Implementing Rate Limiting for NICE CXone Web Messaging Guest Endpoints with Go
- A Go reverse proxy that intercepts incoming requests to NICE CXone Web Messaging guest endpoints, enforces per-client rate limits using a token bucket algorithm backed by Redis, and returns standardized 429 responses with accurate Retry-After headers.
- The proxy evaluates a configurable whitelist of client identifiers, logs rate limit violations for abuse detection, and dynamically adjusts token refill rates based on real-time backend load metrics.
- All implementation uses idiomatic Go 1.21+ standard library components, the official Redis client, and structured logging.
- OAuth Client Type & Scopes: CXone Web Messaging guest endpoints typically operate with public API keys or session tokens. If your proxy forwards authenticated requests, the client credentials must include
webchat:readandconversation:writescopes. The proxy itself does not require OAuth tokens for guest traffic interception. - SDK/API Version: CXone REST API v2. Target endpoint:
/api/v2/engage/webchatand/api/v2/conversations/webchat. - Language/Runtime: Go 1.21 or higher. Requires
net/http,net/http/httputil,log/slog,context,time,sync. - External Dependencies:
github.com/redis/go-redis/v9(v9.5+),github.com/gorilla/mux(optional routing, standardhttp.ServeMuxused here for simplicity). - Infrastructure: Redis 7+ instance with persistent memory enabled. The proxy requires network access to the CXone API gateway and the Redis cluster.
CXone guest webchat endpoints authenticate via session tokens or public keys passed in the Authorization header or as query parameters. The reverse proxy must preserve these headers without modification. If your deployment requires the proxy to authenticate to a downstream CXone instance, configure client credentials flow with webchat:read and conversation:write scopes. The proxy forwards the original Authorization header to CXone. Token caching and refresh logic applies to the upstream CXone client, not the rate limiting layer.
// Proxy authentication passthrough configuration
// The proxy does not alter Authorization headers.
// CXone expects: Bearer <session_token> or API-Key <public_key>
// Required scopes for downstream validation: webchat:read, conversation:write
Step 1: Redis Token Bucket with Atomic Lua Execution
Race conditions occur when multiple goroutines evaluate token availability simultaneously. A Lua script executes atomically inside Redis, guaranteeing accurate token deduction and refill calculation. The script tracks current tokens, calculates elapsed time, applies the refill rate, and returns whether the request is allowed, remaining tokens, and seconds to wait if denied.
package main
import (
"context"
"fmt"
"log/slog"
"math"
"strconv"
"time"
"github.com/redis/go-redis/v9"
const tokenBucketScript = `
local key = KEYS[1]
local capacity = tonumber(ARGV[1])
local refillRate = tonumber(ARGV[2])
local now = tonumber(ARGV[3])
local requested = tonumber(ARGV[4])
local bucket = redis.call('HMGET', key, 'tokens', 'last_refill')
local tokens = tonumber(bucket[1])
local last_refill = tonumber(bucket[2])
if tokens == nil then
tokens = capacity
last_refill = now
end
local elapsed = now - last_refill
tokens = math.min(capacity, tokens + (elapsed * refillRate))
local new_last_refill = now
if tokens >= requested then
tokens = tokens - requested
redis.call('HMSET', key, 'tokens', tokens, 'last_refill', new_last_refill)
redis.call('EXPIRE', key, math.ceil(capacity / refillRate) + 1)
return {1, math.floor(tokens), 0}
else
local wait = math.ceil((requested - tokens) / refillRate)
return {0, math.floor(tokens), wait}
end
type TokenBucket struct {
rdb *redis.Client
script *redis.Script
capacity float64
refillRate float64
func NewTokenBucket(rdb *redis.Client, capacity float64, refillRate float64) *TokenBucket {
return &TokenBucket{
rdb: rdb,
script: redis.NewScript(tokenBucketScript),
capacity: capacity,
refillRate: refillRate,
func (tb *TokenBucket) Allow(ctx context.Context, clientID string) (bool, int, int, error) {
now := float64(time.Now().UnixMilli()) / 1000.0
key := fmt.Sprintf("ratelimit:cxone:webchat:%s", clientID)
result, err := tb.script.Run(ctx, tb.rdb, []string{key},
strconv.FormatFloat(tb.capacity, 'f', -1, 64),
strconv.FormatFloat(tb.refillRate, 'f', -1, 64),
strconv.FormatFloat(now, 'f', -1, 64),
"1").IntSlice()
if err != nil {
return false, 0, 0, fmt.Errorf("redis lua execution failed: %w", err)
if len(result) != 3 {
return false, 0, 0, fmt.Errorf("unexpected lua response length: %d", len(result))
allowed := result[0] == 1
remaining := result[1]
retryAfter := result[2]
return allowed, remaining, retryAfter, nil
The Lua script guarantees atomicity. The EXPIRE command cleans up idle keys. The refillRate represents tokens added per second. If the request exceeds available tokens, the script calculates exact seconds until the next token arrives.
