Implementing Dynamic Outbound Campaign Throttling for SIP Trunk Capacity Protection
This guide details the implementation of a robust throttling architecture for outbound campaigns within Genesys Cloud CX to prevent carrier trunk saturation. The end result is a system where campaign concurrency automatically adjusts based on real-time SIP trunk health and carrier rejection rates, ensuring continuous dialing without triggering SIP 503 errors or compliance violations.
  • Licensing Tier: Genesys Cloud CX Professional or Enterprise license with Advanced Outbound Add-on required for API-driven campaign control. Standard Power Dialer profiles are insufficient for dynamic capacity protection.
  • Granular Permissions:
    • Outbound > Campaigns > Edit (To modify rate limits and pause states)
    • Outbound > Trunks > Read (To verify trunk status)
    • API Keys > Create (For middleware integration)
    • Admin > Settings > System > Read (To monitor global throughput)
  • OAuth Scopes: outbound:read, outbound:write, analytics:read. Middleware must utilize the client_credentials grant type with these scopes to programmatically adjust campaign parameters.
  • External Dependencies: A middleware service (Node.js, Python, or Java) capable of polling Genesys Cloud APIs every 30 seconds and executing asynchronous HTTP requests. The carrier SIP trunk must support granular concurrency reporting via SIP messages or SBC logs.
1. Baseline Trunk Capacity & Static Profile Configuration
Before implementing dynamic logic, you must establish a safe baseline using the Outbound Campaign Profile settings. This step defines the hard ceiling for concurrent calls to prevent immediate saturation upon campaign launch.
Configuration Steps:
  1. Navigate to Admin > Outbound > Campaigns.
  2. Select the target campaign and open the Campaign Settings.
  3. Locate the Rate Limiting section within the Dialer Profile.
  4. Set Max Concurrent Calls to a value strictly lower than your total trunk capacity. For example, if your carrier provisions 100 concurrent SIP channels, set this value to 75 (75% utilization).
  5. Configure Calls Per Second (CPS) based on the expected answer rate and dialing delay. A standard rule of thumb is Max Concurrent Calls / Average Call Duration.
The Trap: The most common misconfiguration occurs when administrators set the Max Concurrent Calls equal to the physical SIP trunk capacity provided by the carrier. This ignores the overhead required for SIP signaling (INVITE, 200 OK, ACK) and media negotiation. When call volume spikes, the signaling path becomes saturated before the voice channel does, leading to SIP 486 Busy or 503 Service Unavailable errors. The carrier rejects new INVITEs because the session border controller (SBC) cannot process the handshake traffic within the timeout window.
Architectural Reasoning:
We reduce the utilization threshold to 75% intentionally. This buffer absorbs signaling bursts during peak dialing periods and provides headroom for retry logic. If you utilize a Power Dialer strategy without this buffer, a sudden surge in answer rates can cause the system to queue excessive INVITEs, overwhelming the network path. The API will accept the request, but the SIP stack at the carrier edge will drop packets, resulting in silent failures where agents never receive the ringing state.
API Payload for Verification:
To confirm the profile settings via API before deployment, use the following endpoint:
GET /api/v2/outbound/campaigns/{campaignId}
Response Body:
  "id": "uuid-campaign-123",
  "name": "Outbound-Compliance-Campaign",
  "dialerProfile": {
    "maxConcurrentCalls": 75,
    "callsPerSecond": 2.0,
    "rateLimit": {
      "enabled": true,
      "limit": 75
  "status": "PAUSED"
2. Implementing Dynamic Throttling via Outbound API
Static profiles cannot react to real-time network conditions. You must implement an external middleware loop that polls campaign health metrics and adjusts the maxConcurrentCalls value dynamically. This requires the outbound:write permission and a secure API key.
  1. Create an OAuth Client in Admin > Outbound > Settings > API Keys.
  2. Assign the client to your middleware application with outbound:read and outbound:write scopes.
  3. Develop a polling loop that queries the /api/v2/outbound/campaigns/{campaignId}/analytics endpoint every 30 seconds.
  4. Monitor the rejectionRate field in the response payload.
  5. If rejectionRate exceeds 15% over a 60-second window, execute a PATCH request to reduce concurrency by 20%.
  6. If rejectionRate drops below 5% for 5 minutes, increase concurrency by 10% up to the baseline limit.
The Trap: A frequent failure mode in this architecture is race conditions during the API call cycle. If your middleware sends a “decrease” command while a carrier network recovery event triggers an automatic system retry, the two signals conflict. The campaign engine may oscillate between pause and resume states rapidly, causing jitter in agent utilization. This leads to poor agent experience where agents hang up on calls that connect just as the system throttles down again.
We implement exponential backoff logic within the middleware rather than linear adjustments. When a rejection spike is detected, we do not simply subtract calls; we calculate a new concurrency level based on the current active call count divided by a safety factor (0.8). This ensures that the system does not drop below a minimum viable throughput required to meet SLAs. Furthermore, we introduce a hysteresis mechanism where the threshold for increasing concurrency is significantly lower than the threshold for decreasing it. This prevents the “ping-pong” effect where the system constantly adjusts parameters in response to transient network noise.
