Implementing Genesys Cloud LLM Gateway Model Fallback Logic with Python SDK
- A production-grade Python module that configures and executes LLM Gateway requests with automatic model fallback chains, latency threshold enforcement, and cost impact validation.
- This implementation uses the Genesys Cloud AI LLM Gateway API (
/api/v2/ai/llmgateway/requests) and the officialgenesyscloudPython SDK. - The tutorial covers Python 3.9+ with
genesyscloud,httpx, andpydanticfor schema validation and structured audit logging.
- OAuth2 Client Credentials flow configured in Genesys Cloud Admin Console
- Required scopes:
ai:llmgateway:write,ai:llmgateway:execute,webhooks:write genesyscloudSDK version 4.0 or higher- Python 3.9 or higher
- External dependencies:
pip install genesyscloud httpx pydantic - A valid Genesys Cloud organization domain (e.g.,
mypurecloud.com)
The Genesys Cloud Python SDK handles token acquisition, caching, and automatic refresh behind the scenes. You must initialize the PureCloudPlatformClientV2 instance and bind it to your organization environment before invoking any AI module methods.
import os
from genesyscloud.platform.client import PureCloudPlatformClientV2
def initialize_genesys_client() -> PureCloudPlatformClientV2:
Initializes and authenticates the Genesys Cloud platform client.
Handles token caching automatically via the SDK.
client = PureCloudPlatformClientV2()
client.set_environment(os.getenv("GENESYS_ORG_DOMAIN", "mypurecloud.com"))
raise ValueError("GENESYS_CLIENT_ID and GENESYS_CLIENT_SECRET must be set.")
# The SDK stores the access token in memory and refreshes it automatically
# when the 401 Unauthorized response is detected or the token expires.
client.authenticate_client_credentials(client_id, client_secret)
return client
Step 1: Construct Fallback Policy and Validate Schema Constraints
Genesys Cloud LLM Gateway enforces strict schema validation to prevent runaway fallback chains and budget exhaustion. You must define a model_matrix containing primary and secondary model identifiers, a switch_directive that dictates transition behavior, and a max_chain_length that caps the number of fallback attempts. The gateway rejects payloads exceeding max_chain_length: 5 to protect downstream model providers from cascade failures.
from pydantic import BaseModel, Field, validator
class FallbackPolicy(BaseModel):
model_matrix: Dict[str, str] = Field(..., description="Primary and secondary model endpoints")
fallback_chain: List[str] = Field(..., description="Ordered list of model IDs for fallback")
switch_directive: str = Field(..., pattern="^(failover|gradual|strict)$")
max_chain_length: int = Field(..., ge=1, le=5)
latency_threshold_ms: int = Field(..., ge=100, le=15000)
cost_impact_check: bool = Field(True, description="Enforces budget guardrails before invocation")
output_compatibility_verification: bool = Field(True, description="Validates response schema against primary model output")
@validator("fallback_chain")
def validate_chain_length(cls, v, values):
if len(v) > values.get("max_chain_length", 5):
raise ValueError("Fallback chain length exceeds max_chain_length constraint.")
return v
def build_gateway_payload(policy: FallbackPolicy, prompt: str) -> Dict[str, Any]:
Constructs the atomic POST payload for /api/v2/ai/llmgateway/requests.
Includes fallback reference, model matrix, and switch directive.
"model_matrix": policy.model_matrix,
"fallback_chain": policy.fallback_chain,
"switch_directive": policy.switch_directive,
"max_chain_length": policy.max_chain_length,
"latency_threshold_ms": policy.latency_threshold_ms,
"cost_impact_check": policy.cost_impact_check,
"output_compatibility_verification": policy.output_compatibility_verification,
"input": {
"messages": [
{"role": "user", "content": prompt}
"parameters": {
"temperature": 0.7,
"max_tokens": 1024
Step 2: Execute Atomic POST with Latency Threshold and Error Detection
The LLM Gateway accepts an atomic POST /api/v2/ai/llmgateway/requests operation. Atomicity guarantees that the gateway evaluates the entire fallback chain before returning a partial response. The latency_threshold_ms parameter triggers automatic secondary model invocation when the primary model exceeds the defined window. You must handle 429 Too Many Requests with exponential backoff to respect rate limits, and 422 Unprocessable Entity for schema violations.
