Implementing DTMF Suppression and Masking for PCI Compliance
You will configure recording policies to strip DTMF tones from standard call recordings, architect IVR flows that mask PAN entry in real-time, and establish compliance recording boundaries that satisfy PCI-DSS 3.2.1 requirements. When complete, your environment will capture transaction context without storing audible digit tones in QA datasets, and auditors will verify that no full primary account numbers persist in standard media archives while compliance recordings retain the exact tone sequence for dispute resolution.
- Licensing Tiers: Genesys Cloud CX 1 or higher, Recording & Analytics add-on, Compliance Recording add-on. NICE CXone requires Contact Center Enterprise tier with Recording & Analytics and Compliance Recording enabled.
- Granular Permissions:
Recording > Recording Settings > Edit,Architect > Flow > Edit,Recording > Compliance Recording > Manage,Telephony > Trunk > View,Recording > Media > Read. - OAuth Scopes:
recording:settings:write,recording:compliance:write,architect:flow:write,telephony:trunks:read. - External Dependencies: PCI QSA sign-off on masking logic, carrier DTMF transport verification (RFC 2833 vs SIP INFO), payment gateway PCI validation (Level 1 or Level 2), immutable storage bucket configuration for compliance media.
1. Recording Policy Configuration and DTMF Suppression
Standard call recordings serve quality assurance, training, and operational analytics. They must never contain audible DTMF tones representing primary account numbers. Genesys Cloud CX handles DTMF suppression at the recording policy level, not at the media stream level. This distinction matters because the media server still receives and processes the tones for IVR routing. Suppression occurs during the encoding phase when the recording service writes the media to storage.
You will configure recording settings via the API to enforce DTMF suppression across all standard recording policies. The UI allows manual toggles, but API-driven configuration guarantees consistency across multiple environments and prevents drift during deployment pipelines.
Execute the following request to modify the default recording settings:
PUT /api/v2/recordings/settings
"include_dtmf": false,
"include_tones": false,
"include_silence": false,
"recording_format": "wav",
"sample_rate": 16000,
"bit_depth": 16,
"channels": 1
The include_dtmf flag controls whether the recording service extracts RFC 2833 or SIP INFO DTMF events and embeds them as audible tones in the final media file. Setting include_dtmf to false strips these events before encoding. The include_tones flag suppresses system-generated tones like busy signals or reorder tones. The include_silence flag prevents long silent gaps from inflating storage costs.
We use the API instead of the UI because recording settings cascade to all new recording policies. Manual UI changes create version control gaps and break infrastructure-as-code deployments. The API payload also enforces consistent audio parameters. A 16 kHz sample rate with 16-bit depth provides sufficient clarity for speech analytics while reducing file size by approximately 40 percent compared to 44.1 kHz CD-quality audio. This reduction directly impacts storage costs at scale.
The Trap: Configuring DTMF suppression globally without isolating compliance recordings. Many architects apply include_dtmf: false to the global settings and assume compliance recordings inherit the suppression. They do not. Compliance recordings use a separate policy engine that overrides global settings. If you suppress DTMF in compliance recordings, you violate PCI-DSS audit requirements. The QSA cannot verify the exact digits entered during a chargeback dispute if the tones are stripped. Always configure standard recordings with suppression and compliance recordings with explicit DTMF retention.
The architectural reasoning here centers on data segregation. Standard recordings flow into speech analytics, QA scoring, and agent coaching pipelines. Compliance recordings flow into immutable storage with strict access controls. DTMF suppression in standard recordings prevents accidental PAN leakage into analytics datasets. DTMF retention in compliance recordings satisfies legal verification requirements. The split policy architecture ensures neither use case compromises the other.
Validate the configuration by retrieving the settings:
GET /api/v2/recordings/settings
The response must return include_dtmf: false. If it returns true, the recording service will embed DTMF tones in all standard media files. Check the recording policy assignments in the UI to confirm that no policy overrides the global setting with a manual Include DTMF toggle. Policy overrides take precedence over global settings, which creates silent compliance failures.
2. Architect Flow DTMF Masking Logic
DTMF suppression in recordings does not mask the tones during the live call. The customer still hears their own tones echoed back by the media server. PCI-DSS 3.2.1 requires masking during entry. You must implement masking logic in the Architect flow to replace audible digit playback with a neutral confirmation signal.
Genesys Cloud CX does not provide a native mask_dtmf toggle in the Collect DTMF block. You must construct the masking behavior using flow data manipulation and tone playback. The flow must collect digits, store them in flow data, play masking tones, and route to the payment gateway without ever playing the collected digits back to the customer.
