Implementing Fraudulent Call Detection using SIP Header Fingerprinting and Reputation Scoring
This guide configures a real-time fraudulent call detection pipeline that inspects SIP headers, applies STIR/SHAKEN verification logic, and routes calls through a reputation scoring engine before queue assignment. When operational, the system automatically isolates spoofed or malicious traffic into a quarantine flow while passing verified traffic to standard routing with full audit logging.
  • Licensing Tiers: Genesys Cloud CX 3 or higher (required for advanced Telephony settings, full Architect expression evaluation, and Data Integration). NICE CXone requires the Enterprise tier with the Advanced Routing and Telephony Management add-on.
  • Granular Permissions: Telephony > Trunk > Edit, Telephony > SIP > Manage, Architect > Flow > Edit, Data > Integration > Edit, Security > API > Manage, Analytics > Report > Create
  • OAuth Scopes: telephony:call:write, architect:flow:edit, data:integration:use, security:api:read, analytics:report:read
  • External Dependencies: STIR/SHAKEN certificate infrastructure or carrier-provided attestation routing, threat intelligence API endpoint (internal scoring service or third-party provider), DNS NAPTR/SRV resolution for SIP routing validation, secure logging warehouse for telemetry retention.
1. Configuring SIP Header Ingestion and Fingerprint Extraction
SIP header parsing is the foundation of call fingerprinting. The platform normalizes incoming SIP messages into a structured attribute namespace before the first routing decision occurs. You must capture the P-Asserted-Identity, From, To, Via, and User-Agent headers, then construct a deterministic fingerprint that survives NAT traversal and proxy rewriting.
In Genesys Cloud, SIP headers are exposed in the SIP_ attribute namespace. You access them directly in Architect expressions using the syntax SIP_<HeaderName>. For example, SIP_P-Asserted-Identity contains the verified caller number if STIR/SHAKEN attestation is present. You will construct a fingerprint by concatenating the calling number, the originating IP from the first Via header, and a hash of the User-Agent string. This combination creates a unique identifier that distinguishes legitimate carrier traffic from VoIP spoofer software.
Configure a custom flow attribute named call.fingerprint using the following Architect expression:
SHA256(CONCAT(SIP_P-Asserted-Identity, "|", GET_FIRST(SPLIT(SIP_Via, "received=")), "|", SIP_User-Agent))
You must also enable SIP header forwarding in your Telephony Settings. Navigate to Telephony > Settings > SIP and ensure that custom header preservation is enabled. If you are deploying via API, apply the telephony configuration using the platform settings endpoint.
The Trap: Overriding default SIP header parsing with aggressive normalization rules that strip P-Asserted-Identity or collapse multi-line Via headers. When you disable header preservation to reduce payload size, you destroy the cryptographic attestation chain required for STIR/SHAKEN validation. Downstream, your reputation engine receives truncated fingerprints, causing false negatives on sophisticated spoofing campaigns. Always verify header continuity by testing with a SIP proxy that injects folded headers. If your fingerprint calculation returns null during load testing, your header parsing configuration is dropping continuation lines.
The architectural reasoning for this approach centers on determinism. Fraud detection requires consistent hashing across retries and re-INVITEs. By anchoring the fingerprint to the first Via hop and the asserted identity, you ensure that the same malicious source generates the same hash regardless of downstream proxy rewrites. This consistency enables accurate threat intelligence correlation.
2. Building the Reputation Scoring Integration and Real-Time Evaluation
Once the fingerprint is extracted, you must route it through a reputation scoring engine. The platform does not include a native threat intelligence database, so you will build a Data Integration that calls your scoring API. This integration must execute synchronously during the initial INVITE processing but must include strict timeout and circuit-breaker logic to prevent call flow blocking.
Create a REST Data Integration in Architect with the following configuration:
  • Name: FraudDetection.ScoringEngine
  • Method: POST
  • Endpoint: https://threat-intel.internal/api/v1/score
  • Timeout: 800 milliseconds (hard limit)
  • Retry Policy: 0 retries (fraud scoring must be idempotent and immediate)
Configure the request payload to transmit the fingerprint, attestation level, and trunk identifier. The platform will map these from flow variables into the JSON body.
