Implementing Predictive Dialer Abandon Rate Monitoring with Automatic Pacing Adjustment
This guide details the architectural configuration of the Genesys Cloud predictive dialer’s pacing engine to enforce strict abandon rate thresholds via dynamic speed adjustment. You will configure the dialer to monitor real-time abandon rates and automatically reduce the dialing speed when thresholds are breached, ensuring compliance with FCC regulations and internal quality standards. The end result is a self-regulating outbound campaign that maintains high agent utilization without triggering regulatory penalties or customer churn due to excessive abandoned calls.
To implement and manage this configuration, the following prerequisites must be met:
  • Licensing: Genesys Cloud CX 3 license (or higher) is required to access the Predictive Dialer features.
  • Roles:
    • Dialer Administrator: Required to create and edit campaigns and configure pacing settings.
    • Queue Administrator: Required to manage the underlying queues used by the dialer.
    • Architect: Required if you need to build custom IVR flows for abandoned call handling or integration with Speech Analytics for post-call scoring.
  • Permissions:
    • Campaigns > Campaign > Read/Write/Update
    • Queues > Queue > Read/Write
    • Routing > Flow > Read/Write (for abandoned call handling)
  • External Dependencies:
    • A configured SIP trunk or Genesys Cloud Voice carrier with sufficient concurrent call capacity.
    • An active outbound queue with agents assigned and set to “Available” status.
    • A defined “Abandoned Call” handling flow (IVR or voicemail) to ensure regulatory compliance for calls that are dropped.
1. Configuring the Predictive Campaign with Dynamic Pacing
The core mechanism for controlling abandon rates lies in the Pacing section of the campaign configuration. Unlike standard preview or progressive dialing, predictive dialing calculates a dialing rate based on agent availability and historical answer rates. To prevent the engine from over-dialing, you must configure the Abandon Rate Limit and the Pacing Adjustment behavior.
Step 1.1: Define the Campaign Structure
Navigate to Admin > Routing > Campaigns. Click Add Campaign.
  1. Campaign Name: Enter a descriptive name, e.g., Outbound_Sales_Predictive_V1.
  2. Campaign Type: Select Predictive. This enables the pacing engine.
  3. Queue: Select the queue that agents will monitor. Ensure this queue has a sufficient number of agents licensed for outbound work.
  4. Dialing List: Attach your contact list. Ensure the list is clean and compliant with DNC (Do Not Call) rules. Genesys Cloud automatically filters national and local DNC numbers, but you must verify list hygiene.
Step 1.2: Configure Pacing Strategy
Scroll to the Pacing section. This is where the architectural decision-making occurs.
  1. Target Utilization: Set this to 85%. This tells the engine to aim for 85% of agent time being spent on calls. Setting this too high (e.g., 95%) increases the risk of over-dialing because the engine assumes a near-perfect match between call answers and agent availability.
  2. Abandon Rate Limit: Set this to 3%. This is the critical threshold. The FCC mandates a maximum of 3% abandoned calls for commercial telemarketing. Configuring this limit ensures the engine treats this as a hard constraint.
  3. Pacing Adjustment Mode: Select Automatic.
    • Static: The engine uses a fixed dialing speed. This is dangerous in predictive mode because agent availability fluctuates.
    • Automatic: The engine dynamically adjusts the dialing speed based on real-time metrics. This is the recommended setting for compliance.
The Trap: Setting the Abandon Rate Limit to 0% or leaving it blank.
  • Consequence: If left blank, Genesys Cloud may default to a higher internal tolerance or rely solely on utilization targets. If set to 0%, the engine may become overly conservative, drastically reducing dialing speed even for a single abandoned call, leading to poor agent utilization and missed revenue opportunities. Always set this to your regulatory maximum (3%) to allow the engine to operate at peak efficiency within safe bounds.
Step 1.3: Configure Abandoned Call Handling
You must define what happens when a customer hangs up before an agent answers. This is not just a technical requirement but a legal one.
  1. Abandoned Call Flow: Select an existing flow or create a new one.
    • Recommended Flow: Play a message informing the customer that they have been abandoned and offer options (e.g., “Press 1 to be called back,” “Press 2 to leave a voicemail”).
    • Do Not Use: A simple hangup or silence. This violates FCC guidelines and damages brand reputation.
  2. Callback Handling: If your flow includes a callback option, ensure the campaign is configured to handle callbacks. Check the Enable Callbacks box and select the callback queue.
Architectural Reasoning: The abandoned call flow is executed in the Genesys Cloud Architect. When a call is abandoned, the engine immediately routes the call to this flow. The pacing engine monitors the outcome of this routing. If the call is answered by the IVR and the customer presses a key, it is logged as a “callback” and not counted as an abandon for pacing purposes, depending on your configuration. This distinction is crucial for maintaining accurate pacing calculations.
2. Understanding the Pacing Engine Algorithm
To effectively monitor and troubleshoot, you must understand how Genesys Cloud calculates the dialing speed. The engine uses the following logic:
Dialing Speed = (Number of Available Agents * Target Utilization) / (Average Answer Rate * (1 - Target Abandon Rate))
  • Available Agents: Agents in the queue with status “Available” or “Not Ready” (if configured to count).
  • Target Utilization: The percentage of time agents should spend on calls.
  • Average Answer Rate: The historical rate at which calls are answered by customers.
  • Target Abandon Rate: The configured abandon rate limit.
When the Actual Abandon Rate exceeds the Target Abandon Rate, the engine reduces the Dialing Speed. It does this by introducing delays between dial attempts. The reduction is proportional to the deviation from the target.
