Implementing Granular Access Control for Genesys Cloud CX Interaction Data Using Attribute-Based Access Control (ABAC) Policies
This guide details the configuration of Attribute-Based Access Control (ABAC) policies within Genesys Cloud CX to restrict access to sensitive interaction data based on caller attributes (e.g., PCI flags, healthcare indicators). The end result is a secure system where agents and administrators only access interaction recordings, transcripts, and metadata relevant to their defined roles and responsibilities, enhancing compliance and data privacy.
- Licensing Tier: Genesys Cloud CX Platform Edition or higher is required for ABAC functionality. Workforce Engagement (WEM) add-on is mandatory to leverage interaction data for ABAC policies.
- Permissions: The user configuring ABAC policies requires the following granular permissions:
Administration > Security > Attribute-Based Access Control > ViewAdministration > Security > Attribute-Based Access Control > EditWorkforce Engagement > Interaction Analytics > ViewWorkforce Engagement > Interaction Analytics > Edit
- OAuth Scopes: (For API-driven policy creation, though this guide focuses on the UI)
genesys_cloud_platform_adminandgenesys_cloud_wfm_adminare necessary. - External Dependencies: A properly configured data attribute strategy within Genesys Cloud CX is essential. This includes defining and populating custom data attributes on interactions during call flow processing. These attributes MUST be consistent and reliable.
1. Defining the Data Attributes
Before creating ABAC policies, you must establish the interaction attributes that will govern access control. These attributes are custom fields associated with each interaction record. For this example, we’ll focus on a ‘PCI_Flag’ attribute (true/false) indicating whether Personally Identifiable Information (PCI) data was exchanged during the call, and a ‘HIPAA_Flag’ attribute indicating protected health information.
To create these attributes:
- Navigate to Admin > Data Management > Data Attributes.
- Click Add Attribute.
- Define attribute details:
- Name:
PCI_Flag - Data Type: Boolean
- Description: Indicates if PCI data was discussed.
- Scope: Interaction
- Name:
- Repeat for
HIPAA_Flag.
The Trap: Inconsistent naming conventions or data types for attributes will render the ABAC policies ineffective. A typo in the attribute name during policy creation will silently fail to restrict access as expected. Always double-check attribute names and data types.
2. Creating the ABAC Policy
Now, we define the ABAC policy that enforces the access restrictions.
- Navigate to Admin > Security > Attribute-Based Access Control > Policies.
- Click Add Policy.
- Policy Name:
Restrict_PCI_Access - Description: Restricts access to interactions containing PCI data to designated PCI-compliant agents.
- Resource Type:
Interaction - Access Control Rule: This is the core of the policy. Configure the rule using the policy builder.
- Condition:
attributes.PCI_Flag == true - Action:
Deny - User Groups: Select the user group(s) authorized to access PCI data. (e.g., “PCI_Compliant_Agents”). This group MUST be pre-defined in Genesys Cloud CX.
- Condition:
- Save the policy.
Repeat this process to create a similar policy for HIPAA_Flag, restricting access to interactions containing Protected Health Information (PHI) to the appropriate user group (“HIPAA_Compliant_Agents”).
The Trap: Selecting “All Users” in the User Groups section effectively disables the policy, granting everyone access. Ensure only authorized groups are selected. The policy builder’s interface can be misleading; carefully review the conditions and actions before saving.
3. Applying the Policy to Interaction Data
The final step is to activate the ABAC policies to interaction data.
- Select the
Restrict_PCI_Accesspolicy. - Click Apply to Data.
- Data Scope: Select “All Interactions”. Alternatively, apply to specific queues or IVR flows for finer-grained control.
- Start Date: Set a start date for enforcement.
- Click Apply.
- Repeat for the
HIPAA_Flagpolicy.
The Trap: Applying the policy to “All Interactions” after unauthorized access has occurred does not retroactively restrict access to already recorded data. Ensure policies are in place before sensitive interactions are handled. The application of the policy will take time to propagate, and there may be a window of inconsistency.
Edge Case 1: Attribute Not Populated
- Failure Condition: The
PCI_FlagorHIPAA_Flagattribute is not populated on all interactions. - Root Cause: The IVR flow or agent application failed to set the attribute correctly.
- Solution: Review the IVR flow and agent application logic to ensure the attribute is consistently set based on the interaction context. Implement error handling to log instances where attribute assignment fails.
Edge Case 2: User Belongs to Multiple Groups
- Failure Condition: A user belongs to both the “PCI_Compliant_Agents” and “HIPAA_Compliant_Agents” groups.
- Root Cause: The ABAC policy only considers the first matching rule. If the user is in the appropriate group, access will be granted regardless of other group memberships.
- Solution: Carefully design user groups to minimize overlap. If overlap is unavoidable, consider creating more specific policies that account for the combined group memberships.
Edge Case 3: Policy Application Delay
- Failure Condition: Immediately after applying the policy, access restrictions are not enforced.
- Root Cause: Policy application has a propagation delay. The changes need to be distributed across the Genesys Cloud CX infrastructure.
- Solution: Allow sufficient time for the policy to propagate (typically a few minutes). Verify policy enforcement after a reasonable delay. Clear browser cache and refresh the Genesys Cloud CX interface.
