Implementing Production-Grade Webchat SDK Connection Retry Logic in React
A React custom hook that detects Genesys Cloud Webchat SDK WebSocket drops, constructs validated retry payloads with session references, applies configurable backoff strategies, refreshes OAuth tokens atomically, and emits structured audit logs and monitoring webhooks. This uses the @genesys/webchat-sdk action dispatch system and React 18. The implementation covers TypeScript.
  • Genesys Cloud Webchat SDK (@genesys/webchat-sdk v1.20.0+)
  • React 18+ with TypeScript 4.9+
  • Node.js 18+ runtime
  • Genesys Cloud OAuth client credentials (confidential or public client)
  • Required OAuth scopes: webchat, openid, profile (for token refresh fallback)
  • External monitoring endpoint URL for retry webhooks
The Webchat SDK manages OAuth tokens internally when initialized with setOAuthConfig. During connection drops, token expiration often triggers the disconnect. The SDK emits a WEBCHAT/TOKEN_EXPIRED event. The retry logic must intercept this event, trigger a token refresh, and only proceed with reconnect dispatches after a valid token is restored.
import { init, setOAuthConfig, dispatch, getState, onEvent } from '@genesys/webchat-sdk';
const OAUTH_CONFIG = {
  clientId: process.env.GENESYS_CLIENT_ID!,
  redirectUrl: window.location.origin,
  scope: 'webchat openid profile',
  loginUrl: `${process.env.GENESYS_ORGANIZATION_URL}/oauth/token`
// Initialize SDK once per application lifecycle
init({
  webchat: {
    organizationUrl: process.env.GENESYS_ORGANIZATION_URL!,
    deploymentId: process.env.GENESYS_DEPLOYMENT_ID!,
    widgetId: process.env.GENESYS_WIDGET_ID!
setOAuthConfig(OAUTH_CONFIG);
The SDK caches tokens in sessionStorage. When the retry pipeline runs, it first checks token validity via getState().webchat.oauth.tokenExpiry. If the token is expired or missing, the pipeline calls dispatch({ type: 'WEBCHAT/REFRESH_TOKEN' }) before attempting reconnect.
Step 1: Network Status Monitoring and Stale State Verification
The retry pipeline must not attempt reconnects when the device is offline or when the SDK state is stale. Stale state occurs when the WebSocket disconnects but the SDK store retains outdated session data. The verification pipeline checks navigator.onLine, compares connectionStatus against expected states, and validates lastActivityTimestamp against a staleness threshold.
type ConnectionState = 'connected' | 'disconnected' | 'connecting' | 'idle';
interface RetryContext {
  attemptCount: number;
  maxAttempts: number;
  lastRetryTimestamp: number | null;
  baseBackoffMs: number;
  maxBackoffMs: number;
const STALE_STATE_THRESHOLD_MS = 30000;
function isNetworkAvailable(): boolean {
  return typeof navigator !== 'undefined' && navigator.onLine;
function isStateStale(): boolean {
  const state = getState();
  if (!state.webchat) return true;
  const lastActivity = state.webchat.lastActivityTimestamp ?? 0;
  const connectionStatus = state.webchat.connectionStatus;
  // State is stale if disconnected for longer than threshold without activity
  const isDisconnectedLongEnough = connectionStatus === 'disconnected'
    && (Date.now() - lastActivity > STALE_STATE_THRESHOLD_MS);
  return isDisconnectedLongEnough;
Step 2: Error Matrix and Exponential Backoff Directive
Connection drops carry specific error codes from the WebSocket layer or Genesys Cloud routing. The error matrix maps these codes to retry eligibility and backoff multipliers. Transient network errors (1006, 1011, 503) trigger full retry. Authentication errors (401) trigger token refresh first. Permanent errors (403, 404) abort the retry loop.
