Implementing Linting and Validation for Architect YAML Definitions
This guide details the architecture and implementation of a pre-deployment linting and validation pipeline for Genesys Cloud CX Architect flow definitions stored as YAML. You will build a deterministic validation layer that verifies JSON Schema compliance, resolves cross-reference integrity, validates custom expression syntax, and enforces organizational routing standards before any flow definition reaches the staging environment. The end result is a CI/CD gate that rejects malformed flows, prevents environment-specific ID collisions, and eliminates runtime expression failures prior to deployment.
- Licensing Tier: CX 1.0 or higher (Architect module access required)
- User Permissions:
architect:flow:view,architect:flow:add,architect:flow:update,architect:flow:delete,architect:queue:view,organization:users:view,view:view - OAuth Scopes:
flow:view,flow:add,flow:update,queue:view,user:view,view:view,analytics:report:view - External Dependencies: Node.js 18 LTS or Python 3.10+,
ajv(JSON Schema Validator),yqorjs-yaml, CI/CD runner with network access to Genesys Cloud Platform API, Git repository for flow definitions - Tooling Context: This guide assumes usage of the
genesyscloud-yamlCLI ecosystem or equivalent GitOps serialization tools that export Architect flows as YAML representations of the underlying JSON API payloads.
1. Establish the JSON Schema Baseline for Architect YAML
Architect flow definitions are fundamentally hierarchical JSON objects serialized as YAML for version control. The first validation layer must verify structural integrity without invoking the Genesys Cloud API. JSON Schema provides deterministic, millisecond-level validation that catches malformed block definitions, missing required fields, and invalid data types before the pipeline proceeds to reference resolution.
You must construct a schema that mirrors the /api/v2/architect/flows payload structure. The schema must enforce strict typing for block properties, validate transition arrays, and restrict dataActions to supported operation types. Loose schema validation is insufficient. Genesys Cloud rejects payloads that contain unexpected keys or incorrect type casting, which causes silent deployment failures when using automated import tools.
"$schema": "http://json-schema.org/draft-07/schema#",
"type": "object",
"required": ["name", "description", "type", "blocks", "transitions"],
"properties": {
"name": { "type": "string", "minLength": 1, "maxLength": 255 },
"description": { "type": "string" },
"type": { "type": "string", "enum": ["voice", "chat", "callback", "email", "sms"] },
"blocks": {
"type": "object",
"additionalProperties": {
"type": "object",
"required": ["type", "name"],
"properties": {
"type": { "type": "string", "enum": ["setInteraction", "queue", "transfer", "hangup", "prompt", "wait", "conditionalGroup"] },
"name": { "type": "string" },
"actions": {
"type": "array",
"items": {
"type": "object",
"required": ["name", "type"],
"properties": {
"type": { "type": "string", "enum": ["setInteraction", "setUser", "setQueue", "setView"] }
"transitions": {
"type": "object",
"type": "array",
"items": {
"type": "object",
"required": ["nextBlock", "expression"],
"properties": {
"nextBlock": { "type": "string" },
"expression": { "type": "string" },
"isDefault": { "type": "boolean" }
The Trap: Relying on top-level key validation while ignoring nested block type constraints. When you validate only the root object, the linter passes flows that contain malformed queue blocks missing queueId or queueName, or prompt blocks with invalid promptId references. The Genesys Cloud API rejects these during import with a 400 Bad Request and a generic payload validation error. The downstream effect is a broken CI/CD pipeline and manual debugging of hundreds of YAML lines.
Architectural Reasoning: We enforce strict nested validation because Architect blocks are polymorphic. A queue block requires completely different properties than a setInteraction block. The schema must validate the union of all block types. We use ajv with allErrors: true to collect every structural violation in a single pass. This prevents iterative debugging and provides a consolidated error report to the developer. The schema lives in the repository root, versioned alongside the flows, ensuring that schema updates align with Genesys Cloud API version changes.
2. Implement Cross-Reference Integrity Resolution
Architect flows reference queues, users, views, integrations, and other flows by UUID. These identifiers are environment-specific. A flow exported from Development contains queue UUIDs that do not exist in Production. If you deploy the raw YAML, the import succeeds structurally but fails functionally because the routing engine cannot resolve the target queue. The linter must extract all reference tokens, map them to environment-specific substitutes, and verify existence against a target environment manifest.
You will implement a reference resolver that parses the YAML, extracts all UUID patterns, and cross-references them against a reference-map.yaml file or a live API cache. The resolver must support three resolution modes: static mapping, API lookup, and regex-based environment substitution.
