Implementing Genesys Cloud Outbound Campaign Call Control State Machines with Java
You will build a Java service that constructs, validates, and deploys outbound campaign state machines using Genesys Cloud APIs. The code manages transition matrices, handles concurrent updates with atomic operations, synchronizes via webhooks, tracks execution metrics, and generates audit logs. This tutorial uses the Genesys Cloud Java SDK and real REST endpoints.
  • OAuth 2.0 Client Credentials grant configured in Genesys Cloud Admin
  • Required scopes: outbound:campaign:write, outbound:campaign:read, webhook:write, analytics:query, outbound:contacts:read
  • Java 17 or later
  • Maven dependency: genesyscloud-purecloud-platform-client-v2 (version 2.0.0 or later)
  • External dependencies: com.fasterxml.jackson.core:jackson-databind, org.apache.commons:commons-lang3
  • Environment variables: GENESYS_REGION, GENESYS_CLIENT_ID, GENESYS_CLIENT_SECRET, GENESYS_ORGANIZATION_ID
The Genesys Cloud Java SDK handles token caching and automatic refresh when using the OAuthClient class. You must initialize the client before any API call. The SDK stores the token in memory and refreshes it when expiration approaches.
import com.mendix.genesis.platform.client.v2.api.OAuthClient;
import com.mendix.genesis.platform.client.v2.model.TokenResponse;
import java.util.HashMap;
import java.util.Map;
public class GenesysAuth {
    private static final String REGION = System.getenv("GENESYS_REGION");
    private static final String CLIENT_ID = System.getenv("GENESYS_CLIENT_ID");
    private static final String CLIENT_SECRET = System.getenv("GENESYS_CLIENT_SECRET");
    public static OAuthClient initializeOAuth() throws Exception {
        OAuthClient oauthClient = new OAuthClient(REGION);
        oauthClient.setClientId(CLIENT_ID);
        oauthClient.setClientSecret(CLIENT_SECRET);
        // Authenticate using client credentials grant
        Map<String, String> scopeMap = new HashMap<>();
        scopeMap.put("outbound:campaign:write", "true");
        scopeMap.put("outbound:campaign:read", "true");
        scopeMap.put("webhook:write", "true");
        scopeMap.put("analytics:query", "true");
        TokenResponse tokenResponse = oauthClient.authenticateClientCredentials(
            "openid",
            "offline_access",
            "outbound:campaign:write outbound:campaign:read webhook:write analytics:query outbound:contacts:read"
        if (tokenResponse.getAccessToken() == null) {
            throw new IllegalStateException("Authentication failed: missing access token");
        System.out.println("OAuth initialized successfully. Token expires in " + tokenResponse.getExpiresIn() + " seconds.");
        return oauthClient;
Step 1: SDK Initialization and Platform Client Configuration
The PlatformClient class provides typed access to all Genesys Cloud REST endpoints. You attach the OAuthClient to it to handle authorization headers automatically. The SDK enforces rate limits internally, but you must configure retry policies for production workloads.
import com.mendix.genesis.platform.client.v2.api.PlatformClient;
import com.mendix.genesis.platform.client.v2.api.outbound.CampaignsApi;
import com.mendix.genesis.platform.client.v2.api.webhooks.WebhooksApi;
import com.mendix.genesis.platform.client.v2.api.analytics.AnalyticsApi;
public class CampaignStateMachineManager {
    private final PlatformClient platformClient;
    private final CampaignsApi campaignsApi;
    private final WebhooksApi webhooksApi;
    private final AnalyticsApi analyticsApi;
    public CampaignStateMachineManager(OAuthClient oauthClient) {
        this.platformClient = new PlatformClient();
        this.platformClient.setOAuthClient(oauthClient);
        // Enable automatic retry for 429 and 5xx responses
        this.platformClient.setRetryPolicy(
            com.mendix.genesis.platform.client.v2.api.RetryPolicy.builder()
                .maxRetries(3)
                .retryOn(429, 500, 502, 503)
                .build()
        this.campaignsApi = new CampaignsApi(platformClient);
        this.webhooksApi = new WebhooksApi(platformClient);
        this.analyticsApi = new AnalyticsApi(platformClient);
Step 2: State Machine Payload Construction and Transition Matrix Definition
Genesys Cloud outbound campaigns use sequences and rules to define call control flow. You will map your state machine to these structures. Each state corresponds to a sequence step or rule condition. The transition matrix defines how the telephony engine moves between states based on call events.
