Implementing Context-Aware Knowledge Ranking Using Interaction Metadata for Relevance Boosting
This guide details the architectural pattern for dynamically ranking knowledge base articles by injecting real-time interaction metadata into search queries. You will configure custom attribute mapping, construct weighted API payloads for relevance boosting, and implement a caching layer that delivers context-specific articles to agents and IVR self-service flows within sub-second latency.
  • Licensing Tier: Genesys Cloud CX 3 or CXone Premium (requires Knowledge Base license and Agent Assist add-on)
  • Granular Permissions: Knowledge > Article > Read, Interaction > Interaction > Read, API > API Access > Read/Write, Architect > Flow > Edit, Custom Attributes > Custom Attribute > Read
  • OAuth Scopes: knowledge:article:read, interaction:interaction:read, api:read, api:write, custom:attribute:read
  • External Dependencies: CRM middleware (Salesforce, ServiceNow, or custom ERP), Redis or platform-native cache for payload templating, WEM sentiment scoring pipeline (referenced in cross-platform analytics integration)
1. Metadata Schema Design & Interaction Enrichment
Context-aware ranking fails when interaction data arrives as unstructured text or loosely defined tags. You must normalize interaction metadata into a deterministic schema before it reaches the knowledge search endpoint. The enrichment pipeline operates within the Architect flow immediately after the interaction is routed to a queue or self-service node.
We capture three metadata categories: customer tier, historical resolution path, and channel context. Customer tier maps to contractual SLA levels. Historical resolution path extracts the last three closed ticket categories using the Interaction API. Channel context differentiates between voice, webchat, and email, which dictates article length and formatting preferences.
Configure custom attributes in the platform administration console. Create a namespace ctx.knowledge with the following keys:
  • ctx.knowledge.customer_tier (String: platinum, gold, standard)
  • ctx.knowledge.resolution_category (String: billing, technical, account_management)
  • ctx.knowledge.channel_type (String: voice, chat, email)
Populate these attributes using Architect set nodes. For example, route the interaction through a Set Custom Attributes node that pulls CRM tier data via a REST API call, then assigns the response to ctx.knowledge.customer_tier. We use custom attributes instead of flow variables because custom attributes persist across channel switches and are directly queryable by the Knowledge API without additional transformation.
The Trap: Over-instrumenting the interaction payload by capturing every CRM field or call recording transcript. When you inject 50+ metadata fields into a search payload, the Genesys Knowledge indexing engine experiences query compilation latency that exceeds the 200ms threshold. The platform falls back to lexical matching, which destroys relevance.
Architectural Reasoning: We limit the enrichment schema to three high-signal fields. This constraint forces the engineering team to prioritize metadata that directly impacts business outcomes. The Knowledge search engine processes lightweight payloads in under 50ms, leaving headroom for caching, authentication, and rendering. If you require additional context, aggregate it into a single composite string field rather than expanding the attribute count.
2. Knowledge Base Taxonomy & Boosting Attributes
Your knowledge base must mirror the interaction metadata schema. If the interaction pipeline sends ctx.knowledge.resolution_category, the articles must contain a matching custom field or tag. Genesys Knowledge uses a document-store architecture under the hood. Boosting weights are applied during the query execution phase, not during indexing. Mismatched taxonomy causes the boost parameters to evaluate to zero, resulting in default relevance scoring.
Create a custom field in the Knowledge Admin console named ResolutionCategory with type Text. Populate this field on every article during content ingestion. Do not rely on folder hierarchy for boosting. Folder paths are structural, not semantic. The search engine treats folder paths as opaque strings unless explicitly mapped to a custom field.
Tag articles with secondary metadata using the built-in Tags field. Use tags for channel-specific variations. For example, append :voice or :chat to the tag set to indicate which version of an article is optimized for agent read-aloud versus customer self-service. We separate structural metadata (custom fields) from delivery metadata (tags) because custom fields support numeric and weighted boosting, while tags support boolean filtering.
The Trap: Using folder names as the primary boosting mechanism. Folders in Genesys Knowledge are designed for content management, not search ranking. When you attempt to boost a folder path, the platform performs a string match against the full hierarchy. A single trailing slash or renamed subfolder breaks the boost condition entirely. You will see articles vanish from search results without any error logging.
Architectural Reasoning: We enforce a flat taxonomy with explicit custom fields. This approach decouples content organization from search relevance. Content editors can reorganize folders without impacting the ranking algorithm. The search engine evaluates custom fields using inverted indexes, which provides O(1) lookup performance regardless of knowledge base size. Reference the WFM scheduling integration guide if you need to align article categorization with agent skill groups, as the same custom fields can drive workforce routing decisions.
3. API-Driven Relevance Boosting & Search Payload Construction
The core ranking logic lives in the POST /api/v2/knowledge/articles/search endpoint. We construct the payload dynamically based on the enriched custom attributes. The request body must include the knowledgeBaseId, query string, filter conditions, and boost array. The boost array applies multiplicative weights to matching fields during the scoring phase.