interface RetryDirective {
  shouldRetry: boolean;
  backoffMultiplier: number;
  requiresTokenRefresh: boolean;
const ERROR_MATRIX: Record<string, RetryDirective> = {
  '1006': { shouldRetry: true, backoffMultiplier: 2, requiresTokenRefresh: false },
  '1011': { shouldRetry: true, backoffMultiplier: 2, requiresTokenRefresh: false },
  '401':  { shouldRetry: true, backoffMultiplier: 1, requiresTokenRefresh: true },
  '403':  { shouldRetry: false, backoffMultiplier: 0, requiresTokenRefresh: false },
  '404':  { shouldRetry: false, backoffMultiplier: 0, requiresTokenRefresh: false },
  '503':  { shouldRetry: true, backoffMultiplier: 3, requiresTokenRefresh: false },
  '504':  { shouldRetry: true, backoffMultiplier: 2, requiresTokenRefresh: false }
function calculateBackoff(attempt: number, baseMs: number, maxMs: number, multiplier: number): number {
  const exponential = baseMs * Math.pow(multiplier, attempt - 1);
  const jitter = Math.random() * (baseMs * 0.5);
  return Math.min(exponential + jitter, maxMs);
Step 3: Retry Payload Construction and Schema Validation
The Webchat SDK uses an action-based store. Reconnect requires a structured payload containing the session ID, retry metadata, and a timestamp. The payload must pass schema validation before dispatch to prevent store corruption. The validation checks required fields, data types, and enforces maximum attempt limits.
interface ReconnectPayload {
  type: 'WEBCHAT/RECONNECT';
  payload: {
    sessionId: string;
    retryAttempt: number;
    timestamp: number;
    reason: string;
function validateReconnectPayload(payload: ReconnectPayload, maxAttempts: number): boolean {
  if (!payload || payload.type !== 'WEBCHAT/RECONNECT') return false;
  if (!payload.payload.sessionId || typeof payload.payload.sessionId !== 'string') return false;
  if (typeof payload.payload.retryAttempt !== 'number' || payload.payload.retryAttempt < 1) return false;
  if (payload.payload.retryAttempt > maxAttempts) return false;
  if (typeof payload.payload.timestamp !== 'number' || payload.payload.timestamp <= 0) return false;
  if (!payload.payload.reason || typeof payload.payload.reason !== 'string') return false;
  return true;
function constructReconnectPayload(sessionId: string, attempt: number, reason: string): ReconnectPayload {
    type: 'WEBCHAT/RECONNECT',
    payload: {
      sessionId,
      retryAttempt: attempt,
      timestamp: Date.now(),
      reason
Step 4: Atomic Dispatch, Token Refresh, and Webhook Synchronization
The retry engine executes dispatch operations atomically. It first triggers token refresh if required, waits for the SDK to update the store, validates the payload, dispatches the reconnect action, and immediately emits a webhook to external monitoring. Latency tracking uses performance.now() to measure recovery duration.
interface RetryAuditLog {
  timestamp: string;
  sessionId: string;
  attempt: number;
  error: string;
  backoffMs: number;
  tokenRefreshed: boolean;
  dispatchSuccess: boolean;
  latencyMs: number;
interface MonitoringWebhookPayload {
  event: 'webchat.connection.retried';
  sessionId: string;
  attempt: number;
  timestamp: string;
  success: boolean;
  latencyMs: number;
async function triggerTokenRefresh(): Promise<boolean> {
    dispatch({ type: 'WEBCHAT/REFRESH_TOKEN' });
    // Wait for SDK internal refresh completion
    await new Promise(resolve => setTimeout(resolve, 1500));
    return !!state.webchat?.oauth?.accessToken;
  } catch {
    return false;
async function emitMonitoringWebhook(payload: MonitoringWebhookPayload): Promise<void> {
  const webhookUrl = process.env.MONITORING_WEBHOOK_URL;
  if (!webhookUrl) return;
    await fetch(webhookUrl, {
      method: 'POST',
      body: JSON.stringify(payload)
  } catch {
    // Fail silently to prevent blocking the retry pipeline
function writeAuditLog(log: RetryAuditLog): void {
  console.log('[WEBCHAT-RETRY-AUDIT]', JSON.stringify(log));
  // In production, pipe this to your logging aggregator or /api/v2/analytics/custom-events/query
Step 5: React Hook Integration and Event Binding
The custom hook binds to SDK events, manages retry state, and exposes a controlled retrier interface. It listens for WEBCHAT/CONNECTION_STATE_CHANGED and WEBCHAT/ERROR to trigger the pipeline. The hook exposes retryCount, isRetrying, and lastError for UI synchronization.
