Implementing Custom Article Ranking for NICE CXone Agent Assist with Python
- A Python service that intercepts knowledge base retrieval, applies a learned-to-rank scoring algorithm, routes sessions through an A/B testing framework, and pushes the reordered results to the NICE CXone Agent Assist API.
- This implementation uses the NICE CXone Agent Assist REST API endpoint
/api/v2/agentassist/sessions/{sessionId}/suggestionsand standard HTTP libraries. - The tutorial covers Python 3.9+ with
requests,numpy, andtyping.
- OAuth 2.0 Client Credentials grant with the
agentassist:writescope assigned to the API key. - NICE CXone API version 2 (
/api/v2/). - Python 3.9 or higher.
- External dependencies:
requests>=2.28.0,numpy>=1.24.0,urllib3>=1.26.0. Install viapip install requests numpy urllib3.
NICE CXone uses standard OAuth 2.0 Client Credentials flow. The authentication client must cache tokens and refresh before expiration to avoid unnecessary network calls. The agentassist:write scope is mandatory for submitting suggestions.
import requests
from typing import Optional
class CXoneAuth:
"""Handles OAuth 2.0 token retrieval and caching for NICE CXone."""
def __init__(self, client_id: str, client_secret: str, region: str = "us-2"):
self.client_id = client_id
self.token_url = f"https://api.{region}.convoacloud.com/oauth/token"
self._expires_at: float = 0.0
self._session = requests.Session()
def get_token(self) -> str:
"""Returns a valid access token. Refreshes automatically if expired."""
if self._token and time.time() < self._expires_at:
return self._token
payload = {
"client_id": self.client_id,
response = self._session.post(self.token_url, data=payload)
response.raise_for_status()
data = response.json()
self._token = data["access_token"]
# Subtract 60 seconds for safe refresh window
self._expires_at = time.time() + data["expires_in"] - 60
return self._token
The token cache uses a 60-second safety buffer before expiration. This prevents race conditions where multiple concurrent requests attempt simultaneous token refreshes.
Step 1: Configure A/B Testing Router and Feedback Collection
A/B testing requires deterministic bucket assignment without external state. Hashing the session ID guarantees consistent routing across service restarts. The feedback collector tracks clicks and dismissals exclusively for treatment groups to prevent data contamination.
import hashlib
from collections import defaultdict
from typing import Dict, List
class ABTestRouter:
"""Deterministic session bucketing and feedback tracking."""
def __init__(self):
# Structure: {session_id: {"clicks": [article_ids], "dismissals": [article_ids], "is_treatment": bool}}
self.feedback_store: Dict[str, Dict] = defaultdict(
lambda: {"clicks": [], "dismissals": [], "is_treatment": False}
def assign_bucket(self, session_id: str) -> bool:
"""Returns True if session belongs to the treatment group (custom ranking)."""
hash_digest = hashlib.sha256(session_id.encode("utf-8")).hexdigest()
hash_value = int(hash_digest, 16)
# 50% treatment, 50% control
return hash_value % 100 >= 50
def record_feedback(self, session_id: str, article_id: str, action: str) -> None:
"""Records agent interaction only for treatment buckets."""
if self.assign_bucket(session_id):
self.feedback_store[session_id]["is_treatment"] = True
if action == "click":
self.feedback_store[session_id]["clicks"].append(article_id)
elif action == "dismiss":
self.feedback_store[session_id]["dismissals"].append(article_id)
The hash modulo operation distributes traffic evenly. Control groups continue to use native CXone relevance scoring, while treatment groups receive the learned-to-rank output.
Step 2: Feature Extraction and Learned-to-Rank Scoring
Listwise ranking outperforms pointwise scoring because it optimizes the entire suggestion list against a global objective function. The feature vector below represents a simplified production model. You will replace the linear weight multiplication with a lightgbm or xgboost model trained on historical click_through_rate and resolution_time labels.
import numpy as np
from dataclasses import dataclass
from typing import List, Tuple
@dataclass
class KnowledgeArticle:
title: str
category: str
last_updated: float
historical_ctr: float
url: str
class LearntToRankScorer:
"""Applies feature weighting to reorder knowledge base articles."""
def __init__(self):
# Production systems load these weights from a trained model file
# Feature order: title_match, category_match, recency_score, historical_ctr
self.feature_weights = np.array([0.35, 0.25, 0.20, 0.20])
def extract_features(self, article: KnowledgeArticle, query: str) -> List[float]:
"""Converts article metadata and query into a numerical feature vector."""
