Implementing Dialogue Context Window Bundling for Cognigy.AI with Python
This tutorial builds a Python module that bundles conversation history into optimized context windows, validates payloads against NLU token limits, prunes low-relevance history, and synchronizes compressed bundles to Cognigy.AI sessions and external vector stores. The implementation uses the Cognigy.AI REST API with Python httpx and pydantic for strict schema enforcement. The programming language is Python 3.10 or higher.
  • OAuth 2.0 Client Credentials flow with scopes: context:write, sessions:read, webhooks:manage, analytics:read
  • Cognigy.AI API v1 endpoint: https://{org}.cognigy.ai/api/v1/
  • Python 3.10+ runtime
  • External dependencies: pip install httpx pydantic aiofiles pyjwt
Cognigy.AI and NICE CXone integrations rely on OAuth 2.0 Client Credentials for server-to-server API calls. The following code demonstrates token acquisition, caching, and automatic refresh logic. The token endpoint requires your organization credentials and returns a Bearer token valid for thirty minutes.
import httpx
import threading
from typing import Optional
class CognigyAuthManager:
    def __init__(self, base_url: str, client_id: str, client_secret: str):
        self.client_id = client_id
        self._expires_at: float = 0.0
        self._lock = threading.Lock()
    def _fetch_token(self) -> str:
        url = f"{self.base_url}/oauth/token"
        payload = {
            "scope": "context:write sessions:read webhooks:manage analytics:read"
        response = httpx.post(url, data=payload, auth=(self.client_id, self.client_secret), timeout=10.0)
        response.raise_for_status()
        return response.json()["access_token"]
    def get_token(self) -> str:
        with self._lock:
            if self._token is None or time.time() >= self._expires_at - 60:
                self._token = self._fetch_token()
                self._expires_at = time.time() + 1740  # 29 minutes buffer
            return self._token
The get_token method ensures thread-safe token retrieval and refreshes the credential before expiration. The response body contains access_token and expires_in. You must pass this token in the Authorization: Bearer <token> header for all subsequent Cognigy.AI API calls.
Step 1: Constructing Bundling Payloads and Validating NLU Constraints
Context bundling requires a structured payload containing a context reference, a window matrix defining temporal boundaries, and a compress directive that instructs the NLU engine to aggregate redundant turns. Pydantic models enforce schema validation against maximum token payload limits.
from pydantic import BaseModel, Field, validator
class WindowMatrix(BaseModel):
    start_turn: int
    end_turn: int
    max_tokens: int = Field(default=4096, le=8192)
    step_size: int = Field(default=1, ge=1)
class CompressDirective(BaseModel):
    strategy: str = Field(..., pattern="^(semantic|turn_aggregation|entity_merge)$")
    threshold: float = Field(..., ge=0.0, le=1.0)
    preserve_entities: bool = True
class ContextBundlePayload(BaseModel):
    context_reference: str
    window: WindowMatrix
    compress: CompressDirective
    history: List[Dict[str, Any]]
    @validator("history")
    def validate_token_budget(cls, v, values):
        if not values.get("window"):
            raise ValueError("Window matrix must be defined before history validation")
        estimated_tokens = sum(len(str(turn.get("text", ""))) // 4 for turn in v)
        if estimated_tokens > values["window"].max_tokens:
            raise ValueError(f"History exceeds token limit: {estimated_tokens} > {values['window'].max_tokens}")
        return v
The validate_token_budget validator calculates an approximate token count using a standard four-character-per-token heuristic. If the payload exceeds the max_tokens threshold defined in the window matrix, Pydantic raises a ValidationError. This prevents bundling failure at the NLU ingestion layer.
Expected HTTP POST request to Cognigy.AI:
POST /api/v1/sessions/{sessionId}/context/bundle
  "context_reference": "sess_8f3a9c2b",
  "window": {"start_turn": 10, "end_turn": 25, "max_tokens": 2048, "step_size": 2},
  "compress": {"strategy": "semantic", "threshold": 0.85, "preserve_entities": true},
  "history": [
    {"turn_id": "t_01", "role": "user", "text": "I need to update my billing address"},
    {"turn_id": "t_02", "role": "bot", "text": "Please provide the new street and zip code"}
Response body on success:
  "bundle_id": "bund_9d4e1f0a",
  "status": "compressed",
  "token_count": 1842,
  "pruned_turns": 3,
  "expires_at": "2024-12-31T23:59:59Z"
Step 2: Memory Allocation, History Pruning, and Atomic POST Operations
Memory allocation calculation determines whether the current bundle fits within the session context window. History pruning removes turns below a relevance score threshold. The bundler executes an atomic POST operation that verifies format compliance and triggers automatic cache eviction upon successful ingestion.
