Implementing PCI-DSS Level 1 Compliance for CXone Voice Recordings by Encrypting Audio Streams at Rest Using AWS KMS Customer-Managed Keys and Strict Access Policies
You will configure NICE CXone voice recording storage to utilize AWS S3 with AWS KMS Customer-Managed Keys, enforce strict IAM boundary policies for CXone service accounts, and align the architecture with PCI-DSS Level 1 requirements for encryption at rest and access control. The end result is a fully auditable recording pipeline where audio streams are encrypted with a key you control, access is restricted to explicit CXone service principals, and compliance validation passes automated PCI-DSS scanning.
  • CXone Licensing: CXone Platform Tier 2 or higher with the Media Services and Recording add-on enabled. The CXone Secure Data Add-on is required for enhanced audit logging and tamper-evident trails.
  • CXone Permissions: Admin > Settings > Edit, Admin > Recordings > Manage, Admin > Security > Role Management, Admin > Integrations > Edit, Admin > Audit Logs > View
  • AWS Permissions: kms:CreateKey, kms:PutKeyPolicy, kms:EnableKeyRotation, kms:CreateGrant, iam:CreateRole, iam:AttachRolePolicy, iam:PutRolePolicy, s3:CreateBucket, s3:PutBucketPolicy, s3:PutBucketEncryption, s3:PutBucketVersioning
  • OAuth Scopes (CXone REST API): recordings:read, recordings:write, settings:read, settings:write, admin:read, auditlogs:read
  • External Dependencies: AWS Account with KMS and S3 enabled, CXone Integration ID for S3 connector, PCI-DSS Level 1 QSA audit scope defined, TLS 1.2 enforced across all endpoints.
1. Provisioning the AWS KMS Customer-Managed Key
PCI-DSS Requirement 3.4 mandates that stored PAN data and associated voice recordings containing PAN be rendered unreadable. AWS managed keys do not provide the audit granularity or key isolation required for Level 1 compliance. You must provision a Customer-Managed Key (CMK) that enforces strict usage boundaries and enables automatic key rotation.
Execute the following AWS CLI command to create the CMK with automatic rotation enabled:
aws kms create-key \
  --description "CXone-PCI-Recording-Encryption-Key" \
  --key-spec SYMMETRIC_DEFAULT \
  --bypass-policy-lockout-safety-check \
  --tags Key=Environment,Value=Production Key=Compliance,Value=PCI-DSS-L1 Key=Owner,Value=SecurityTeam
You must immediately attach a restrictive key policy. The policy must explicitly define the AWS account as the key admin and grant CXone’s AWS service principal permission to encrypt and decrypt. Never use Principal: "*" in a production key policy. The following policy structure enforces PCI-DSS Requirement 7.2 by limiting administrative actions to your security role and cryptographic operations to the CXone integration account.
  "Version": "2012-10-17",
  "Id": "CXone-PCI-Recording-Key-Policy",
  "Statement": [
      "Sid": "EnableRootAccountAccess",
      "Effect": "Allow",
      "Principal": {
        "AWS": "arn:aws:iam::YOUR_AWS_ACCOUNT_ID:root"
      "Action": "kms:*",
      "Resource": "*"
      "Sid": "AllowCXoneServicePrincipalToUseKey",
      "Effect": "Allow",
      "Principal": {
        "AWS": "arn:aws:iam::CXONE_INTEGRATION_ACCOUNT_ID:role/cxone-s3-integration-role"
      "Action": [
        "kms:Decrypt",
        "kms:Encrypt",
        "kms:GenerateDataKey",
        "kms:GenerateDataKeyWithoutPlaintext",
        "kms:ReEncryptFrom",
        "kms:ReEncryptTo",
        "kms:DescribeKey"
      "Resource": "*"
The Trap: Engineers frequently attach the KMS key policy directly to the IAM role instead of defining the principal at the key level. KMS key policies operate independently of IAM policies. If the key policy does not explicitly allow the CXone integration role to perform cryptographic operations, CXone will receive AccessDenied errors during recording ingestion, even if the IAM policy is perfectly configured. This misconfiguration causes silent recording failures where calls are marked as completed in CXone, but the audio file never persists to S3.
Architectural Reasoning: We isolate the CMK at the infrastructure layer rather than relying on S3 server-side encryption with AWS managed keys. This design satisfies PCI-DSS Requirement 3.4.1 by ensuring the encryption key lifecycle is controlled by your security team. Automatic rotation is enabled at the KMS level, which generates a new cryptographic material every 365 days without impacting active CXone workloads. The key policy acts as the primary access control boundary, while IAM policies handle secondary authorization. This dual-layer model prevents privilege escalation if an IAM role is compromised.