title_match = 1.0 if query.lower() in article.title.lower() else 0.0
category_match = 1.0 if article.category.lower() in query.lower() else 0.0
# Recency decays exponentially: newer articles score higher
days_old = max(0.0, (time.time() - article.last_updated) / 86400.0)
recency_score = np.exp(-0.1 * days_old)
return [title_match, category_match, recency_score, article.historical_ctr]
def score_and_rank(self, articles: List[KnowledgeArticle], query: str) -> List[Tuple[KnowledgeArticle, float]]:
"""Returns articles sorted by descending relevance score."""
scored_articles: List[Tuple[KnowledgeArticle, float]] = []
for article in articles:
features = self.extract_features(article, query)
# Linear combination mimics a trained LTR model output
relevance_score = float(np.dot(features, self.feature_weights))
scored_articles.append((article, relevance_score))
# Sort descending by score
scored_articles.sort(key=lambda x: x[1], reverse=True)
return scored_articles
The extract_features method normalizes inputs to a 0-1 range where applicable. The exponential decay function ensures recently updated articles receive priority without completely discarding evergreen content.
Step 3: Paginated Knowledge Base Retrieval and Ranking
NICE CXone Knowledge API returns results in paginated blocks. The ranking service must fetch all relevant pages, flatten the results, and apply the scoring function before submission. This step demonstrates proper pagination handling and memory-efficient processing.
class KnowledgeRetriever:
"""Simulates paginated CXone Knowledge API retrieval."""
def __init__(self, base_url: str, auth: CXoneAuth):
self.base_url = base_url
self.auth = auth
self.session = requests.Session()
def fetch_all_articles(self, query: str, limit: int = 20) -> List[KnowledgeArticle]:
"""Paginates through CXone Knowledge API and returns flattened results."""
all_articles: List[KnowledgeArticle] = []
offset = 0
headers = {"Authorization": f"Bearer {self.auth.get_token()}"}
while True:
url = f"{self.base_url}/api/v2/knowledge/articles"
params = {"query": query, "limit": limit, "offset": offset}
response = self.session.get(url, params=params, headers=headers)
articles_page = data.get("articles", [])
if not articles_page:
break
for art in articles_page:
all_articles.append(KnowledgeArticle(
id=art["id"],
title=art["title"],
category=art.get("category", "general"),
last_updated=art.get("lastUpdatedDate", time.time()),
historical_ctr=art.get("historicalCtR", 0.0),
url=art.get("url", "")
# Pagination check
if len(articles_page) < limit:
break
offset += limit
return all_articles
The pagination loop terminates when the returned page contains fewer items than the requested limit. This matches the standard CXone API pagination contract.
Step 4: Submit Ranked Suggestions with Retry Logic
The Agent Assist API enforces strict rate limits. The submission client uses urllib3 retry logic with exponential backoff for 429 and 5xx responses. The payload structure must match the CXone suggestion schema exactly.
import requests
from requests.adapters import HTTPAdapter
from urllib3.util.retry import Retry
from typing import List, Tuple, Dict
class CXoneAgentAssistClient:
"""Handles suggestion submission with production-grade retry logic."""
def __init__(self, auth: CXoneAuth, region: str = "us-2"):
self.auth = auth
self.base_url = f"https://api.{region}.convoacloud.com"
# Configure retry strategy for transient failures and rate limits
retry_strategy = Retry(
total=3,
backoff_factor=1.5,
status_forcelist=[429, 500, 502, 503, 504],
allowed_methods=["POST"]
adapter = HTTPAdapter(max_retries=retry_strategy)
self.session.mount("https://", adapter)
def submit_ranked_suggestions(self, session_id: str, ranked_articles: List[Tuple[KnowledgeArticle, float]], max_suggestions: int = 5) -> Dict:
"""Pushes the top N ranked articles to the Agent Assist session."""
url = f"{self.base_url}/api/v2/agentassist/sessions/{session_id}/suggestions"
headers = {
"Authorization": f"Bearer {self.auth.get_token()}",
# Format payload according to CXone Agent Assist schema
suggestions_payload = []
for article, score in ranked_articles[:max_suggestions]:
suggestions_payload.append({
"type": "article",
"content": {
"id": article.id,
"title": article.title,
"url": article.url,
"preview": article.title[:100] + "..." if len(article.title) > 100 else article.title
"score": round(score, 4)
payload = {"suggestions": suggestions_payload}
response = self.session.post(url, json=payload, headers=headers)
return response.json()
The retry strategy applies exponential backoff (1.5s, 2.25s, 3.375s) for 429 responses. The allowed_methods parameter restricts retries to POST operations. The payload truncates preview text to prevent JSON payload size violations.