Step 2: Reverse Proxy Middleware and Request Interception
The proxy uses httputil.ReverseProxy to forward traffic to CXone. Middleware wraps the handler to extract client identifiers, evaluate the token bucket, and short-circuit with 429 when limits are exceeded. The middleware calculates Retry-After based on the token bucket response and sets standard HTTP headers.
import (
"net/http"
"net/http/httputil"
"net/url"
"time"
func RateLimitMiddleware(limiter *TokenBucket, next http.Handler) http.Handler {
return http.HandlerFunc(func(w http.ResponseWriter, r *http.Request) {
clientID := extractClientID(r)
if clientID == "" {
clientID = r.RemoteAddr
allowed, remaining, retryAfter, err := limiter.Allow(r.Context(), clientID)
if err != nil {
slog.ErrorContext(r.Context(), "rate limit evaluation failed", "error", err)
http.Error(w, "Internal server error", http.StatusInternalServerError)
return
if !allowed {
w.Header().Set("Retry-After", strconv.Itoa(retryAfter))
w.Header().Set("X-RateLimit-Remaining", "0")
w.WriteHeader(http.StatusTooManyRequests)
_, _ = w.Write([]byte(fmt.Sprintf(`{"error":"rate_limit_exceeded","retry_after":%d}`, retryAfter)))
return
w.Header().Set("X-RateLimit-Remaining", strconv.Itoa(remaining))
next.ServeHTTP(w, r)
func extractClientID(r *http.Request) string {
if cid := r.Header.Get("X-Client-Id"); cid != "" {
return cid
if cid := r.URL.Query().Get("client_id"); cid != "" {
return cid
return ""
The middleware returns 429 with a JSON body and Retry-After header. CXone clients parse this header to schedule exponential backoff. The proxy preserves all original request headers and body during forwarding.
Step 3: Client ID Whitelisting and Violation Logging
Enterprise deployments require trusted clients to bypass rate limits. The whitelist loads from configuration and evaluates before the token bucket. Violations log to slog with structured fields for downstream SIEM ingestion. The logging handler captures client ID, endpoint, timestamp, and remaining capacity.
type Config struct {
WhitelistedClients map[string]bool
CXoneBaseURL string
RedisAddr string
MetricsEndpoint string
BaseCapacity float64
BaseRefillRate float64
func WhitelistMiddleware(whitelist map[string]bool) func(http.Handler) http.Handler {
return func(next http.Handler) http.Handler {
if clientID != "" && whitelist[clientID] {
slog.InfoContext(r.Context(), "whitelisted client bypass", "client_id", clientID)
return
func ViolationLogger(next http.Handler) http.Handler {
start := time.Now()
rw := &responseCapture{ResponseWriter: w, statusCode: http.StatusOK}
next.ServeHTTP(rw, r)
duration := time.Since(start)
if rw.statusCode == http.StatusTooManyRequests {
slog.WarnContext(r.Context(), "rate limit violation detected",
"client_id", clientID,
"path", r.URL.Path,
"method", r.Method,
"duration_ms", duration.Milliseconds())
type responseCapture struct {
http.ResponseWriter
statusCode int
func (rc *responseCapture) WriteHeader(code int) {
rc.statusCode = code
rc.ResponseWriter.WriteHeader(code)
The responseCapture wrapper intercepts status codes without modifying the response body. Violations log at WARN level. The whitelist middleware short-circuits evaluation for approved clients.