import { useState, useEffect, useRef, useCallback } from 'react';
interface UseWebchatRetrierOptions {
  maxAttempts?: number;
  baseBackoffMs?: number;
  maxBackoffMs?: number;
  onRetry?: (log: RetryAuditLog) => void;
export function useWebchatRetrier(options: UseWebchatRetrierOptions = {}) {
  const {
    maxAttempts = 5,
    baseBackoffMs = 1000,
    maxBackoffMs = 15000,
    onRetry
  } = options;
  const [retryCount, setRetryCount] = useState(0);
  const [isRetrying, setIsRetrying] = useState(false);
  const [lastError, setLastError] = useState<string | null>(null);
  const abortControllerRef = useRef<AbortController | null>(null);
  const optionsRef = useRef(options);
  useEffect(() => {
    optionsRef.current = options;
  }, [options]);
  const processRetry = useCallback(async (errorCode: string, reason: string) => {
    if (!isNetworkAvailable()) {
      setLastError('Network unavailable. Aborting retry.');
      return;
    const directive = ERROR_MATRIX[errorCode] || { shouldRetry: false, backoffMultiplier: 1, requiresTokenRefresh: false };
    if (!directive.shouldRetry) {
      setLastError(`Error ${errorCode} is not retryable.`);
      return;
    setIsRetrying(true);
    const startLatency = performance.now();
    let tokenRefreshed = false;
    if (directive.requiresTokenRefresh) {
      tokenRefreshed = await triggerTokenRefresh();
      if (!tokenRefreshed) {
        setLastError('Token refresh failed. Aborting retry.');
        setIsRetrying(false);
        return;
    const sessionId = state.webchat?.sessionId || 'unknown';
    if (isStateStale()) {
      setLastError('Session state is stale. Full reinitialization required.');
      return;
    const nextAttempt = retryCount + 1;
    if (nextAttempt > maxAttempts) {
      setLastError(`Maximum retry attempts (${maxAttempts}) reached.`);
      return;
    const backoffMs = calculateBackoff(nextAttempt, baseBackoffMs, maxBackoffMs, directive.backoffMultiplier);
    const payload = constructReconnectPayload(sessionId, nextAttempt, reason);
    if (!validateReconnectPayload(payload, maxAttempts)) {
      setLastError('Retry payload validation failed. Schema mismatch.');
      return;
    // Atomic dispatch
    let dispatchSuccess = false;
      dispatch(payload);
      dispatchSuccess = true;
    } catch {
    const latencyMs = performance.now() - startLatency;
    const auditLog: RetryAuditLog = {
      sessionId,
      attempt: nextAttempt,
      error: errorCode,
      backoffMs,
      tokenRefreshed,
      dispatchSuccess,
      latencyMs
    writeAuditLog(auditLog);
    onRetry?.(auditLog);
    await emitMonitoringWebhook({
      event: 'webchat.connection.retried',
      sessionId,
      success: dispatchSuccess,
      latencyMs
    setRetryCount(nextAttempt);
    setLastError(null);
    // Schedule next retry if needed
    if (dispatchSuccess && nextAttempt < maxAttempts) {
      abortControllerRef.current = new AbortController();
      setTimeout(() => {
        if (!abortControllerRef.current?.signal.aborted) {
          processRetry(errorCode, reason);
      }, backoffMs);
  }, [retryCount, baseBackoffMs, maxBackoffMs, maxAttempts]);
  useEffect(() => {
    const connectionHandler = (event: { payload: { state: string } }) => {
      if (event.payload.state === 'disconnected') {
        setRetryCount(0);
        setLastError(null);
    const errorHandler = (event: { payload: { code: string; message: string } }) => {
      setLastError(event.payload.message);
      processRetry(event.payload.code, event.payload.message);
    onEvent('WEBCHAT/CONNECTION_STATE_CHANGED', connectionHandler);
    onEvent('WEBCHAT/ERROR', errorHandler);
    return () => {
      if (abortControllerRef.current) {
        abortControllerRef.current.abort();
  }, [processRetry]);
  return { retryCount, isRetrying, lastError };
The following React component demonstrates integration with the Genesys Cloud Webchat UI and the retry hook. It mounts the SDK, binds the retrier, and exposes retry status to the UI layer.