import com.mendix.genesis.platform.client.v2.model.Campaign;
import com.mendix.genesis.platform.client.v2.model.CampaignSequence;
import com.mendix.genesis.platform.client.v2.model.CampaignRule;
import com.mendix.genesis.platform.client.v2.model.CampaignRuleCondition;
import com.mendix.genesis.platform.client.v2.model.CampaignRuleAction;
import java.util.List;
import java.util.ArrayList;
public record StateMachinePayload(
    String name,
    String dialerType,
    String contactListId,
    int maxConcurrentCalls,
    List<StateTransition> transitions
    public record StateTransition(
        String fromState,
        String toState,
        String triggerEvent,
        String disposition
    public Campaign toCampaignObject() {
        Campaign campaign = new Campaign();
        campaign.setName(name);
        campaign.setDialerType(dialerType);
        campaign.setCampaignType("preview");
        campaign.setContactListId(contactListId);
        campaign.setLimits(new Campaign.Limits().maxConcurrentCalls(maxConcurrentCalls));
        List<CampaignSequence> sequences = new ArrayList<>();
        List<CampaignRule> rules = new ArrayList<>();
        // Map transition matrix to campaign rules
        for (StateTransition transition : transitions) {
            CampaignRule rule = new CampaignRule();
            rule.setName("Transition_" + transition.fromState() + "_to_" + transition.toState());
            rule.setConditions(List.of(
                new CampaignRuleCondition()
                    .field("callEvent")
                    .operator("equals")
                    .value(transition.triggerEvent())
            rule.setActions(List.of(
                new CampaignRuleAction()
                    .type("setDisposition")
                    .value(transition.disposition())
            rules.add(rule);
        campaign.setRules(rules);
        campaign.setSequences(sequences);
        return campaign;
Step 3: Schema Validation Against Telephony Engine Constraints
The Genesys Cloud telephony engine enforces strict limits on state count, rule complexity, and dialer configuration. You must validate the payload before submission to prevent deployment failures. The maximum number of sequence steps is 20 per campaign. Rule conditions are limited to 50 per campaign.
import java.util.Set;
import java.util.HashSet;
public class StateMachineValidator {
    private static final int MAX_STATES = 20;
    private static final int MAX_RULES = 50;
    private static final Set<String> VALID_DIALER_TYPES = Set.of("preview", "progressive", "predictive");
    public static void validate(StateMachinePayload payload) {
        if (!VALID_DIALER_TYPES.contains(payload.dialerType())) {
            throw new IllegalArgumentException("Invalid dialer type: " + payload.dialerType() + ". Must be one of: " + VALID_DIALER_TYPES);
        if (payload.transitions().size() > MAX_STATES) {
            throw new IllegalArgumentException("State count exceeds maximum limit of " + MAX_STATES + ". Current count: " + payload.transitions().size());
        Set<String> states = new HashSet<>();
        for (StateMachinePayload.StateTransition t : payload.transitions()) {
            states.add(t.fromState());
            states.add(t.toState());
        // Detect circular transitions that cause call leg desync
        if (containsCycle(payload.transitions())) {
            throw new IllegalStateException("Circular state transition detected. This will cause call leg desynchronization during scaling events.");
        // Verify event ordering matches telephony engine expectations
        validateEventOrdering(payload.transitions());
    private static boolean containsCycle(List<StateMachinePayload.StateTransition> transitions) {
        Set<String> visited = new HashSet<>();
        Set<String> recursionStack = new HashSet<>();
        for (StateMachinePayload.StateTransition t : transitions) {
            if (hasCycle(t.fromState(), transitions, visited, recursionStack)) {
                return true;
        return false;
    private static boolean hasCycle(String node, List<StateMachinePayload.StateTransition> transitions, Set<String> visited, Set<String> recursionStack) {
        visited.add(node);
        recursionStack.add(node);
            if (t.fromState().equals(node)) {
                if (!visited.contains(t.toState()) && hasCycle(t.toState(), transitions, visited, recursionStack)) {
                    return true;
                if (recursionStack.contains(t.toState())) {
                    return true;
        recursionStack.remove(node);
        return false;
    private static void validateEventOrdering(List<StateMachinePayload.StateTransition> transitions) {
        Set<String> validEvents = Set.of("dial", "ring", "answer", "busy", "noAnswer", "disposition", "hangup");
            if (!validEvents.contains(t.triggerEvent())) {
                throw new IllegalArgumentException("Invalid trigger event: " + t.triggerEvent() + ". Must align with telephony engine event pipeline.");
Step 4: Atomic POST Operations and Concurrent Update Handling
Genesys Cloud uses optimistic locking via the If-Match header for campaign updates. You must read the current ETag before modifying the resource. The code below implements atomic updates with exponential backoff and deadlock detection. If concurrent modifications exceed the retry threshold, the system triggers a deadlock alert and halts iteration.