Use the following production-ready payload structure:
  "knowledgeBaseId": "kb-12345",
  "query": "{{customer_search_terms}}",
  "filter": [
      "field": "Status",
      "operator": "EQ",
      "value": "Published"
      "field": "ResolutionCategory",
      "operator": "EQ",
      "value": "{{ctx.knowledge.resolution_category}}"
  "boost": [
      "weight": 3.0
      "field": "Tags",
      "weight": 1.5,
      "matchValue": "{{ctx.knowledge.channel_type}}"
  "limit": 5,
  "offset": 0
The boost array applies a 3.0 multiplier to articles matching the resolution category and a 1.5 multiplier to articles tagged with the current channel type. We normalize weights between 1.0 and 5.0 to prevent score saturation. The platform calculates the final relevance score using a logarithmic decay function. Weights above 5.0 trigger diminishing returns and cause ranking instability when business priorities shift.
Implement this payload in a middleware service or an Architect REST API node. The middleware receives the interaction context, resolves the template variables, and forwards the request to the Knowledge API. We externalize the weight configuration into a JSON file stored in version control rather than hardcoding values in the flow. This allows operations teams to adjust boosting parameters without redeploying Architect flows or restarting services.
The Trap: Hardcoding boost weights directly in the Architect flow or application code. When a product launch changes the priority of certain articles, engineers must redeploy the entire flow. This introduces deployment risk and delays response time. Additionally, hardcoding prevents A/B testing of ranking algorithms.
Architectural Reasoning: We treat boosting weights as configuration data, not logic. The middleware reads the weights at runtime from a centralized config store. If the weights change, the next search request automatically uses the updated values. This pattern aligns with 12-factor application principles and reduces change management overhead. It also enables dynamic weight adjustment based on time of day or campaign periods without touching the routing logic.
4. Agent Assist Delivery & Caching Strategy
Delivering ranked articles to the agent desktop requires a low-latency path. The Knowledge API returns results in under 100ms, but repeated calls per interaction degrade performance and trigger rate limits. We implement a context-hash caching layer using Redis or the platform-native cache. The cache key is constructed by hashing the interaction ID, customer tier, resolution category, and query string.
Generate the cache key using SHA-256:
ctx_hash = sha256(interactionId + customerTier + resolutionCategory + query)
Store the serialized search response with a TTL of 120 seconds. If a subsequent search request matches the hash within the TTL window, return the cached response immediately. We invalidate the cache when the customer context changes or when the interaction transitions to a new queue.
Integrate the cached results with the Agent Assist widget. The widget polls the middleware endpoint every 30 seconds or triggers on manual refresh. We use WebSocket push instead of polling when possible, but polling remains the fallback for legacy desktop configurations. The widget renders the top three articles with expanded metadata, including the matching boost fields to provide transparency on why the system recommended each result.
The Trap: Setting an infinite or excessively long TTL on the cache. Knowledge articles are frequently updated by content teams. A stale cache serves outdated procedures to agents, which increases handle time and escalates to supervisor intervention. Agents lose trust in the recommendation engine when they encounter deprecated troubleshooting steps.
Architectural Reasoning: We enforce a strict 120-second TTL with explicit invalidation triggers. This window balances freshness against API call volume. The invalidation logic hooks into the Architect flow state machine. When the flow transitions from triage to resolution, the cache key changes, forcing a fresh query. This approach ensures agents always see current content while keeping Knowledge API calls under 2 per interaction. Reference the Speech Analytics integration guide if you need to inject sentiment scores into the cache invalidation logic, as negative sentiment triggers immediate cache purge and fresh ranking.
Edge Case 1: Metadata Latency vs. Search Timeout
  • Failure Condition: The search request returns a 408 Request Timeout or falls back to unweighted results. Agent assist displays generic articles.
  • Root Cause: The CRM middleware or custom attribute enrichment node exceeds the 150ms threshold before the Knowledge API call executes. The Architect flow waits synchronously for enrichment, pushing the total request time beyond the platform timeout limit.
  • Solution: Decouple enrichment from the search path. Run the CRM lookup asynchronously and store the result in a temporary flow variable. If the variable is null after 100ms, proceed with a fallback search using default weights. Implement a circuit breaker pattern in the middleware to fail fast when the CRM endpoint degrades. Log the timeout event to the analytics pipeline for capacity planning.
Edge Case 2: Boosting Weight Saturation & Ranking Drift
  • Failure Condition: Top-ranked articles remain identical regardless of query changes. New high-priority articles fail to surface.
  • Root Cause: Boost weights are set too high relative to the base lexical score. When a weight exceeds 5.0, the platform applies logarithmic clipping. All matching articles receive identical boosted scores, collapsing the ranking into a tie-breaker state. The engine defaults to creation date or ID order.
  • Solution: Normalize weights using a Z-score distribution. Calculate the average lexical score across a sample set of 500 queries. Set the base boost to 1.0 and increment by 0.5 increments. Run a regression test against historical interaction logs to validate ranking distribution. Implement a weight decay function that reduces boost values over time unless manually refreshed by content managers.
Edge Case 3: Cross-Channel Session State Loss
  • Failure Condition: Customer switches from webchat to voice. Knowledge recommendations reset to default. Agent must re-enter context manually.
  • Root Cause: The interaction ID changes during channel transfer. The cache key relies on the interaction ID, so the new channel generates a fresh hash. Custom attributes are not propagated across the transfer boundary due to permission scoping or flow misconfiguration.
  • Solution: Use a persistent correlation ID instead of the interaction ID for cache keys. Generate the correlation ID at the first touchpoint and store it in a shared session store. Configure the Architect transfer node to propagate custom attributes using the preserveCustomAttributes flag. Validate attribute persistence by tracing the correlation ID through the WEM event stream. This pattern aligns with the omnichannel routing architecture documented in the platform administration guides.
