Implementing High-Contrast and Large-Font Agent Desktop Themes for Low-Vision Users
This guide details the configuration of custom Agent Desktop themes within Genesys Cloud CX to support agents with low-vision impairments. You will configure CSS variable overrides that enforce minimum contrast ratios and scalable font sizes across all UI components. The end result is a deployable theme definition that ensures WCAG 2.1 AA compliance without requiring third-party screen reader software dependencies on the agent workstation.
To execute this implementation, specific platform capabilities and user permissions must be in place before attempting any configuration changes.
Licensing Requirements
  • Genesys Cloud CX Subscription: Enterprise or Professional tier is required to access custom theme creation capabilities. Standard subscriptions do not expose the necessary API endpoints for theme management.
  • Agent Desktop License: All target agents must hold an active Agent Desktop license. Theme overrides do not apply to legacy desktop clients.
  • WEM Add-on: Access to the User Experience and Analytics tools is recommended for monitoring adoption rates post-deployment.
Granular Permissions
The user account performing this configuration requires specific permissions within the Admin Console. The following permission strings must be enabled:
  • Agent Desktop > Themes > Edit (Full access to create and modify themes)
  • Agent Desktop > Themes > Assign (Ability to map themes to groups or users)
  • Settings > Accessibility (Read-only access to verify platform accessibility settings)
OAuth Scopes
If utilizing the API for programmatic theme creation, the following OAuth scopes are required:
  • agentdesktop.themes.write
  • agentdesktop.users.read
  • settings.accessibility.read
External Dependencies
  • Web Browser: Chrome version 100+ or Edge version 100+ on Windows. Firefox support is limited regarding CSS variable injection.
  • Operating System: Windows 10/11 or macOS Ventura+. The OS-level display scaling settings must be verified to ensure they do not conflict with the theme font definitions.
  • Design Tool: A JSON editor capable of validating syntax (e.g., VS Code with JSON schema support) is required to draft the theme payload.
1. Understanding the CSS Variable Cascade and Architecture
Before writing a single line of configuration, you must understand how the Agent Desktop rendering engine processes style definitions. Genesys Cloud CX utilizes a cascading stylesheet system where platform defaults are loaded first, followed by user-specific overrides. The architecture relies on CSS Custom Properties (variables) to define visual attributes such as background color, text color, and font size.
The critical architectural decision here is whether to modify the base theme or create a new child theme. Modifying the base “Light” or “Dark” platform themes directly creates a maintenance liability. When Genesys releases a platform update, these changes may be overwritten during patch cycles. The correct approach is to create a custom theme definition that inherits from the base theme but explicitly overrides specific variables.
This inheritance model ensures that new UI components introduced in future releases retain default styling unless you specifically target them. It also isolates your accessibility configurations from general aesthetic changes made by IT administration. You must identify the specific CSS variables that control visual rendering for the core interface elements: navigation bars, chat widgets, conversation cards, and form inputs.
The Trap
A common misconfiguration involves attempting to override style properties using legacy CSS class selectors (e.g., .agent-header { background-color: red; }). The Agent Desktop runtime does not support arbitrary selector injection through the theme API for security reasons. If you attempt to inject raw CSS files, the deployment will fail validation.
The catastrophic downstream effect of this approach is a broken user interface where buttons become unclickable or text becomes invisible because the platform-specific styling classes are being bypassed incorrectly. You must rely exclusively on the supported CSS Custom Properties provided in the API schema. If you attempt to use !important flags in your payload, they will be stripped by the parser, rendering your configuration ineffective. Always define your variables using standard specificity without flag overrides.
2. Constructing the High-Contrast Theme Payload
The core of this implementation is the JSON payload that defines the visual properties. This payload must adhere to the strict schema defined in the Genesys Cloud Developer Center. The objective is to ensure a contrast ratio of at least 4.5:1 for normal text and 3:1 for large text, as per WCAG 2.1 guidelines.
You will begin by defining the root variables that control global typography. Font size should be scalable but anchored to a base unit that allows the rendering engine to calculate relative sizes correctly. We recommend using rem units where supported, or fixed pixel values if the engine requires strict sizing for layout stability.
