Implementing Dynamic Skill Assignment in Genesys Cloud Routing with Python SDK
- This script polls the Genesys Cloud Interaction API for new conversations, extracts caller intent attributes, and matches them against a YAML-defined skill matrix.
- The client uses the Genesys Cloud Python SDK to attach routing skills via
PUT /api/v2/routing/interactions/{interactionId}and validates interaction existence when the API returns 404. - The implementation triggers supervisor email notifications via the Communications API when high-priority skills are applied, with full OAuth token management, pagination handling, and exponential backoff for rate limits.
- Language: Python 3.9+
- OAuth Client Type: Confidential Client (Client Credentials Flow)
- Required OAuth Scopes:
interaction:read,routing:interaction:write,communications:write,user:read - SDK:
genesys-cloud>=2.0.0 - Runtime: Python 3.9 or higher
- External Dependencies:
requests>=2.31.0,pyyaml>=6.0,httpx>=0.25.0 - Genesys Cloud Environment: A valid organization with routing skills, interactions, and at least one supervisor user with email notification enabled
Genesys Cloud uses OAuth 2.0 Client Credentials for server-to-server integrations. The following code implements token retrieval with in-memory caching and automatic refresh when the token expires. The SDK does not manage tokens natively, so you must pass a valid bearer token to the Configuration object.
import requests
from typing import Optional
class TokenManager:
def __init__(self, client_id: str, client_secret: str, org_host: str):
self.client_id = client_id
self.token_url = f"https://{org_host}/oauth/token"
self._expires_at: float = 0.0
def get_token(self) -> str:
if time.time() < self._expires_at - 60:
return self._token
payload = {
"client_id": self.client_id,
"scope": "interaction:read routing:interaction:write communications:write user:read"
response = requests.post(self.token_url, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
self._expires_at = time.time() + data["expires_in"]
return self._token
The TokenManager class caches the access token and subtracts a 60-second safety margin before the actual expiry. Every SDK client initialization will call get_token() to ensure the bearer token remains valid across long-running polling cycles.
Step 1: Initialize SDK and Load Skill Matrix Configuration
The routing logic depends on a YAML configuration that maps intent keywords to skill IDs, priority levels, and supervisor contact information. The SDK requires a Configuration object bound to an ApiClient.
import yaml
import logging
from genesys_cloud.rest import Configuration, ApiClient
from genesys_cloud.apis.interaction import InteractionApi
from genesys_cloud.apis.routing import RoutingApi
from genesys_cloud.apis.user_management import UserManagementApi
from genesys_cloud.models import RoutingInteraction, RoutingSkill
def load_skill_matrix(config_path: str) -> list[dict]:
with open(config_path, "r") as f:
config = yaml.safe_load(f)
return config.get("skill_matrix", [])
def init_apis(org_host: str, token_manager: TokenManager):
config = Configuration(
host=f"https://{org_host}",
access_token=token_manager.get_token()
api_client = ApiClient(config)
return (
InteractionApi(api_client),
RoutingApi(api_client),
UserManagementApi(api_client)
The load_skill_matrix function parses the YAML file. The init_apis function constructs the three required SDK clients: InteractionApi for polling conversations, RoutingApi for skill assignment, and UserManagementApi for resolving supervisor IDs. All clients share the same underlying ApiClient instance, which reuses the TCP connection pool.
Step 2: Poll Interaction API and Extract Attributes
The Interaction API supports pagination via pageSize and pageNumber. You must request expand=attributes to retrieve custom caller data. The following function fetches interactions within a specific time window and extracts the intent attribute.
from datetime import datetime, timezone, timedelta
def fetch_active_interactions(interaction_api: InteractionApi, since: datetime, page_size: int = 100) -> list:
date_from = since.isoformat()
date_to = datetime.now(timezone.utc).isoformat()
all_interactions = []
page_number = 1
has_more = True
while has_more:
result = interaction_api.get_interactions(
expand="attributes",
date_from=date_from,
date_to=date_to,
page_size=page_size,
page_number=page_number
logging.error("Failed to fetch interactions: %s", e)
break
if not result.entities:
break
all_interactions.extend(result.entities)
if page_number >= result.page_count:
has_more = False
else:
page_number += 1
return all_interactions
The loop continues until page_number reaches result.page_count. Each interaction entity contains an attributes dictionary. You will read the intent from interaction.attributes.get("intent", "") in the next step.
