This masterclass details the implementation of Automated Interaction Summarization using Large Language Models (LLMs). By the end of this guide, you will be able to architect a system that automatically generates a concise, structured summary of every customer interaction (Voice or Digital) the moment it ends. You will learn how to integrate Genesys Cloud transcripts with an LLM (e.g., GPT-4o, Claude 3.5 Sonnet), push the summary into the Agent Workspace to eliminate manual note-taking, and ensure the summary is written back to your CRM as a “System of Record.”
Automated summarization requires the Genesys Cloud AI Experience and access to the Conversation API.
- Licensing: Genesys Cloud CX 3 OR CX 1/2 with AI Experience (Copilot/Agent Assist).
- Permissions:
Speech Analytics > Transcript > ViewConversations > Participant > Edit
- OAuth Scopes:
speech_analytics,conversations. - AI Infrastructure: Access to an LLM API via Genesys Cloud AI Integrations or a custom Data Action middleware.
1. Capturing the Interaction Transcript
The “Source Material” for the summary is the real-time transcript.
Implementation Step:
- Enable Genesys Cloud Native Transcription on the target queue.
- Use a Data Action or EventBridge trigger to detect the
v2.detail.events.conversation.{id}.user.endevent. - Fetch the full interaction transcript using the
GET /api/v2/speechandtextanalytics/conversations/{id}/transcriptendpoint.
2. Designing the “Summarization Prompt”
The quality of the summary depends on the prompt sent to the LLM.
Architectural Reasoning:
Do not just ask for a “Summary.” You must ask for a Structured Summary that includes:
- Reason for Call: (e.g., “Billing Dispute”)
- Resolution: (e.g., “Applied 10% discount”)
- Next Steps: (e.g., “Technician scheduled for Tuesday”)
- Sentiment: (e.g., “Initially frustrated, ended neutral”)
3. Injecting the Summary into the Agent Workspace
The agent needs to see and verify the summary before it is finalized.
Implementation Pattern:
Use Genesys Cloud Agent Copilot (Native) or a Custom Interaction Widget.
- The Native Way: Enable Auto-Summarization in the Copilot configuration. The AI generates the summary in real-time as the call progresses.
- The Custom Way: Use the Client App SDK to display the LLM-generated summary in a sidebar. Allow the agent to edit the text if necessary, then click “Confirm” to save it.
4. Writing back to the CRM (System of Record)
A summary in Genesys Cloud is helpful, but it belongs in the CRM for long-term customer history.
- Once the agent confirms the summary, the middleware triggers a CRM Data Action.
- Endpoint:
POST /services/data/v58.0/sobjects/Task(Salesforce Example). - Payload: Map the
conversationId,agentName, and thellmSummaryto the CRM Task record.
Edge Case 1: Hallucinations and Incorrect Facts
- The failure condition: The LLM summarizes that the customer was offered a refund, but the agent actually refused the refund.
- The root cause: The LLM prioritized “politeness” over “factual accuracy” or misinterpreted the agent’s negative sentiment.
- The solution: Implement Fact Extraction. In your LLM prompt, explicitly instruct the AI: “If a specific outcome is not clearly stated in the transcript, mark the ‘Resolution’ as ‘Undetermined’ rather than guessing.”
Edge Case 2: PII/PCI Data Leakage
- The failure condition: The customer says their credit card number during the call, and the LLM includes the card number in the summary.
- The root cause: Failure to redact sensitive data before sending it to the LLM.
- The solution: Always use Genesys Cloud PII Redaction on transcripts. Ensure the “Redact Transcripts” toggle is enabled in the Speech Analytics settings. The LLM should only ever receive
[REDACTED]strings for sensitive data.
