Implementing Custom CXone Agent Dashboards using WebSocket Streams
This guide details the architectural and implementation steps required to build a real-time, custom agent dashboard for NICE CXone using the WebSocket API. The end result is a low-latency client-side application that receives streaming presence, queue, and interaction data without relying on high-frequency polling, enabling sub-second UI updates for agent status changes and incoming interaction notifications.
  • Licensing Tier: CXone Standard or Premium. The WebSocket API is available across all tiers, but advanced presence metrics (such as detailed wrap-up codes and custom presence states) may require specific feature flags enabled by your CXone administrator.
  • Granular Permissions:
    • User > Read (to resolve user IDs)
    • Presence > Read (to subscribe to presence updates)
    • Interaction > Read (if the dashboard displays incoming interaction metadata)
    • Queue > Read (if the dashboard displays queue statistics)
  • OAuth Scopes: presence:read, interaction:read, queue:read, user:read. You must generate a JWT or use the OAuth2 client credentials flow with these scopes attached to the access token used for the initial WebSocket handshake.
  • External Dependencies: A secure HTTPS endpoint for the dashboard frontend, a backend proxy service (recommended to avoid exposing the CXone API directly to the browser due to CORS and token management complexities), and a CXone tenant with WebSocket access enabled (default in most regions, but verify with your CXone account team if you are on a legacy on-premises hybrid deployment).
1. Architectural Foundation and Authentication Strategy
Building a real-time dashboard requires a shift from request-response thinking to event-driven architecture. The primary challenge is not the WebSocket connection itself, but the secure and efficient delivery of the authentication token required to establish that connection. Browsers cannot safely store long-lived CXone OAuth tokens, and exposing the CXone API directly to the frontend introduces CORS issues and security vulnerabilities.
The Architectural Reasoning: We use a backend proxy pattern. The frontend makes a standard HTTPS request to your internal backend service. The backend service, which holds the secure OAuth token or manages the token refresh cycle, establishes the WebSocket connection with CXone. The backend then bridges the WebSocket messages to the frontend via Server-Sent Events (SSE) or a secondary WebSocket connection. This decouples the CXone API from the browser, allows for token rotation without disrupting the user experience, and provides a single point for message filtering and transformation.
The Trap: Attempting to authenticate the WebSocket connection directly from the browser using a JWT stored in local storage. This fails because CXone’s WebSocket endpoint does not support CORS headers for the initial handshake in the same way REST endpoints do, and more critically, it exposes your tenant’s API credentials to the client. If a user’s token expires, the WebSocket connection drops, and the browser cannot silently refresh it without a backend intermediary.
Implementation Steps:
  1. Generate the Access Token: Use the CXone OAuth2 client credentials flow or JWT grant. Ensure the token includes the presence:read scope.
    POST /v2/oauth/token
    grant_type=client_credentials&scope=presence:read+interaction:read
  2. Establish the Backend WebSocket Connection: Your backend service initiates the connection to the CXone WebSocket endpoint. The endpoint varies by region. For example, the US region uses wss://platform.nice-incontact.com.
    const WebSocket = require('ws');
    const token = 'your_cxone_access_token';
    const ws = new WebSocket('wss://platform.nice-incontact.com/v1/streaming/presence', {
      headers: {
        'Content-Type': 'application/json'
    ws.on('open', () => {
      console.log('WebSocket connection established');
      // Send the subscription payload
      ws.send(JSON.stringify({
        type: 'subscribe',
        payload: {
          presence: {
            userIds: ['user_id_1', 'user_id_2'] // Specific users or null for all accessible
    ws.on('message', (data) => {
      // Process and forward to frontend
      const message = JSON.parse(data);
      handleCxoneMessage(message);
    ws.on('error', (error) => {
      console.error('WebSocket error:', error);
      // Implement reconnection logic with exponential backoff
2. Subscription Payload Construction and Scope Management
The CXone WebSocket API uses a subscription model where you explicitly declare what data streams you want to receive. Sending a blanket subscription for all data is inefficient and can lead to message flooding, especially in large tenants. You must construct a precise subscription payload that requests only the necessary metrics.
The Architectural Reasoning: Granular subscriptions reduce bandwidth consumption and processing overhead on both the CXone platform and your backend service. By specifying userIds in the presence subscription, you ensure that your dashboard only receives updates for the agents it is monitoring. This is critical for performance when scaling to dashboards that monitor hundreds of agents simultaneously.
The Trap: Subscribing to presence updates for all users in the tenant by omitting the userIds array or setting it to null without considering the tenant size. In a large tenant with thousands of agents, this results in a high volume of heartbeat and status update messages, causing latency spikes and potential message queue bottlenecks in your backend service. The CXone platform may also throttle or disconnect the connection if it detects excessive resource usage.
  1. Define the Subscription Scope: Determine which agents or queues your dashboard needs to monitor. If the dashboard is for a specific team, retrieve the user IDs associated with that team’s queues.
  2. Construct the Payload: The payload must conform to the CXone Streaming API schema. For presence, you request updates for specific user IDs.
      "type": "subscribe",
      "payload": {
        "presence": {
          "userIds": ["550e8400-e29b-41d4-a716-446655440000", "6ba7b810-9dad-11d1-80b4-00c04fd430c8"]
  3. Handle Confirmation: CXone will respond with a subscribed message confirming the subscription. Always wait for this confirmation before assuming the data stream is active.
