Implementing guest session timeout detection and seamless re-authentication flows in the Genesys Cloud Web Messaging Client SDK using JavaScript
- You will build a session manager that detects guest JWT expiration, triggers automatic re-authentication, and restores the active messaging conversation without dropping the user.
- You will use the
@genesyscloud/web-messaging-sdkpackage alongside direct REST calls to/api/v2/conversations/messagingand/api/v2/externalcontacts. - You will implement the solution in modern JavaScript using ES modules,
async/await, and thefetchAPI.
- OAuth 2.0 Client Credentials grant type with scopes:
webmessaging:guest:login,conversation:read,externalcontact:read - Genesys Cloud Web Messaging SDK version
3.0.0or higher - Node.js
18.xor modern browser environment with ES module support - Dependencies:
npm install @genesyscloud/web-messaging-sdk
The Web Messaging SDK handles guest authentication through a specialized JWT flow. You do not generate OAuth tokens manually for guest logins. Instead, you initialize the client with your environment URL and organization ID, then call loginGuest. The SDK exchanges a generated guest identity for a short-lived JWT and manages internal refresh cycles.
You must configure the SDK to expose session lifecycle events. The following initialization pattern establishes the client, attaches critical listeners, and prepares the re-authentication trigger.
import { WebMessagingClient } from '@genesyscloud/web-messaging-sdk';
const ENV_URL = 'https://api.mypurecloud.com';
const ORG_ID = 'a1b2c3d4-e5f6-7890-abcd-ef1234567890';
const client = new WebMessagingClient({
environment: ENV_URL,
orgId: ORG_ID,
debug: false
client.on('connectionStateChange', (state) => {
console.log('Connection state:', state.currentState);
client.on('guestSessionExpired', async () => {
console.warn('Guest session expired. Initiating re-authentication.');
await handleGuestReAuth();
client.on('error', (err) => {
console.error('SDK error:', err);
The guestSessionExpired event fires when the underlying JWT crosses its validity threshold or when the server rejects a stale token. You must implement handleGuestReAuth to restore the session. The SDK does not automatically reconnect conversations after expiration, so you must explicitly call loginGuest again and reattach to the active conversation.
Step 1: Initialize Guest Login and Capture Session Metadata
You must log the guest in and immediately capture the conversationId and externalContactId. These identifiers persist across guest JWT rotations. Storing them in memory allows you to restore the conversation after re-authentication.
let activeConversationId = null;
let externalContactId = null;
let guestName = 'Anonymous Guest';
async function initiateGuestSession() {
const loginResult = await client.loginGuest({
email: null,
metadata: {
source: 'web-sdk-tutorial',
externalContactId = loginResult.id;
console.log('Guest logged in. External Contact ID:', externalContactId);
client.on('conversationUpdated', (update) => {
if (update.conversationId) {
activeConversationId = update.conversationId;
console.log('Active conversation assigned:', activeConversationId);
return loginResult;
} catch (error) {
if (error.status === 429) {
console.warn('Rate limited during login. Implementing exponential backoff.');
await delay(2000);
return initiateGuestSession();
console.error('Guest login failed:', error.message);
throw error;
function delay(ms) {
return new Promise(resolve => setTimeout(resolve, ms));
The loginGuest method returns an object containing the id (external contact identifier). When a routing strategy assigns a conversation, the conversationUpdated event fires. You capture the conversationId immediately. This ID remains valid even after the guest JWT expires.
Step 2: Implement Timeout Detection and Re-Authentication Logic
You must implement the handleGuestReAuth function referenced in the event listener. This function logs the guest in again, reattaches to the conversation, and fetches recent message history to restore context. You must handle 429 responses during history retrieval and verify that the conversation still exists.
async function handleGuestReAuth() {
console.log('Re-authenticating guest session...');
const freshLogin = await client.loginGuest({
metadata: {
reauth: true
if (!freshLogin || !freshLogin.id) {
throw new Error('Re-authentication returned invalid guest identity.');
externalContactId = freshLogin.id;
console.log('Re-authentication successful. New External Contact ID:', externalContactId);
if (activeConversationId) {
await restoreConversationContext(activeConversationId);
return freshLogin;
} catch (error) {
console.error('Re-authentication failed:', error.message);
throw error;
async function restoreConversationContext(conversationId) {
const history = await fetchConversationHistory(conversationId);
console.log(`Restored ${history.total} messages for conversation ${conversationId}`);
client.on('messageReceived', (msg) => {
if (msg.conversationId === conversationId) {
console.log('New message received after re-auth:', msg.text);
} catch (error) {
console.error('Failed to restore conversation context:', error.message);
The re-authentication flow does not preserve the SDK’s internal message buffer. You must explicitly fetch recent messages using the REST API or SDK methods. The restoreConversationContext function bridges the gap between the fresh JWT and the existing conversation state.
