Implementing Queue Callback Strategies with Position Preservation and Estimated Wait Updates
This guide details the architectural configuration and flow design required to deploy a queue callback system that maintains caller position across reconnection attempts and delivers accurate estimated wait time updates. You will configure queue-level callback policies, build an Architect flow that handles callback requests, implement real-time ETW calculation, and deploy webhook-driven update mechanisms. The end result is a production-grade callback architecture that prevents position loss during network drops, delivers sub-minute ETW accuracy, and scales under concurrent load without degrading agent routing efficiency.
- Licensing: Genesys Cloud CX Tier 2 or higher. Queue callback and position preservation require CX 2. Estimated Wait Time calculations are native to CX 1, but webhook-driven update delivery requires CX 2+ for outbound SMS/Voice integration.
- Administrative Permissions:
Queue > Callback > ReadandQueue > Callback > WriteArchitect > Flow > ReadandArchitect > Flow > WriteWebhook > ReadandWebhook > WriteTelephony > Outbound > Edit
- OAuth Scopes (API/Integration):
queue:read,queue:write,webhook:read,webhook:write,architect:flow:read,architect:flow:write - External Dependencies: A configured outbound SMS/Voice provider (Twilio, Bandwidth, or native Genesys Telephony), a message center routing configuration, and an SMTP server or email relay for fallback updates.
1. Queue Callback Configuration & Position Preservation Logic
Position preservation is not a default behavior. It requires explicit queue policy configuration and careful handling of the callback state machine. When a caller requests a callback, the system must detach the interaction from the active voice channel while retaining the queue position token. If you detach without preserving the token, the caller re-enters the queue at the tail position upon callback delivery, which destroys customer experience and invalidates your ETW calculations.
Navigate to Admin > Routing > Queues and select the target queue. Under the Callback section, enable Allow callbacks. Set Position preservation to Enabled. Configure the Callback wait time to align with your service level objectives. We set this to 300 seconds in most deployments. Any value above 600 seconds introduces stale ETW risk, as queue dynamics shift significantly beyond a five-minute window.
The Trap: Enabling position preservation without configuring Maximum callback attempts creates a resource leak. If a caller misses the callback due to a dead number or voicemail threshold, the system retries indefinitely. Each retry consumes a queue position slot and generates unnecessary telephony charges. Set Maximum callback attempts to 3. Configure Retry interval to 120 seconds. This balances delivery success against queue congestion.
The architectural reasoning here is straightforward. Queue position is maintained via an internal interaction ID that maps to a virtual queue node. When position preservation is enabled, Genesys stores the caller position in the interaction metadata rather than attaching it to the active media channel. This decoupling allows the system to reattach the position token when the outbound callback initiates. You must validate that your queue does not have Longest Wait routing disabled. Position preservation only functions correctly with Longest Wait or Longest Wait with Skill Priority. Using Round Robin or Least Available breaks the position token mapping because those algorithms do not track chronological queue entry.
2. Architect Flow Design for Callback Request Handling
The Architect flow must intercept the callback request, validate the caller number, and hand off control to the queue callback engine. Do not use a simple Queue block with callback enabled. That approach lacks validation, fails to capture consent, and provides no mechanism for ETW update delivery.
Build a flow that begins with a Gather block for phone number collection. Route to a Set User Data block to store the raw number in a flow variable named callback_phone. Use a Condition block with the expression callback_phone != null && callback_phone.length >= 10 to validate format. Invalid numbers must route to a Play block with an error prompt and a loop back to the gather step.
After validation, route to a Queue block. In the queue block settings, enable Offer callback. Set the Callback prompt to a concise audio file that explicitly states the estimated wait time and position. Do not use the default system prompt. Custom prompts reduce hang-up rates by 18 to 24 percent in high-volume deployments.
The Trap: Placing the Queue block after a Transfer block or an Outbound Call block breaks the callback context. The callback engine only tracks position when the queue entry originates from the primary inbound flow path. If you route through multiple queue blocks or use a Split to Queue pattern without consolidating position tokens, the system treats each queue entry as a separate interaction. The caller loses position on the second queue attempt. Always consolidate queue logic into a single Queue block. Use Split to Queue only when you require skill-based routing, and ensure the Preserve position across queues toggle is enabled.
The architectural decision to validate before queuing prevents queue pollution. Invalid numbers generate callback attempts that fail at the carrier level, which inflates your queue metrics and triggers false service level breaches. By validating upfront, you ensure that every callback request represents a deliverable interaction. The flow variable callback_phone must be passed to the queue block via the Callback number field. This binds the number to the position token before the interaction enters the queue state machine.
3. Estimated Wait Time (ETW) Calculation & Update Delivery Architecture
Estimated wait time is not a static value. It is a dynamic calculation derived from queue depth, agent availability, and historical average handle time (AHT). Genesys Cloud calculates ETW using the formula: (Queue Length * AHT) / Available Agents. This calculation runs continuously, but you must trigger update delivery at specific intervals to prevent caller anxiety without overwhelming the telephony gateway.
Build a separate Architect flow dedicated to ETW updates. This flow must subscribe to queue state changes via a Webhook trigger. The webhook payload contains the current queue length, available agents, and the calculated ETW. Use a Condition block to filter updates. Only trigger an update when new_ewt - old_ewt > 60 or when queue_length > threshold. Sending updates on every state change generates SMS spam and degrades gateway throughput.
The update delivery mechanism must use an Outbound SMS or Outbound Call block. For SMS, use the message template: Your position is {position}. Estimated wait: {ewt_minutes} minutes. Reply STOP to cancel. For voice updates, use a Play block with a pre-recorded prompt that dynamically inserts the position and ETW via TTS or variable substitution. We prefer SMS for cost efficiency and voice for accessibility compliance. Configure the flow to route based on caller preference captured during the initial callback request.
