Implementing Presence Protocol Design for Accurate Multi-Device Agent Online Status Tracking
This guide details the architectural design and implementation of a WebSocket-driven presence subscription system that synchronizes agent status across multiple concurrent endpoints. The end result is a deterministic state machine that resolves device-level conflicts, handles network partitions, and guarantees sub-second status accuracy for real-time routing and workforce management compliance.
- Genesys Cloud CX Licensing: CX 1 tier or higher. Presence APIs require active telephony licensing for accurate routing state. WEM Add-on required if presence data feeds into workforce scheduling rules.
- NICE CXone Licensing: Standard Agent License. Presence API access requires
API Enabledtenant configuration. - Genesys Cloud Permissions:
Telephony > Phone > View,Telephony > Line Group > View,Presence > Subscribe,User > View - NICE CXone Permissions:
Agent Management > View,Presence > Read/Write,API > Access - OAuth Scopes:
presence:subscribe,telephony:phone:view,user:read,realtime:presence:read - External Dependencies: TLS 1.2+ compliant WebSocket client library, exponential backoff implementation, JSON schema validator, carrier SIP trunk status monitoring (optional but recommended for correlation)
1. Establishing the WebSocket Presence Channel and Subscription Scope
Presence tracking in modern CCaaS platforms relies entirely on persistent WebSocket connections rather than REST polling. Polling introduces 5 to 15 second latency windows that break real-time routing accuracy and cause WFM compliance drift. The platform maintains a stateful server-side subscription registry that pushes delta updates whenever an agent transitions between status codes.
You initiate the channel by upgrading an HTTP connection to the platform presence endpoint. The connection string must include the tenant subdomain and the authenticated access token as a query parameter. The WebSocket handshake returns a 101 Switching Protocols response only when the token contains the required presence:subscribe scope.
GET /api/v2/presence?access_token=<OAUTH_TOKEN> HTTP/1.1
Host: api.mypurecloud.com
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Key: <GENERATED_CLIENT_KEY>
Sec-WebSocket-Version: 13
Once the tunnel is established, you must immediately transmit a subscription payload. The platform supports three subscription scopes: user, device, and global. You will never use global in production. You will subscribe to user for composite agent status and device for endpoint-level telemetry. The subscription payload must explicitly declare the state types you require. Requesting all states forces the platform to serialize every internal transition, including transient routing calculations, which degrades client performance under scale.
"subscriptions": [
"type": "user",
"filter": {
"ids": ["user-id-1", "user-id-2"]
"stateTypes": ["available", "notReady", "onCall", "wrapUp", "offline"]
"type": "device",
"filter": {
"ids": ["device-id-a", "device-id-b", "device-id-c"]
"stateTypes": ["online", "offline", "ringing", "inUse"]
Architectural Reasoning: We separate user and device subscriptions because the routing engine evaluates composite user state, while telephony infrastructure evaluates device state. A single agent may have a desktop softphone, a mobile app, and a SIP desk phone registered simultaneously. The platform merges these into a unified user presence object, but your integration must track the underlying device states to diagnose why a composite state changed.
The Trap: Subscribing to stateTypes: ["all"] or omitting the filter object entirely. When you request all states without scoping, the platform pushes internal routing engine calculations, queue position updates, and internal SIP dialog states. This floods the WebSocket channel with irrelevant delta messages. Under load, the client buffer overflows, drops legitimate status transitions, and causes false offline states in your middleware. Always constrain stateTypes to the exact routing codes your application requires.
2. Multi-Device State Conflict Resolution and Priority Mapping
Multi-device environments introduce state divergence. An agent may be Available on their desktop softphone while simultaneously On Call on their mobile app. The platform resolves this through a weighted priority matrix, but your integration must implement the same logic locally to maintain UI consistency and prevent routing conflicts.
The platform publishes presence updates as JSON delta objects containing userId, deviceId, state, statusCode, lastUpdated, and reason. When a device state changes, the platform recalculates the composite user state and pushes both updates. You must process these updates through a deterministic state machine.