Step 3: Fetch Message History with Retry Logic and Pagination
The Genesys Cloud API enforces strict rate limits on conversation history endpoints. You must implement exponential backoff for 429 responses and handle pagination. The following function demonstrates a production-ready history fetcher that respects API constraints.
async function fetchConversationHistory(conversationId, maxRetries = 3) {
const url = `${ENV_URL}/api/v2/conversations/messaging/${conversationId}/messages?pageSize=25&sortOrder=desc`;
const headers = {
'Accept': 'application/json'
let attempts = 0;
while (attempts < maxRetries) {
const response = await fetch(url, { method: 'GET', headers });
if (response.status === 401) {
throw new Error('Unauthorized. Guest token may have expired again.');
if (response.status === 403) {
throw new Error('Forbidden. Missing conversation:read scope.');
if (response.status === 429) {
const retryAfter = response.headers.get('Retry-After') || Math.pow(2, attempts);
console.warn(`Rate limited. Retrying in ${retryAfter}s...`);
await delay(retryAfter * 1000);
attempts++;
continue;
if (!response.ok) {
throw new Error(`HTTP ${response.status}: ${response.statusText}`);
const data = await response.json();
return data;
} catch (error) {
if (attempts === maxRetries - 1) throw error;
attempts++;
await delay(1000 * Math.pow(2, attempts));
The endpoint /api/v2/conversations/messaging/{conversationId}/messages returns a paginated array of message objects. A realistic response body contains message IDs, participant IDs, timestamps, and content.
"total": 12,
"pageSize": 25,
"page": 1,
"entities": [
"id": "msg-987654321",
"conversationId": "conv-a1b2c3d4",
"from": {
"id": "ext-contact-123",
"name": "Anonymous Guest"
"to": [
"id": "agent-456",
"name": "Support Agent"
"text": "Is my order still being processed?",
"dateCreated": "2024-05-15T14:32:10.000Z",
"dateUpdated": "2024-05-15T14:32:10.000Z",
"type": "text",
"state": "DELIVERED"
"links": {
"self": {
"href": "/api/v2/conversations/messaging/conv-a1b2c3d4/messages?pageSize=25&sortOrder=desc"
You must parse the entities array and render it to the UI. The SDK does not automatically sync historical messages after re-authentication, so manual fetching is required.
Step 4: Handle Conversation Lifecycle and Edge Cases
Conversations can end while the guest session is active. You must detect termination events and prevent re-attachment to closed conversations. The following listener monitors conversation state changes and handles graceful cleanup.
if (!update || !update.conversationId) return;
if (update.state === 'CLOSED' || update.state === 'TERMINATED') {
console.log(`Conversation ${update.conversationId} has ended. Clearing active session.`);
return;
if (update.state === 'ACTIVE' || update.state === 'ROUTED') {
console.log(`Conversation ${activeConversationId} is active.`);
client.on('messageSent', (message) => {
console.log('Message sent successfully:', message.id);
client.on('messageFailed', (error) => {
console.error('Message delivery failed:', error);
if (error.code === 'GUEST_SESSION_EXPIRED') {
handleGuestReAuth().then(() => {
console.log('Re-auth completed. Retrying message send.');
The messageFailed event catches delivery failures caused by token expiration. You trigger re-authentication immediately and retry the send operation. This pattern prevents silent message drops during network transitions or JWT rollovers.
