Implementing Dynamic Branching in CXone Studio Snippets with ASSIGN and IF Actions
- A CXone Studio Snippet that evaluates a caller’s VIP status and recent interaction history to route them to a priority queue or standard support.
- This tutorial uses the NICE CXone Studio Snippet configuration format and the CXone API for deployment.
- The implementation covers JSON-based Snippet configuration and validation via the CXone REST API.
- OAuth Client Type: Resource Owner Password Credentials (ROPC) or Client Credentials (for API deployment, though Snippets are often configured via UI, we will use the API to retrieve and validate the structure).
- Required Scopes:
snippet:read,snippet:write,analytics:read(for testing data sources). - SDK Version: NICE CXone API Client (v2). We will use Python
requestsfor direct API interaction as the Snippet DSL is JSON-native. - Runtime Requirements: Python 3.8+,
requestslibrary. - External Dependencies: None beyond standard library and
requests.
CXone APIs require OAuth 2.0 authentication. For programmatic access to configuration resources, you must obtain an access token. The following Python code demonstrates the ROPC flow, which is common for administrative scripts.
import requests
import json
import sys
# Configuration - Replace with your actual CXone instance details
CXONE_DOMAIN = "your-instance.my.cxone.com"
CLIENT_ID = "your_client_id"
CLIENT_SECRET = "your_client_secret"
USERNAME = "admin@yourdomain.com"
PASSWORD = "your_secure_password"
OAUTH_URL = f"https://{CXONE_DOMAIN}/oauth/token"
def get_access_token() -> str:
Retrieves an OAuth access token from CXone.
Implements basic exponential backoff for 429 Too Many Requests.
headers = {
"Content-Type": "application/x-www-form-urlencoded",
"Authorization": f"Basic {__encode_basic_auth()}"
data = {
"grant_type": "password",
"username": USERNAME,
"password": PASSWORD
retries = 3
for attempt in range(retries):
response = requests.post(OAUTH_URL, data=data, headers=headers, timeout=10)
if response.status_code == 200:
token_data = response.json()
return token_data.get("access_token")
elif response.status_code == 429:
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
print(f"Rate limited. Waiting {retry_after} seconds...")
time.sleep(retry_after)
else:
print(f"Error: {response.status_code} - {response.text}")
sys.exit(1)
print(f"Network error: {e}")
sys.exit(1)
print("Failed to acquire token after retries.")
sys.exit(1)
def __encode_basic_auth() -> str:
"""Encodes Client ID and Secret for Basic Auth."""
import base64
credentials = f"{CLIENT_ID}:{CLIENT_SECRET}"
return base64.b64encode(credentials.encode("utf-8")).decode("utf-8")
# Initialize token
ACCESS_TOKEN = get_access_token()
AUTH_HEADER = {"Authorization": f"Bearer {ACCESS_TOKEN}"}
CXone Studio Snippets are defined as JSON objects. The ASSIGN action creates variables in the conversation context, and the IF action evaluates boolean conditions to determine the flow path.
Step 1: Defining the ASSIGN Action
The ASSIGN action is used to store data. In a branching scenario, you typically assign a boolean or an integer that the IF block will evaluate.
Concept:
- Retrieve the customer’s
vip_levelfrom a data source (e.g., Database Lookup or Previous Interaction). - Assign a new variable
is_prioritybased on that level.
Code Example: Snippet JSON Structure for ASSIGN
Below is the JSON fragment representing an ASSIGN action. This is not a full executable script but the configuration payload you would send to the CXone API or edit in the Studio UI.
"name": "Check VIP Status",
"type": "ASSIGN",
"properties": {
"variables": [
"name": "is_priority",
"value": {
"type": "EXPRESSION",
"expression": "data.vip_level > 5"
"name": "customer_tier_label",
"value": {
"type": "LITERAL",
"value": "Gold"
Explanation:
name: The display name of the action in Studio.type: Must beASSIGN.properties.variables: An array of variable assignments.value.type: Can beLITERAL(static string/number),EXPRESSION(dynamic calculation), orDATA_SOURCE(referencing a lookup).expression: Uses the CXone expression language.data.vip_levelrefers to a property previously resolved by a data lookup action.
Step 2: Implementing the IF Branching Logic
The IF action evaluates a condition. It has two primary outcomes: true and false. Each outcome can point to another action ID.
Concept:
- Evaluate
is_priorityfrom the previous step. - If
true, proceed toRouteToPriorityQueue. - If
false, proceed toRouteToStandardQueue.