  "http_method": "POST",
  "endpoint": "https://threat-intel.internal/api/v1/score",
  "headers": {
    "Authorization": "Bearer <OAUTH_TOKEN>"
  "body": {
    "fingerprint": "${call.fingerprint}",
    "attestation_level": "${SIP_P-Asserted-Identity-Attestation}",
    "trunk_id": "${call.trunk.id}",
    "timestamp_epoch": "${now()}"
The scoring engine must return a numeric reputation score between 0 and 100, along with a categorical disposition. Your Data Integration will parse the response into call.fraud.score and call.fraud.disposition. You must implement a fallback mechanism for timeout scenarios. If the integration fails or exceeds 800 milliseconds, the flow must assign a neutral score of 50 and log the failure for offline analysis. Blocking a call due to a scoring API latency spike violates service level agreements and creates unnecessary false positives.
The Trap: Configuring synchronous REST calls without circuit breakers or timeout boundaries. Under peak call volume, a degraded threat intelligence endpoint will queue thousands of INVITE requests. The platform will hold SIP sessions open until the default timeout expires, exhausting trunk capacity and causing SIP 408 Request Timeout responses to legitimate callers. You must enforce a hard timeout at the Data Integration level and implement a local cache for recently seen fingerprints. If your scoring API experiences a 5xx error rate above 2%, the integration should automatically switch to a cached response mode rather than failing open or closed.
The architectural reasoning for this design prioritizes availability over perfect accuracy. Fraud detection is a loss-prevention control, not a hard security gate. By bounding execution time and providing deterministic fallbacks, you maintain routing continuity while still capturing malicious traffic patterns. The 800 millisecond threshold aligns with SIP INVITE processing windows before early media negotiation begins.
3. Architect Flow Routing and Quarantine Logic
With the reputation score available, you will implement routing logic that separates verified traffic from suspicious traffic. The flow must evaluate the score against configured thresholds and route calls accordingly. Verified traffic proceeds to standard queue assignment. Suspicious traffic enters a quarantine flow designed to limit resource consumption and prevent IVR topology mapping.
Implement the routing decision using an Architect expression block:
IF(call.fraud.score < 30, "quarantine", IF(call.fraud.score >= 30 AND call.fraud.score < 70, "monitor", "standard"))
Route the quarantine disposition to a dedicated flow that immediately disables IVR navigation, disables call recording, and routes to a null endpoint or logging service. The monitor disposition routes to a standard queue but applies a high_priority label and enables extended recording for post-call review. The standard disposition follows normal business hours routing.
You must configure the quarantine flow to terminate SIP sessions gracefully. Use a Play Prompt node with a generic busy tone, followed by a Disconnect node. Do not allow menu navigation, DTMF collection, or transfer capabilities in the quarantine path. Fraudulent actors often probe IVR menus to discover queue names, agent extensions, and system architecture. Exposing any interactive elements to quarantined traffic provides reconnaissance data for future attacks.
The Trap: Routing flagged calls to a standard queue without disabling IVR navigation or recording. When you treat suspicious traffic identically to verified traffic, you allow attackers to map your contact center topology. They will navigate menus, trigger custom prompts, and identify high-value departments. This reconnaissance enables targeted vishing campaigns. Additionally, recording quarantined calls without consent flags may violate regulatory requirements in jurisdictions with strict wiretapping laws. Always isolate quarantined traffic in a flow that explicitly disables all interactive nodes and applies a fraud_quarantine disposition tag for analytics filtering.
The architectural reasoning for this separation relies on resource isolation. Quarantine flows consume trunk capacity, media servers, and database writes. By terminating sessions immediately and bypassing queue assignment, you preserve infrastructure for legitimate traffic. The monitor tier provides a middle ground for borderline scores, allowing human review without exposing system internals. This tiered approach balances security posture with operational efficiency.
