Implementing Predictive Routing Model Training Using Historical Agent-Outcome Correlation Data
This guide details the architectural configuration of a Genesys Cloud CX Predictive Routing model that leverages historical agent-outcome correlation data to optimize real-time routing decisions. You will define outcome taxonomies, map wrap-up codes to training labels, configure the model training window, and integrate the model into Architect flows with deterministic fallback strategies. The end result is a production-grade routing engine that scores agents based on their historical probability of achieving specific business outcomes for given interaction attributes, reducing reliance on static skill-based routing.
- Licensing Tier: CX3 or CX4 license. Predictive Routing is an advanced feature typically included in CX3 or available as an add-on module depending on the contract region.
- Administrative Roles:
Telephony > Routing > Edit(Required to create and modify predictive routing models)Telephony > Routing > View(Required to inspect model training status and outcomes)Data > Analytics > View(Required to validate historical interaction data and outcome distribution)Architect > View(Required to implement routing blocks in Architect flows)
- External Dependencies:
- Minimum of 30 days of historical interaction data within the target queues.
- Configured wrap-up codes and disposition codes in the Admin console.
- Agents actively assigned to the target queues with a history of completed interactions.
- OAuth Scopes (API Management):
routing:models:write(For programmatic model creation and training triggers)routing:models:read(For monitoring training status and retrieving model metrics)routing:outcomes:read(For validating outcome mappings)
1. Defining the Outcome Taxonomy and Mapping Historical Data
Predictive routing relies on supervised learning. The model requires clear, binary, or weighted classification labels derived from historical interactions. In Genesys Cloud, these labels are defined as Outcomes. You must establish a taxonomy that directly correlates to business value, such as “Sale Closed,” “Issue Resolved on First Contact,” or “Escalation Required.”
Navigate to Admin > Telephony > Routing > Outcomes. Create distinct outcomes for your target metrics. For example, create an outcome named High_Value_Sale. Next, you must map existing wrap-up codes to this outcome. When an agent completes an interaction and selects a wrap-up code, Genesys Cloud evaluates the mapping. If the wrap-up code is mapped to High_Value_Sale, the interaction is tagged with that outcome and enters the training dataset.
The Trap: Mapping too many wrap-up codes to a single outcome, or creating overlapping outcome definitions. A common misconfiguration is mapping “Sale Attempted,” “Sale Qualified,” and “Sale Closed” all to a single outcome named Positive_Sale_Outcome. This destroys the signal-to-noise ratio. The model cannot differentiate between an agent who successfully closes transactions and an agent who merely attempts them. The resulting model will route to agents with high volume but low conversion rates because the model perceives all mapped interactions as equal successes.
Architectural Reasoning: Machine learning models optimize for precision and recall based on the clarity of the training labels. Ambiguous labels cause class imbalance and model drift. You must maintain a strict 1:1 or mutually exclusive mapping between wrap-up codes and outcomes. If an agent selects a wrap-up code that is not mapped to any outcome, that interaction is excluded from the training data. You must ensure your wrap-up code taxonomy covers at least 80% of your interaction volume to provide sufficient training density.
2. Configuring the Predictive Routing Model and Training Window
With outcomes defined, you create the predictive routing model. Navigate to Admin > Telephony > Routing > Predictive Routing Models and create a new model. You will specify the target queues, the outcome to optimize, and the training window.
The Training Window determines the historical lookback period used to calculate agent scores. A typical configuration uses a 90-day rolling window. You must also decide between Continuous Training and Scheduled Training. Continuous training updates the model incrementally as new interactions close, allowing the model to adapt to daily performance shifts. Scheduled training runs on a fixed cadence (e.g., nightly), providing a stable model state but introducing latency in adapting to sudden performance changes.
The Trap: Configuring a training window that is too short for low-volume queues, or failing to account for agent turnover. If you set a 7-day training window for a queue that receives 50 interactions per day, individual agents may only have 2-3 interactions in the dataset. The statistical variance is too high, and the model will produce erratic scores. Conversely, a 365-day window includes historical data from agents who have left the organization or whose skills have degraded, skewing the model toward legacy performance patterns.
Architectural Reasoning: You must balance recency bias against statistical significance. The model requires a minimum number of interactions per agent to calculate a reliable confidence score. For high-volume queues, a 14-30 day window with continuous training is optimal to capture real-time performance. For low-volume queues, you must extend the window to 90-180 days to accumulate enough data points. You must also enable Agent Minimum Interaction Threshold in the model settings. This prevents the model from routing to agents with insufficient historical data by excluding them from the candidate pool until they meet the threshold.
3. Integrating the Model into Architect Flows with Deterministic Fallback
Once the model is active, you integrate it into your IVR or routing flow. In Architect, drag the Predictive Routing block into your flow. Configure the block by selecting the target model and the target queue. You must define the Minimum Confidence Threshold. This setting dictates the lowest probability score the model must assign to an agent before routing is allowed.
Crucially, you must configure the Fallback Routing Strategy. Predictive routing is probabilistic. If the model cannot find an agent with a confidence score above the threshold, or if all agents are offline, the interaction must have a deterministic path. Configure the fallback to use Skill Routing, Longest Available, or Custom Queue routing.