import React, { useEffect } from 'react';
import { init, setOAuthConfig } from '@genesys/webchat-sdk';
import { useWebchatRetrier } from './useWebchatRetrier';
export default function WebchatContainer() {
  const { retryCount, isRetrying, lastError } = useWebchatRetrier({
    maxAttempts: 5,
    baseBackoffMs: 1000,
    maxBackoffMs: 15000,
    onRetry: (log) => {
      console.info('Retry executed:', log);
  useEffect(() => {
    init({
      webchat: {
  return (
    <div style={{ padding: 20 }}>
      <h2>Genesys Cloud Webchat</h2>
      {isRetrying && <p>Reconnecting... Attempt {retryCount}</p>}
      {lastError && <p style={{ color: 'red' }}>Connection issue: {lastError}</p>}
      <div id="genesys-webchat-container" />
    </div>
Error: 401 Unauthorized during reconnect dispatch
  • Cause: The OAuth token expired between the disconnect event and the retry attempt. The SDK store still holds an expired access token.
  • Fix: The error matrix routes 401 to requiresTokenRefresh: true. The pipeline calls dispatch({ type: 'WEBCHAT/REFRESH_TOKEN' }) and waits for the new token before constructing the reconnect payload. Ensure your OAuth client has the webchat scope and that the loginUrl points to your organization’s /oauth/token endpoint.
  • Code verification: Check triggerTokenRefresh() return value. If false, abort retry and force a full SDK reinitialization.
Error: 429 Too Many Requests on reconnect
  • Cause: The retry loop fires faster than Genesys Cloud’s WebSocket rate limits allow. This happens when baseBackoffMs is too low or jitter is missing.
  • Fix: Increase baseBackoffMs to at least 2000. The calculateBackoff function applies exponential growth and random jitter. Verify maxBackoffMs caps at 15000 to prevent infinite delays. Add a server-side check for Retry-After headers if you proxy reconnects through a custom backend.
  • Code verification: Log backoffMs in RetryAuditLog. Ensure values increase across attempts.
Error: Payload validation failed
  • Cause: The SDK state returns undefined for sessionId or lastActivityTimestamp. This occurs when the component mounts before the SDK finishes initialization.
  • Fix: Guard the retry pipeline with if (!state.webchat) return;. Delay retry binding until WEBCHAT/CONNECTION_STATE_CHANGED emits connected at least once. Use the isStateStale() function to block retries when store data is missing.
  • Code verification: Add explicit null checks before constructReconnectPayload. Log the exact schema mismatch using validateReconnectPayload return path.
Error: WebSocket policy limit exceeded
  • Cause: Genesys Cloud enforces a maximum number of simultaneous WebSocket connections per deployment. Aggressive retrying across multiple client tabs triggers policy blocks.
  • Fix: Implement tab synchronization using BroadcastChannel or localStorage events. Only allow one active retry pipeline per session ID. The abortControllerRef in the hook cancels pending retries when the component unmounts.
  • Code verification: Monitor retryCount across tabs. If count exceeds 3 within 10 seconds, throttle dispatches globally.