The Trap: Misinterpreting “Abandon Rate” as a real-time instantaneous value.
  • Consequence: The pacing engine uses a rolling window (typically 1-5 minutes, configurable in advanced settings) to calculate the abandon rate. A single abandoned call will not cause an immediate speed drop unless the rolling average exceeds the threshold. If you expect immediate reaction to a single hangup, you will perceive the system as unresponsive. The system is designed to smooth out noise and prevent overreaction to transient spikes.
3. Monitoring and Alerting Configuration
Passive configuration is insufficient. You must implement active monitoring to detect when the pacing engine is struggling or when the abandon rate is creeping up due to external factors (e.g., list quality degradation).
Step 3.1: Configure Real-Time Dashboards
Navigate to Admin > Routing > Campaigns > [Your Campaign] > Monitor.
  1. Real-Time Metrics: Enable the following metrics:
    • Current Abandon Rate: The rolling average of abandoned calls.
    • Dialing Speed: The current number of calls dialed per minute.
    • Agent Utilization: The percentage of time agents are on calls.
    • Calls Dialed: Total calls initiated.
    • Calls Answered: Total calls answered by customers.
  2. Alerts: Configure email or in-app alerts for:
    • Abandon Rate > 2.5%: Set this slightly below the 3% limit to provide a buffer. This allows you to intervene before the engine starts throttling speed.
    • Dialing Speed < X: Alert if the dialing speed drops below a certain threshold, indicating the engine is overly conservative or agent availability is low.
Architectural Reasoning: Setting the alert threshold at 2.5% rather than 3% provides a “warning zone.” When the abandon rate hits 2.5%, you can investigate potential issues (e.g., agent login problems, network latency) before the pacing engine automatically reduces speed, which impacts revenue.
Step 3.2: API-Driven Monitoring for Advanced Integration
For enterprise environments, integrate with external monitoring tools (e.g., Datadog, Splunk) using the Genesys Cloud APIs.
Endpoint: GET /api/v2/outbound/campaigns/{campaignId}/performance
This endpoint returns detailed performance metrics, including abandon rates, pacing speed, and agent utilization. You can poll this endpoint every 60 seconds to build a custom dashboard.
Example JSON Response Snippet:
  "id": "12345678-1234-1234-1234-123456789012",
  "name": "Outbound_Sales_Predictive_V1",
  "type": "PREDICTIVE",
  "status": "ACTIVE",
  "performance": {
    "currentDialingSpeed": 12.5,
    "targetUtilization": 0.85,
    "currentAbandonRate": 0.028,
    "totalCallsDialed": 1500,
    "totalCallsAnswered": 1200,
    "totalAbandonedCalls": 42
The Trap: Polling the API too frequently.
  • Consequence: Genesys Cloud has rate limits on API calls. Polling every second will result in 429 Too Many Requests errors, causing data gaps in your monitoring. Adhere to the recommended polling interval of 60 seconds for performance metrics. For real-time streaming, consider using the Genesys Cloud WebSockets API if available for your use case, but be aware of the increased complexity in handling stream reconnections and data normalization.
Edge Case 1: The “Cold Start” Problem
The Failure Condition: When a campaign starts, the abandon rate spikes to 100% for the first few calls because the engine has no historical answer rate data.
The Root Cause: The pacing engine initializes with a default answer rate (e.g., 10%). If the actual answer rate is lower, the engine over-dials. The first few calls are likely to be abandoned because agents are not yet available or the list is cold.
The Solution:
  1. Warm-Up Period: Start the campaign with a low Target Utilization (e.g., 50%) for the first 15 minutes. Then gradually increase it to 85%.
  2. Manual Pacing Override: Use the Manual Pacing mode for the first hour. Set the Dialing Speed to a low value (e.g., 5 calls per minute). Monitor the abandon rate. Once it stabilizes below 1%, switch back to Automatic pacing.
Edge Case 2: Agent Availability Mismatch
The Failure Condition: The abandon rate rises despite correct pacing configuration.
The Root Cause: Agents are logging off, going on break, or being transferred to other queues unexpectedly. The pacing engine assumes the agents listed as “Available” will remain available. If agents disappear, the engine continues to dial at the same speed, leading to abandoned calls.
The Solution:
  1. Monitor Agent Status: Ensure agents are trained to use the correct statuses. Avoid using “Not Ready” for long breaks; use “Offline” or “Login” instead.
  2. Adjust Pacing Sensitivity: In the campaign settings, reduce the Pacing Adjustment Sensitivity. This makes the engine react more quickly to changes in agent availability.
  3. Queue Configuration: Ensure the queue has a sufficient buffer of agents. A rule of thumb is to have 1.2x the number of agents required for the target dialing speed.
Edge Case 3: Network Latency and SIP Timing
The Failure Condition: Calls are marked as abandoned even though the customer picked up, but the agent did not connect in time.
The Root Cause: High latency between the Genesys Cloud platform and the SIP trunk or the agent’s endpoint. The SIP INVITE takes too long to complete, and the customer hangs up before the call is bridged to the agent.
The Solution:
  1. Check SIP Trunk Performance: Use the Genesys Cloud Telephony > Trunks > Monitor feature to check for high latency or packet loss.
  2. Adjust SIP Timeout: In the trunk configuration, increase the SIP Invite Timeout if necessary. However, this is rarely the root cause. The issue is usually network quality.
  3. Optimize Agent Endpoints: Ensure agents are using headsets with low latency and are connected via a stable wired network, not Wi-Fi.
