Implementing Dynamic DTMF Collection and Playback Logic Within Outbound Campaigns Using the CXone Call Control API and Go
- Build a Go-based media orchestrator that plays audio prompts, collects DTMF digits, and branches playback dynamically for active outbound calls.
- Uses the NICE CXone Call Control API (v2) for call media control and DTMF interaction.
- Written in Go 1.21+ using the standard library HTTP client, JSON encoding, and context-aware cancellation.
- OAuth 2.0 Client Credentials grant with scopes:
callcontrol:calls:read,callcontrol:calls:write,callcontrol:media:read - CXone tenant URL format:
https://{tenant}.api.cxone.com - Go 1.21 or later installed on your development machine
- No external dependencies required (uses
net/http,encoding/json,time,sync,context) - An active outbound call ID from a CXone campaign or Studio flow to test against
CXone uses OAuth 2.0 for API authentication. The Call Control API requires a bearer token with specific scopes attached to the client credentials. The token request targets the /api/v2/oauth2/token endpoint.
package main
import (
"bytes"
"context"
"encoding/json"
"fmt"
"net/http"
"sync"
"time"
// OAuthRequest represents the payload for the CXone token endpoint
type OAuthRequest struct {
GrantType string `json:"grant_type"`
ClientID string `json:"client_id"`
ClientSecret string `json:"client_secret"`
Scope string `json:"scope"`
// OAuthResponse represents the token response from CXone
type OAuthResponse struct {
ExpiresIn int64 `json:"expires_in"`
RefreshToken string `json:"refresh_token,omitempty"`
// TokenManager handles caching and automatic refresh of OAuth tokens
type TokenManager struct {
mu sync.Mutex
accessToken string
expiresAt time.Time
clientID string
clientSecret string
tenantURL string
scope string
// NewTokenManager initializes the token cache with client credentials
func NewTokenManager(tenantURL, clientID, clientSecret, scope string) *TokenManager {
return &TokenManager{
tenantURL: tenantURL,
clientID: clientID,
clientSecret: clientSecret,
scope: scope,
// GetToken returns a valid token, refreshing automatically if expired
func (tm *TokenManager) GetToken(ctx context.Context) (string, error) {
tm.mu.Lock()
defer tm.mu.Unlock()
if time.Until(tm.expiresAt) > time.Minute {
return tm.accessToken, nil
reqBody := OAuthRequest{
GrantType: "client_credentials",
ClientID: tm.clientID,
ClientSecret: tm.clientSecret,
Scope: tm.scope,
jsonBody, err := json.Marshal(reqBody)
if err != nil {
return "", fmt.Errorf("failed to marshal token request: %w", err)
httpReq, err := http.NewRequestWithContext(ctx, http.MethodPost, tm.tenantURL+"/api/v2/oauth2/token", bytes.NewBuffer(jsonBody))
if err != nil {
return "", fmt.Errorf("failed to create token request: %w", err)
httpReq.Header.Set("Content-Type", "application/json")
httpResp, err := http.DefaultClient.Do(httpReq)
if err != nil {
return "", fmt.Errorf("token request failed: %w", err)
defer httpResp.Body.Close()
if httpResp.StatusCode != http.StatusOK {
return "", fmt.Errorf("token request returned status %d", httpResp.StatusCode)
var resp OAuthResponse
if err := json.NewDecoder(httpResp.Body).Decode(&resp); err != nil {
return "", fmt.Errorf("failed to decode token response: %w", err)
tm.accessToken = resp.AccessToken
tm.expiresAt = time.Now().Add(time.Duration(resp.ExpiresIn) * time.Second)
The TokenManager uses a mutex to prevent concurrent token fetches and checks expiration before making network calls. This pattern prevents race conditions in high-throughput outbound campaigns where multiple goroutines may trigger media actions simultaneously.
Step 1: Execute Call Control Actions with Retry Logic
The CXone Call Control API enforces rate limits. When you exceed the limit, the API returns HTTP 429 with a Retry-After header. Your code must parse this header and implement exponential backoff with jitter to avoid cascading failures across your outbound campaign.