# reference-map.yaml
environment: prod
overrides:
queues:
"dev-queue-uuid-1234": "prod-queue-uuid-5678"
"dev-queue-uuid-9012": "prod-queue-uuid-3456"
"dev-view-uuid-1111": "prod-view-uuid-2222"
users:
"dev-user-uuid-3333": "prod-user-uuid-4444"
The resolver script performs a depth-first traversal of the YAML structure. It identifies fields known to contain UUIDs (queueId, queueName, viewId, userId, promptId, integrationId). It replaces development tokens with production equivalents using the mapping file. If a token lacks a mapping, the script queries the Genesys Cloud Platform API to verify existence in the target environment.
# API validation for queue existence
curl -X GET \
"https://{organization}.mypurecloud.com/api/v2/queues/{queueUuid}" \
-H "Authorization: Bearer {access_token}" \
-H "Content-Type: application/json"
The Trap: Assuming that all referenced IDs exist in the current environment. Cross-environment deployments frequently fail because queue UUIDs, view UUIDs, and user group UUIDs are scoped to the organization’s environment. When you deploy without resolution, the flow imports successfully, but routing rules point to null targets. Calls drop, chats timeout, and WEM captures show zero utilization because the routing engine cannot match the flow to an active queue.
Architectural Reasoning: We separate reference resolution from schema validation because they solve different problems. Schema validation checks structure. Reference resolution checks runtime connectivity. We maintain a reference-map.yaml as the source of truth for environment substitution. The linter validates that every required reference has a valid substitute. If a mapping is missing, the pipeline fails fast with a clear error indicating which UUID requires a production counterpart. This prevents accidental deployment of development-specific routing targets. We cache API lookups in a local JSON manifest to reduce API call volume and prevent rate limiting during large repository scans.
3. Validate Architect Expression Syntax and Type Safety
Architect uses a custom expression language enclosed in {{ }} delimiters. Expressions evaluate at runtime to determine routing paths, data transformations, and conditional branching. Invalid expressions do not fail during YAML import. They fail silently at runtime, causing calls to route to default transitions or drop entirely. The linter must parse expressions, verify syntax, validate function availability, and enforce type safety against declared data actions.
You will implement a static expression parser that extracts all {{ expression }} blocks, validates them against a known function registry, and checks variable scope against the flow’s declared context objects. The parser must reject undefined functions, mismatched parentheses, and invalid type coercion patterns.
// Expression validation logic (Node.js)
const expressionRegex = /\{\{([^}]+)\}\}/g;
const validFunctions = [
'concat', 'trim', 'lower', 'upper', 'length', 'substring',
'equals', 'contains', 'startsWith', 'endsWith',
'getDate', 'getTime', 'formatDate', 'formatTime',
'toInt', 'toFloat', 'toString', 'toBoolean',
'random', 'uuid', 'now'
function validateExpression(expression, contextVars) {
const matches = expression.match(expressionRegex);
if (!matches) return true;
for (const match of matches) {
const content = match.slice(2, -2).trim();
// Check for undefined functions
const functionCalls = content.match(/\b([a-zA-Z_]\w*)\s*\(/g);
if (functionCalls) {
for (const call of functionCalls) {
const funcName = call.slice(0, -2).trim();
if (!validFunctions.includes(funcName)) {
throw new Error(`Undefined function: ${funcName}`);
// Check for undefined variables
const variableRefs = content.match(/\b([a-zA-Z_]\w*)\s*\./g);
if (variableRefs) {
for (const ref of variableRefs) {
const varName = ref.slice(0, -1).trim();
if (!contextVars.includes(varName)) {
throw new Error(`Undefined context variable: ${varName}`);
return true;
The Trap: Using runtime testing or manual QA to catch expression errors. Expressions like {{ concat(queue.name, " - ", user.firstName) }} fail silently until runtime if the queue context object is not populated at that block execution phase. When you rely on post-deployment testing, you discover routing failures during business hours. The downstream effect is dropped interactions, SLA breaches, and emergency hotfix deployments.
Architectural Reasoning: We validate expressions statically because runtime evaluation is impossible in a CI/CD environment. The linter maintains a context availability matrix that maps each block type to its accessible context objects (contactAttributes, interaction, user, queue, view, customData). When an expression references a variable, the linter checks whether that variable is available in the current block’s execution context. If the expression references interaction.direction inside a setInteraction block, the linter flags it because interaction context is not populated until after the block executes. This prevents type coercion failures and undefined variable errors before deployment.