"eventType": "presenceStateChange",
"userId": "user-id-1",
"deviceId": "device-id-a",
"state": "onCall",
"statusCode": "onCall",
"lastUpdated": "2024-05-12T14:32:10.452Z",
"reason": "incoming_call",
"compositeState": {
"state": "onCall",
"priority": 3,
"deviceStates": [
{"deviceId": "device-id-a", "state": "onCall", "timestamp": "2024-05-12T14:32:10.452Z"},
{"deviceId": "device-id-b", "state": "available", "timestamp": "2024-05-12T14:30:05.112Z"}
You must implement a local priority resolver that evaluates the highest-weight device state and overrides the composite state if necessary. The standard routing priority hierarchy is: On Call (highest) > Wrap Up > Not Ready > Available > Offline (lowest). When multiple devices report conflicting states, the highest priority state wins. You store this in a local cache keyed by userId and invalidate it only when a new delta arrives with a later lastUpdated timestamp.
Architectural Reasoning: We enforce strict priority mapping because routing engines rely on deterministic state evaluation. If your middleware treats Available on Device B as authoritative while Device A is On Call, the routing engine will still attempt to deliver calls to Device B. This causes concurrent call collisions, SIP 486 Busy Here responses, and abandoned call metrics that skew service level calculations. Priority resolution prevents routing engines from targeting agents who are already engaged.
The Trap: Treating device presence as authoritative over user presence, or ignoring the lastUpdated timestamp during state reconciliation. When you ignore timestamps, your local cache processes out-of-order delta messages during network reordering. A stale Available update arriving after an On Call update will incorrectly flip the agent to idle. The routing engine immediately queues calls to that agent, causing dropped calls and compliance violations. Always validate lastUpdated against your cached timestamp and discard deltas that are older than the current state.
3. Heartbeat, Reconnection Strategy and Latency Tolerance
WebSocket presence channels require explicit keep-alive handling. The platform sends periodic ping frames to verify client liveness. Your client must respond with pong frames within the platform timeout window. If the platform does not receive a pong, it terminates the WebSocket and marks all subscribed devices as offline. This is intentional. The platform cannot risk routing calls to an agent whose client has crashed but left a stale Available state.
You must implement a reconnection strategy that balances rapid recovery with platform rate limits. Immediate retry loops during carrier outages or DNS failures trigger connection storms. The platform enforces a maximum WebSocket connection rate per tenant. Exceeding this threshold causes temporary IP blocking and presence subscription failures across your entire deployment.
// Production-ready reconnection logic with exponential backoff
const INITIAL_BACKOFF = 1000; // ms
const MAX_BACKOFF = 30000; // ms
const JITTER_FACTOR = 0.1; // 10% randomization
function calculateBackoff(attempt) {
const base = Math.min(INITIAL_BACKOFF * Math.pow(2, attempt), MAX_BACKOFF);
const jitter = base * JITTER_FACTOR * (Math.random() - 0.5) * 2;
return Math.floor(base + jitter);
async function reconnectPresenceChannel() {
let attempt = 0;
while (true) {
await establishWebSocket();
await resubscribePresence();
break; // Success, exit loop
} catch (error) {
attempt++;
const delay = calculateBackoff(attempt);
console.warn(`Presence reconnection attempt ${attempt} failed. Retrying in ${delay}ms`);
You must also implement latency tolerance for UI components. When the WebSocket drops, your interface should transition to a Stale or Disconnected state rather than showing the last known presence. You achieve this by tracking the last successful ping timestamp and applying a decay threshold. If the current time minus the last ping exceeds 5 seconds, you mark the presence as stale. This prevents supervisors from making routing decisions based on expired data.
Architectural Reasoning: We enforce exponential backoff with jitter because network partitions rarely resolve instantly. Aggressive reconnection attempts consume platform connection quotas and degrade presence accuracy for other clients. Jitter prevents thundering herd scenarios where thousands of endpoints reconnect simultaneously after a brief outage. The stale state threshold ensures supervisors and WFM dashboards reflect reality, not cached history.
The Trap: Implementing a fixed retry interval or disabling the stale state threshold. Fixed intervals create synchronized reconnection waves that overwhelm the platform WebSocket gateway. Disabling stale thresholds leaves dashboards displaying Available states for agents whose clients have been disconnected for minutes. Routing engines continue targeting those agents, causing failed call deliveries and inflated abandon rates. Always implement randomized backoff and enforce strict staleness decay.