API Payload for Concurrency Adjustment:
When the middleware determines a reduction is necessary, use this payload:
PATCH /api/v2/outbound/campaigns/{campaignId}
Body:
  "dialerProfile": {
    "maxConcurrentCalls": 60
API Payload for Resume/Increase:
When conditions normalize, use this payload to restore capacity:
Body:
  "dialerProfile": {
3. Integrating Carrier Feedback Loops for SIP Health
The most advanced throttling system integrates directly with carrier telemetry if available. Some carriers provide webhook endpoints or specific SIP headers indicating congestion levels. Genesys Cloud does not expose raw SIP headers to the campaign engine, so this integration occurs at the middleware layer via SBC logs or carrier dashboards.
  1. Configure your Session Border Controller (SBC) to forward SIP failure codes (486, 503, 500) to a logging destination accessible by the middleware.
  2. Map these SIP codes to a “Congestion Score” in your middleware logic.
  3. Correlate the Congestion Score with the campaign rejectionRate metric.
  4. If the Congestion Score indicates persistent carrier-side overload (e.g., >10 consecutive failures), force the campaign into a PAUSED state immediately rather than just throttling concurrency.
The Trap: The most catastrophic error in this stage is assuming that all SIP 503 errors are caused by the outbound side. A SIP 503 Service Unavailable often originates from the carrier’s inbound voice gateway being overloaded by incoming calls, not the outbound dialer. If you throttle the outbound campaign based on this metric, you reduce revenue-generating activity for no reason. The system incorrectly assumes it is the cause of the congestion when it is actually a symptom of broader network issues.
We distinguish between “Carrier Provisioning Limits” and “Network Congestion.” Carrier provisioning limits are hard caps (e.g., 100 channels). Network congestion is a soft cap caused by latency or packet loss. We use the SIP response codes to differentiate these. A 486 Busy indicates a hard capacity limit has been reached. A 503 Service Unavailable may indicate resource exhaustion on the carrier side. Our logic prioritizes checking rejectionRate from the Genesys Cloud Outbound API first, as this metric is internal and accurate regarding our own dialing attempts. We only cross-reference SIP logs if the rejection rate remains high despite low concurrency settings. This layered approach ensures that we do not over-throttle during genuine carrier network outages where no amount of throttling will resolve the issue.
Middleware Logic Snippet (Pseudo-code for Reference):
def adjust_campaign_rate(congestion_score, rejection_rate, current_concurrency):
    if congestion_score > 10:
        return "PAUSE"
    if rejection_rate > 0.15:
        return max(10, current_concurrency * 0.8)
    if rejection_rate < 0.05 and current_concurrency < MAX_LIMIT:
        return min(MAX_LIMIT, current_concurrency * 1.1)
    return current_concurrency
Edge Case 1: Sudden SIP Rejection Spikes During High-Volume Campaigns
The Failure Condition: A campaign launches during a known high-volume period (e.g., Black Friday). Within minutes, the carrier begins rejecting INVITEs with SIP 503 errors. The throttling middleware has not yet detected the pattern due to polling latency.
The Root Cause: Polling intervals of 30 seconds are too slow to catch instantaneous traffic bursts. By the time the middleware reads the rejection rate, thousands of calls have already failed, causing a backlog in the SIP queue that persists even after throttling begins.
The Solution: Implement a “Fast-Track” polling mode triggered by system alerts. Configure Genesys Cloud Alerts to notify the middleware via webhook when rejectionRate spikes above 10%. This bypasses the standard polling loop and triggers an immediate API call to reduce concurrency to the absolute minimum (e.g., 5 concurrent calls) within 5 seconds of detection.
Edge Case 2: Campaign Pause/Resume Latency
The Failure Condition: The system throttles down a campaign, but when conditions improve, the campaign remains paused or fails to resume automatically due to state synchronization issues between the API and the Dialer engine.
The Root Cause: The Outbound API does not always immediately reflect the new state in the analytics dashboard. The middleware may read stale data indicating the campaign is still throttled, preventing it from issuing a resume command.
The Solution: Explicitly check the status field of the campaign object before attempting to modify concurrency. If the status is PAUSED, ensure the dialerProfile update includes an explicit state change request if required by the API version. Use the PATCH /api/v2/outbound/campaigns/{campaignId} endpoint with a body that explicitly sets the desired status alongside the new maxConcurrentCalls to force a state refresh.
Edge Case 3: Time Zone Compliance vs. Capacity Throttling
The Failure Condition: The system reduces concurrency during peak hours to protect trunk capacity, but this inadvertently violates TCPA or Do Not Call (DNC) regulations which mandate specific calling windows based on the consumer’s time zone.
The Root Cause: Global throttling settings apply uniformly across all number lists regardless of the recipient’s location. A reduction in concurrency might push calls outside the permitted calling window for specific segments of the database.
The Solution: Do not use global concurrency throttling as a primary compliance mechanism. Instead, segment campaigns by time zone or region before applying throttling logic. Ensure that the middleware respects the timeZone property on the list level when adjusting rate limits. If a campaign must be throttled due to trunk capacity, ensure the reduction does not push the dialing window past 9 PM local time for any segment. Implement a check in the middleware that validates the projected end-time of the dialing window against regulatory constraints before applying the throttle command.
