Implementing IVR Prompt Audio File Migration with Format Conversion and Quality Validation
This guide details the automated pipeline for migrating legacy IVR prompt libraries into Genesys Cloud CX, including programmatic format conversion, loudness normalization, and API-driven quality validation before deployment. You will establish a repeatable migration workflow that guarantees codec compliance, prevents runtime playback failures, and maintains consistent acoustic quality across global language packs.
  • Licensing Tier: Genesys Cloud CX 1 or higher (Prompt Management is included in base CX licensing). No WEM or Speech Analytics add-ons are required for this scope.
  • Granular Permissions: Media > Prompt > Edit, Media > Prompt > Upload, Integration > OAuth Client > Read, Organization > Suborganization > Read (if deploying across multiple regions)
  • OAuth Scopes: prompt:read, prompt:write, media:read, integration:oauthclient:read
  • External Dependencies: FFmpeg 6.x+, Python 3.10+, cloud object storage bucket (AWS S3/Azure Blob) for staging, Genesys Cloud OAuth 2.0 Service Account with application grant type
  • Network Requirements: Outbound HTTPS connectivity to api.mypurecloud.com and media.mypurecloud.com, TLS 1.2 minimum, no proxy interference on multipart/form-data payloads
1. Staging Architecture and Idempotent Pipeline Design
Direct manual upload of legacy prompt libraries through the Genesys Cloud UI introduces naming inconsistencies, metadata loss, and rate-limit exhaustion during large-scale deployments. The correct approach separates ingestion, transformation, validation, and registration into distinct pipeline stages. This separation provides an audit trail, enables rollback capabilities, and isolates conversion failures from platform API limits.
You will architect a four-stage pipeline:
  1. Ingestion: Legacy files are copied to a versioned object storage bucket. The bucket enforces immutable storage to preserve source artifacts.
  2. Transformation: A worker process scans the bucket, applies format conversion, and writes processed files to a quarantine directory.
  3. Validation: An acoustic analysis script verifies codec compliance, loudness targets, and silence boundaries. Files that fail validation are routed to a rejection queue with detailed error manifests.
  4. Registration: A dedicated upload service authenticates via OAuth, pushes validated files to the Genesys Cloud Prompt API, and maps the returned prompt IDs to your internal routing configuration.
The Trap: Designing the pipeline as a synchronous linear process where conversion, validation, and upload occur in a single thread per file. Under load, this architecture exhausts database connections, triggers HTTP 429 rate limits on the Genesys API, and leaves partial libraries deployed when a single file fails.
Architectural Reasoning: We decouple these stages using message queues (SQS/Event Grid) or job schedulers. Each stage operates independently with retry logic and dead-letter queues. The upload stage implements idempotency by generating a consistent hash of the audio payload and checking GET /api/v2/media/prompts?search={hash} before initiating POST. This prevents duplicate prompt registration and ensures infrastructure drift does not corrupt your media library. You will reference the WFM Data Export pipeline pattern when designing job retries, as both systems require identical backoff strategies for external API throttling.
2. Format Conversion and Codec Compliance Enforcement
Genesys Cloud CX media servers optimize playback when prompts arrive in pre-encoded, platform-native formats. While the platform accepts WAV, MP3, and OGG Vorbis, runtime transcoding of non-compliant files increases CPU utilization on the media gateway and introduces playback latency. You will enforce a strict conversion profile that aligns with Genesys Cloud recommendations and global SIP trunk bandwidth constraints.
Target specification for all migrated prompts:
  • Container: OGG Vorbis (preferred for bandwidth efficiency) or WAV PCM 16-bit (for ultra-low latency routing)
  • Sample Rate: 24 kHz (sufficient for telephony voice band, reduces file size by 50% compared to 48 kHz)
  • Bit Depth: 16-bit
  • Channels: Mono (IVR prompts are monophonic; stereo encoding wastes bandwidth and triggers unnecessary channel mixing in the media server)
  • Bitrate: Constant Bit Rate (CBR) 48 kbps for OGG, 384 kbps for WAV
Execute conversion using FFmpeg with explicit codec flags. Variable Bit Rate (VBR) encoding must be disabled, as VBR causes unpredictable buffering behavior in the Genesys Cloud media player component.
ffmpeg -i input_legacy.wav \
  -ac 1 \
  -ar 24000 \
  -sample_fmt s16 \
  -codec:a libvorbis \
  -b:a 48k \
  -vbr on \
  -vbr_quality 5 \
  -vn \
  -map_metadata -1 \
  -y output_compliant.ogg
The Trap: Uploading MP3 files encoded with VBR or prompts containing embedded ID3v2 metadata tags. The Genesys Cloud media parser does not strip ID3 tags during ingestion. These tags are interpreted as audio frames, resulting in silent gaps, audible clicks, or complete playback failure during IVR execution.