Code Example: Snippet JSON Structure for IF
"name": "Route Based on VIP",
"type": "IF",
"properties": {
"condition": {
"expression": "is_priority == true"
"true": "action_id_priority_queue",
"false": "action_id_standard_queue"
Critical Parameter Details:
condition.expression: The boolean logic. Note that CXone expressions are case-sensitive.true: The ID of the action to execute if the condition is met.false: The ID of the action to execute if the condition is not met. This is optional; if omitted, the flow ends.
Step 3: Constructing the Full Snippet Definition
A complete Snippet consists of a header and a body (list of actions). The actions are referenced by their id (not their name) in the true/false fields.
Working Code: Generating the Snippet JSON
This Python script constructs a valid Snippet JSON object that combines ASSIGN and IF.
def create_vip_routing_snippet() -> dict:
Constructs a CXone Snippet JSON object for VIP routing.
snippet_definition = {
"name": "VIP Routing Logic",
"description": "Routes calls based on VIP status using ASSIGN and IF",
"type": "SNIPPET",
"body": [
"id": "assign_vip_status",
"name": "Assign VIP Boolean",
"type": "ASSIGN",
"properties": {
"variables": [
"value": {
"expression": "data.customer.vip_score > 80"
"id": "check_vip_condition",
"name": "Check if VIP",
"type": "IF",
"properties": {
"condition": {
"true": "route_priority",
"false": "route_standard"
"id": "route_priority",
"name": "Route to Priority Queue",
"type": "ROUTE",
"properties": {
"queueId": "priority_queue_id_123",
"strategy": "LONGEST_AVAILABLE_AGENT"
"id": "route_standard",
"name": "Route to Standard Queue",
"type": "ROUTE",
"properties": {
"queueId": "standard_queue_id_456",
"strategy": "NEXT_AVAILABLE_AGENT"
return snippet_definition
# Generate the snippet
snippet_json = create_vip_routing_snippet()
print(json.dumps(snippet_json, indent=2))
The following script demonstrates how to deploy this snippet to CXone using the API. It includes error handling for common deployment issues.
import requests
import json
import sys
# Reuse ACCESS_TOKEN and AUTH_HEADER from Authentication Setup
CXONE_SNIPPET_URL = f"https://{CXONE_DOMAIN}/api/v2/snippets"
def deploy_snippet(snippet_data: dict) -> str:
Deploys a snippet to CXone.
Returns the Snippet ID if successful.
headers = {
**AUTH_HEADER,
response = requests.post(CXONE_SNIPPET_URL, json=snippet_data, headers=headers, timeout=15)
if response.status_code == 201:
result = response.json()
snippet_id = result.get("id")
print(f"Snippet deployed successfully. ID: {snippet_id}")
return snippet_id
elif response.status_code == 400:
print(f"Bad Request: {response.text}")
print("Check JSON structure and action IDs.")
sys.exit(1)
elif response.status_code == 401:
print("Unauthorized: Token may be expired.")
sys.exit(1)
elif response.status_code == 403:
print("Forbidden: Insufficient permissions.")
sys.exit(1)
else:
print(f"Unexpected Error: {response.status_code} - {response.text}")
sys.exit(1)
print(f"Network error during deployment: {e}")
sys.exit(1)
# 1. Construct Snippet
snippet_payload = create_vip_routing_snippet()
# 2. Deploy Snippet
snippet_id = deploy_snippet(snippet_payload)
# 3. Verify Deployment (Optional)
verify_url = f"https://{CXONE_DOMAIN}/api/v2/snippets/{snippet_id}"
verify_response = requests.get(verify_url, headers=AUTH_HEADER)
if verify_response.status_code == 200:
print("Snippet verification successful.")
else:
print(f"Verification failed: {verify_response.status_code}")
Error: 400 Bad Request - Invalid Action ID
Cause: The true or false property in the IF action references an ID that does not exist in the body array, or the ID is misspelled.
Fix: Ensure every action has a unique id field. Verify that the true/false values match these IDs exactly.
// Incorrect
"true": "route_to_priority" // ID in body is "route_priority"
// Correct
Error: 400 Bad Request - Expression Syntax Error
Cause: The expression in ASSIGN or IF uses invalid syntax. Common issues include undefined variables or incorrect comparison operators.
Fix: Use the CXone Expression Language reference. Ensure variables used in expressions are defined in earlier actions.
// Incorrect: Undefined variable
"expression": "unknown_var > 5"
// Correct: Variable defined in previous ASSIGN
Cause: Exceeding the API rate limit.
Fix: Implement exponential backoff in your deployment script. The get_access_token function above includes this logic.
Error: 403 Forbidden
Cause: The OAuth token does not have the snippet:write scope.
Fix: Update your OAuth client configuration in CXone Admin to include snippet:write.
