Implementing High-Availability SIP Trunk Architectures for Zero-Downtime Voice Infrastructure
This guide details the configuration of redundant SIP trunk groups, carrier failover logic, and network path diversity within a Genesys Cloud CX environment. You will build an infrastructure where voice traffic automatically routes to secondary providers during primary link degradation or complete outage. The end result is a telephony stack capable of sustaining call volume without interruption during carrier maintenance, regional network failures, or SBC connectivity loss.
To implement this architecture, you require specific entitlements and permissions within the Genesys Cloud CX platform.
  • Licensing Tier: Genesys Cloud CX (Flex) with WEM Add-on enabled for advanced failover monitoring. Basic Voice licenses do not support multiple trunk groups per routing profile without additional cost.
  • Granular Permissions: The following resource permissions must be assigned to the user executing the configuration:
    • Telephony > Trunk > Edit
    • Telephony > Routing Profiles > Edit
    • Admin > View (for verifying API access logs)
  • OAuth Scopes: If automating trunk creation via Admin API, include org.admin and telephony.trunkgroups:readwrite scopes.
  • External Dependencies: Two distinct SIP Trunk endpoints from different carriers or one carrier with diverse network paths. DNS records must support TTLs under 300 seconds for rapid failover propagation.
1. Configuring Primary and Secondary SIP Trunk Groups
The foundation of zero-downtime voice infrastructure is the physical and logical separation of inbound and outbound media paths. You must configure two distinct SIP Trunk Groups in Genesys Cloud CX, each pointing to a different carrier endpoint or SBC IP address range.
Configuration Steps:
  1. Navigate to Telephony > Trunks in the platform UI.
  2. Click Add Trunk Group.
  3. Configure the Primary Trunk:
    • Name: SIP-TRUNK-PRIMARY-CARRIER-A
    • Outbound Route: Select the corresponding Carrier Gateway.
    • Inbound SIP Address: Enter the IP or FQDN of the carrier edge.
    • Authentication Method: Set to None for internal routing if using direct IP whitelisting, or Digest with distinct credentials per trunk.
    • Media Encryption: Enforce TLS 1.2 minimum and SRTP.
  4. Click Save.
  5. Repeat the process for the Secondary Trunk:
    • Name: SIP-TRUNK-SECONDARY-CARRIER-B
    • Outbound Route: Select a different Carrier Gateway or physical path.
    • Inbound SIP Address: Enter the distinct IP or FQDN of the secondary carrier edge.
The Trap:
A common misconfiguration is assigning identical credentials to both trunk groups when using the same carrier for redundancy. While this works for basic failover, it prevents you from distinguishing between primary and secondary link health in logs. If both trunks share the same SIP digest hash, troubleshooting a specific carrier path failure becomes impossible because call routing logs do not differentiate which physical link handled the session. Always use distinct authentication credentials or separate SBC IP whitelists to ensure telemetry data isolates the active path.
Architectural Reasoning:
Separating trunks at the Genesys Cloud level allows for granular health checks per endpoint. Genesys performs SIP OPTIONS ping probes on configured endpoints. By having two distinct trunks, you create two independent health check paths. If the primary trunk returns a 408 Request Timeout or 503 Service Unavailable, the platform marks that specific resource as unavailable without affecting the secondary resource. This isolation is critical for avoiding cascading failures where a signaling storm on one link brings down the entire telephony stack.
2. Defining Failover Logic in Routing Profiles
Configuring the trunks alone does not guarantee failover. You must define the logic that dictates how calls transition from the primary path to the secondary path during degradation. This occurs within the Routing Profile hierarchy.
  1. Navigate to Telephony > Routing Profiles.
  2. Select the profile associated with your contact center queue (e.g., RP-GENERAL-INBOUND).
  3. Expand the Call Control settings and locate the Trunk Group assignment section.
  4. Configure the Failover Strategy:
    • Set Primary Trunk Group to SIP-TRUNK-PRIMARY-CARRIER-A.
    • Set Secondary Trunk Group to SIP-TRUNK-SECONDARY-CARRIER-B.
    • Enable Automatic Failover.
  5. Save the Routing Profile.
The Trap:
Engineers often configure both trunks as “Equal Priority” in load balancing mode. While this distributes traffic during normal operations, it introduces significant risk during failover scenarios. If the primary link is degrading (high packet loss), calls routed to that link will drop or experience latency before the system recognizes the failure and switches. This results in a period of degraded service where customers hear ringing but get no answer. You must configure Active/Standby logic for voice traffic, ensuring the secondary trunk remains idle until the primary health status drops below the defined threshold.
