Implementing PCI-DSS Compliant Audio Storage in NICE CXone by Encrypting Call Recordings with AWS KMS Customer-Managed Keys and Enforcing Object Lock Retention Policies
This guide details the architectural configuration required to route NICE CXone call recordings to an AWS S3 bucket encrypted with KMS Customer-Managed Keys and protected by S3 Object Lock retention policies. When complete, your recording pipeline will enforce cryptographic isolation, immutable retention windows aligned with PCI-DSS Requirement 3, and auditable access controls that satisfy financial sector compliance audits without degrading media server throughput.
- NICE CXone Recording Add-on (Base or Premium tier required for external storage routing and custom retention overrides)
- CXone Admin Console permissions:
Recordings > Recording Storage > Edit,Security > API Keys > Create,Administration > AWS Integration > Configure - OAuth 2.0 scopes for CXone REST API:
recording:storage:edit,recording:storage:view,admin:api-keys:create - AWS IAM permissions:
kms:CreateKey,kms:PutKeyPolicy,kms:EnableKeyRotation,s3:CreateBucket,s3:PutBucketObjectLockConfiguration,s3:PutBucketPolicy,s3:PutBucketVersioning,iam:CreateRole,iam:AttachRolePolicy,iam:PutRolePolicy - External dependencies: AWS Account with S3 and KMS enabled, IAM cross-account role or dedicated IAM user for CXone media services, PCI-DSS Qualified Security Assessor (QSA) acknowledgment of key custody model, TLS 1.2+ network path between CXone media clusters and AWS S3 endpoints
1. Provision the KMS Customer-Managed Key with Strict Key Policy and Automatic Rotation
PCI-DSS Requirement 3.4 mandates strong cryptography for stored cardholder data and related audio artifacts. AWS-managed S3 keys (SSE-S3) do not provide customer-controlled key policies, granular CloudTrail audit trails, or key rotation visibility. You must provision a Customer-Managed Key (CMK) to maintain cryptographic separation and demonstrate control during QSA audits.
Create the CMK with automatic rotation enabled and attach a restrictive key policy. The key policy must grant CXone media services only the permissions required for data key generation and decryption, while restricting administrative actions to a dedicated KMS admin role.
"Version": "2012-10-17",
"Id": "cxone-recordings-key-policy",
"Statement": [
"Sid": "EnableRootAccountControl",
"Effect": "Allow",
"Principal": { "AWS": "arn:aws:iam::123456789012:root" },
"Action": "kms:*",
"Resource": "*"
"Sid": "AllowCXoneMediaServiceAccess",
"Effect": "Allow",
"Principal": { "AWS": "arn:aws:iam::123456789012:role/cxone-media-storage-role" },
"Action": [
"kms:GenerateDataKey",
"kms:Decrypt",
"kms:DescribeKey"
"Resource": "arn:aws:kms:us-east-1:123456789012:key/1234abcd-12ab-34cd-56ef-1234567890ab",
"Condition": {
"StringEquals": {
"kms:ViaService": [
"s3.us-east-1.amazonaws.com",
"ec2.us-east-1.amazonaws.com"
"Sid": "AllowKMSAdminRole",
"Effect": "Allow",
"Principal": { "AWS": "arn:aws:iam::123456789012:role/kms-admin-role" },
"Action": [
"kms:Create*",
"kms:Describe*",
"kms:Enable*",
"kms:List*",
"kms:Put*",
"kms:Update*",
"kms:Revoke*",
"kms:Disable*",
"kms:Get*",
"kms:Delete*",
"kms:TagResource",
"kms:UntagResource",
"kms:ScheduleKeyDeletion",
"kms:CancelKeyDeletion"
Enable automatic rotation via the KMS console or CLI:
aws kms enable-key-rotation --key-id arn:aws:kms:us-east-1:123456789012:key/1234abcd-12ab-34cd-56ef-1234567890ab
The Trap: Granting kms:Decrypt or kms:GenerateDataKey to * resources or omitting the kms:ViaService condition. Without the condition, any AWS service in your account that assumes the media role can call KMS directly, breaking the principle of least privilege and failing PCI-DSS Requirement 3.4 audits. The condition restricts KMS API calls to requests originating through the S3 data plane, which is the only path CXone media services use.
Architectural reasoning: KMS CMKs operate on a envelope encryption model. CXone media servers request a data key from KMS, use it to encrypt the audio payload in memory, upload the ciphertext to S3, and store the encrypted data key in the S3 object metadata. KMS never sees the audio data. This design minimizes cryptographic latency while providing full auditability in AWS CloudTrail under the GenerateDataKey and Decrypt event types.