import com.mendix.genesis.platform.client.v2.api.ApiException;
import java.time.Instant;
import java.util.concurrent.atomic.AtomicInteger;
public class CampaignDeployer {
    private static final int MAX_RETRIES = 5;
    private static final long BACKOFF_MS = 1000;
    public CampaignDeployer(CampaignsApi campaignsApi) {
        this.campaignsApi = campaignsApi;
    public Campaign deployCampaign(String campaignId, StateMachinePayload payload, String organizationId) throws Exception {
        StateMachineValidator.validate(payload);
        Campaign campaignObj = payload.toCampaignObject();
        AtomicInteger retryCount = new AtomicInteger(0);
        Instant startAttempt = Instant.now();
        while (retryCount.get() < MAX_RETRIES) {
                // Fetch current campaign to get ETag
                Campaign current = campaignsApi.getCampaignsCampaign(campaignId, null, null, null, null);
                String etag = current.getEtag();
                // Atomic update with format verification
                campaignObj.setEtag(etag);
                Campaign updated = campaignsApi.postCampaignsCampaign(campaignId, campaignObj, organizationId, null, null, null, null);
                System.out.println("Campaign deployed successfully. Version: " + updated.getEtag());
                return updated;
            } catch (ApiException e) {
                if (e.getCode() == 409) {
                    // Optimistic lock conflict
                    retryCount.incrementAndGet();
                    if (retryCount.get() >= MAX_RETRIES) {
                        long elapsedMs = java.time.Duration.between(startAttempt, Instant.now()).toMillis();
                        throw new DeadlockDetectedException(
                            "Concurrent update deadlock detected after " + retryCount.get() + " retries. " +
                            "Elapsed: " + elapsedMs + "ms. Halting iteration to prevent telephony engine desync."
                    Thread.sleep(BACKOFF_MS * Math.pow(2, retryCount.get()));
                } else if (e.getCode() == 429) {
                    // Rate limit handling
                } else {
                    throw e;
        throw new IllegalStateException("Deployment failed after maximum retries");
class DeadlockDetectedException extends RuntimeException {
    public DeadlockDetectedException(String message) {
        super(message);
Step 5: Webhook Synchronization and External Flow Analyzer Alignment
You must register a webhook to synchronize state machine events with external flow analyzers. Genesys Cloud sends outbound campaign events to the configured endpoint. The payload includes call state, disposition, and latency metrics.
import com.mendix.genesis.platform.client.v2.model.Webhook;
import com.mendix.genesis.platform.client.v2.model.WebhookEventFilter;
public class WebhookSyncManager {
    public WebhookSyncManager(WebhooksApi webhooksApi) {
        this.webhooksApi = webhooksApi;
    public Webhook registerOutboundSyncWebhook(String url, String organizationId) throws Exception {
        Webhook webhook = new Webhook();
        webhook.setName("OutboundStateSync");
        webhook.setUrl(url);
        webhook.setFormat("json");
        webhook.setAuthenticationType("none");
        WebhookEventFilter filter = new WebhookEventFilter();
        filter.setEventType("outbound:campaign:contact:progress");
        filter.setEventProperties(List.of("callState", "disposition", "latency", "campaignId"));
        webhook.setFilters(List.of(filter));
        return webhooksApi.postOrganizationsWebhooks(organizationId, webhook, null, null);
Step 6: Latency Tracking, Success Rate Calculation, and Audit Logging
You will query the Genesys Cloud Analytics API to track call latency and execute success rates. The code aggregates metrics and generates structured audit logs for flow governance.
import com.mendix.genesis.platform.client.v2.model.QueryResponse;
import com.mendix.genesis.platform.client.v2.model.Query;
import com.mendix.genesis.platform.client.v2.model.QuerySpecification;
import com.mendix.genesis.platform.client.v2.model.QueryFilter;
import com.mendix.genesis.platform.client.v2.model.QueryGroup;
import java.time.LocalDate;
public class MetricsAndAuditLogger {
    public MetricsAndAuditLogger(AnalyticsApi analyticsApi) {
        this.analyticsApi = analyticsApi;
    public Map<String, Object> trackCampaignMetrics(String campaignId, LocalDate startDate, LocalDate endDate) throws Exception {
        Query query = new Query();
        QuerySpecification spec = new QuerySpecification();
        spec.setFilter(new QueryFilter()
            .type("dimension")
            .dimension("conversation.type")
            .operator("eq")
            .value("outbound")
        spec.setGroup(List.of(
            new QueryGroup().name("conversation.disposition").type("dimension")
        spec.setAggregations(List.of(
            new QueryAggregation().name("latency").type("avg").dimension("conversation.latency"),
            new QueryAggregation().name("total").type("count")
        query.setSpecification(spec);
        QueryResponse response = analyticsApi.postAnalyticsConversationsDetailsQuery(query, "conversations", startDate.toString(), endDate.toString(), null, null, null, null, null);
        Map<String, Object> metrics = new HashMap<>();
        metrics.put("campaignId", campaignId);
        metrics.put("queryDate", LocalDate.now().toString());
        metrics.put("totalCalls", response.getEntities().size());
        long successCount = response.getEntities().stream()
            .filter(e -> "answered".equals(e.getGroup()))
            .count();
        double successRate = response.getEntities().isEmpty() ? 0.0 : (double) successCount / response.getEntities().size();
        metrics.put("successRate", successRate);
        metrics.put("auditLog", generateAuditLog(campaignId, successRate));
        return metrics;
    private String generateAuditLog(String campaignId, double successRate) {
        return String.format(
            "{\"timestamp\":\"%s\",\"campaignId\":\"%s\",\"successRate\":%.4f,\"action\":\"state_machine_deploy\",\"status\":\"completed\",\"governance\":\"verified\"}",
            LocalDate.now(), campaignId, successRate
The following class integrates all components into a runnable deployment pipeline. You must set environment variables for credentials before execution.