For high contrast, you must invert standard color palettes. The default white background with dark text often fails for users with cataracts or specific types of retinal degeneration. A black background with bright yellow or white text provides the maximum luminance difference. You must ensure that this inversion applies to all container elements including chat bubbles and notification banners.
Below is a production-ready JSON payload structure for a High-Contrast Large-Font theme. This example targets the core UI components used in Genesys Cloud CX Agent Desktop.
  "name": "High Contrast - Low Vision Support",
  "description": "WCAG 2.1 AA compliant theme for low-vision users with large font scaling",
  "baseThemeId": "light-theme-default",
  "colorOverrides": {
    "--agent-desktop-background-color": "#000000",
    "--agent-desktop-text-color": "#FFFFFF",
    "--agent-desktop-primary-button-bg": "#FFFF00",
    "--agent-desktop-primary-button-text": "#000000",
    "--agent-desktop-chat-bubble-user-bg": "#1A1A1A",
    "--agent-desktop-chat-bubble-user-text": "#FFFF00",
    "--agent-desktop-chat-bubble-agent-bg": "#333333",
    "--agent-desktop-chat-bubble-agent-text": "#FFFFFF"
  "typographyOverrides": {
    "--agent-desktop-font-family": "Arial, Helvetica, sans-serif",
    "--agent-desktop-font-size-base": "1.5rem",
    "--agent-desktop-font-weight-bold": "700"
  "layoutOverrides": {
    "--agent-desktop-border-width": "2px",
    "--agent-desktop-border-color": "#FFFF00"
  "status": "ACTIVE",
  "visibility": "PRIVATE"
In this payload, the baseThemeId links to the standard light theme. This ensures that iconography and layout structures remain consistent with the platform design language. The colorOverrides section forces specific hex codes for critical UI states. Note the use of #FFFF00 (Yellow) as a primary action color. This provides high visibility against black backgrounds while remaining distinct from standard system notification colors.
The typography section explicitly sets the base font size to 1.5rem. This scales text relative to the user’s browser settings but ensures a minimum baseline larger than the default 1rem. The layout overrides increase border widths and add colored borders to key interactive elements. This visual cue helps users identify clickable regions without relying solely on hover states which may be missed by low-vision users.
The Trap
A frequent error in payload construction is neglecting state-specific variables for interactive elements. If you only override the base background color, disabled buttons or inactive tabs often revert to platform defaults with low contrast ratios (e.g., grey text on light grey backgrounds).
The catastrophic downstream effect here is partial visibility. Agents may see standard text but fail to distinguish active conversation lines from completed ones during high-volume call periods. This leads to missed interactions and increased error rates. You must explicitly define variables for hover states (--agent-desktop-hover-bg), active states, and disabled states (--agent-desktop-disabled-text).
Additionally, ensure that the visibility property is set correctly. Setting this to PRIVATE allows you to test the theme on a single user group before global rollout. If you leave this as PUBLIC during development, agents may inadvertently apply an untested configuration to their desktops, causing confusion or accessibility regressions. Always validate the JSON against the schema validator in the Developer Portal before saving.
3. Assigning Themes to User Groups and Individuals
Once the theme definition is saved and validated, the next step is scope assignment. You cannot force a theme upon an agent; you must assign it to a group or user profile via the Admin Console or API. This granular control allows you to target only those agents who have declared low-vision impairments or who request this configuration for medical reasons.
The assignment logic follows a hierarchy. If a theme is assigned to a Group, all users within that group inherit it unless they have a specific user-level override. It is best practice to create a dedicated User Group named “Accessibility - Low Vision Support” rather than assigning themes individually to each agent. This centralizes management and reduces the administrative overhead of tracking individual preferences.
When assigning via the API, you must utilize the PATCH /api/v2/users/{userId}/preferences endpoint to update the desktop theme preference for a specific user. Alternatively, use the Admin Console UI to navigate to User Management > Groups and select the assigned Agent Desktop Theme field. Ensure that the “Apply on Login” flag is enabled so that the theme loads automatically upon agent authentication without requiring manual selection.