The following script combines all components into a runnable service. Replace the credential placeholders before execution.
import requests
import numpy as np
import hashlib
from typing import List, Tuple, Dict, Optional
@dataclass
title: str
category: str
last_updated: float
url: str
class CXoneAuth:
return self._token
payload = {"grant_type": "client_credentials", "client_id": self.client_id, "client_secret": self.client_secret}
return self._token
class ABTestRouter:
def __init__(self):
return int(hash_digest, 16) % 100 >= 50
def __init__(self):
self.auth = auth
retry_strategy = Retry(total=3, backoff_factor=1.5, status_forcelist=[429, 500, 502, 503, 504], allowed_methods=["POST"])
self.session.mount("https://", HTTPAdapter(max_retries=retry_strategy))
headers = {"Authorization": f"Bearer {self.auth.get_token()}", "Content-Type": "application/json"}
"type": "article",
"content": {"id": article.id, "title": article.title, "url": article.url, "preview": article.title},
def main():
# Configuration
CLIENT_ID = "YOUR_CLIENT_ID"
CLIENT_SECRET = "YOUR_CLIENT_SECRET"
REGION = "us-2"
SESSION_ID = "agent-session-8821"
QUERY = "billing payment failed"
auth = CXoneAuth(CLIENT_ID, CLIENT_SECRET, REGION)
router = ABTestRouter()
scorer = LearntToRankScorer()
client = CXoneAgentAssistClient(auth, REGION)
# Simulated retrieved articles (replace with actual Knowledge API pagination call)
retrieved_articles = [
KnowledgeArticle("art-001", "Payment Failed Troubleshooting", "billing", time.time() - 86400, 0.75, "https://kb.example.com/art-001"),
KnowledgeArticle("art-002", "General Account Settings", "account", time.time() - 172800, 0.30, "https://kb.example.com/art-002"),
KnowledgeArticle("art-003", "Billing Cycle Updates", "billing", time.time() - 3600, 0.82, "https://kb.example.com/art-003")
is_treatment = router.assign_bucket(SESSION_ID)
print(f"Session {SESSION_ID} assigned to {'Treatment' if is_treatment else 'Control'} group.")
if is_treatment:
ranked = scorer.score_and_rank(retrieved_articles, QUERY)
print("Applying learned-to-rank scoring...")
for article, score in ranked:
print(f" {article.title}: {score:.4f}")
result = client.submit_ranked_suggestions(SESSION_ID, ranked)
print(f"Suggestions submitted successfully. Response: {result}")
print(f"API submission failed: {e.response.status_code} - {e.response.text}")
else:
print("Control group: Skipping custom ranking. Using native CXone relevance.")
main()
- Cause: The OAuth token has expired, the client credentials are incorrect, or the API key lacks the
agentassist:writescope. - Fix: Verify the client ID and secret match the credentials registered in the CXone Admin Portal. Confirm the API key has the
agentassist:writescope assigned. TheCXoneAuthclass automatically refreshes tokens before expiration, but network timeouts during refresh will trigger this error. - Code showing the fix: The
get_tokenmethod already implements TTL-based caching. If you encounter persistent 401 errors, add explicit scope validation during token retrieval by checking theresponse.json()payload for scope grants, or regenerate the API key in the CXone console.
- Cause: The service exceeds CXone rate limits for the Agent Assist endpoint. CXone enforces limits per tenant and per API key.
- Fix: The
HTTPAdapterwithRetryhandles automatic backoff. If retries exhaust, implement a token bucket or leaky bucket rate limiter at the application layer. Batch suggestion submissions to reduce call frequency. - Code showing the fix: The retry strategy in
CXoneAgentAssistClientalready covers this. For high-volume deployments, add a pre-flight check:
class RateLimiter:
def __init__(self, max_calls: int = 10, period: int = 60):
self.max_calls = max_calls
self.period = period
self.calls = []
def acquire(self):
now = time.time()
self.calls = [t for t in self.calls if now - t < self.period]
if len(self.calls) >= self.max_calls:
wait_time = self.period - (now - self.calls[0])
time.sleep(wait_time)
self.calls.append(now)
Error: 400 Bad Request (Invalid Suggestion Payload)
- Cause: The JSON payload structure does not match the CXone Agent Assist schema. Common mistakes include missing
typefields, incorrectcontentnesting, or exceeding the maximum suggestion count per request. - Fix: Validate the payload against the official schema before submission. Ensure
typeis set toarticleandcontentcontainsid,title, andurl. Limit submissions to 5-10 suggestions per call to match UI rendering constraints. - Code showing the fix: The
submit_ranked_suggestionsmethod enforcesmax_suggestions=5and structures the payload exactly as required. Add a validation step before the POST call:
if not payload["suggestions"]:
raise ValueError("Cannot submit empty suggestion list.")
for s in payload["suggestions"]:
if "type" not in s or "content" not in s:
raise ValueError("Invalid suggestion schema.")