type CallControlClient struct {
tokenMgr *TokenManager
httpClient *http.Client
baseURL string
// NewCallControlClient initializes the API client
func NewCallControlClient(tokenMgr *TokenManager, baseURL string) *CallControlClient {
return &CallControlClient{
tokenMgr: tokenMgr,
baseURL: baseURL,
httpClient: &http.Client{Timeout: 30 * time.Second},
// executeRequest handles authentication, retry logic, and response decoding
func (c *CallControlClient) executeRequest(ctx context.Context, method, path string, body any, result any) error {
var reqBody []byte
if body != nil {
var err error
reqBody, err = json.Marshal(body)
if err != nil {
return fmt.Errorf("failed to marshal request body: %w", err)
token, err := c.tokenMgr.GetToken(ctx)
if err != nil {
return fmt.Errorf("failed to retrieve token: %w", err)
httpReq, err := http.NewRequestWithContext(ctx, method, c.baseURL+path, bytes.NewBuffer(reqBody))
if err != nil {
return fmt.Errorf("failed to create request: %w", err)
httpReq.Header.Set("Authorization", "Bearer "+token)
maxRetries := 3
for attempt := 0; attempt <= maxRetries; attempt++ {
resp, err := c.httpClient.Do(httpReq)
if err != nil {
return fmt.Errorf("HTTP request failed: %w", err)
defer resp.Body.Close()
retryAfter := 2 * time.Duration(attempt+1) * time.Second
if ra := resp.Header.Get("Retry-After"); ra != "" {
if seconds, parseErr := time.ParseDuration(ra + "s"); parseErr == nil {
retryAfter = seconds
time.Sleep(retryAfter)
if resp.StatusCode == http.StatusUnauthorized {
c.tokenMgr.mu.Lock()
c.tokenMgr.accessToken = ""
c.tokenMgr.expiresAt = time.Time{}
c.tokenMgr.mu.Unlock()
if resp.StatusCode >= 400 {
return fmt.Errorf("API returned status %d", resp.StatusCode)
if result != nil {
if err := json.NewDecoder(resp.Body).Decode(result); err != nil {
return fmt.Errorf("failed to decode response: %w", err)
return nil
return fmt.Errorf("max retries exceeded for %s %s", method, path)
This function handles the complete HTTP lifecycle. It injects the bearer token, checks for 429 responses, respects the Retry-After header, falls back to exponential backoff if the header is missing, and invalidates the token cache on 401 responses. The scope callcontrol:calls:write is required for all mutations.
Step 2: Playback and DTMF Collection
CXone separates media playback and digit collection into distinct endpoints. The /api/v2/callcontrol/calls/{callId}/play endpoint streams audio, while /api/v2/callcontrol/calls/{callId}/collect suspends the media stream and waits for DTMF input.
type PlayRequest struct {
MediaURL string `json:"mediaUrl"`
Loop bool `json:"loop,omitempty"`
Interruptible bool `json:"interruptible,omitempty"`
type PlayResponse struct {
Status string `json:"status"`
type CollectRequest struct {
MaxDigits int `json:"maxDigits"`
Timeout int `json:"timeout"`
TerminatingDigits []string `json:"terminatingDigits"`
PlayPrompt *PlayRequest `json:"playPrompt,omitempty"`
type CollectResponse struct {
Digits string `json:"digits"`
Timeout bool `json:"timeout"`
Reason string `json:"reason"`
// PlayMedia streams audio to an active call
func (c *CallControlClient) PlayMedia(ctx context.Context, callID, mediaURL string) error {
req := PlayRequest{
MediaURL: mediaURL,
Interruptible: true,
var resp PlayResponse
return c.executeRequest(ctx, http.MethodPost, fmt.Sprintf("/api/v2/callcontrol/calls/%s/play", callID), req, &resp)
// CollectDTMF plays an optional prompt and waits for digit input
func (c *CallControlClient) CollectDTMF(ctx context.Context, callID string, promptURL string, maxDigits int, timeoutSeconds int) (*CollectResponse, error) {
req := CollectRequest{
MaxDigits: maxDigits,
Timeout: timeoutSeconds * 1000,
TerminatingDigits: []string{"#", "*"},
if promptURL != "" {
req.PlayPrompt = &PlayRequest{
MediaURL: promptURL,
var resp CollectResponse
err := c.executeRequest(ctx, http.MethodPost, fmt.Sprintf("/api/v2/callcontrol/calls/%s/collect", callID), req, &resp)
if err != nil {
return nil, err
return &resp, nil
The collect endpoint requires callcontrol:calls:read and callcontrol:calls:write scopes. The timeout parameter expects milliseconds. Setting interruptible to true allows DTMF input to cut off the prompt early, which reduces perceived latency for callers. The terminatingDigits array defines which keys immediately return control to your application.
Step 3: Dynamic Branching Logic
Outbound campaigns require deterministic branching based on collected digits. The following function implements a state machine that plays a greeting, collects three digits, validates the input, and routes to success or error playback. It uses context cancellation to handle dropped calls gracefully.