The Trap: Calculating ETW using a static AHT value causes massive estimation drift during shift changes or campaign launches. If your AHT is set to 240 seconds but actual handle time drops to 120 seconds due to a new knowledge base article, your ETW calculations will overestimate wait time by 100 percent. Callers will abandon the callback queue because the estimated wait appears artificially long. Always configure your queue to use Dynamic AHT calculation. This setting pulls real-time handle time data from the last 24 hours and adjusts the ETW formula accordingly. Disable static AHT overrides in production environments.
The architectural reasoning for a separate ETW update flow is isolation. Queue routing flows must remain lightweight to prevent call processing latency. ETW calculations involve database queries, webhook payloads, and outbound messaging. Running these operations in the primary routing flow increases call setup time by 300 to 500 milliseconds. By offloading ETW logic to a webhook-triggered flow, you maintain sub-second queue entry processing while delivering accurate updates asynchronously.
4. Webhook Integration & State Management
Real-time position preservation and ETW delivery require a webhook that monitors queue state and triggers update flows. Configure the webhook in Admin > Integrations > Webhooks. Set the Trigger to Queue stats changed. Map the payload to include queueId, position, estimatedWaitTime, availableAgents, and queueLength.
The webhook must POST to an internal endpoint or a Genesys Cloud Architect webhook listener. Use the following payload structure for validation:
"trigger": "queue_stats_changed",
"data": {
"queueId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"position": 14,
"estimatedWaitTime": 420,
"availableAgents": 8,
"queueLength": 22,
"timestamp": "2024-05-15T14:32:10Z"
Configure the webhook to retry on failure with exponential backoff. Set Max retries to 3. Set Retry delay to 5 seconds. This prevents payload loss during network blips without overwhelming your listener endpoint.
The Trap: Binding the webhook to Interaction created instead of Queue stats changed generates duplicate callbacks. The interaction created trigger fires once per caller, but it does not track position changes. If you use it for ETW updates, the system sends the initial estimate and never updates it. Callers receive stale information and abandon the queue. Always use Queue stats changed for position and ETW tracking. Use Interaction updated only for callback delivery status tracking (delivered, failed, answered).
The architectural decision to use exponential backoff prevents cascade failures. During peak load, webhook listeners may experience temporary saturation. Linear retry patterns generate thundering herd effects that crash the listener service. Exponential backoff distributes retry load and allows the system to recover gracefully. You must also implement idempotency checks in your listener. Webhook retries may deliver duplicate payloads. Use the timestamp and position fields to deduplicate updates. If new_position == stored_position and new_ewt == stored_ewt, discard the update. This prevents redundant SMS delivery and conserves carrier quota.
Edge Case 1: Position Inflation During Agent Burst Availability
The failure condition: Callers receive position updates that jump from position 45 to position 120 within a 30-second window, despite no new queue entries.
The root cause: A sudden influx of agents logging in triggers a routing recalibration. The queue engine temporarily assigns virtual positions to newly available agents to balance skill distribution. This recalibration inflates the visible position count for existing callers.
The solution: Disable Dynamic skill balancing in the queue settings if your deployment does not require it. If skill balancing is mandatory, configure the ETW update flow to filter position changes that exceed a 50 percent delta within a 60-second window. Add a Condition block that compares current_position to previous_position. If abs(current_position - previous_position) / previous_position > 0.5, suppress the update and queue a manual review alert. This prevents caller panic while maintaining accurate routing.
Edge Case 2: Stale ETW Delivery After Queue Policy Changes
The failure condition: ETW updates continue reflecting a 10-minute wait time after a manager changes the queue from Longest Wait to Round Robin.
The root cause: The queue policy change invalidates the position token mapping. The ETW calculation engine caches the previous routing algorithm for 5 to 10 minutes. During this cache window, the system continues calculating ETW based on chronological queue entry, which no longer applies to Round Robin routing.
The solution: Implement a webhook listener that monitors Queue updated events. When a routing algorithm change is detected, purge the ETW cache by sending a cache_invalidation command to the update flow. Add a Set User Data block that resets cached_algorithm to null. Force the ETW flow to recalculate using the new algorithm before delivering the next update. This eliminates stale estimates and aligns ETW delivery with the active routing strategy.
Edge Case 3: SMS/Email Gateway Throttling During Peak Load
The failure condition: Callback requests succeed, but ETW updates fail with 429 Too Many Requests from the SMS provider. Callers receive no updates and abandon the queue.
The root cause: The webhook triggers an update for every position change. During peak load, queue length fluctuates by 10 to 20 interactions per minute. This generates 60 to 120 SMS requests per minute, which exceeds most carrier rate limits.
The solution: Implement a rate limiter in the ETW update flow. Use a Set User Data block to store last_update_timestamp. Add a Condition block that checks current_timestamp - last_update_timestamp > 300. Only allow an update if 5 minutes have elapsed since the last delivery. For high-priority queues, reduce the threshold to 120 seconds. Configure the SMS provider to use a dedicated throughput pool for callback updates. Isolate callback traffic from marketing or transactional SMS to prevent quota contention.
Validation Procedure
- Inject a test caller into the queue using the Simulate Call tool in Architect.
- Verify that the callback prompt plays and the position token stores correctly.
- Disconnect the test call and wait for the callback delivery window.
- Confirm that the callback routes to the correct queue position and does not reset to the tail.
- Monitor the webhook logs for ETW payload delivery. Validate that updates trigger only on significant position or ETW deltas.
- Test agent burst scenarios by logging in 10 agents simultaneously. Verify that position inflation does not trigger false updates.
- Validate SMS rate limiting by simulating 50 concurrent callback requests. Confirm that the gateway returns
200 OKfor all deliveries.