      "type": "subscribed",
      "payload": {
        "presence": {
3. Message Parsing and State Management
Once the subscription is active, CXone streams JSON messages representing state changes. These messages are deltas, not full state snapshots. Your backend service must parse these deltas and maintain a local state cache to provide a complete picture to the frontend.
The Architectural Reasoning: Relying on the frontend to reconstruct state from deltas is error-prone and inefficient. The backend service should act as the source of truth, merging incoming deltas with the cached state. This allows the backend to send only the relevant, aggregated state to the frontend, reducing the payload size and simplifying the frontend logic.
The Trap: Treating every incoming WebSocket message as a full state update and rendering it directly in the frontend. This leads to UI flickering, inconsistent states, and missed updates if messages arrive out of order. The CXone WebSocket API does not guarantee strict ordering of all message types, so your backend must implement sequence number tracking or timestamp-based ordering to ensure state consistency.
  1. Initialize the State Cache: Create an in-memory data structure (e.g., a hash map) to store the current presence state for each monitored user.
    let presenceState = new Map();
  2. Parse Incoming Messages: Handle different message types, such as presence.update. Extract the relevant fields (e.g., status, queueName, wrapUpCode) and update the cache.
    function handleCxoneMessage(message) {
      if (message.type === 'presence.update') {
        const userId = message.payload.userId;
        const status = message.payload.status;
        const queueName = message.payload.queueName;
        // Update the cache
        presenceState.set(userId, { status, queueName, timestamp: Date.now() });
        // Emit the updated state to the frontend
        emitToFrontend(userId, presenceState.get(userId));
  3. Handle Heartbeats and Keep-Alives: CXone sends periodic heartbeat messages to keep the connection alive. Your backend must respond to these heartbeats to prevent the connection from timing out. Failure to respond to heartbeats will result in the CXone platform closing the WebSocket connection.
4. Frontend Integration and Real-Time UI Updates
The frontend dashboard receives updates from the backend service via SSE or a secondary WebSocket. The UI must be designed to handle asynchronous updates gracefully, ensuring that the user interface remains responsive and accurate.
The Architectural Reasoning: Using React, Vue, or Angular with reactive state management (e.g., Redux, Vuex, or Angular Signals) allows the UI to automatically update when the underlying state changes. This eliminates the need for manual DOM manipulation and reduces the risk of UI inconsistencies.
The Trap: Blocking the main UI thread with heavy parsing or rendering logic when processing incoming WebSocket messages. This causes the UI to freeze, leading to a poor user experience. All message processing should be offloaded to Web Workers or handled asynchronously to ensure the UI remains responsive.
  1. Establish the Frontend Connection: Connect to the backend service’s SSE or WebSocket endpoint.
    const eventSource = new EventSource('/api/dashboard/stream');
    eventSource.onmessage = (event) => {
      const data = JSON.parse(event.data);
      updateDashboardState(data);
  2. Update the UI: Use the framework’s state management system to update the dashboard UI based on the incoming data.
    function updateDashboardState(data) {
      // Assuming a React-like state management
      setState(prevState => ({
        ...prevState,
        [data.userId]: data.state
  3. Handle Disconnections: Implement reconnection logic on the frontend to handle temporary network issues or backend restarts. Use exponential backoff to avoid overwhelming the backend service with reconnection attempts.
Edge Case 1: Token Expiration During Active Stream
  • The Failure Condition: The WebSocket connection drops unexpectedly, and subsequent reconnection attempts fail with a 401 Unauthorized error.
  • The Root Cause: The OAuth access token used to establish the WebSocket connection has expired. CXone access tokens typically have a short lifespan (e.g., 1 hour). The WebSocket connection does not automatically refresh the token.
  • The Solution: Implement a token refresh mechanism in your backend service. Before initiating the WebSocket connection, check the token’s expiration time. If the token is close to expiring, refresh it using the OAuth2 refresh token flow or client credentials flow. Store the new token and use it for the next WebSocket connection. Implement a background job to proactively refresh tokens before they expire to avoid dropping active streams.
Edge Case 2: Message Ordering and State Inconsistency
  • The Failure Condition: The dashboard displays an agent as “Available” when they are actually “In Call,” or the status flickers rapidly between states.
  • The Root Cause: WebSocket messages may arrive out of order due to network latency or processing delays in the backend service. If a presence.update message indicating “In Call” arrives after a subsequent “Available” message, the cache will be updated with the incorrect state.
  • The Solution: Implement sequence number tracking. Each CXone WebSocket message includes a sequence number. Your backend service should maintain a sequence counter for each user and only apply updates with a sequence number greater than the last processed one. Discard or queue out-of-order messages for later processing if possible. Alternatively, use timestamp-based ordering, but be aware of clock skew issues between the CXone platform and your backend service.
Edge Case 3: High Volume of Wrap-Up Code Updates
  • The Failure Condition: The backend service becomes overwhelmed with presence update messages when agents complete a high volume of interactions and select wrap-up codes.
  • The Root Cause: Each wrap-up code selection triggers a presence update message. In a high-volume contact center, this can result in thousands of messages per minute, causing memory leaks or CPU spikes in the backend service.
  • The Solution: Implement message filtering and batching on the backend service. Filter out presence updates that do not contain relevant information for the dashboard (e.g., ignore wrap-up code changes if the dashboard only displays high-level status). Batch multiple updates for the same user within a short time window (e.g., 100ms) before emitting them to the frontend. This reduces the number of messages processed and transmitted.
