Implementing Multi-Region Active-Active Contact Center Architectures for Zero-RPO Continuity
You will configure a true active-active routing topology across two Genesys Cloud CX regions with synchronous state replication, global SIP trunk distribution, and region-agnostic Architect flows. The end result is a contact center that maintains call state, agent availability, and queue metrics across regions with zero recovery point objective (RPO) for routing metadata and sub-second failover during regional outages.
- Licensing: Genesys Cloud CX 3.0 or CX 3.0 Premium. NICE CXone requires CXone Plus or Enterprise tier with the Multi-Region Routing add-on.
- Permissions:
Admin > Multi-Region > Edit,Telephony > Trunk > Edit,Architect > Flow > Edit,Admin > Global Directory > Manage,Admin > Queue > Edit - OAuth Scopes:
admin:multi-region:write,telephony:trunk:manage,architect:flow:write,global:directory:read,routing:queue:write - External Dependencies: Global Server Load Balancing (GSLB) provider configured for health-check based routing, SIP trunk providers supporting BCP/BCF failover, DNS propagation under 60 seconds, synchronized NTP infrastructure across all data center locations, and a CRM middleware capable of handling cross-region context injection.
1. Global Directory Initialization and Synchronous State Replication
Global Directory establishes the identity backbone for active-active architectures. It synchronizes users, skills, presence status, and routing metadata across regions. We do not rely on platform-native asynchronous replication because it introduces a window where agent capacity and queue depth diverge during a failover event. Functional zero-RPO requires synchronous replication for all routing state.
Navigate to Admin > Global Directory and create a new directory instance. Assign the primary region as the sourceOfTruth and the secondary region as replicationTarget. Enable syncMode: "SYNCHRONOUS" for identity and routing metadata. Set the replicationLatencyThreshold to 200ms. This threshold triggers an automatic routing exclusion if the secondary region falls out of sync, preventing calls from routing to a stale node.
The Trap: Configuring asynchronous replication for agent state while expecting zero-RPO continuity. Asynchronous replication batches state changes to reduce network overhead. During a regional partition, the secondary region processes calls using agent availability data that is seconds old. This causes over-routed calls, immediate call drops, and severe SLA degradation. We enforce synchronous replication for routing metadata because the network penalty is negligible compared to the cost of routing to unavailable agents.
Architectural Reasoning: Identity and routing state must decouple from media processing. Global Directory handles the routing topology. Multi-Region Routing (MRR) handles the call session. Synchronous replication ensures that when Region A experiences a health check failure, Region B maintains an identical view of skill capacities, queue depths, and wrap-up timers. We configure conflictResolutionStrategy: "LATEST_WRITERS_WIN" to prevent split-brain identity states during brief network jitter.
2. Cross-Region SIP Trunk Provisioning with BCP/BCF Health Monitoring
SIP trunking must terminate in both regions simultaneously. We distribute inbound traffic at the network edge using GSLB health checks, not DNS round-robin. DNS TTLs create 30 to 60 second black holes during failover. BCP (Backup Call Processing) and BCF (Backup Call Forwarding) operate at the SIP proxy layer and react to SIP 408, 503, or custom health check failures within 500 milliseconds.
Create a trunk group in each region pointing to the same carrier endpoints. Configure BCP to route to the secondary region when the primary SIP proxy returns consecutive 503 Service Unavailable responses. Set bcpThreshold: 2 and bcpInterval: 1000ms. Configure BCF to redirect active calls to the secondary region if the media gateway fails. Use the following API payload to register the cross-region trunk group:
POST https://platform.genesys.cloud/api/v2/telephony/providers/ips
Authorization: Bearer <ACCESS_TOKEN>
"name": "Global_Inbound_Trunk_Group",
"description": "Active-Active SIP Trunk with BCP/BCF Failover",
"ipAddresses": [
"ip": "203.0.113.10",
"mask": "255.255.255.0",
"protocol": "UDP",
"port": 5060
"ip": "203.0.113.20",
"protocol": "UDP",
"port": 5060
"sipSettings": {
"codecs": ["G711u", "G711a", "OPUS"],
"dtmfType": "RFC2833",
"transportProtocol": "UDP"
"bcpSettings": {
"enabled": true,
"backupRegionId": "us-east-1",
"failureThreshold": 2,
"healthCheckIntervalMs": 1000,
"failoverStrategy": "IMMEDIATE"
The Trap: Setting BCF thresholds too aggressively or relying on DNS TTL for failover. DNS-based routing cannot detect application-level SIP proxy failures. Calls queue at the edge and timeout. Additionally, mismatched SIP codec negotiation across regions causes one-way audio or call drops during handoff. We enforce a strict global codec priority list (G711u > G711a > OPUS) and disable automatic transcoding in the trunk configuration. Transcoding consumes CPU cycles and introduces latency that breaks zero-RPO media continuity.
Architectural Reasoning: SIP is stateless for request routing but stateful for session establishment. BCP/BCF must operate at the SIP proxy layer to inspect transaction state. We configure failoverStrategy: "IMMEDIATE" because queue-based failover introduces artificial wait times that violate continuity requirements. The secondary region accepts the INVITE with identical routing logic, preserving the caller position in the queue.
3. Region-Agnostic Architect Flow Design and Dynamic Queue Routing
Architect flows must not contain hardcoded region endpoints, static IP addresses, or region-specific URI references. Flows must treat regions as compute nodes rather than destinations. We use dynamic lookups, region-agnostic queue routing blocks, and context preservation blocks to ensure identical execution paths regardless of the processing region.