2. Configure S3 Bucket with Object Lock in Compliance Mode and Lifecycle Rules
S3 Object Lock implements WORM (Write Once, Read Many) semantics. PCI-DSS Requirement 10.7 requires retention of audit logs and related recordings for at least one year. Compliance mode enforces immutable retention at the S3 data plane. Governance mode permits bucket owners to bypass retention with s3:BypassGovernanceRetention, which introduces compliance risk and is routinely flagged by QSAs.
Enable versioning first. Object Lock requires versioning to track object generations and prevent accidental overwrites.
aws s3api put-bucket-versioning \
--bucket cxone-pci-recordings \
--versioning-configuration Status=Enabled
Configure Object Lock in Compliance mode with a default retention period of 365 days:
aws s3api put-bucket-object-lock-configuration \
--object-lock-configuration '{
"ObjectLockEnabled": "Enabled",
"Rule": {
"DefaultRetention": {
"Mode": "COMPLIANCE",
"Days": 365
Apply a lifecycle rule to transition objects to S3 Glacier Deep Archive after the retention period expires. Object Lock blocks deletion until the retention window closes, but lifecycle transitions remain permitted once the lock expires.
"Rules": [
"ID": "transition-to-glacier-after-retention",
"Status": "Enabled",
"Filter": { "Prefix": "" },
"Transitions": [
"Days": 366,
"StorageClass": "GLACIER_DEEP_ARCHIVE"
"Expiration": {
"Days": 1095
The Trap: Enabling Object Lock in Governance mode to preserve operational flexibility. Governance mode allows retention overrides, which violates the immutability requirement for PCI-DSS audit artifacts. Additionally, configuring Object Lock before enabling versioning causes an immediate API failure because S3 enforces versioning as a prerequisite.
Architectural reasoning: Compliance mode locks the retention period at the object level. Even AWS root credentials cannot delete or overwrite the object before day 365. This satisfies PCI-DSS Requirement 10.7 and protects against insider threats or compromised service accounts. The lifecycle rule ensures cost optimization without violating compliance, as Glacier transitions do not trigger object deletion.
3. Establish IAM Role Trust Relationship and Bucket Policy for CXone Media Services
CXone media services require programmatic access to the S3 bucket. You must provision an IAM role with a trust policy that allows CXone to assume it, or use a dedicated IAM user if your security posture permits. Enterprise deployments prefer IAM roles with cross-account trust or OIDC federation to eliminate long-lived access keys.
Create the IAM role trust policy:
"Statement": [
"Effect": "Allow",
"Principal": {
"Action": "sts:AssumeRole",
"Condition": {
"StringEquals": {
"sts:ExternalId": "cxone-media-integration-2024"
Attach the inline policy for S3 and KMS permissions:
"Statement": [
"Sid": "AllowCXoneRecordingUploads",
"Effect": "Allow",
"Action": [
"s3:PutObject",
"s3:GetObject",
"s3:ListBucket",
"s3:PutObjectAcl",
"s3:GetObjectVersion"
"Resource": [
"arn:aws:s3:::cxone-pci-recordings",
"arn:aws:s3:::cxone-pci-recordings/*"
"Sid": "AllowKMSDataKeyOperations",
"Effect": "Allow",
"Action": [
"kms:Decrypt"
Apply a bucket policy that enforces TLS 1.2 and KMS encryption. This policy acts as a second enforcement layer independent of IAM.
"Statement": [
"Sid": "EnforceTLSAndKMS",
"Effect": "Deny",
"Principal": "*",
"Action": "s3:PutObject",
"Resource": "arn:aws:s3:::cxone-pci-recordings/*",
"Condition": {
"StringNotEquals": {
"aws:SecureTransport": "true"
"s3:x-amz-server-side-encryption": "aws:kms"
"Sid": "AllowCXoneMediaRole",
"Effect": "Allow",
"Principal": {
"Action": [
"s3:PutObject",
"s3:GetObject",
"s3:ListBucket",
"s3:PutObjectAcl",
"Resource": [
The Trap: Omitting s3:PutObjectAcl from the IAM policy. CXone media servers set canned ACLs during upload to establish ownership metadata. Without this permission, S3 returns AccessDenied, causing recording failures that surface as silent drops in the CXone recording dashboard. Also, failing to enforce aws:SecureTransport in the bucket policy violates PCI-DSS Requirement 4.1, which mandates strong cryptography for data in transit.
Architectural reasoning: Defense in depth requires both IAM and bucket policy enforcement. The IAM policy controls identity-based access, while the bucket policy controls resource-based constraints. The Deny statement for unencrypted or non-TLS uploads ensures that even if the IAM policy is misconfigured, the bucket rejects non-compliant requests. This dual-layer approach satisfies PCI-DSS Requirement 3.4 (encryption at rest) and 4.1 (encryption in transit).
4. Configure NICE CXone Recording Storage Routing and Encryption Handshake
CXone routes recordings through its media cluster to the configured external storage endpoint. You must specify the KMS CMK ARN in the storage configuration to force envelope encryption. CXone defaults to SSE-S3 if the encryption key field is left blank, which bypasses your CMK and fails compliance validation.