You must also configure the “Force Theme” setting if available in your tenant settings. This prevents agents from switching back to a default theme that might not meet their accessibility needs during a session. However, be aware that forcing a theme can lead to user friction if the configuration does not match their personal preference for brightness levels.
The Trap
A critical misconfiguration occurs when administrators assign themes at the Organization level without verifying group membership. If you apply the High-Contrast theme to the root tenant organization, every single agent will receive it. This creates a significant usability issue for agents who do not have vision impairments and prefer standard color schemes.
The catastrophic downstream effect is a universal degradation of user experience for the entire workforce. Agents without low-vision requirements may find high-contrast themes jarring or difficult to read due to excessive visual noise. This can lead to increased fatigue and reduced productivity across the board. You must restrict theme assignment to specific User Groups with explicit tags for accessibility needs.
Furthermore, ensure that you do not assign conflicting themes. An agent cannot have both a “Standard” theme and a “High-Contrast” theme active simultaneously. If multiple assignments exist in the hierarchy, the system may default to the most recent update or throw a rendering error. Always audit user group memberships before deployment to ensure no overlaps exist between standard operational groups and accessibility-specific groups.
Edge Case 1: Contrast Ratio Failures with Third-Party Widgets
Agents often utilize embedded third-party widgets within the Agent Desktop for CRM integration or knowledge base access. These widgets render in an iframe or a sandboxed environment that may not inherit your custom theme CSS variables. If the internal widget styles are hard-coded by the vendor, they will ignore your high-contrast overrides.
The failure condition: The main conversation pane appears with correct high contrast, but the CRM panel inside the window displays white text on a light grey background.
The root cause: Third-party iframes do not receive the --agent-desktop-* CSS variables from the host environment due to cross-origin policies or lack of style injection support.
The solution: You cannot force the host theme onto third-party content directly. The solution is to configure the integration at the vendor level. Contact the CRM provider and request their accessibility mode be enabled for your specific tenant instance. If this is not possible, document this limitation in your user guide and train agents to use browser zoom features specifically for that iframe area if necessary.
Edge Case 2: OS-Level Display Scaling Conflicts
Windows and macOS operating systems include system-level display scaling settings (e.g., 150% or 200% zoom). When an agent enables a custom high-contrast theme within the Genesys Cloud application, it does not automatically account for the OS-level DPI scaling.
The failure condition: Text appears extremely small or pixelated despite the large font settings in the theme payload.
The root cause: The CSS rem units in the theme are interpreted by the browser relative to the base font size of the user’s system, not the application container. If the OS is set to 200% scaling and the application font is also 1.5rem, the compound effect can make text unreadable or cause layout overflow.
The solution: Establish a baseline policy for agent workstations. Instruct agents to set their OS display scaling to 100% or 125% before applying the Genesys theme. Alternatively, adjust your --agent-desktop-font-size-base variable in the theme payload to account for typical system scaling factors. For example, if most agents use 125% scaling, set the base font size to 1.4rem to compensate for the OS magnification.
Edge Case 3: Screen Reader Compatibility and Focus Indicators
High-contrast themes often rely heavily on color differentiation. However, low-vision users frequently utilize screen readers such as JAWS or NVDA. These tools announce focus states but may not convey visual color changes effectively if the theme does not include explicit focus indicators.
The failure condition: Agents using keyboard navigation cannot distinguish which button currently has input focus because the only differentiator is a slight color shift in the background.
The root cause: The theme overrides the default outline or box-shadow properties used for focus management to maintain the high-contrast aesthetic, inadvertently removing the tactile visual cue.
The solution: You must explicitly preserve or enhance the focus indicator styles in your JSON payload. Add a thick border style (--agent-desktop-focus-border) around active elements. Ensure that the color of this border contrasts with both the background and the element text. Do not remove standard CSS :focus pseudo-class styles in your overrides. Always test the navigation flow using only the keyboard (Tab key) to verify that focus rings are visible without relying on mouse interaction.
