Implementing Multi-Party Encryption Key Ceremony Procedures for Recording Encryption Keys
This guide details the configuration of Customer Managed Keys (CMK) to enforce a multi-party encryption ceremony for call recordings within Genesys Cloud CX. The end result is a secure recording infrastructure where key generation, import, and usage authorization are separated across distinct administrative roles and external Hardware Security Modules (HSM). Upon completion, you will have an auditable workflow ensuring that no single administrator possesses the capability to decrypt recordings without explicit multi-signature approval or time-delayed rotation policies.
To implement this architecture, specific licensing tiers and granular permissions are required. Standard CCaaS entitlements do not automatically enable Customer Managed Keys for recording encryption.
  • Licensing Tier: Genesys Cloud CX Enterprise or Premium license with the Customer Managed Keys add-on enabled in the organization settings. This feature is region-specific and requires prior approval from Account Management for PCI-DSS or FedRAMP environments.
  • External Dependencies: An active external Key Management System (KMS) such as AWS KMS, Azure Key Vault, or HashiCorp Vault. The KMS must be configured in the same cloud region as your Genesys Cloud organization to ensure low-latency cryptographic operations.
  • Granular Permissions:
    • Key Administrator Role: Requires Encryption > Keys > Edit and Encryption > Keys > Import. This role manages the external HSM integration but cannot access recording content.
    • Recording Policy Administrator: Requires Recording > Policies > Edit. This role binds keys to queues but cannot view key material or plaintext recordings.
    • Auditor Role: Requires Audit Logs > Read and Encryption > Keys > View Metadata. This role verifies the ceremony occurred without possessing decryption capabilities.
  • OAuth Scopes: API-driven ceremonies require the following scopes for the Service Account used in the handshake: key_management:read, key_management:write, recording_policy:read, recording_policy:write.
1. Establishing the Trust Anchor (External KMS Configuration)
The first phase of a multi-party ceremony involves establishing a cryptographic root of trust outside the CCaaS platform. This ensures that key material never traverses the public internet in plaintext and that the private key remains within the customer-controlled HSM boundary.
You must configure the external KMS to generate an asymmetric key pair or an AES symmetric key depending on your compliance requirement. For recording encryption, a symmetric key is standard, but the master key wrapping process often utilizes asymmetric cryptography.
Step 1.1: Generate Key Material in External KMS
Initiate the key generation via the external provider API. Do not use the CCaaS UI for this step. The private key must remain in the KMS; only the public portion or the wrapped symmetric key is transferred.
  • API Endpoint: POST /api/v2/keys (Genesys Cloud)
  • Payload Structure:
  "name": "RecordingEncryptionCMK_01",
  "keyType": "AWS_KMS",
  "region": "us-east-1",
  "arn": "arn:aws:kms:us-east-1:123456789012:key/abcd1234-a123-456a-8b12-cd1234ef5678",
  "keyState": "ENABLED",
  "description": "Primary key for PCI-DSS compliant call recording encryption"
  • The Trap: Many engineers attempt to export the private key from the KMS to import it into Genesys Cloud. This violates FIPS 140-2 standards and creates a single point of failure where the private key exists on disk within the CCaaS environment. The correct pattern is to reference the ARN (Amazon Resource Name) or Vault ID directly from the external provider without exporting the secret material.
  • Architectural Reasoning: By referencing the ARN, Genesys Cloud invokes the KMS API to perform cryptographic operations on behalf of your tenant. The data encryption key (DEK) is generated by the KMS, encrypted with a customer-managed master key (KEK), and stored in Genesys storage. When playback is required, Genesys requests the KMS to unwrap the DEK using the KEK. This ensures the plaintext decryption key never resides on the CCaaS servers.
2. Executing the API-Driven Key Import Ceremony
The “multi-party” aspect of this ceremony is realized through a strict separation of duties during the import phase. One administrator generates the key in the KMS, a second administrator authorizes the import request via OAuth token, and a third system component validates the binding.
You must use a Service Account with elevated privileges to execute this import. Do not use a standard user session for this operation.
Step 2.1: Generate Service Account Token
Create a dedicated service account for key management ceremonies. This prevents personal credentials from being used in automated scripts and allows for distinct audit trails.
  • API Endpoint: POST /api/v2/oauth/tokens
  "grantType": "client_credentials",
  "scopes": [
    "key_management:read",
    "key_management:write",
    "recording_policy:read"
  "applicationId": "service-account-key-ceremony-01",
  "expirationSeconds": 3600
Step 2.2: Bind Key to Organization
Once the token is obtained, initiate the binding of the external key reference to your Genesys organization. This step triggers a validation handshake where Genesys Cloud verifies that the service account has permission to access the specified ARN in the external KMS.