Construct the flow using the Queue Routing block with routingStrategy: "BEST_AVAILABLE". This strategy evaluates real-time capacity, skill match scores, and regional latency metrics before selecting a target. Disable regionLock to allow cross-region agent assignment. Implement the following expression in a Set Data block to dynamically resolve the primary queue without hardcoding identifiers:
queueRoutingConfig.routingStrategy == "BEST_AVAILABLE" ?
getGlobalDirectoryQueue("PRIMARY_SUPPORT_QUEUE") :
getFallbackQueue("SECONDARY_SUPPORT_QUEUE")
The Trap: Embedding static IP addresses or region-specific URI endpoints in flow blocks. This breaks during active-active load balancing and causes routing loops when the platform attempts to resolve an endpoint that no longer holds session affinity. We replace all static endpoints with dynamic directory lookups. The platform resolves the endpoint at runtime based on the caller’s current region context.
Architectural Reasoning: Flows execute as state machines. State machines must remain idempotent across regions. We configure preserveContextAcrossRegions: true in the flow settings. This flag serializes the interaction context, including IVR selections, CRM data, and queue position, and replicates it synchronously to the secondary region. When a regional failover triggers, the secondary region resumes the flow at the exact block where the primary region failed, without dropping the caller or resetting IVR progress.
4. Global Capacity Sharing and Skill-Based Overflow Configuration
Queue routing across regions requires explicit capacity sharing rules. We do not use static overflow thresholds because they fail to account for regional load variance. Instead, we configure dynamic overflow with skill-based routing to distribute calls based on real-time agent availability and proficiency scores.
Navigate to Admin > Routing > Queues and enable globalCapacitySharing: true. Set overflowStrategy: "DYNAMIC" and configure skillBasedRouting: true. Assign identical skill profiles to agents across both regions. Use the following API call to update the queue configuration:
PUT https://platform.genesys.cloud/api/v2/routing/queues/{queueId}
"name": "Global_Support_Queue",
"description": "Active-Active Queue with Dynamic Overflow",
"routingRules": [
"name": "Primary_Skill_Match",
"expression": "interaction.skillRequirements.skills[0].name == 'Tier1_Support'",
"routingStrategy": "BEST_AVAILABLE",
"capacitySharing": {
"enabled": true,
"overflowStrategy": "DYNAMIC",
"maxOverflowPercentage": 100,
"regionLock": false
"outboundCallingEnabled": false,
"skillRequirements": {
"skills": [
"name": "Tier1_Support",
"proficiency": 5
The Trap: Overlapping queue priorities causing call stranding or double-assignment. When two regions evaluate the same queue simultaneously with mismatched priority rules, the platform may assign the same caller to two different agents. We enforce priorityConflictResolution: "HIGHEST_PRIORITY_WINS" and disable allowDoubleAssignment: true. This prevents race conditions during cross-region capacity evaluation.
Architectural Reasoning: Priority must be globally consistent. We use skill-based routing with region-agnostic skill assignments. Capacity sharing uses overflowStrategy: "DYNAMIC" to prevent hot-potato routing where regions aggressively push calls to each other. The platform calculates a global capacity score that factors in agent wrap-up times, scheduled breaks, and historical handle times. Calls route to the region with the highest probability of first-contact resolution, not the region with the lowest current queue depth.
Edge Case 1: Split-Brain Routing During Partial Network Partition
The Failure Condition: Inbound traffic reaches both regions simultaneously. Each region processes calls independently. Duplicate interactions appear in CRM systems. Queue metrics diverge.
The Root Cause: GSLB health checks pass for both regions, but the internal replication link experiences packet loss. Global Directory cannot confirm synchronous state. The platform defaults to independent processing mode.
The Solution: Configure partitionTolerance: "QUORUM_REQUIRED" in the Multi-Region routing settings. The platform requires a majority vote from replication nodes before accepting inbound traffic. If the replication link degrades below the defined throughput threshold, the GSLB automatically removes the affected region from the rotation. We implement a circuit breaker pattern in the Architect flow that rejects calls if replicationLatency > 300ms. This forces traffic to the healthy region and preserves data integrity.
Edge Case 2: Context Desynchronization During Cross-Region Handoff
The Failure Condition: A caller transfers from an agent in Region A to a supervisor in Region B. The supervisor receives a blank interaction context. CRM data, IVR selections, and queue position are missing.
The Root Cause: Context serialization fails during the transfer event. The platform attempts to fetch context from the originating region, but the regional API gateway returns a 404 Not Found due to session timeout or network routing asymmetry.
The Solution: Enable contextPersistence: "CROSS_REGION_SYNC" in the transfer configuration. We inject a transferContextToken into the SIP REFER header during the transfer. The receiving region uses this token to pull context from the global cache rather than the originating region’s local cache. We configure the cache TTL to 300 seconds and implement a fallback expression that reconstructs context from CRM webhook data if the token expires. This ensures supervisors always receive complete interaction history.
Edge Case 3: OAuth Token Region Mismatch in API-Driven Flows
The Failure Condition: Architect flows call external APIs using OAuth tokens. Requests to the secondary region fail with 401 Unauthorized. Integration logs show region mismatch errors.
The Root Cause: OAuth tokens are region-scoped by default. A token generated in Region A does not authorize API calls in Region B. The platform attempts to reuse the cached token during failover.
The Solution: Configure oauthRegionScope: "GLOBAL" in the integration settings. We generate tokens using the global authorization endpoint (https://api.mypurecloud.com/oauth/token) instead of region-specific endpoints. The platform automatically rotates tokens across regions during failover. We implement a token refresh hook in the Architect flow that validates token.regionScope == "GLOBAL" before executing API calls. If validation fails, the flow regenerates the token using the global endpoint. This prevents authentication failures during active-active routing.