Step 3: Match Intent, Validate IDs, and Handle 404 Responses
The routing assignment must occur only when the interaction exists and matches a known intent. The API returns 404 if the interaction was deleted, transferred, or already closed. You must validate the ID before attempting the skill update.
def validate_interaction_id(interaction_api: InteractionApi, interaction_id: str) -> bool:
interaction_api.get_interaction(interaction_id=interaction_id)
return True
status_code = getattr(e, "status", None)
if status_code == 404:
logging.warning("Interaction %s not found. Skipping assignment.", interaction_id)
return False
raise
This function calls GET /api/v2/interactions/{interactionId}. If the response is 404, the function logs the event and returns False. Any other exception propagates to the caller. You will call this validation before constructing the PUT payload.
Step 4: Apply Routing Skills via PUT and Implement Retry Logic
The PUT /api/v2/routing/interactions/{interactionId} endpoint replaces the entire routing configuration. You must fetch the current routing state, append the new skill, and submit the complete object. The following function implements exponential backoff for 429 rate limit responses.
import time as time_module
def apply_routing_skill(
routing_api: RoutingApi,
interaction_id: str,
skill_id: str,
priority: str,
max_retries: int = 5
) -> bool:
base_delay = 1.0
current = routing_api.get_routing_interaction(interaction_id=interaction_id)
new_skill = RoutingSkill(skill_id=skill_id, priority=priority)
if not current.routing_skills:
current.routing_skills = []
existing_skill_ids = {s.skill_id for s in current.routing_skills}
if skill_id not in existing_skill_ids:
current.routing_skills.append(new_skill)
routing_api.update_routing_interaction(
interaction_id=interaction_id,
routing_interaction=current
logging.info("Applied skill %s to interaction %s.", skill_id, interaction_id)
return True
else:
logging.info("Skill %s already assigned to interaction %s.", skill_id, interaction_id)
return True
if status_code == 429:
delay = base_delay * (2 ** attempt)
logging.warning("Rate limited (429). Retrying in %.2f seconds.", delay)
time_module.sleep(delay)
elif status_code == 404:
logging.error("Routing interaction %s not found during update.", interaction_id)
return False
else:
logging.error("Failed to apply skill: %s", e)
return False
logging.error("Max retries exceeded for interaction %s.", interaction_id)
return False
The retry loop doubles the delay on each 429 response. The function fetches the existing RoutingInteraction, merges the new RoutingSkill, and submits via update_routing_interaction. Duplicate skill IDs are skipped to prevent payload conflicts.
Step 5: Trigger Supervisor Notifications for High Priority Matches
When the YAML configuration marks a skill as high priority, the system must notify the designated supervisor. The Communications API accepts email targets via POST /api/v2/communications/messages. You must resolve the supervisor email from the configuration and construct a valid message payload.
import httpx
def notify_supervisor(token_manager: TokenManager, org_host: str, supervisor_email: str, interaction_id: str, skill_id: str) -> None:
token = token_manager.get_token()
url = f"https://{org_host}/api/v2/communications/messages"
headers = {
payload = {
"targets": [{"type": "email", "address": supervisor_email}],
"body": {
"contentType": "text/plain",
"content": f"High priority skill {skill_id} applied to interaction {interaction_id}. Immediate review required."
"subject": f"Genesys Alert: High Priority Skill Assignment ({interaction_id})"
with httpx.Client() as client:
response = client.post(url, headers=headers, json=payload)
logging.info("Supervisor notification sent for interaction %s.", interaction_id)
logging.error("Notification failed with status %s: %s", e.response.status_code, e.response.text)
logging.error("Notification request failed: %s", e)
The function uses httpx for explicit HTTP cycle visibility. The payload targets an email address and includes a plain-text body with the interaction ID and skill ID. The request reuses the same OAuth token manager to avoid scope mismatches.