The following module combines all components into a single runnable class. You only need to replace the environment URL, organization ID, and guest name before execution.
class WebMessagingSessionManager {
constructor(envUrl, orgId, guestName) {
this.envUrl = envUrl;
this.orgId = orgId;
this.guestName = guestName;
this.client = new WebMessagingClient({
environment: envUrl,
orgId: orgId,
debug: false
this.activeConversationId = null;
this.externalContactId = null;
this._bindEvents();
_bindEvents() {
this.client.on('connectionStateChange', (state) => {
this.client.on('guestSessionExpired', async () => {
await this._handleGuestReAuth();
this.client.on('error', (err) => {
this.client.on('conversationUpdated', (update) => {
if (!update?.conversationId) return;
console.log('Conversation ended. Session cleared.');
return;
this.activeConversationId = update.conversationId;
console.log('Active conversation:', this.activeConversationId);
this.client.on('messageFailed', async (error) => {
console.error('Message failed:', error);
async start() {
const result = await this.client.loginGuest({
metadata: { source: 'session-manager', ts: new Date().toISOString() }
this.externalContactId = result.id;
console.log('Initial guest login successful:', this.externalContactId);
return result;
} catch (error) {
await this._delay(2000);
return this.start();
throw error;
async _handleGuestReAuth() {
const fresh = await this.client.loginGuest({
metadata: { source: 'session-manager', reauth: true }
this.externalContactId = fresh.id;
console.log('Re-auth successful:', this.externalContactId);
if (this.activeConversationId) {
await this._restoreHistory(this.activeConversationId);
} catch (error) {
console.error('Re-auth failed:', error.message);
throw error;
async _restoreHistory(conversationId) {
const url = `${this.envUrl}/api/v2/conversations/messaging/${conversationId}/messages?pageSize=20&sortOrder=desc`;
const headers = { 'Content-Type': 'application/json', 'Accept': 'application/json' };
let attempts = 0;
while (attempts < 3) {
const res = await fetch(url, { method: 'GET', headers });
if (res.status === 429) {
const retry = res.headers.get('Retry-After') || Math.pow(2, attempts);
await this._delay(retry * 1000);
attempts++;
continue;
if (!res.ok) throw new Error(`History fetch failed: ${res.status}`);
const data = await res.json();
console.log(`Restored ${data.total} messages.`);
break;
_delay(ms) {
// Usage
const manager = new WebMessagingSessionManager(
'https://api.mypurecloud.com',
'a1b2c3d4-e5f6-7890-abcd-ef1234567890',
'Tutorial Guest'
manager.start().catch(console.error);
Error: 401 Unauthorized during history fetch
- Cause: The guest JWT expired between the
guestSessionExpiredevent firing and thefetchcall executing. The SDK event is asynchronous, and network latency can cause the token to become invalid before the retry completes. - Fix: Re-trigger
loginGuestimmediately before any REST call after expiration. The complete working example handles this by calling_handleGuestReAuthbefore_restoreHistory. - Code showing the fix:
if (res.status === 401) {
console.warn('Token stale during history fetch. Re-authenticating...');
return this._restoreHistory(conversationId);
Error: 403 Forbidden on /api/v2/conversations/messaging
- Cause: The OAuth client associated with your environment lacks the
conversation:readscope, or the guest identity does not have visibility into the conversation due to routing configuration. - Fix: Verify the OAuth client scopes in the Genesys Cloud admin console. Ensure the web messaging channel is configured to allow guest access. Guest tokens inherit channel-level permissions, not user-level scopes.
- Code showing the fix: No code change required. Update OAuth client scopes in the admin console to include
conversation:readandexternalcontact:read.
Error: 429 Too Many Requests on message history
- Cause: The API enforces a limit of 30 requests per second per organization for conversation endpoints. Rapid re-authentication loops or aggressive polling triggers rate limiting.
- Fix: Implement exponential backoff with jitter. Read the
Retry-Afterheader when present. The complete example usesMath.pow(2, attempts)with a maximum of three retries. - Code showing the fix:
const retryAfter = parseInt(res.headers.get('Retry-After') || '2', 10);
const jitter = Math.floor(Math.random() * 1000);
await this._delay((retryAfter * 1000) + jitter);
attempts++;
continue;
Error: SDK throws GUEST_SESSION_EXPIRED during sendMessage
- Cause: The message queue attempts to send while the JWT is rotating. The SDK intercepts the failure and emits
messageFailed. - Fix: Catch the event, re-authenticate, and retry the send operation. Ensure your UI disables the send button during re-authentication to prevent duplicate submissions.
// Retry logic should be implemented in your UI layer
console.log('Re-auth complete. UI should retry send.');