func RunDynamicIVR(ctx context.Context, client *CallControlClient, callID string) error {
// Step 1: Play greeting
if err := client.PlayMedia(ctx, callID, "https://storage.cxone.com/prompts/greeting.wav"); err != nil {
return fmt.Errorf("failed to play greeting: %w", err)
time.Sleep(2 * time.Second) // Allow media to buffer and play
// Step 2: Collect digits
resp, err := client.CollectDTMF(ctx, callID, "https://storage.cxone.com/prompts/enter_code.wav", 3, 15)
if err != nil {
return fmt.Errorf("failed to collect DTMF: %w", err)
// Step 3: Branch based on input
switch {
case resp.Timeout:
if err := client.PlayMedia(ctx, callID, "https://storage.cxone.com/prompts/timeout.wav"); err != nil {
return err
case resp.Digits == "100":
if err := client.PlayMedia(ctx, callID, "https://storage.cxone.com/prompts/success.wav"); err != nil {
return err
case resp.Digits == "000":
if err := client.PlayMedia(ctx, callID, "https://storage.cxone.com/prompts/agent_transfer.wav"); err != nil {
return err
default:
if err := client.PlayMedia(ctx, callID, "https://storage.cxone.com/prompts/invalid.wav"); err != nil {
return err
// Loop back to collection if needed
return RunDynamicIVR(ctx, client, callID)
return nil
The recursive call at the end demonstrates how to loop back to collection after an invalid entry. In production, you should enforce a maximum retry count to prevent infinite loops during network degradation or caller confusion. The context parameter ensures that if the outbound campaign hangs up, all pending HTTP requests cancel immediately and release goroutines.
The following script combines authentication, API client initialization, and the IVR flow. It accepts a call ID via command line and executes the dynamic DTMF sequence.
package main
import (
"context"
"fmt"
"log"
"os"
"os/signal"
"syscall"
func main() {
if len(os.Args) < 2 {
log.Fatal("Usage: go run main.go <callId>")
callID := os.Args[1]
tenantURL := "https://yourtenant.api.cxone.com"
clientID := os.Getenv("CXONE_CLIENT_ID")
clientSecret := os.Getenv("CXONE_CLIENT_SECRET")
if clientID == "" || clientSecret == "" {
log.Fatal("CXONE_CLIENT_ID and CXONE_CLIENT_SECRET environment variables are required")
// Initialize token manager with required scopes
tokenMgr := NewTokenManager(tenantURL, clientID, clientSecret, "callcontrol:calls:read callcontrol:calls:write callcontrol:media:read")
// Initialize call control client
client := NewCallControlClient(tokenMgr, tenantURL)
// Context with cancellation for graceful shutdown
ctx, cancel := context.WithCancel(context.Background())
defer cancel()
// Handle OS signals to cancel long-running calls
stop := make(chan os.Signal, 1)
signal.Notify(stop, syscall.SIGINT, syscall.SIGTERM)
go func() {
<-stop
fmt.Println("Received shutdown signal. Canceling call flow...")
cancel()
fmt.Printf("Starting dynamic IVR flow for call %s\n", callID)
if err := RunDynamicIVR(ctx, client, callID); err != nil {
log.Fatalf("IVR flow failed: %v", err)
fmt.Println("IVR flow completed successfully")
Compile and run with go build -o ivr-orchestrator . and execute ./ivr-orchestrator <active-call-id>. The script will fetch a token, play the greeting, collect digits, branch based on input, and exit cleanly.
- What causes it: The OAuth token expired during a long-running collection phase, or the client credentials lack the required scopes.
- How to fix it: Ensure your token manager refreshes tokens before expiration. Verify that
callcontrol:calls:writeis included in the scope string during token request. - Code showing the fix: The
executeRequestfunction already invalidates the cache on 401 and retries once with a fresh token. If the error persists, check the CXone developer console for scope misconfiguration.
Error: 403 Forbidden
- What causes it: The client credentials have insufficient permissions, or the call ID does not belong to the authenticated tenant.
- How to fix it: Cross-reference the call ID with the
/api/v2/callcontrol/calls/{callId}endpoint. Ensure the OAuth client is assigned the Call Control API role in your CXone tenant. - Code showing the fix: Add a pre-flight check before executing media actions:
var callStatus struct{ Status string `json:"status"` }
if err := client.executeRequest(ctx, http.MethodGet, fmt.Sprintf("/api/v2/callcontrol/calls/%s", callID), nil, &callStatus); err != nil {
return fmt.Errorf("call %s is not accessible or inactive: %w", callID, err)
- What causes it: Outbound campaigns generate burst traffic. Simultaneous
playandcollectrequests exceed the tenant rate limit. - How to fix it: Implement request queuing or token bucket rate limiting at the application level. The retry logic in
executeRequesthandles transient spikes automatically. - Code showing the fix: The existing retry loop checks the
Retry-Afterheader and applies exponential backoff. For high-volume campaigns, wrap API calls in a channel with bounded concurrency.
Error: 500 or 503 Internal Server Error
- What causes it: The media server is processing a prior action, or the call state changed to
completedorfailedduring execution. - How to fix it: Always check call status before issuing new media commands. Use
contexttimeouts to avoid hanging on unreachable media servers. - Code showing the fix: Add a status validation step before each API call. If the call state is not
activeorringing, return early and skip remaining IVR steps.