The Trap: Failing to configure a fallback strategy, or setting the confidence threshold too high. If you set the minimum confidence threshold to 95% and do not configure a fallback, interactions will drop when the model cannot find a near-perfect match. This causes immediate SLA breaches and abandoned calls. Another common error is ignoring the interaction attribute matching. Predictive routing correlates agent history with interaction attributes (e.g., customer_segment, product_type). If you do not populate these attributes in the flow before the routing block, the model treats the interaction as generic, reducing routing accuracy.
Architectural Reasoning: Predictive routing calculates a score based on P(Outcome | Agent, Interaction_Attributes). The routing engine multiplies this predictive score by the agent’s availability score. You must design the fallback to handle scenarios where the predictive engine returns an empty candidate list. The fallback acts as the safety rail. You should also implement a Parallel Routing strategy if your use case demands it, allowing the predictive model to route to the best agent while a secondary skill-based route waits in a backup queue, though this requires careful capacity planning to avoid double-dialing.
4. API-Driven Model Monitoring and Retriggering
Relying solely on the Admin console for model management is insufficient for enterprise deployments. You must implement programmatic monitoring using the Genesys Cloud API to track training status, precision metrics, and model health. The training process is asynchronous. When you update the training window or outcome mappings, the model enters a training state. Routing continues using the previous model version until training completes and the status transitions to ready.
Use the following API call to check the model status and training progress:
GET /api/v2/routing/models/{modelId}
Authorization: Bearer {access_token}
The response payload includes the trainingStatus, lastTrainingTimestamp, and trainingProgress. You must poll this endpoint with exponential backoff to avoid rate limiting. If the training fails or stalls, you can force a retraining cycle using the following endpoint:
POST /api/v2/routing/models/{modelId}/training
"trainingType": "full"
The Trap: Assuming the model trains instantly after configuration changes, or ignoring the trainingStatus field. A frequent deployment error occurs when an architect updates the outcome mappings and immediately tests the routing flow. The model is still in the training state, so it uses the old mappings. The test fails, and the architect incorrectly concludes the configuration is broken. Additionally, failing to monitor the precision and recall metrics returned in the model details leads to undetected model degradation.
Architectural Reasoning: Continuous monitoring allows you to correlate model performance with business metrics. You should build a dashboard that tracks the averageConfidenceScore and fallbackRate. If the fallback rate spikes, it indicates the model is failing to find matches, which may require adjusting the confidence threshold or expanding the training window. Programmatic retraining is essential for seasonal campaigns. You can trigger a full retrain via API immediately after a major campaign launch to ensure the model adapts to the new interaction patterns without waiting for the scheduled cycle.
Edge Case 1: The Cold Start Insufficient Historical Data Problem
The Failure Condition: The predictive routing model returns low confidence scores for all agents, causing the routing flow to consistently trigger the fallback strategy. Agents are not being routed predictively despite the model being active.
The Root Cause: The queue is new, or the training window does not contain enough interactions to meet the agent minimum interaction threshold. The model cannot calculate a reliable probability distribution when the dataset is sparse.
The Solution: Reduce the training window to force the model to use the most recent data, even if the volume is lower, or temporarily lower the agent minimum interaction threshold in the model settings. If the queue is entirely new, you must rely on skill-based routing until sufficient historical data accumulates. You can also inject synthetic interaction data via the API to seed the model, though this requires careful validation to avoid corrupting the training dataset.
Edge Case 2: Outcome Mapping Skew and Class Imbalance
The Failure Condition: The model routes to the same 3-5 agents regardless of interaction attributes. The predictive score shows no variation across the agent pool.
The Root Cause: Class imbalance in the training data. If 90% of interactions result in the target outcome, the model learns that any agent is likely to succeed. The signal is diluted because the outcome does not differentiate between high and low performers.
The Solution: Refine the outcome taxonomy to create a more balanced distribution. Split the outcome into multiple levels (e.g., Sale_Closed_High, Sale_Closed_Low) and map wrap-up codes accordingly. Alternatively, segment the queue into sub-queues with different outcome profiles to balance the distribution. You may also need to adjust the outcome weighting if the platform configuration allows prioritizing specific outcomes over others.
Edge Case 3: Agent Availability vs. Predictive Score Conflict
The Failure Condition: The model predicts Agent A is the best candidate with a 95% confidence score, but the interaction routes to Agent B with a 70% score.
The Root Cause: The routing engine applies an availability multiplier to the predictive score. Agent A may be on a long hold, have a low availability state, or be nearing their maximum concurrent interaction limit. The final routing score is Predictive_Score * Availability_Score. If Agent A’s availability drops below a certain threshold, their final score falls below Agent B’s.
The Solution: Tune the availabilityThreshold in the predictive routing block. You can configure the block to prioritize predictive score over availability by setting a lower availability threshold, allowing the model to route to agents who are less available but historically more effective. You must also review agent capacity settings to ensure high-performing agents are not artificially capped.
Edge Case 4: Attribute Mismatch and Generic Routing
The Failure Condition: The model routes interactions to agents who are experts in a different product line than the interaction requires.
The Root Cause: The interaction attributes (e.g., product_type, customer_segment) are not populated in the flow before the predictive routing block. The model receives a generic interaction profile and defaults to routing based on overall agent performance rather than attribute-specific performance.
The Solution: Ensure all relevant attributes are set using Set Data blocks or API Connector blocks before the predictive routing block. Validate the attribute names match exactly with the attribute names used during model training. You can use the Get Model Score block in Architect to inspect the predictive score and the attributes used for scoring during testing, allowing you to debug attribute mismatches before deployment.