4. REST API Validation and State Reconciliation
WebSocket channels handle real-time delta updates, but you must validate presence state through REST endpoints during initialization and after prolonged disconnections. The platform presence REST API returns the authoritative state snapshot, which you use to seed your local cache before subscribing to WebSocket deltas.
GET /api/v2/presence/users/{userId} HTTP/1.1
Authorization: Bearer <OAUTH_TOKEN>
Accept: application/json
// Response
"statusCode": "available",
"lastUpdated": "2024-05-12T14:35:22.891Z",
"devices": [
"state": "online",
"state": "offline",
"lastUpdated": "2024-05-12T14:30:05.112Z"
You execute this call once during application startup and again after any WebSocket reconnection event. The REST response provides the baseline state. You then merge subsequent WebSocket deltas into this baseline. If the REST endpoint returns a state that conflicts with your cached WebSocket state, you discard the cache and adopt the REST snapshot. The REST API is the source of truth. WebSocket deltas are optimizations.
Architectural Reasoning: We anchor presence state to REST validation because WebSocket connections are ephemeral. State can drift during reconnection windows if the platform processes status transitions while the client is offline. The REST snapshot guarantees you start from a known good state. Merging deltas afterward maintains sub-second accuracy without repeated polling.
The Trap: Relying exclusively on WebSocket deltas without REST validation after reconnection. When you skip REST validation, your local cache may miss status transitions that occurred during the disconnection window. An agent could have switched from Available to Not Ready while your client was reconnecting. Your dashboard will still display Available, causing routing mismatches and supervisor confusion. Always fetch the REST snapshot after every reconnection event.
Edge Case 1: Cross-Platform State Drift During Softphone Handoff
The failure condition: An agent initiates a call on Device A, then transfers the call to Device B. The dashboard shows the agent as On Call on both devices simultaneously for 3 to 5 seconds. Routing engines queue additional calls to the agent, causing collision.
The root cause: The platform processes device state transitions asynchronously. Device A transitions to Available after the transfer completes, but Device B transitions to On Call slightly later due to SIP dialog negotiation latency. Your local priority resolver processes the Available delta before the On Call delta, temporarily lowering the composite state priority.
The solution: Implement a deduplication window. When you receive a state delta, you hold the update for 500 milliseconds before applying it to the composite state. You buffer all deltas during this window and apply them in chronological order based on lastUpdated. This prevents transient state inversions from propagating to your UI or routing middleware. You also log state sequence anomalies for platform diagnostics.
Edge Case 2: WebSocket Session Expiry vs Agent Status Persistence
The failure condition: The WebSocket connection drops due to carrier timeout. The platform marks the agent as Offline. The agent is actually still logged in and working, but the dashboard shows Offline for 10 seconds until reconnection completes. WFM systems record false idle time.
The root cause: The platform presence engine treats WebSocket liveness as a proxy for agent availability. When the ping/pong cycle breaks, the platform assumes the client has crashed. This is by design to prevent routing to dead endpoints. Your reconnection logic is executing, but the dashboard and WFM integrations are reading the platform state directly.
The solution: Decouple UI presence from platform routing presence. Your middleware should maintain a local clientDisconnected flag that overrides the platform state during reconnection windows. You display a Reconnecting banner instead of Offline. You also implement a local heartbeat tracker that logs the exact disconnection duration. After reconnection, you send a presence correction event through the REST API to reset WFM idle timers. You coordinate with your WFM team to ignore platform presence states during client reconnection windows longer than 3 seconds.
Edge Case 3: OAuth Token Rotation Mid-Stream
The failure condition: The WebSocket connection drops unexpectedly with a 401 Unauthorized frame. The client attempts to reconnect using the same token, but receives repeated 401 errors. Presence tracking halts entirely.
The root cause: The OAuth access token expired while the WebSocket was active. WebSocket connections do not automatically refresh tokens. The platform rejects the stale token during the reconnection handshake. Your client cached the expired token and failed to rotate it.
The solution: Implement token lifecycle monitoring alongside WebSocket management. You track the token expiration timestamp and trigger a refresh 60 seconds before expiry. You store the new token in a secure vault and use it for the next WebSocket handshake. You also listen for platform 401 frames and immediately trigger token rotation before attempting reconnection. You never reuse an expired token for presence subscriptions.