import httpx
import logging
logger = logging.getLogger("cognigy_bundler")
class ContextBundler:
    def __init__(self, auth: CognigyAuthManager, org_id: str, max_retries: int = 3):
        self.auth = auth
        self.base_url = f"https://{org_id}.cognigy.ai/api/v1"
        self.max_retries = max_retries
        self._cache: Dict[str, Any] = {}
    def _calculate_memory_footprint(self, payload: ContextBundlePayload) -> int:
        # Approximate memory allocation in bytes for NLU processing
        base_overhead = 256
        turn_bytes = sum(len(str(t.get("text", ""))) * 2 for t in payload.history)
        return base_overhead + turn_bytes
    def _prune_history(self, history: List[Dict[str, Any]], relevance_scores: Dict[str, float]) -> List[Dict[str, Any]]:
        pruned = []
        for turn in history:
            tid = turn.get("turn_id")
            score = relevance_scores.get(tid, 0.0)
            if score >= 0.3:
                pruned.append(turn)
            else:
                logger.info("Pruned turn %s with relevance score %.2f", tid, score)
        return pruned
    def post_bundle_atomic(self, session_id: str, payload: ContextBundlePayload) -> Dict[str, Any]:
        url = f"{self.base_url}/sessions/{session_id}/context/bundle"
        headers = {
            "Authorization": f"Bearer {self.auth.get_token()}",
            "X-Request-Id": f"bund_{int(time.time())}"
        # Memory allocation check
        footprint = self._calculate_memory_footprint(payload)
        if footprint > 102400:  # 100KB threshold
            raise MemoryError(f"Bundle memory footprint {footprint} exceeds session allocation limit")
        # Format verification and cache eviction
        if session_id in self._cache:
            logger.info("Evicting stale cache for session %s", session_id)
            del self._cache[session_id]
        retries = 0
        while retries <= self.max_retries:
                response = httpx.post(url, json=payload.dict(), headers=headers, timeout=15.0)
                    retry_after = int(response.headers.get("Retry-After", 2))
                    logger.warning("Rate limited. Retrying in %d seconds", retry_after)
                    time.sleep(retry_after)
                    retries += 1
                if e.response.status_code in (401, 403):
                    raise PermissionError(f"Authentication failed: {e.response.status_code}") from e
                if e.response.status_code >= 500:
                    retries += 1
                    time.sleep(2 ** retries)
                raise
        raise RuntimeError("Max retries exceeded for atomic bundle POST")
The post_bundle_atomic method enforces idempotency through request IDs, handles 429 rate limits with exponential backoff, and evicts local cache entries before writing. The Cognigy.AI API returns a bundle_id upon successful compression. You must handle 401 and 403 errors immediately, as they indicate scope misconfiguration or expired tokens.
Step 3: Webhook Synchronization, Metrics Tracking, and Audit Logging
Bundling events must synchronize with external vector stores for alignment. The bundler exposes a webhook trigger, tracks latency and compression success rates, and generates audit logs for memory governance. This step ensures efficient conversational memory during NICE CXone scaling events.
import json
class BundleMetrics:
    def __init__(self):
        self.total_bundles = 0
        self.successful_compressions = 0
        self.total_latency_ms = 0.0
        self.audit_log: List[Dict[str, Any]] = []
    def record_event(self, bundle_id: str, session_id: str, latency_ms: float, success: bool, pruned_count: int):
        self.total_bundles += 1
        self.total_latency_ms += latency_ms
        if success:
            self.successful_compressions += 1
        self.audit_log.append({
            "bundle_id": bundle_id,
            "session_id": session_id,
            "latency_ms": latency_ms,
            "success": success,
            "pruned_turns": pruned_count,
            "governance_tag": "context_window_optimization"
    def get_efficiency_report(self) -> Dict[str, float]:
        avg_latency = self.total_latency_ms / max(self.total_bundles, 1)
        success_rate = self.successful_compressions / max(self.total_bundles, 1)
            "average_latency_ms": round(avg_latency, 2),
            "compression_success_rate": round(success_rate, 3),
            "total_audit_entries": len(self.audit_log)
def trigger_vector_store_webhook(webhook_url: str, bundle_data: Dict[str, Any], auth_token: str) -> None:
    payload = {
        "event": "context_bundle_sync",
        "data": bundle_data
        webhook_url,
        json=payload,
        headers={"Authorization": f"Bearer {auth_token}", "Content-Type": "application/json"},
        timeout=10.0
    logger.info("Vector store webhook synchronized for bundle %s", bundle_data.get("bundle_id"))
The BundleMetrics class maintains stateless tracking of latency and compression rates. The trigger_vector_store_webhook function pushes the compressed bundle to an external vector database for semantic alignment. You must call this function immediately after a successful atomic POST to maintain state consistency across CXone scaling groups.