  • API Endpoint: POST /api/v2/keys/{keyId}
  "encryptionType": "AES-256-GCM",
  "keyProvider": {
    "providerType": "AWS_KMS",
    "keyArn": "arn:aws:kms:us-east-1:123456789012:key/abcd1234-a123-456a-8b12-cd1234ef5678"
  "autoRotate": true,
  "rotationPeriodDays": 90,
  "status": "ACTIVE"
  • The Trap: A common failure mode occurs when the keyArn in the payload does not match the region specified in the Genesys organization settings. If your Genesys environment is hosted in us-east-1 but you reference an AWS key in eu-west-1, the handshake will fail with a 403 Forbidden error due to cross-region replication restrictions and data residency compliance rules. Always validate that the KMS region matches the Genesies Cloud region exactly.
  • Architectural Reasoning: The autoRotate flag is critical for long-term compliance. When enabled, the KMS will generate a new version of the key every 90 days. However, this does not automatically re-encrypt existing recordings. You must configure a background rotation policy to handle legacy data if your compliance framework requires re-encryption at rest.
3. Configuring Recording Policies for Key Binding
With the key imported and validated, the final step is to bind the encryption key to specific recording queues. This configuration dictates which calls are encrypted using this specific CMK instance.
Step 3.1: Create or Update Recording Policy
Navigate to the Recording > Policies interface via API to ensure precise control over which queue triggers the encryption logic.
  • API Endpoint: POST /api/v2/recordings/policies
  "name": "PCI-DSS Secure Recording Policy",
  "description": "Enforces CMK encryption for all inbound calls to PCI queues",
  "recordingType": "AUDIO_AND_VIDEO",
  "encryptionKeyReference": {
    "keyId": "cmk-recording-key-01",
  "targetType": "QUEUE",
  "targetIds": [
    "d6f8c3a1-b2e4-4f5a-9c8b-1a2b3c4d5e6f"
  "status": "ENABLED",
  "conditions": {
    "direction": "INBOUND",
    "callerIdPattern": null,
    "timeWindow": null
  • The Trap: Do not apply CMK encryption to all queues globally. If a key rotation event occurs during the ceremony and the KMS service is temporarily unavailable, recordings for non-critical queues will fail, causing data loss for those calls. Isolate CMK usage to specific high-compliance queues only. This limits the blast radius of any potential key management outage.
  • Architectural Reasoning: The encryptionKeyReference field links the policy to the imported CMK object. When a call is recorded, the Genesys media server requests a Data Encryption Key (DEK) from the KMS. The recording file is encrypted with the DEK, and the DEK itself is encrypted with the Master Key (KEK) stored in your AWS account. This layered approach allows you to revoke access to recordings by deleting the KEK without needing to re-encrypt every individual recording file stored on disk.
Edge Case 1: KMS Service Interruption During Recording
The Failure Condition: An agent begins a call that triggers recording encryption. The Genesys media server attempts to fetch the DEK from the external KMS, but the network path is congested or the KMS service is degraded. The recording fails to start, or the call drops.
The Root Cause: Synchronous cryptographic operations block the media pipeline. If the KMS handshake exceeds the timeout threshold (typically 5 seconds), the signaling stack treats this as a critical failure.
The Solution: Implement a fallback encryption key for non-critical traffic. Configure two policies: one for high-compliance queues using CMK, and a secondary policy for standard queues using platform-managed keys. If the CMK handshake fails, route the call to the standard queue where recording proceeds with default encryption. This ensures business continuity while maintaining security posture for critical data.
Edge Case 2: Key Rotation Without Re-Encryption
The Failure Condition: A compliance audit requires all stored recordings from the last 365 days to be encrypted under the current key version. However, only new recordings are being re-encrypted during rotation.
The Root Cause: Customer Managed Keys typically support automatic rotation of the Master Key (KEK) but do not automatically trigger a bulk re-encryption job for existing data objects stored in object storage (S3/ADLS).
The Solution: Schedule a manual re-encryption job via API if your compliance framework mandates it. Genesys Cloud provides an endpoint to trigger a re-encryption batch process, but this is computationally expensive and requires a maintenance window.
  "endpoint": "/api/v2/recordings/reencrypt",
  "method": "POST",
  "body": {
    "policyIds": ["policy-pci-dss-01"],
    "targetKeyVersion": "v5",
    "dryRun": false
Verification: Monitor the audit logs for reencryption_job_started and reencryption_job_completed events. Ensure the duration of the job does not impact real-time transcription or analytics capabilities during the process.
Edge Case 3: Cross-Region Key Replication Failure
The Failure Condition: You attempt to import a key from AWS us-east-1 into Genesys Cloud us-west-2. The API returns a 400 Bad Request.
The Root Cause: Data residency and sovereignty regulations prevent cryptographic material from crossing region boundaries in this configuration. Genesys Cloud enforces strict locality for KMS references to ensure latency requirements are met for media processing.
The Solution: You must provision a new key within the exact same cloud region as your Genesies Cloud organization. Use the AWS CLI or Azure CLI to generate the key in the target region, then update the keyArn field in your import payload. Verify the region alignment by checking the output of aws kms describe-key --region us-west-2 --key-id <id>.