Step 4: Dynamic Limit Adjustment via Backend Load Metrics
CXone backend load fluctuates during peak engagement hours. The proxy polls a configured metrics endpoint, parses CPU or queue depth values, and scales the token bucket refill rate. High load reduces the refill rate to protect CXone infrastructure. Low load increases the rate to maximize throughput.
func DynamicLimitAdjuster(limiter *TokenBucket, config Config, rdb *redis.Client) {
ticker := time.NewTicker(10 * time.Second)
defer ticker.Stop()
for range ticker.C {
loadFactor, err := fetchBackendLoad(config.MetricsEndpoint)
if err != nil {
slog.Error("failed to fetch backend load metrics", "error", err)
newRefillRate := config.BaseRefillRate * loadFactor
if newRefillRate < 0.1 {
newRefillRate = 0.1
limiter.refillRate = newRefillRate
slog.Info("adjusted rate limit parameters",
"load_factor", loadFactor,
"new_refill_rate", newRefillRate,
"capacity", limiter.capacity)
func fetchBackendLoad(endpoint string) (float64, error) {
ctx, cancel := context.WithTimeout(context.Background(), 5*time.Second)
defer cancel()
req, err := http.NewRequestWithContext(ctx, http.MethodGet, endpoint, nil)
if err != nil {
return 0.0, fmt.Errorf("request creation failed: %w", err)
resp, err := client.Do(req)
if err != nil {
return 0.0, fmt.Errorf("metrics request failed: %w", err)
defer resp.Body.Close()
return 0.0, fmt.Errorf("unexpected metrics status: %d", resp.StatusCode)
var metrics struct {
CPUUtilization float64 `json:"cpu_utilization"`
QueueDepth int `json:"queue_depth"`
if err := json.NewDecoder(resp.Body).Decode(&metrics); err != nil {
return 0.0, fmt.Errorf("metrics decode failed: %w", err)
// Inverse relationship: higher load yields lower refill rate
// Normalize to 0.2 (heavy load) to 1.5 (idle)
loadFactor := 1.0 - (metrics.CPUUtilization / 200.0)
if loadFactor < 0.2 {
loadFactor = 0.2
if loadFactor > 1.5 {
loadFactor = 1.5
return loadFactor, nil
The adjuster runs asynchronously. It calculates a loadFactor between 0.2 and 1.5. The token bucket applies the new refillRate immediately without restarting the proxy. Redis keys retain their current token state, preventing sudden allowance spikes.
package main
import (
"context"
"encoding/json"
"fmt"
"log/slog"
"net/http"
"net/http/httputil"
"net/url"
"os"
"os/signal"
"strconv"
"syscall"
"time"
// Config holds deployment parameters
Port string
CXoneBaseURL string
RedisAddr string
func loadConfig() Config {
return Config{
Port: os.Getenv("PROXY_PORT"),
CXoneBaseURL: os.Getenv("CXONE_BASE_URL"),
RedisAddr: os.Getenv("REDIS_ADDR"),
MetricsEndpoint: os.Getenv("METRICS_ENDPOINT"),
BaseCapacity: 10.0,
BaseRefillRate: 2.0,
WhitelistedClients: map[string]bool{"trusted-analytics": true},
func main() {
config := loadConfig()
if config.Port == "" {
config.Port = "8080"
if config.CXoneBaseURL == "" {
config.CXoneBaseURL = "https://api.cxone.com"
if config.RedisAddr == "" {
config.RedisAddr = "localhost:6379"
if config.MetricsEndpoint == "" {
config.MetricsEndpoint = "http://localhost:9090/api/v2/system/load"
rdb := redis.NewClient(&redis.Options{
Addr: config.RedisAddr,
MinIdleConns: 5,
PoolSize: 20,
DialTimeout: 5 * time.Second,
ReadTimeout: 3 * time.Second,
ctx := context.Background()
if err := rdb.Ping(ctx).Err(); err != nil {
slog.Error("redis connection failed", "error", err)
os.Exit(1)
limiter := NewTokenBucket(rdb, config.BaseCapacity, config.BaseRefillRate)
go DynamicLimitAdjuster(limiter, config, rdb)
proxyURL, err := url.Parse(config.CXoneBaseURL)
if err != nil {