4. Telemetry, Audit Logging, and Feedback Loop Configuration
Detection models degrade without continuous feedback. You must log SIP fingerprints, attestation levels, reputation scores, and routing outcomes to a data warehouse for model retraining. The platform provides event streaming capabilities that capture call lifecycle data. You will configure an integration that pushes telemetry to your analytics pipeline at the call.disconnect event.
Create a webhook integration that fires upon call completion. The payload must include the fingerprint, final disposition, talk time, and agent interaction data. Mask or hash any personally identifiable information before transmission to comply with GDPR and HIPAA requirements.
  "endpoint": "https://analytics.internal/api/v1/telemetry/call",
  "headers": {
    "X-API-Key": "<ANALYTICS_KEY>"
  "body": {
    "call_id": "${call.id}",
    "fraud_score": "${call.fraud.score}",
    "disposition": "${call.fraud.disposition}",
    "talk_time_seconds": "${call.duration}",
    "agent_id": "${call.agent.id}",
Configure the analytics pipeline to aggregate scores by fingerprint and update the threat intelligence database hourly. Fingerprints that consistently receive low scores and trigger quarantine dispositions must be flagged for automatic blocklist promotion. Conversely, fingerprints that repeatedly pass verification should be added to a whitelist cache to bypass scoring on subsequent calls.
The Trap: Logging raw P-Asserted-Identity values alongside SIP fingerprints without hashing or masking. When you store unredacted caller numbers in telemetry pipelines, you create a data liability that violates privacy regulations. Law enforcement requests or data breaches expose customer PII. Always apply a cryptographic hash to identity fields before storage. If your analytics pipeline rejects payloads containing unmasked phone numbers, your logging integration will fail silently, creating blind spots in your detection model. Validate payload schema against your warehouse ingestion rules before deployment.
The architectural reasoning for this feedback loop centers on adaptive security. Static rule-based detection fails against evolving spoofing techniques. By continuously ingesting routing outcomes and updating threat scores, you transform the system into a self-correcting control. The hourly aggregation window balances data freshness with processing overhead. Real-time updates would overwhelm the scoring database, while daily updates would allow active fraud campaigns to persist unchecked.
Edge Case 1: STIR/SHAKEN Attestation Level Mismatch
  • The failure condition: Legitimate carrier traffic receives a C attestation level but the scoring engine flags it as suspicious because it expects A or B. The flow routes verified calls to the monitor tier, increasing agent workload and causing false positive alerts.
  • The root cause: Different carriers implement STIR/SHAKEN with varying attestation standards. Level C indicates partial verification where the service provider has not verified the calling party but has not modified the call. Your scoring model likely treats C as unverified, which is incorrect for legacy trunk routes.
  • The solution: Update the scoring payload to include the trunk identifier and carrier profile. Configure the reputation engine to weight attestation levels based on trusted trunk lists. Modify the Architect routing expression to treat C attestation from approved carriers as equivalent to B for scoring purposes. Implement a carrier mapping table in your Data Integration to normalize attestation expectations per trunk group.
Edge Case 2: SIP Header Injection via Malicious User-Agent Strings
  • The failure condition: The fingerprint hash changes unexpectedly during call retries, causing the reputation engine to treat a single attacker as multiple distinct sources. Quarantine thresholds are never reached, and fraudulent traffic bypasses detection.
  • The root cause: Malicious VoIP software randomizes User-Agent strings on each INVITE to evade fingerprinting. When your hash function includes the User-Agent header, the fingerprint becomes volatile. The scoring engine cannot correlate attempts, and your threat intelligence database fragments.
  • The solution: Remove User-Agent from the primary fingerprint calculation. Rely on P-Asserted-Identity and the first Via hop IP for deterministic hashing. Maintain User-Agent as a secondary metadata field for forensic analysis only. Update the Architect expression to SHA256(CONCAT(SIP_P-Asserted-Identity, "|", GET_FIRST(SPLIT(SIP_Via, "received=")))). This stabilizes the fingerprint across retries while preserving investigative data in telemetry logs. Validate the change against historical fraud samples to confirm detection accuracy remains above 94%.