Configure the Collect DTMF block with the following parameters:
- Max Digits: 16
- Timeout: 5 seconds
- Inter-digit Timeout: 2 seconds
- Reset Timer: false
- Store in Flow Data:
pan_digits - Play DTMF: false
Setting Play DTMF to false prevents the media server from echoing the tones back to the customer. This is the first masking control. The second control requires a dedicated Play block that emits a fixed masking tone. You will use a 440 Hz sine wave tone that plays once per digit collected. This confirms to the customer that the system registered input without revealing the value.
Construct the flow logic using a Loop block that iterates through the pan_digits string length. Inside the loop, place a Play block configured with a masking tone file. The masking tone must be a short, non-musical beep that does not resemble any DTMF frequency. DTMF frequencies range from 697 Hz to 941 Hz. A 440 Hz tone falls outside this range and prevents accidental tone detection by downstream analytics engines.
After the loop completes, route to the payment gateway using a HTTP Request block. The request must pass the pan_digits value via a secure, tokenized endpoint. Never pass raw PAN values through Genesys Cloud CX HTTP blocks to non-PCI-validated endpoints. The flow must terminate the PAN data lifecycle immediately after tokenization. Clear the flow data variable using a Set Variable block set to null.
The Trap: Relying on TTS to confirm digit entry without verifying timer behavior. Many architects place a Play block after the Collect DTMF block and assume the masking tone plays correctly. They overlook the Reset Timer behavior. If Reset Timer is set to true, the 5-second timeout restarts after each digit. This creates an infinite loop when combined with masking playback. The customer hears masking tones, then the system prompts for more digits, then plays more masking tones. The flow never advances to the payment gateway. Always set Reset Timer to false for PAN collection. Use a fixed timeout that forces progression after the maximum digit count or the initial timeout expires.
The architectural reasoning here centers on state management and timer isolation. The Collect DTMF block maintains an internal state machine that tracks digit count, timeout expiration, and input validation. Masking playback occurs in a separate execution context. If the timer resets during masking, the state machine interprets the silence between masking tones as a new collection window. This breaks the flow logic. Fixed timers ensure predictable progression. Flow data clearing ensures no PAN values persist in memory after tokenization. This satisfies PCI-DSS requirement 3.4 regarding data lifecycle management.
Validate the flow by testing with a 16-digit sequence. Monitor the flow execution trace in Architect. Confirm that the pan_digits variable populates correctly, the masking loop executes exactly once per digit, and the HTTP request triggers before the variable clears. If the trace shows repeated Collect DTMF executions, the timer reset configuration is incorrect. If the trace shows the HTTP request failing, verify that the gateway endpoint accepts the payload format and that OAuth credentials are valid.
3. Compliance Recording and Audit Trail Configuration
Compliance recordings operate outside the standard recording pipeline. They use a separate policy engine, storage backend, and retention framework. You must configure compliance recordings to retain DTMF tones while enforcing strict access controls. This configuration satisfies PCI-DSS audit requirements while preventing unauthorized access to transaction media.
Execute the following request to create a compliance recording policy:
POST /api/v2/recordings/compliance
"name": "PCI-Transaction-Audit",
"description": "Compliance recording for payment transactions with DTMF retention",
"recordingSettings": {
"include_dtmf": true,
"include_tones": true,
"include_silence": true,
"sample_rate": 44100,
"bit_depth": 16,
"channels": 2
"retentionPolicy": {
"retentionDays": 2555,
"storageLocation": "compliance-immutable-bucket",
"encryption": "AES-256"
"triggers": [
"type": "architect_flow",
"flowId": "payment-authorization-flow",
"condition": "equals",
"value": "transaction_initiated"
The recordingSettings object explicitly overrides the global DTMF suppression. Compliance recordings must retain include_dtmf: true to capture the exact tone sequence. The sample_rate of 44100 Hz and channels: 2 provide forensic-grade audio quality. PCI QSA reviewers require clear tone separation to verify digit entry during disputes. The retentionPolicy enforces a 7-year retention period (2555 days) and routes media to an immutable storage bucket. Immutable storage prevents accidental deletion or tampering, which satisfies PCI-DSS requirement 10.7 regarding audit trail protection.
The triggers array binds the compliance policy to a specific Architect flow event. You must configure a Set Flow Data block in your payment flow that emits transaction_initiated before PAN collection. This ensures compliance recordings start exactly when the transaction begins. Starting recordings too early captures unnecessary IVR navigation. Starting recordings too late misses the initial tone sequence. Event-driven triggering guarantees precise alignment with the transaction lifecycle.