HTTP Request/Response Cycle Reference
POST /api/v2/ai/llmgateway/requests HTTP/1.1
Host: mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
"model_matrix": {"primary": "gpt-4o", "secondary": "claude-3-haiku"},
"fallback_chain": ["gpt-4o", "claude-3-haiku"],
"switch_directive": "failover",
"max_chain_length": 2,
"latency_threshold_ms": 3500,
"cost_impact_check": true,
"output_compatibility_verification": true,
"input": {
"messages": [{"role": "user", "content": "Summarize the transcript."}],
"parameters": {"temperature": 0.7, "max_tokens": 512}
HTTP/1.1 200 OK
"request_id": "req_8f3a9c2b-1d4e-4f2a-9b7c-5e6d8a9f0c1d",
"status": "completed",
"model_used": "claude-3-haiku",
"fallback_triggered": true,
"latency_ms": 2800,
"cost_cents": 0.04,
"output": {
"text": "The customer reported intermittent connectivity issues resolved by router reset."
from genesyscloud.ai.api import AiApi
def execute_gateway_request(ai_api: AiApi, payload: Dict[str, Any], max_retries: int = 3) -> Dict[str, Any]:
Executes the LLM Gateway request with 429 retry logic and error detection.
attempt = 0
while attempt < max_retries:
# SDK method maps to POST /api/v2/ai/llmgateway/requests
response = ai_api.post_ai_llmgateway_requests(body=payload)
return response.to_dict()
except ApiException as e:
if e.status == 429:
retry_after = int(e.headers.get("Retry-After", 2 ** attempt))
print(f"Rate limited (429). Retrying in {retry_after}s...")
time.sleep(retry_after)
attempt += 1
elif e.status == 422:
raise ValueError(f"Schema validation failed: {e.body}")
elif e.status in (401, 403):
raise PermissionError(f"Authentication/Authorization failed: {e.status} {e.body}")
else:
raise
raise RuntimeError("Max retries exceeded for 429 rate limiting.")
Step 3: Process Results, Trigger Secondary Invocation, and Verify Output Compatibility
When the gateway returns a response, you must evaluate fallback_triggered and latency_ms against your thresholds. If output_compatibility_verification is enabled, the gateway validates that the secondary model output matches the primary model schema. You must inspect model_used to confirm which model served the request and calculate cost impact before proceeding.
def process_gateway_response(response: Dict[str, Any]) -> Dict[str, Any]:
Validates output compatibility, calculates latency delta, and confirms cost impact.
if response.get("status") != "completed":
raise RuntimeError(f"Gateway request failed with status: {response.get('status')}")
latency = response.get("latency_ms", 0)
model_used = response.get("model_used")
fallback_triggered = response.get("fallback_triggered", False)
cost_cents = response.get("cost_cents", 0.0)
result = {
"text": response.get("output", {}).get("text", ""),
"model_used": model_used,
"fallback_triggered": fallback_triggered,
"latency_ms": latency,
"cost_cents": cost_cents,
"request_id": response.get("request_id")
# Verify output compatibility flag from gateway
if response.get("output_compatibility_verification") and not result["text"]:
raise ValueError("Output compatibility verification failed. Secondary model returned empty payload.")
return result
Step 4: Synchronize Events with External Reliability Monitors via Webhooks
Genesys Cloud supports webhook registration for AI Gateway events. You must register a webhook endpoint that accepts ai.llmgateway.fallback.triggered and ai.llmgateway.request.completed events. The webhook payload contains the full request context, enabling external reliability monitors to track switch success rates and latency distributions.
import httpx
def register_fallback_webhook(platform_client: PureCloudPlatformClientV2, webhook_url: str) -> str:
Registers a webhook for LLM Gateway fallback events.
Uses httpx for direct webhook POST to /api/v2/webhooks.
headers = {
"Authorization": f"Bearer {platform_client.access_token}",
payload = {
"name": "LLM Gateway Fallback Monitor",
"uri": webhook_url,
"method": "POST",
"events": [
"ai.llmgateway.fallback.triggered",
"ai.llmgateway.request.completed"
"request_body_template": "{ \"request_id\": \"{{requestId}}\", \"model_used\": \"{{modelUsed}}\", \"fallback_triggered\": {{fallbackTriggered}}, \"latency_ms\": {{latencyMs}} }",
"request_headers": {
"X-Webhook-Source": "genesys-llm-gateway"
"retry_policy": {
"max_retries": 3,
"retry_interval_seconds": 10
with httpx.Client() as client:
response = client.post(
f"https://{platform_client.environment}/api/v2/webhooks",
headers=headers,
json=payload
response.raise_for_status()
return response.json().get("id", "")
Step 5: Track Latency, Switch Rates, and Generate Audit Logs
For AI governance and compliance, you must maintain an audit log that records every invocation, fallback event, cost impact, and latency measurement. The audit pipeline uses structured JSON logging with ISO 8601 timestamps and request IDs for traceability.
