Implementing Emergency Call Routing (911/988) with Dynamic Location-Based PSAP Selection
This guide details the architectural implementation of dynamic emergency call routing for remote and mobile agents within Genesys Cloud CX. The end result is a telephony system that captures real-time agent location data via API, maps it to the correct Public Safety Answering Point (PSAP), and routes 911 or 988 calls with the appropriate Enhanced Line Identification Number (ELIN). This configuration ensures compliance with RAY BAUMs Act requirements for non-traditional work environments.
Licensing Requirements
- Genesys Cloud CX Edition: Enterprise Edition or higher.
- Add-on Required: Emergency Calling Add-on (E911 Service). Without this license, location data cannot be transmitted to the PSTN gateway during an emergency call setup.
- Location Management: A valid billing address for the organization is required in the Cloud CX Admin portal to establish the primary ELIN pool.
Granular Permissions
The implementing engineer requires the following permission scopes within the Genesys Cloud Platform:
Emergency Calling > Emergency Call > View(To view active emergency call logs).Emergency Calling > Emergency Call > Edit(To manage routing rules and ELIN assignments).Locations > View(To verify agent location data).API Keys > Create(To generate OAuth credentials for external location services).
OAuth Scopes
For any external system pushing location data to Genesys Cloud, the following scopes must be granted to the Service Account:
location:write: Required to update device or user location objects.call:read: Required by Architect flows to check current call context if needed (though primarily read-only during setup).
External Dependencies
- Location Source: A mobile app, web beacon, or hardware registration system that can capture latitude/longitude or address strings from the agent device.
- PSAP Mapping Database: A reference dataset mapping postal codes or coordinates to specific PSAP contact numbers and ELINs. This is often maintained via a third-party vendor like Neustar or Telnyx, but can be custom-mapped within the Cloud if volume allows.
1. Establishing Dynamic Location Data Ingestion
The core of dynamic emergency routing lies in the data pipeline that feeds location information to the cloud platform. Static addresses configured on a user profile are insufficient for remote workforces. The architecture must support real-time updates triggered by device registration or application heartbeat.
Architectural Reasoning
You must separate the identity of the agent from the location of the call. A static address tied to the user profile is only valid if the agent remains at that desk. For remote agents, the location object must be decoupled and updated per session or per device registration. The Genesys Cloud API allows you to update a Location object associated with a specific User ID or Device ID.
Implementation Steps
- Identify the Location Object Type: In Genesys Cloud, locations can be assigned to Users (for desktop agents) or Devices (for mobile apps). For dynamic routing, we recommend updating the
Userlocation if the agent logs in from a specific device profile, or theDevicelocation for softphone applications that maintain persistent sessions. - API Payload Construction: When an agent logs into their softphone application and connects to Wi-Fi, trigger a POST request to update their location context.
POST https://api.mypurecloud.com/api/v2/locations
"name": "Agent-1049-Laptop",
"type": "WORKPLACE",
"address": {
"line1": "1234 Remote Way",
"city": "San Francisco",
"stateProvince": "CA",
"postalCode": "94105",
"country": "US"
"coordinates": {
"latitude": 37.7749,
"longitude": -122.4194
- Association with User: The API response returns a
locationId. You must associate this ID with the user or device via the/api/v2/users/{userId}endpoint using thelocationsarray field.
The Trap: Location Caching and Staleness
A critical failure mode occurs when location data is cached on the client device but not refreshed before an emergency call is placed. If an agent moves from a residential zone to a commercial zone, the system may route the 911 call to the PSAP serving the home address rather than the current work site.
Mitigation Strategy
Implement a TTL (Time To Live) on your location update logic. Force a location refresh every 30 minutes of active session time or upon any network interface change. Additionally, configure a “heartbeat” API call that runs immediately before any outbound call initiation event to verify the location is current. If the last update was older than 15 minutes, trigger a forced refresh from the device before allowing call setup to proceed.
2. Configuring PSAP Mapping and ELIN Assignment
Once location data flows into Genesys Cloud, the platform requires a mapping logic to translate that address into a routable PSTN endpoint. This involves defining Emergency Routes and associating them with specific locations.
Genesys Cloud utilizes an E911 routing engine that matches the postalCode or coordinates against a database of PSAP coverage areas. You do not manually define every street address. Instead, you configure “Emergency Routes” which contain the ELINs (Enhanced Line Identification Numbers) required for dispatch to return the callback number.
- Define Emergency Routes: Navigate to Admin > Telephony > Emergency Routes. Create a new route for your region.
- Assign ELINs: Within the route, assign the pool of ELINs purchased from your provider. These numbers must be valid within the E911 system for that specific geographic area.
- Map Locations to Routes: In the same Emergency Route configuration, define the
locationFilters. This is where you specify the postal codes or states covered by this route.
"name": "US-West-PSAP-Route",
"emergencyRoutes": [
"routingType": "POSTAL_CODE",
"value": "94105"
"elins": [
"id": "ELIN_ID_1234567890",
"number": "+14155550199"
- Handling 988 Routing: While 988 is a national suicide prevention lifeline, in the context of Genesys Cloud telephony routing, it typically routes through the same infrastructure as 911 but requires specific handling to ensure the PSAP receives the correct metadata. Configure the Architect flow to treat 988 calls identically to 911 regarding location validation, but tag them for analytics differentiation.
The Trap: ELIN Pool Exhaustion and Mismatch
A common misconfiguration involves assigning a single ELIN to an entire geographic region without accounting for high call volumes. If the PSAP requires multiple callback numbers due to network congestion or failover requirements, failing to assign a sufficient pool of ELINs can result in blocked calls during peak load.