Architectural Reasoning: We enforce CBR OGG encoding because the Genesys Cloud media server streams prompts using progressive download. CBR provides predictable frame sizes, allowing the media player to calculate exact seek positions without parsing variable-length headers. The -map_metadata -1 flag strips all source metadata, preventing tag injection. You will validate the output using ffprobe -v quiet -print_format json -show_streams output_compliant.ogg to confirm the codec string matches vorbis and the sample rate equals 24000. Any deviation triggers a pipeline rejection before API submission.
3. Acoustic Quality Validation and Loudness Normalization
Prompt libraries migrated from legacy PBX systems often contain inconsistent loudness levels, excessive head/tail silence, and peak clipping. These acoustic anomalies directly impact customer experience metrics. The Genesys Cloud media gateway applies automatic gain control, but it cannot recover from clipped peaks or normalize extreme dynamic ranges without introducing distortion artifacts. You will implement a validation stage that enforces EBU R128 loudness standards and trims acoustic boundaries.
Target acoustic parameters:
  • Integrated Loudness: -23 LUFS ± 1 LU
  • True Peak: -1.0 dBTP maximum
  • Head Silence: ≤ 100 ms
  • Tail Silence: ≤ 200 ms
  • Dynamic Range: 12 to 18 LU (prevents over-compression)
Use a Python-based validation script leveraging pydub and loudness libraries. The script calculates integrated loudness, applies loudness normalization if required, and trims silence using energy-based threshold detection.
import os
import subprocess
from pydub import AudioSegment
from loudness import Loudness
def validate_and_normalize(prompt_path, output_path, target_lufs=-23.0, max_peak=-1.0):
    audio = AudioSegment.from_file(prompt_path)
    # Calculate integrated loudness
    loudness_calc = Loudness(str(audio))
    loudness_val = loudness_calc.estimate()
    # Normalize if outside tolerance
    if abs(loudness_val - target_lufs) > 1.0:
        gain_db = target_lufs - loudness_val
        audio = audio.apply_gain(gain_db)
    # Enforce true peak limit
    peak_db = audio.dBFS
    if peak_db > max_peak:
        audio = audio.apply_gain(max_peak - peak_db)
    # Trim head silence (100ms threshold)
    audio = audio.strip_silence(silence_thresh=-40, silence_len=100, keep_silence=50)
    # Trim tail silence (200ms threshold)
    audio = audio.strip_silence(silence_thresh=-40, silence_len=200, keep_silence=50, reverse=True)
    # Export to compliant WAV for final API upload
    audio.export(output_path, format="ogg", codec="libvorbis", bitrate="48k")
    return True
The Trap: Applying loudness normalization after API upload. The Genesys Cloud Prompt API does not support post-ingestion acoustic modification. Once a prompt is registered, you must delete it, re-upload the corrected file, and update all IVR flow references. This causes routing downtime and configuration drift across multiple Architect flows.
Architectural Reasoning: We enforce acoustic compliance at the validation stage because the Genesys Cloud media server treats prompts as static assets. The platform caches prompt payloads at the edge based on suborganization and region. Modifying audio after registration invalidates edge caches, forces full re-sync cycles, and increases CDN egress costs. By normalizing to -23 LUFS with a -1.0 dBTP ceiling, we ensure consistent playback volume across different trunk paths (PRI, SIP, WebRTC) and prevent the media gateway from applying aggressive dynamic range compression, which introduces pumping artifacts during background music playback. You will cross-reference the Speech Analytics Audio Quality Guide when configuring silence thresholds, as both systems rely on identical energy-detection algorithms to segment utterances.
4. API-Driven Bulk Upload and Prompt Registration
Manual prompt upload does not scale beyond dozens of files. You will implement a programmatic upload service using the Genesys Cloud Prompt API. The service authenticates via OAuth 2.0 client credentials, constructs multipart/form-data payloads, and manages concurrent upload sessions with exponential backoff.