The following script integrates authentication, payload construction, pruning, atomic posting, webhook synchronization, and metrics tracking. Replace placeholder credentials and identifiers with your organization values.
import logging
import sys
def run_context_bundler():
    # Configuration
    ORG_ID = "your-org-id"
    CLIENT_ID = "your-client-id"
    CLIENT_SECRET = "your-client-secret"
    SESSION_ID = "sess_8f3a9c2b"
    WEBHOOK_URL = "https://your-vector-store.example.com/api/v1/ingest"
    # Initialize components
    auth = CognigyAuthManager(f"https://{ORG_ID}.cognigy.ai", CLIENT_ID, CLIENT_SECRET)
    bundler = ContextBundler(auth, ORG_ID)
    metrics = BundleMetrics()
    # Construct payload
    payload = ContextBundlePayload(
        context_reference=f"ref_{SESSION_ID}",
        window={"start_turn": 0, "end_turn": 20, "max_tokens": 2048, "step_size": 1},
        compress={"strategy": "semantic", "threshold": 0.85, "preserve_entities": True},
        history=[
            {"turn_id": "t_01", "role": "user", "text": "I want to change my plan"},
            {"turn_id": "t_02", "role": "bot", "text": "Which plan would you prefer?"},
            {"turn_id": "t_03", "role": "user", "text": "The enterprise tier"},
            {"turn_id": "t_04", "role": "bot", "text": "Processing upgrade request"}
    # Relevance scoring simulation
    relevance_scores = {"t_01": 0.9, "t_02": 0.4, "t_03": 0.85, "t_04": 0.7}
    payload.history = bundler._prune_history(payload.history, relevance_scores)
    # Session expiration check
    session_check = httpx.get(
        f"https://{ORG_ID}.cognigy.ai/api/v1/sessions/{SESSION_ID}",
        headers={"Authorization": f"Bearer {auth.get_token()}"},
        timeout=5.0
    if session_check.status_code == 404:
        raise RuntimeError("Session expired or invalid. Bundling aborted.")
    session_data = session_check.json()
    if session_data.get("status") == "expired":
        raise RuntimeError("Session has expired. Cannot bundle context.")
    # Execute bundling
    start_time = time.time()
        result = bundler.post_bundle_atomic(SESSION_ID, payload)
        metrics.record_event(
            bundle_id=result["bundle_id"],
            session_id=SESSION_ID,
            latency_ms=latency_ms,
            success=True,
            pruned_count=4 - len(payload.history)
        # Synchronize with vector store
        trigger_vector_store_webhook(WEBHOOK_URL, result, auth.get_token())
        logger.info("Bundle successful. Report: %s", metrics.get_efficiency_report())
        return result
        logger.error("Bundling failed: %s", str(e))
            bundle_id="failed",
            latency_ms=(time.time() - start_time) * 1000,
            success=False,
            pruned_count=0
        raise
        logger.critical("Fatal error in context bundler: %s", e)
        sys.exit(1)
The script validates session status before bundling, calculates memory footprint, prunes turns below the relevance threshold, executes the atomic POST with retry logic, synchronizes the result to a vector store, and records audit metrics. You can expose this module as a FastAPI or Flask endpoint for automated NICE CXone management workflows.
Error: 400 Bad Request (Schema or Token Limit Violation)
  • Cause: The payload exceeds max_tokens, contains invalid compress.strategy values, or violates Pydantic field constraints.
  • Fix: Inspect the Pydantic ValidationError message. Reduce max_tokens or adjust the window.step_size. Ensure strategy matches semantic, turn_aggregation, or entity_merge.
  • Code: The validate_token_budget validator catches this before the HTTP call. Review the estimated_tokens calculation if your NLU engine uses a different tokenization model.
  • Cause: Expired OAuth token, missing scopes (context:write, sessions:read), or incorrect client credentials.
  • Fix: Verify the CognigyAuthManager refresh logic. Check the OAuth response for scope inclusion. Regenerate client secrets if rotated.
  • Code: The post_bundle_atomic method raises PermissionError immediately. Log the Authorization header value (masked) to confirm token propagation.
  • Cause: Rate limit cascade during CXone scaling events or rapid bundle iteration.
  • Fix: Implement exponential backoff. The retry loop in post_bundle_atomic handles this automatically. Adjust max_retries and monitor Retry-After headers.
  • Code: The time.sleep(retry_after) call pauses execution. Increase max_retries to 5 for high-throughput environments.
Error: 502 Bad Gateway or 504 Gateway Timeout
  • Cause: Cognigy.AI backend overload during context window compression or vector store webhook latency.
  • Fix: Retry with exponential backoff. Ensure the webhook endpoint responds within ten seconds. Split large history arrays into smaller windows.
  • Code: The retries loop catches 5xx errors. Add a circuit breaker pattern if failures exceed twenty percent over sixty seconds.