slog.Error("invalid cxone base url", "error", err)
os.Exit(1)
proxy := httputil.NewSingleHostReverseProxy(proxyURL)
proxy.ErrorHandler = func(w http.ResponseWriter, r *http.Request, err error) {
slog.Error("proxy upstream error", "error", err)
http.Error(w, "upstream service unavailable", http.StatusBadGateway)
mux := http.NewServeMux()
mux.Handle("/api/v2/engage/webchat",
ViolationLogger(
WhitelistMiddleware(config.WhitelistedClients)(
RateLimitMiddleware(limiter, proxy))))
mux.Handle("/api/v2/conversations/webchat",
ViolationLogger(
srv := &http.Server{
Addr: ":" + config.Port,
Handler: mux,
ReadTimeout: 15 * time.Second,
WriteTimeout: 30 * time.Second,
IdleTimeout: 120 * time.Second,
go func() {
slog.Info("starting rate limit proxy", "port", config.Port)
if err := srv.ListenAndServe(); err != nil && err != http.ErrServerClosed {
slog.Error("server failed", "error", err)
os.Exit(1)
quit := make(chan os.Signal, 1)
signal.Notify(quit, syscall.SIGINT, syscall.SIGTERM)
<-quit
slog.Info("shutting down server")
ctx, cancel := context.WithTimeout(context.Background(), 10*time.Second)
defer cancel()
if err := srv.Shutdown(ctx); err != nil {
slog.Error("server shutdown failed", "error", err)
The example chains middleware in reverse order of execution: ViolationLogger wraps WhitelistMiddleware, which wraps RateLimitMiddleware, which wraps the httputil.ReverseProxy. Environment variables configure endpoints and credentials. The server handles graceful shutdown.
Error: 429 Too Many Requests from Upstream CXone
- Cause: The proxy forwards traffic faster than CXone accepts it. CXone returns 429 with its own
Retry-Afterheader. - Fix: Configure the proxy to detect upstream 429 responses and propagate them without consuming local tokens. Add a response interceptor in the proxy handler to check
resp.StatusCode == 429and forward the originalRetry-Afterheader. - Code Fix:
proxy.Transport = &roundTripCapture{
original: http.DefaultTransport,
onResponse: func(resp *http.Response) {
retryAfter := resp.Header.Get("Retry-After")
slog.Warn("upstream cxone rate limited", "retry_after", retryAfter)
Error: Redis Connection Pool Exhaustion
- Cause: High concurrency triggers
redis: connection pool timeout. The Lua script blocks until tokens evaluate. - Fix: Increase
PoolSizeandMinIdleConnsin Redis client options. Add context timeouts tolimiter.Allowcalls. Implement circuit breaker logic that returns 503 when Redis fails, preventing request queue buildup. - Code Fix:
ctx, cancel := context.WithTimeout(r.Context(), 500*time.Millisecond)
defer cancel()
allowed, _, _, err := limiter.Allow(ctx, clientID)
if err != nil {
slog.Error("redis timeout", "error", err)
http.Error(w, "rate limiter unavailable", http.StatusServiceUnavailable)
return
Error: Incorrect Retry-After Calculation
- Cause: Timezone drift between proxy and Redis, or millisecond precision mismatch in the Lua script.
- Fix: Use Unix epoch seconds with millisecond division in both Go and Lua. Ensure all nodes run NTP-synchronized clocks. Validate
Retry-Aftervalues against actual token refill intervals usingcurlandsleepcommands. - Verification Command:
curl -H "X-Client-Id: test-client" http://localhost:8080/api/v2/engage/webchat -D- | grep -E "Retry-After|X-RateLimit"
Error: Whitelist Bypass Fails
- Cause: Client ID extraction mismatches header casing or query parameter encoding.
- Fix: Normalize client IDs to lowercase before map lookup. Use
strings.ToLower()inextractClientID. Log extraction failures for debugging. - Code Fix:
return strings.ToLower(cid)
return ""