Active/Standby routing ensures that the secondary path is not subjected to signaling load during normal operations, preserving capacity for when it becomes the primary path. Genesys Cloud evaluates trunk health based on SIP OPTIONS response codes and round-trip time metrics. By enforcing a strict hierarchy, you ensure that calls only traverse the secondary network if the primary network proves incapable of completing the SIP handshake within the configured timeout window (typically 10 to 30 seconds). This prevents “flapping” where calls bounce between links due to transient network jitter, which causes call setup failures.
3. Implementing Network Layer Redundancy and DNS TTL
The application-level failover described above is ineffective if the underlying network path cannot resolve during a carrier outage. You must configure the Domain Name System (DNS) records associated with your SIP trunks to ensure rapid propagation of IP address changes or health status updates.
  1. Access your DNS provider console for the FQDNs used in your SIP Trunk configurations.
  2. Verify that TTL (Time To Live) values for A and SRV records are set to a maximum of 300 seconds (5 minutes).
  3. Ensure you have configured CNAME records pointing to the carrier gateway IPs rather than hardcoding static IPs in the platform if possible, allowing the DNS layer to handle load balancing logic upstream.
  4. Validate firewall rules on the Genesys Cloud side (or your on-premise SBC) allow UDP/TCP 5060 and 10000-20000 for both primary and secondary carrier IP ranges simultaneously.
The Trap:
Many organizations set DNS TTLs to high values (e.g., 3600 seconds or 1 hour) to reduce DNS query load. In a zero-downtime architecture, this creates a “stale cache” problem. If the primary carrier changes their IP address due to a migration or outage, your Genesys Cloud instance will continue resolving the old IP for up to an hour. During this window, calls will fail at the network layer before the application logic ever attempts to switch trunks. You must accept the increased DNS query load in exchange for faster convergence during outages.
DNS TTL is a critical variable in failover speed. A lower TTL ensures that when a carrier updates their DNS records to reflect a new IP address, your infrastructure queries the updated information almost immediately. This reduces the Mean Time To Recovery (MTTR) for network-level failures. Additionally, allowing both IP ranges simultaneously on firewalls prevents “blackholing” where the secondary path is unreachable due to security groups blocking the new traffic during a failover event. Security policies must be dynamic or pre-configured to allow all potential carrier endpoints in the redundancy design.
Edge Case 1: Carrier Link Flapping
The Failure Condition: The primary SIP trunk status oscillates between Available and Unavailable every few minutes during a period of network instability. Calls begin dropping as the system switches paths repeatedly.
The Root Cause: The health check threshold is too sensitive, or the carrier link has intermittent jitter causing OPTIONS ping timeouts. Genesys Cloud marks the trunk as unavailable based on a single failed probe before the circuit stabilizes.
The Solution: Adjust the Health Check Interval and Thresholds in the Trunk configuration. Increase the number of consecutive failed probes required to mark a trunk as down (e.g., change from 1 failure to 3 failures). This adds hysteresis to the failover logic, preventing rapid switching during transient network events.
Edge Case 2: SIP Header Integrity During Failover
The Failure Condition: Calls successfully route to the secondary trunk but fail to connect to the destination agent or external number. The call drops with a 503 Service Unavailable error on the receiving end.
The Root Cause: The Secondary Trunk is configured with different Allow headers or codecs than the Primary Trunk. When the system switches trunks, the secondary link rejects the media negotiation parameters established during the initial invite.
The Solution: Standardize codec configurations across all trunk groups in the redundancy set. Ensure both trunks support G.711 A-law/U-law and Opus. Verify that Allow headers match exactly between trunks to ensure consistent SDP (Session Description Protocol) negotiation. Use the Admin API to validate header consistency:
  "name": "SIP-TRUNK-PRIMARY-CARRIER-A",
  "trunkType": "STANDARD",
  "sipAddress": "primary.sip.carrier.net",
  "outboundAuthMethod": "NONE",
  "inboundAuthMethod": "NONE",
  "mediaEncryption": "TLS_SRP",
  "codecs": [
      "type": "G711A",
      "priority": 1
      "type": "G711U",
      "priority": 2
  "failoverTrunkGroupId": "uuid-secondary-trunk-id"
Edge Case 3: PSTN Provider Latency Thresholds
The Failure Condition: During a primary carrier outage, the system takes longer than expected to fail over, resulting in audible ringing for up to 45 seconds before the secondary trunk attempts the call.
The Root Cause: The Failover Timeout setting in the Routing Profile is set too aggressively or too conservatively. If set too low, calls drop during legitimate brief blips. If set too high, customers experience excessive wait times during real outages.
The Solution: Tune the Call Timeout and Ring Duration settings to align with the carrier’s failover detection speed. For Genesys Cloud CX, the default failover detection time is approximately 15-30 seconds. Ensure your application flow logic does not enforce additional delays after the routing profile decision. If using a custom flow, remove any explicit wait nodes between the Trunk Select and the Agent Connect step to minimize latency during a switch.