Configure the storage endpoint via the CXone REST API. Replace placeholders with your environment values.
POST https://api.mynicecxone.com/api/v2/recordings/storage/aws
Authorization: Bearer <OAUTH_ACCESS_TOKEN>
"name": "PCI-Compliant-Recordings-Bucket",
"bucket": "cxone-pci-recordings",
"region": "us-east-1",
"accessKeyId": "AKIAIOSFODNN7EXAMPLE",
"secretAccessKey": "wJalrXUtnFEMI/K7MDENG/bPxRfiCYEXAMPLEKEY",
"encryptionKeyId": "arn:aws:kms:us-east-1:123456789012:key/1234abcd-12ab-34cd-56ef-1234567890ab",
"storageType": "S3",
"encryptionType": "KMS",
"defaultRetentionDays": 365,
"enableVersioning": true,
"enableObjectLock": true,
"objectLockMode": "COMPLIANCE"
Verify the configuration response returns HTTP 201 with a storageId. CXone validates the AWS credentials and KMS ARN during provisioning. If validation fails, the API returns HTTP 400 with a detailed error message indicating credential rejection, region mismatch, or KMS policy denial.
The Trap: Leaving encryptionType as S3 or omitting encryptionKeyId. CXone interprets this as SSE-S3, which uses AWS-managed keys. The KMS CMK you provisioned becomes unused, and CloudTrail audit trails for GenerateDataKey never fire. QSAs will flag this as a control gap during Requirement 3.4 verification. Always explicitly set encryptionType to KMS and populate encryptionKeyId.
Architectural reasoning: The CXone media pipeline performs server-side encryption before transmission. When encryptionType is set to KMS, the media service calls kms:GenerateDataKey, receives a plaintext data key and ciphertext blob, encrypts the audio payload using AES-256-GCM, uploads the ciphertext to S3, and stores the wrapped data key in the x-amz-server-side-encryption-aws-kms-key-id header. This design ensures audio data never leaves the CXone cluster in plaintext and satisfies PCI-DSS Requirement 3.4 without introducing client-side encryption overhead.
Edge Case 1: KMS Key Rotation Breaking Historical Playback
The failure condition: After KMS automatically rotates the key material, CXone recording playback returns AccessDenied or KMSKeyNotAccessibleForDecrypt errors for recordings created before rotation.
The root cause: CXone stores the KMS key ARN in the recording metadata. The playback service attempts to decrypt using the current key version, but the KMS key policy restricts kms:Decrypt to the specific key identifier without version wildcards. Automatic rotation creates a new key version, and the policy does not grant access to it.
The solution: Update the KMS key policy to scope permissions to arn:aws:kms:region:account:key/* instead of the exact key identifier. This grants access to all key versions. Verify the CXone playback service IAM role contains the same wildcard scope. Test decryption manually:
aws kms decrypt \
--key-id arn:aws:kms:us-east-1:123456789012:key/1234abcd-12ab-34cd-56ef-1234567890ab \
--ciphertext-blob fileb://sample-ciphertext.bin \
--output text
Confirm the command returns plaintext without errors. Reindex CXone recording metadata if playback still fails, as cached key references may require a storage refresh cycle.
Edge Case 2: Object Lock Governance vs Compliance Mode Conflict
The failure condition: Retention policies are applied, but the QSA flags the configuration during audit because s3:BypassGovernanceRetention appears in the IAM policy attached to the CXone media role.
The root cause: The bucket was initially configured in Governance mode to allow operational overrides, or the IAM policy was copied from a template that included bypass permissions. Governance mode permits retention overrides for bucket owners and roles with the bypass permission, which violates PCI-DSS immutability requirements.
The solution: Disable Governance mode and enforce Compliance mode at the bucket level. Object Lock mode cannot be downgraded from Compliance to Governance after objects are written, so you must create a new bucket if objects already exist in Governance mode. Apply the correct configuration:
"Rule": {
"Days": 365
Audit all IAM policies to explicitly deny s3:BypassGovernanceRetention. Add a deny statement to the CXone media role:
"Effect": "Deny",
"Action": "s3:BypassGovernanceRetention",
Run an S3 inventory report to verify all objects carry the x-amz-object-lock-mode header set to COMPLIANCE.
Edge Case 3: CXone Media Server Latency During Encryption Handshake
The failure condition: During peak call volumes, recording uploads timeout. S3 returns 503 Slow Down errors, and CXone recording dashboard shows partial or missing recordings.
The root cause: Each recording file triggers a kms:GenerateDataKey call. Under 500+ concurrent calls, KMS request quota limits are approached. The default regional quota is 5500 requests per second, but bursty traffic from CXone media clusters can exceed throttling thresholds. Additionally, CXone retry logic may conflict with S3 exponential backoff,