2. Configuring CXone Recording Storage with KMS CMK Binding
CXone stores voice recordings as binary objects in an external S3 bucket when configured for enterprise storage. You must bind the KMS CMK to the recording storage pipeline through the CXone Settings API. The UI configuration path exists, but the API provides version control and infrastructure-as-code repeatability.
Retrieve your current recording storage configuration first:
GET https://platform.nicecxone.com/api/v2/settings/recordings/storage
Authorization: Bearer <OAUTH_TOKEN>
Accept: application/json
Apply the updated configuration with the KMS key ID and S3 bucket ARN:
PATCH https://platform.nicecxone.com/api/v2/settings/recordings/storage
  "storageType": "S3",
  "bucketArn": "arn:aws:s3:::your-cxone-pci-recordings-bucket",
  "region": "us-east-1",
  "encryption": {
    "type": "AWS_KMS",
    "keyId": "arn:aws:kms:us-east-1:YOUR_AWS_ACCOUNT_ID:key/12345678-1234-1234-1234-123456789012"
  "pathPrefix": "recordings/pci-compliant/",
  "retentionPolicy": {
    "enabled": true,
    "duration": "P1Y"
The Trap: Misaligning the AWS region between the CXone storage configuration and the KMS key causes KMSInvalidStateException. CXone evaluates the region field in the settings payload against the keyId ARN. If the key resides in us-west-2 but the configuration specifies us-east-1, CXone routes the PUT request to the wrong region endpoint, and KMS returns a 403 error. This misconfiguration breaks the entire recording pipeline and generates excessive failed API calls that trigger rate limiting.
Architectural Reasoning: We use the PATCH endpoint instead of PUT to preserve existing recording metadata mappings. CXone maintains internal references to recording paths for playback, analytics, and compliance exports. A full PUT operation clears these mappings and forces a storage reindex, which causes temporary playback failures across all active queues. The pathPrefix parameter isolates PCI-scoped recordings from non-compliant media, satisfying PCI-DSS Requirement 3.1 by maintaining a strict data classification boundary. The retention policy enforces automatic lifecycle deletion, preventing storage bloat and reducing the attack surface for stale data.
3. Enforcing Strict IAM Access Policies for CXone Service Accounts
CXone requires an IAM role with cross-account access to your S3 bucket. The role must enforce least privilege, require TLS 1.2, and restrict access to the specific bucket path containing PCI recordings. You must also attach a condition key that enforces KMS encryption for all object uploads.
Create the IAM role and attach the following inline policy:
  "Statement": [
      "Sid": "AllowCXoneS3Access",
      "Effect": "Allow",
      "Action": [
        "s3:PutObject",
        "s3:GetObject",
        "s3:ListBucket",
        "s3:DeleteObject"
      "Resource": [
        "arn:aws:s3:::your-cxone-pci-recordings-bucket/recordings/pci-compliant/*"
      "Condition": {
        "StringEquals": {
          "aws:SecureTransport": "true"
        "Bool": {
          "s3:ExistingObjectTag/Compliance": "true"
      "Sid": "EnforceKMSEncryptionOnUpload",
      "Effect": "Deny",
      "Principal": "*",
      "Action": "s3:PutObject",
      "Resource": "arn:aws:s3:::your-cxone-pci-recordings-bucket/recordings/pci-compliant/*",
      "Condition": {
        "StringNotEquals": {
          "s3:x-amz-server-side-encryption": "aws:kms"
The Trap: Omitting the s3:x-amz-server-side-encryption deny statement allows CXone to fall back to unencrypted storage if the KMS key experiences a temporary outage. PCI-DSS Requirement 3.4 requires encryption at rest without exceptions. If an engineer configures the policy with only Allow statements, AWS evaluates the request against the most permissive matching statement. Under high load, CXone may retry uploads with default S3 encryption, resulting in plaintext audio objects that fail compliance scans.
Architectural Reasoning: We use an explicit Deny statement for unencrypted uploads because AWS IAM policy evaluation follows the explicit deny override rule. This guarantees that any request lacking the aws:kms encryption header is rejected at the gateway level, before the object reaches the storage layer. The aws:SecureTransport condition enforces TLS 1.2, satisfying PCI-DSS Requirement 4.1 for data in transit. The path-level resource restriction limits CXone to the PCI-compliant prefix, preventing cross-contamination with non-sensitive media. This design eliminates the need for bucket-level versioning conflicts and ensures deterministic access control.
4. Validating Encryption at Rest and Audit Trails
PCI-DSS Requirement 10.2 mandates comprehensive audit logging for all access to stored cardholder data. You must verify that CXone recording ingestion, playback, and deletion events are captured in both AWS CloudTrail and CXone audit logs. Additionally, you must confirm that every object in the S3 bucket carries the correct KMS key metadata.