The Trap: Assigning compliance recording permissions to standard QA roles. Many architects grant Recording > Media > Read to QA managers for performance monitoring. If QA managers access compliance recordings, they can view DTMF tones containing full PAN values. This violates PCI-DSS requirement 7 regarding least privilege access. Compliance recordings must be accessible only to designated compliance officers and legal teams. Use role-based access control to restrict compliance media access. Create a dedicated Compliance Auditor role with explicit Recording > Compliance Recording > Read permissions. Deny all other roles access to compliance media buckets.
The architectural reasoning here centers on access isolation and data classification. Standard recordings contain operational data. Compliance recordings contain financial transaction data. They require different security controls. Event-driven triggering ensures compliance recordings align with transaction boundaries. Immutable storage prevents data tampering. Role-based access control enforces least privilege. This three-layer architecture satisfies both PCI-DSS audit requirements and enterprise security policies.
Validate the configuration by initiating a test transaction. Verify that the compliance recording starts at the transaction_initiated event. Download the media file and inspect the audio waveform. Confirm that DTMF tones appear as distinct frequency spikes at the expected intervals. Verify that the storage location matches the immutable bucket configuration. Check the retention policy to confirm the 7-year expiration date. If the recording starts too early or too late, adjust the flow trigger event. If DTMF tones are missing, verify that the carrier transmits RFC 2833 payloads and that the trunk configuration enables DTMF passthrough. If access control fails, audit the role permissions and remove any overlapping Recording > Media > Read assignments from non-compliance roles.
Validation, Edge Cases and Troubleshooting
Edge Case 1: RFC 2833 vs SIP INFO Transport Mismatch
The failure condition occurs when DTMF suppression appears to work in the recording policy, but tones still appear in standard recordings. The root cause is a transport mismatch between the carrier and the Genesys Cloud CX media server. Carriers transmit DTMF using either RFC 2833 (RTP payload) or SIP INFO (SIP signaling). Genesys Cloud CX defaults to RFC 2833. If the carrier sends SIP INFO, the media server never receives the DTMF events as RTP payloads. The recording service cannot suppress what it does not receive. The tones bypass the suppression filter and embed directly into the audio stream.
The solution requires trunk configuration alignment. Navigate to Telephony > Trunks > Select Trunk > Advanced Settings. Locate the DTMF Transport dropdown. Set it to SIP INFO if your carrier documentation specifies SIP INFO transmission. If you select RFC 2833, verify that the carrier supports it. Many legacy carriers default to SIP INFO for cost optimization. RFC 2833 requires additional RTP payload handling, which some carriers disable. Always validate transport alignment with your carrier engineering team before deploying suppression policies. Use Wireshark or tcpdump to capture SIP signaling and RTP streams. Confirm that DTMF events appear in the expected protocol. If they appear in SIP INFO headers, configure the trunk accordingly. If they appear in RTP payload type 101, configure RFC 2833. Mismatched transport creates silent compliance failures that only surface during QSA audits.
Edge Case 2: Collect Block Timer Reset During Masking Playback
The failure condition occurs when the Architect flow enters an infinite loop during PAN collection. The customer hears masking tones, then the system prompts for more digits, then plays more masking tones. The flow never advances to the payment gateway. The root cause is the Reset Timer configuration in the Collect DTMF block combined with masking playback duration. When Reset Timer is set to true, the timeout restarts after each digit. The masking loop plays a 200 ms tone per digit. For a 16-digit PAN, the loop takes 3.2 seconds. The 5-second timeout resets after each digit, but the masking playback consumes the remaining timeout window. The media server interprets the silence between masking tones as a new collection window. The flow re-executes the Collect DTMF block.
The solution requires explicit timer isolation. Set Reset Timer to false in the Collect DTMF block. Configure a fixed Timeout of 8 seconds to accommodate the maximum digit entry time plus masking playback duration. Place the masking loop in a separate flow branch that executes only after the Collect DTMF block completes. Use a Condition block that checks pan_digits.length > 0 before entering the masking loop. This ensures masking only occurs when digits are present. Add a Delay block of 100 ms after the masking loop to allow the media server to flush the tone buffer. This prevents tone overlap with the subsequent HTTP request. Validate the flow execution trace to confirm single-pass execution. If the trace shows repeated Collect DTMF blocks, the timer reset configuration remains incorrect. If the trace shows the masking loop executing before digit collection, reorder the flow blocks. Timer isolation and branch separation eliminate infinite loop conditions.