import json
import logging
class FallbackAuditLogger:
def __init__(self, log_file: str = "llm_gateway_audit.jsonl"):
self.log_file = log_file
self.switch_success_count = 0
self.total_requests = 0
self.total_latency = 0
def log_invocation(self, request_id: str, model_used: str, fallback_triggered: bool, latency_ms: int, cost_cents: float, status: str):
self.total_requests += 1
self.total_latency += latency_ms
if fallback_triggered:
self.switch_success_count += 1
audit_entry = {
"request_id": request_id,
"latency_ms": latency_ms,
"status": status,
"average_latency_ms": self.total_latency / self.total_requests,
"switch_success_rate": self.switch_success_count / self.total_requests if self.total_requests > 0 else 0.0
with open(self.log_file, "a") as f:
f.write(json.dumps(audit_entry) + "\n")
logging.info(f"Audit logged: {request_id} | Model: {model_used} | Fallback: {fallback_triggered}")
The following script combines authentication, policy construction, execution, webhook registration, and audit logging into a single runnable module. Replace the environment variables with your credentials before execution.
import os
import logging
import httpx
# Initialize logging
def run_llm_gateway_fallback():
# 1. Authentication
platform_client = PureCloudPlatformClientV2()
platform_client.set_environment(os.getenv("GENESYS_ORG_DOMAIN", "mypurecloud.com"))
platform_client.authenticate_client_credentials(
os.getenv("GENESYS_CLIENT_ID"),
ai_api = AiApi(platform_client)
audit_logger = FallbackAuditLogger()
# 2. Policy Construction
policy = FallbackPolicy(
model_matrix={"primary": "gpt-4o", "secondary": "claude-3-haiku"},
fallback_chain=["gpt-4o", "claude-3-haiku"],
switch_directive="failover",
max_chain_length=2,
latency_threshold_ms=3500,
cost_impact_check=True,
output_compatibility_verification=True
payload = build_gateway_payload(policy, "Analyze customer sentiment and extract key issues.")
# 3. Execute Request with Retry Logic
raw_response = execute_gateway_request(ai_api, payload)
# 4. Process and Validate
result = process_gateway_response(raw_response)
# 5. Audit Logging
audit_logger.log_invocation(
request_id=result["request_id"],
model_used=result["model_used"],
fallback_triggered=result["fallback_triggered"],
latency_ms=result["latency_ms"],
cost_cents=result["cost_cents"],
status="completed"
print(f"Response: {result['text']}")
print(f"Model Used: {result['model_used']} | Fallback Triggered: {result['fallback_triggered']}")
# 6. Register Webhook for Continuous Monitoring
webhook_id = register_fallback_webhook(
platform_client,
os.getenv("WEBHOOK_URL", "https://monitoring.example.com/genesys/llm-fallback")
print(f"Webhook registered successfully. ID: {webhook_id}")
except PermissionError as e:
logging.error(f"Authentication failed: {e}")
except ValueError as e:
logging.error(f"Schema validation failed: {e}")
except RuntimeError as e:
logging.error(f"Execution failed: {e}")
logging.error(f"API Error {e.status}: {e.body}")
Error: 422 Unprocessable Entity
- What causes it: The
max_chain_lengthexceeds the gateway limit of 5, or theswitch_directivecontains an invalid value. Theoutput_compatibility_verificationflag may also fail if the secondary model returns a schema that does not match the primary model contract. - How to fix it: Validate the
FallbackPolicyobject before serialization. Ensurefallback_chainlength matchesmax_chain_length. Verify that secondary model outputs conform to the expected JSON structure. - Code showing the fix:
if len(policy.fallback_chain) > policy.max_chain_length:
raise ValueError("Chain length exceeds gateway constraint. Reduce fallback_chain or increase max_chain_length (max 5).")
- What causes it: The LLM Gateway enforces organization-level rate limits to protect downstream model providers. Burst traffic triggers cascading 429 responses across microservices.
- How to fix it: Implement exponential backoff with jitter. The
execute_gateway_requestfunction already handles this by reading theRetry-Afterheader and sleeping before retrying. - Code showing the fix:
Error: 401 Unauthorized / 403 Forbidden
- What causes it: The OAuth token has expired, or the client credentials lack
ai:llmgateway:executeorai:llmgateway:writescopes. - How to fix it: Verify scope configuration in the Genesys Cloud Admin Console under Applications > API Clients. The SDK automatically refreshes tokens, but initial scope misconfiguration requires console correction.
raise PermissionError(f"Missing required scopes: ai:llmgateway:execute, ai:llmgateway:write")
Error: Latency Threshold Exceeded Without Fallback
switch_directiveis set tostrict, which prevents automatic fallback even whenlatency_msexceedslatency_threshold_ms. - How to fix it: Change
switch_directivetofailoverorgradualto allow the gateway to invoke secondary models when primary latency breaches the threshold. - Code showing the fix:
policy.switch_directive = "failover" # Enables automatic secondary invocation on latency breach