Authentication requires a service account with the prompt:write scope. Generate an access token before initiating the upload pipeline.
curl -X POST "https://api.mypurecloud.com/api/v2/oauth/token" \
  -H "Content-Type: application/x-www-form-urlencoded" \
  -d "grant_type=client_credentials&client_id={YOUR_CLIENT_ID}&client_secret={YOUR_CLIENT_SECRET}&scope=prompt:read%20prompt:write%20media:read"
Use the returned access_token to upload prompts. The endpoint accepts multipart/form-data with a JSON metadata part and the audio file part.
curl -X POST "https://api.mypurecloud.com/api/v2/media/prompts" \
  -H "Authorization: Bearer {ACCESS_TOKEN}" \
  -H "Content-Type: multipart/form-data" \
  -F "file=@output_compliant.ogg;type=audio/ogg" \
  -F 'metadata={"name":"Welcome_Main_En","language":"en-US","category":"System","description":"Primary IVR greeting"}'
Implement a concurrency pool of 10 to 15 threads per suborganization. Monitor HTTP 429 responses and implement a jittered exponential backoff starting at 2 seconds, doubling up to 60 seconds. Track successful uploads in a state file that maps internal filenames to Genesys Cloud id and uri fields.
The Trap: Reusing a single OAuth token across multiple upload threads without handling token expiration. OAuth tokens expire after 3600 seconds. Concurrent threads that outlive the token window receive 401 Unauthorized errors, causing partial pipeline failures and requiring full re-execution.
Architectural Reasoning: We implement a token refresh wrapper that checks expiration timestamps and regenerates credentials before the 3600-second boundary. The upload service maintains a connection pool with keep-alive headers to reduce TCP handshake overhead. We structure the metadata payload to include a category and language field because Genesys Cloud uses these attributes for prompt routing optimization. When an IVR flow requests a prompt, the media server selects the closest matching language pack and category to reduce cross-region fetch latency. By populating these fields during migration, you eliminate the need for post-migration bulk updates and ensure Architect flows resolve prompts deterministically.
Edge Case 1: Cross-Region Prompt Caching Mismatch
The failure condition: Prompts play correctly in the US East suborganization but return silent audio or fallback to text-to-speech in EU West or APAC regions after migration.
The root cause: Genesys Cloud caches prompt payloads at regional edge locations. If the upload API targets a specific suborganization without explicit region replication flags, the prompt remains isolated to the origin region. Architect flows in other regions attempt to fetch the prompt URI, receive a 404 from the local edge cache, and trigger fallback routing.
The solution: Execute the upload pipeline against each target suborganization using the POST /api/v2/media/prompts endpoint with the appropriate subOrganizationId header. Alternatively, enable global prompt replication in the Media settings and verify the replicationStatus field in the prompt metadata response. Run GET /api/v2/media/prompts?search={prompt_name} against each region to confirm cache propagation before decommissioning legacy PBX media servers.
Edge Case 2: Unsupported Metadata Injection in OGG Headers
The failure condition: Prompts upload successfully and pass FFmpeg validation, but playback in Architect flows introduces 500 ms delays or audible static bursts at the start of the prompt.
The root cause: OGG Vorbis containers support custom comment fields. Legacy conversion tools sometimes inject ENCODER, COMMENT, or DESCRIPTION fields that exceed the Vorbis specification limit. The Genesys Cloud media parser attempts to read these headers during initialization, causing frame alignment shifts and buffer underruns.
The solution: Enforce strict header stripping during conversion using -map_metadata -1 and append -metadata encoder="FFmpeg" to prevent empty header blocks. Validate the final payload using ogginfo output_compliant.ogg to confirm zero custom comment fields. If legacy files already contain embedded headers, run a second-pass conversion that explicitly discards all metadata before API submission.
Edge Case 3: Locale-Specific Character Encoding in Prompt Names
The failure condition: Prompts with accented characters or non-Latin script names fail to resolve in Architect flows, returning PROMPT_NOT_FOUND errors despite successful API upload.
The root cause: The Genesys Cloud Prompt API accepts UTF-8 encoded names, but legacy migration scripts sometimes transmit names using ISO-8859-1 or Windows-1252 encodings. The API silently truncates or replaces invalid byte sequences, causing the stored name to mismatch the reference in Architect flow blocks.
The solution: Normalize all prompt names to ASCII-compatible identifiers during the validation stage using a transliteration library (e.g., unidecode in Python). Map the original legacy name to a description field in the JSON metadata payload to preserve auditability. Update all Architect flow prompt blocks to reference the normalized ASCII name. Execute a flow validation sweep using GET /api/v2/analytics/flows/query to identify unresolved prompt references before promoting the migration to production.