Mitigation Strategy
Maintain at least three distinct ELINs per regional Emergency Route. Configure these as a list rather than a single value. Ensure the routingType matches the granularity of your location data. If you send latitude/longitude, use coordinate-based routing filters if supported by your carrier integration. If only postal codes are available to the platform, ensure the address parsing logic in your ingestion pipeline extracts the 5-digit or 9-digit zip code accurately.
3. Architect Flow for Emergency Call Interception and Routing
The final step is embedding the logic into the call flow to intercept emergency dialed numbers (911, 988) before they hit the standard dial plan. This ensures the system validates the location context dynamically.
Standard IVR flows often fail here because they assume a static trunk connection. Emergency routing requires a dynamic check against the user’s current location object at the moment of call setup. You must use a “Route Call” node in Architect that evaluates the Location context variable before determining the destination.
- Create an Interrupt Flow: Design a specific flow named
Emergency-Interceptor. This flow triggers on incoming calls matching the pattern911or988. - Check Location Context: Add a
Get Call Datanode to retrieve theCallerLocationcontext variable. This variable contains the address object pushed via the API in Step 1. - Conditional Routing Logic: Use a decision tree to validate the location.
- If
Locationis valid: Proceed toEmergency Routenode. - If
Locationis missing or stale: Trigger a voice prompt warning the agent of potential routing issues and route to a fallback queue (e.g., Supervisor).
- If
JSON Flow Snippet (Architect Logic)
The following logic represents the decision tree structure within the Architect JSON export format.
"nodes": [
"id": "node_1",
"type": "Interrupt",
"config": {
"dialedNumber": "911",
"flowName": "Emergency-Interceptor"
"id": "node_2",
"type": "Decision",
"config": {
"expression": "${callerLocation} != null && ${callerLocation.address.postalCode} != null"
"branches": [
"condition": "true",
"targetNodeId": "node_3"
"condition": "false",
"targetNodeId": "node_4"
"id": "node_3",
"type": "RouteCall",
"config": {
"routingType": "EMERGENCY_ROUTE",
"destinationId": "route_us_west_01"
"id": "node_4",
"type": "SayText",
"config": {
"text": "Warning: Location data missing. Please verify your connection or contact IT support immediately."
The Trap: Latency During Call Setup
Emergency calls require immediate routing. Introducing complex API calls within the Architect flow that fetch location data in real-time can introduce latency exceeding 2-3 seconds. This delay causes call drops or time-outs on the PSTN side, which is a compliance violation for emergency services.
Mitigation Strategy
The architecture must rely on pushed location data, not pulled data during the call. As detailed in Step 1, ensure the location is updated via API before the agent attempts to place a call. The Architect flow should only read the context variable (${callerLocation}), which is cached locally by the Genesys Cloud media server for the duration of the session. Do not add external HTTP requests or database queries inside the Architect decision nodes for emergency routing. If validation is absolutely necessary, pre-validate the location upon login and store the validity flag in a user attribute accessible via context variables.
Edge Case 1: Agent Location Update Failure During Call Setup
The Failure Condition: An agent attempts to place a 911 call from a new network (e.g., hotel Wi-Fi) but the location update API fails or times out before the call connects. The system defaults to a static profile address.
The Root Cause: Network segmentation preventing the softphone app from reaching the Genesys Cloud API endpoint for location updates before the dial event fires.
The Solution: Implement a fallback mechanism in the Architect flow. If the callerLocation object is flagged as unverified or outdated, route the call to a specialized “Emergency Verification” queue rather than blindly routing it to an incorrect PSAP. This ensures human intervention validates the location before PSTN transmission.
Edge Case 2: Cross-Border Emergency Routing
The Failure Condition: An agent travels from California (US) to Oregon (US) and dials 911. The system routes the call based on the cached California address, sending the call to a PSAP that does not cover Oregon.
The Root Cause: The location update interval is set too high (e.g., every hour), allowing the agent to move outside the service boundary before the next API heartbeat.
The Solution: Configure the softphone application to trigger a location update immediately upon network change detection or GPS coordinate shift greater than 5 miles. In Genesys Cloud, ensure your Emergency Routes cover the specific border postal codes correctly. Test this by simulating a call from a test number associated with the destination postal code and verifying the ELIN matches the local jurisdiction.
Edge Case 3: 988 Specific Routing Latency
The Failure Condition: The system routes 988 calls to the same PSAP as 911, but the PSAP is not equipped to handle suicide prevention referrals, causing a delay in connecting the caller to the correct crisis counselor.
The Root Cause: Treating 988 as a pure telephony emergency without metadata tagging for routing logic differentiation.
The Solution: Modify the Architect flow to tag 988 calls differently. Use the RouteCall node configuration to specify a different destination queue or SIP trunk that routes to a specialized crisis center if your carrier supports it. Ensure the location data is still validated, as physical location is critical for dispatching local resources.
Troubleshooting Checklist
- Verify API Response Codes: Check the logs for
200 OKresponses on POST requests to/api/v2/locations. A403 Forbiddenindicates permission issues with the Service Account. - Check Context Variables: In Architect, use the
Get Call Datanode to inspect${callerLocation}. If this returnsnull, the location was not pushed successfully. - PSTN Trace: Engage your carrier provider to trace the SIP INVITE message. Verify that the P-Asserted-Identity header contains the correct ELIN number associated with the agent’s current PSAP region.
- Compliance Logs: Review the Emergency Calling logs in the Admin portal under Analytics > Reporting. Look for “Emergency Call Failed” statuses which indicate routing mismatches.