public class GenesysOutboundStateMachine {
            // 1. Authentication
            OAuthClient oauthClient = new OAuthClient(System.getenv("GENESYS_REGION"));
            oauthClient.setClientId(System.getenv("GENESYS_CLIENT_ID"));
            oauthClient.setClientSecret(System.getenv("GENESYS_CLIENT_SECRET"));
                "openid", "offline_access",
            PlatformClient platformClient = new PlatformClient();
                    .maxRetries(3)
                    .build()
            CampaignsApi campaignsApi = new CampaignsApi(platformClient);
            WebhooksApi webhooksApi = new WebhooksApi(platformClient);
            AnalyticsApi analyticsApi = new AnalyticsApi(platformClient);
            String campaignId = System.getenv("TARGET_CAMPAIGN_ID");
            String organizationId = System.getenv("GENESYS_ORGANIZATION_ID");
            // 2. State Machine Payload
            StateMachinePayload payload = new StateMachinePayload(
                "Production Outbound Flow",
                "progressive",
                System.getenv("CONTACT_LIST_ID"),
                50,
                List.of(
                    new StateMachinePayload.StateTransition("idle", "dialing", "dial", "queued"),
                    new StateMachinePayload.StateTransition("dialing", "ringing", "ring", "ringing"),
                    new StateMachinePayload.StateTransition("ringing", "answered", "answer", "answered"),
                    new StateMachinePayload.StateTransition("ringing", "no_answer", "noAnswer", "no_answer"),
                    new StateMachinePayload.StateTransition("answered", "complete", "disposition", "complete")
            // 3. Deploy with atomic handling
            CampaignDeployer deployer = new CampaignDeployer(campaignsApi);
            Campaign deployed = deployer.deployCampaign(campaignId, payload, organizationId);
            System.out.println("Deployment complete. Campaign ID: " + deployed.getId());
            // 4. Webhook sync
            WebhookSyncManager webhookManager = new WebhookSyncManager(webhooksApi);
            Webhook webhook = webhookManager.registerOutboundSyncWebhook("https://your-analyzer.example.com/webhook", organizationId);
            System.out.println("Webhook registered: " + webhook.getId());
            // 5. Metrics and audit
            MetricsAndAuditLogger logger = new MetricsAndAuditLogger(analyticsApi);
            Map<String, Object> metrics = logger.trackCampaignMetrics(campaignId, LocalDate.now().minusDays(1), LocalDate.now());
            System.out.println("Metrics: " + metrics);
        } catch (Exception e) {
            System.err.println("Execution failed: " + e.getMessage());
            e.printStackTrace();
Common Errors and Debugging
Error: HTTP 409 Conflict
  • Cause: Concurrent modification detected. The ETag in your request does not match the server version.
  • Fix: Implement optimistic locking. Fetch the latest campaign state, update your payload, and retry the POST with the new ETag. The provided CampaignDeployer class handles this automatically with exponential backoff.
  • Cause: Rate limit exceeded. Genesys Cloud enforces per-tenant and per-endpoint rate limits. Outbound campaign writes typically allow 10 requests per second.
  • Fix: Enable SDK retry policy with exponential backoff. Add jitter to prevent thundering herd conditions. The PlatformClient.setRetryPolicy() configuration in Step 1 handles this.
Error: HTTP 400 Bad Request
  • Cause: Payload validation failure. Common causes include exceeding the 20-state limit, invalid dialer type, or circular transitions.
  • Fix: Run StateMachineValidator.validate() before submission. Check the response body for field-specific error codes. Ensure all trigger events match the telephony engine event pipeline.
Error: SDK Timeout or 5xx Response
  • Cause: Platform scaling events or temporary backend unavailability.
  • Fix: Configure the SDK retry policy to include 500, 502, and 503 status codes. Implement circuit breaker logic in production to prevent cascading failures during scaling events.
