completed"}
def main() -> None:
CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
RECORDING_ID = os.getenv("GENESYS_RECORDING_ID")
CONVERSATION_ID = os.getenv("GENESYS_CONVERSATION_ID")
if not all([CLIENT_ID, CLIENT_SECRET, RECORDING_ID, CONVERSATION_ID]):
print("Missing required environment variables.")
sys.exit(1)
cache = TokenCache()
token = cache.get_token(CLIENT_ID, CLIENT_SECRET)
print("Fetching recording metadata...")
download_url = get_recording_download_url(token, RECORDING_ID)
# Example: Mute 10.0-15.0s and 30.0-35.0s
redaction_windows = [(10.0, 15.0), (30.0, 35.0)]
print("Downloading and applying redaction...")
redacted_path = download_and_redact(download_url, redaction_windows)
print("Uploading redacted recording...")
result = upload_redacted_recording(token, redacted_path, CONVERSATION_ID)
print(f"Redaction complete. New recording ID: {result['recordingId']}")
os.unlink(redacted_path)
main()
- Cause: The OAuth token expired, the client credentials are incorrect, or the
Authorizationheader is malformed. - Fix: Verify the
client_idandclient_secretmatch the Genesys Cloud integration. Ensure the token cache refreshes before theexpires_inwindow closes. Check that theBearerprefix contains exactly one space. - Code Fix: The
TokenCacheclass automatically refreshes tokens whentime.time() >= self._expires_at - 60. If you bypass the cache, regenerate the token before retrying.
Error: 403 Forbidden
- Cause: The OAuth client lacks
media:readormedia:writescopes, or the recording is locked by Genesys Cloud retention policies. - Fix: Navigate to the Genesys Cloud Admin console, locate the integration, and verify that
media:readandmedia:writeare assigned. If the recording is locked, you must request a compliance override or export the recording before the retention lock engages. - Code Fix: Catch
403explicitly and log the missing scope. The API response body typically contains amessagefield indicating the exact permission gap.
- Cause: You exceeded the tenant-level or endpoint-level rate limit. Genesys Cloud enforces strict caps on media uploads to protect storage infrastructure.
- Fix: Implement exponential backoff. The
retry_on_429decorator handles this automatically. If the error persists, reduce concurrent upload threads or stagger requests using a token bucket algorithm. - Code Fix: The
Retry-Afterheader in the 429 response dictates the exact wait time. Modify the retry decorator to parseresponse.headers.get("Retry-After")instead of using a fixed exponential curve for maximum efficiency.
Error: FFmpeg Filter Syntax Failure
- Cause: Overlapping time windows, negative durations, or malformed
between()expressions cause FFmpeg to abort with a filter graph error. - Fix: Validate that
start < endfor every tuple. Sort the windows and merge overlapping ranges before constructing the filter string. - Code Fix: Add a preprocessing step:
def normalize_windows(windows: List[Tuple[float, float]]) -> List[Tuple[float, float]]:
sorted_w = sorted(windows, key=lambda x: x[0])
merged = [sorted_w[0]]
for start, end in sorted_w[1:]:
if start <= merged[-1][1]:
merged[-1] = (merged[-1][0], max(merged[-1][1], end))
else:
merged.append((start, end))
return merged