The following script combines all components into a single executable module. Save it as dynamic_skill_assigner.py and run it with python dynamic_skill_assigner.py.
import yaml
import logging
import httpx
from genesys_cloud.models import RoutingSkill
class TokenManager:
return self._token
payload = {
import requests
return self._token
page_number = 1
has_more = True
while has_more:
date_to=date_to,
break
break
has_more = False
else:
page_number += 1
return True
return False
raise
def apply_routing_skill(routing_api: RoutingApi, interaction_id: str, skill_id: str, priority: str, max_retries: int = 5) -> bool:
base_delay = 1.0
return True
else:
return True
time.sleep(delay)
return False
else:
return False
return False
headers = {
payload = {
"body": {
def main():
ORG_HOST = "mycompany.genesiscloud.com"
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
CONFIG_PATH = "skill_matrix.yaml"
POLL_INTERVAL_SECONDS = 30
token_manager = TokenManager(CLIENT_ID, CLIENT_SECRET, ORG_HOST)
config = Configuration(host=f"https://{ORG_HOST}", access_token=token_manager.get_token())
interaction_api = InteractionApi(api_client)
routing_api = RoutingApi(api_client)
skill_matrix = load_skill_matrix(CONFIG_PATH)
last_processed = datetime.now(timezone.utc) - timedelta(minutes=5)
logging.info("Starting dynamic skill assignment poller.")
while True:
interactions = fetch_active_interactions(interaction_api, last_processed)
for interaction in interactions:
intent = interaction.attributes.get("intent", "") if interaction.attributes else ""
matched_rule = next((r for r in skill_matrix if r.get("intent_keyword") in intent.lower()), None)
if not matched_rule:
interaction_id = interaction.id
if not validate_interaction_id(interaction_api, interaction_id):
success = apply_routing_skill(
routing_api,
interaction_id,
matched_rule["skill_id"],
matched_rule["priority"]
if success and matched_rule["priority"] == "high":
notify_supervisor(token_manager, ORG_HOST, matched_rule["supervisor_email"], interaction_id, matched_rule["skill_id"])
time.sleep(POLL_INTERVAL_SECONDS)
main()
The main function establishes the polling loop. It fetches interactions, matches intent against the YAML rules, validates the ID, applies the skill, and triggers notifications when the priority matches “high”. The loop sleeps for 30 seconds between cycles to respect API rate limits.
- Cause: The OAuth token expired or the client credentials are incorrect.
- Fix: Verify
CLIENT_IDandCLIENT_SECRETin the configuration. Ensure the token manager refreshes the token before each API call. Check the OAuth client scope list in the Genesys Cloud admin console. - Code: The
TokenManagerclass already implements automatic refresh with a 60-second safety margin. If 401 persists, addlogging.debug("Token refresh triggered")insideget_token()to confirm execution.
Error: 403 Forbidden
- Cause: The OAuth client lacks the required scope, or the organization enforces role-based access control that blocks programmatic writes.
- Fix: Grant the client credentials the
routing:interaction:writeandcommunications:writescopes. Assign the OAuth client to a system role with “Routing Administration” and “Messaging” permissions. - Code: The scope string in
TokenManagerexplicitly requests all required permissions. Verify the exact scope names match your tenant configuration.
Error: 404 Not Found on Routing Update
- Cause: The interaction was deleted, merged, or routed to a different queue before the PUT request executed.
- Fix: The
validate_interaction_idfunction catches this condition early. If the error occurs duringupdate_routing_interaction, the retry loop catches the 404 status code and returnsFalsewithout crashing the poller. - Code: The
apply_routing_skillfunction checksstatus_code == 404and logs the event. You can add a dead-letter queue or database record for auditing skipped interactions.
- Cause: The polling interval is too aggressive, or multiple instances of the script are running concurrently.
- Fix: Increase
POLL_INTERVAL_SECONDSto 60 or higher. The retry loop implements exponential backoff with a base delay of 1 second. The delay doubles on each subsequent 429 response. - Code: The
apply_routing_skillfunction sleeps forbase_delay * (2 ** attempt)seconds. Monitor theRetry-Afterheader in the 429 response body if Genesys Cloud returns a specific wait time.