4. Integrate into CI/CD with Pre-Flight Dry-Run Simulation
The final validation layer leverages Genesys Cloud’s native draft flow mechanism to perform a pre-flight simulation. You create a draft flow in the target environment, run programmatic validation, and delete the draft if validation fails. This approach uses the platform’s built-in validation engine while keeping the pipeline immutable and auditable.
You will configure the CI/CD pipeline to trigger on pull requests targeting the main or production branch. The pipeline executes schema validation, reference resolution, expression checking, and draft simulation in sequence. If any step fails, the pipeline rejects the merge request and attaches the validation report to the PR comments.
# .github/workflows/architect-lint.yml
name: Architect Flow Validation
on:
pull_request:
branches: [main]
paths:
- 'architect/flows/**/*.yaml'
jobs:
validate:
runs-on: ubuntu-latest
steps:
- uses: actions/checkout@v4
- name: Setup Node.js
uses: actions/setup-node@v4
with:
node-version: '18'
- name: Install Dependencies
run: npm install ajv js-yaml
- name: Schema Validation
run: node scripts/schema-validator.js architect/flows/
- name: Reference Resolution
run: node scripts/reference-resolver.js --env prod --map reference-map.yaml
- name: Expression Validation
run: node scripts/expression-validator.js architect/flows/
- name: Draft Simulation
run: |
curl -X POST \
"https://${{ secrets.ORG_DOMAIN }}/api/v2/architect/flows" \
-H "Authorization: Bearer ${{ secrets.ACCESS_TOKEN }}" \
-H "Content-Type: application/json" \
-d @architect/flows/payload.json \
--fail
- name: Cleanup Draft
if: always()
run: |
curl -X DELETE \
"https://${{ secrets.ORG_DOMAIN }}/api/v2/architect/flows/${{ env.DRAFT_FLOW_ID }}" \
The Trap: Deploying directly to production without a staging validation step. Architect flows with circular transitions, missing default transitions, or invalid queue routing rules cause immediate routing black holes. When you bypass draft simulation, you rely on the production environment to catch validation errors. The downstream effect is degraded routing performance, increased average speed of answer, and potential SLA violations during business hours.
Architectural Reasoning: We use the draft flow mechanism because it provides native platform validation without affecting active routing. The draft is created in the target environment with a draft: true flag (or via API payload structure). The linter checks the HTTP response code. A 201 Created response indicates structural validity. A 400 or 422 response returns detailed validation errors from the Genesys Cloud engine. We delete the draft immediately after validation to prevent environment clutter. This approach combines static analysis with platform-native validation, ensuring that flows pass both structural checks and runtime engine requirements before reaching production.
Edge Case 1: Circular Transition Detection
- The Failure Condition: The flow imports successfully, but calls enter an infinite routing loop. The interaction never reaches a queue or termination block. WEM captures show high interaction duration and zero disposition.
- The Root Cause: Transitions form a closed loop without an exit condition or default transition. For example, Block A transitions to Block B, Block B transitions to Block C, and Block C transitions back to Block A. The routing engine cycles indefinitely until the interaction times out or the caller disconnects.
- The Solution: Implement a graph traversal algorithm using Depth-First Search (DFS) on the transition matrix. The linter builds an adjacency list from the
transitionsobject and detects cycles by tracking visited nodes and recursion stacks. If a cycle is detected, the pipeline fails with a report listing the exact block sequence forming the loop. You must also enforce that every block contains at least one transition withisDefault: true. This guarantees an exit path when conditional expressions evaluate to false.
Edge Case 2: Expression Context Scope Violations
- The Failure Condition: The flow routes to an unexpected default transition. Calls drop or route to the wrong queue. Genesys Cloud logs show
Expression evaluation failedorUndefined variableerrors in the flow execution trace. - The Root Cause: Expressions reference context objects not available in the specific block type. For example, a
setInteractionblock attempts to evaluate{{ interaction.direction }}before the interaction object is fully populated. Or aqueueblock references{{ customData.customerTier }}without declaring asetInteractionaction to populatecustomDatafirst. - The Solution: Maintain a context availability matrix that maps each block type to its accessible execution phase. The linter cross-references expression variables against the allowed context for that block. If an expression references a variable that requires a prior
setInteractionaction, the linter validates that the action exists in an upstream block. You must also validate type coercion patterns. Expressions like{{ toInt(contactAttributes.customData.priority) }}fail ifpriorityis null. The linter enforces null-safe evaluation patterns or requires explicit default value handling using{{ or(contactAttributes.customData.priority, 0) }}. This prevents runtime type errors and ensures deterministic routing behavior.