Execute the following AWS CLI command to validate encryption metadata across the bucket:
aws s3api list-objects-v2 \
  --bucket your-cxone-pci-recordings-bucket \
  --prefix "recordings/pci-compliant/" \
  --query "Contents[].{Key:Key,ServerSideEncryption:SSEAlgorithm,KeyId:ServerSideEncryptionKeyId}" \
  --output json
Cross-reference the output with the KMS key ARN. Every object must return aws:kms for ServerSideEncryption and your CMK ARN for KeyId. If any object returns AES256 or an empty KeyId, the upload bypassed the encryption policy, and you must investigate the CXone service account permissions immediately.
Configure CXone audit logging to capture recording access events:
PATCH https://platform.nicecxone.com/api/v2/settings/auditlogs
  "enabled": true,
  "retentionPeriod": "P3Y",
  "eventTypes": [
    "RECORDING_INGESTED",
    "RECORDING_ACCESSED",
    "RECORDING_DELETED",
    "RECORDING_EXPORTED",
    "STORAGE_CONFIG_UPDATED"
  "tamperProof": true
The Trap: Relying solely on CXone audit logs for PCI-DSS validation. CXone logs track application-level events, but they do not capture AWS infrastructure-level access attempts. If an attacker compromises the IAM role and directly queries S3, CXone logs remain silent. This gap fails PCI-DSS Requirement 10.6, which requires monitoring of all access to network resources and system components.
Architectural Reasoning: We enable tamper-proof audit logging in CXone to satisfy Requirement 10.5.5, which mandates secure log storage. The tamperProof flag encrypts log entries with a secondary key and appends cryptographic hashes to each record. This prevents log injection or deletion during an incident. We cross-validate with AWS CloudTrail data events for S3 and KMS API calls. The dual-logging architecture ensures that application actions and infrastructure actions are correlated, providing the complete chain of custody required for Level 1 QSA audits.
Edge Case 1: KMS Key Rotation Breaks Legacy Recording Playback
  • The Failure Condition: After KMS automatic rotation executes, CXone returns 403 Forbidden when agents attempt to play back recordings older than 365 days.
  • The Root Cause: AWS KMS rotates the cryptographic material but maintains backward compatibility through multi-Region replica keys or previous key versions. CXone’s media playback service requests decryption using the current key ID. If the key policy restricts kms:Decrypt to only the current key version without allowing historical versions, decryption fails for legacy objects.
  • The Solution: Update the KMS key policy to allow kms:Decrypt on all key versions. KMS automatically handles version routing. Add the following condition to the principal statement:
    "Condition": {
      "StringEquals": {
        "kms:ViaService": ["s3.us-east-1.amazonaws.com"]
    This ensures S3 service principal can decrypt regardless of key version. Verify playback after rotation using the CXone recording search API.
Edge Case 2: S3 Bucket Policy Conflicts with KMS Grant
  • The Failure Condition: CXone successfully uploads recordings, but the CXone Speech Analytics engine fails to process audio files, returning AccessDenied during transcription ingestion.
  • The Root Cause: The S3 bucket policy contains a Deny statement for non-TLS traffic that inadvertently blocks internal AWS service-to-service calls. Speech Analytics uses a separate AWS service principal that does not match the CXone integration role. The KMS key policy grants access to the integration role, but the bucket policy blocks the analytics role.
  • The Solution: Scope the bucket policy deny statement to specific IAM roles rather than using Principal: "*". Add an explicit Allow statement for the CXone Analytics service principal:
      "Effect": "Allow",
      "Principal": {
        "Service": "analytics.nicecxone.com"
      "Action": "s3:GetObject",
    Validate using the CXone Speech Analytics configuration dashboard and monitor CloudTrail for s3:GetObject success rates.
Edge Case 3: Recording Retention Deletion Fails on Encrypted Objects
  • The Failure Condition: S3 lifecycle rules trigger deletion after 365 days, but objects remain in the bucket. CXone storage metrics show continuous growth despite retention policies.
  • The Root Cause: AWS KMS keys with key rotation enabled require the kms:Decrypt permission for the S3 service to verify object integrity before deletion. If the KMS key policy restricts kms:Decrypt to only the CXone integration role, S3 lifecycle execution lacks cryptographic verification rights and aborts the delete operation.
  • The Solution: Grant the S3 service principal kms:Decrypt and kms:DescribeKey permissions in the KMS key policy:
      "Effect": "Allow",
      "Principal": {
        "Service": "s3.amazonaws.com"
      "Action": [
        "kms:Decrypt",
        "kms:DescribeKey"
      "Resource": "*",
      "Condition": {
        "StringEquals": {
          "kms:ViaService": "s3.us-east-1.amazonaws.com"
    Enable S3 object lifecycle expiration with NoncurrentVersionExpiration if versioning is active. Verify deletion by checking the S3 lifecycle management console and CXone storage analytics.
