Implementing automatic token refresh logic in the Genesys Cloud Python SDK to handle silent authentication for long-running batch analytics jobs
- A production-grade Python script that pulls historical conversation analytics data over multiple days without manual token intervention.
- This implementation uses the Genesys Cloud Python SDK (
genesyscloudv2.x) with automatic refresh token rotation and exponential backoff for rate limits. - The tutorial covers Python 3.9+ with standard library dependencies and the official Genesys Cloud SDK.
- OAuth client type: Machine-to-Machine (Client Credentials) with
offline_accessscope enabled in the Genesys Cloud admin console. - Required scopes:
analytics:query,offline_access - SDK version:
genesyscloud>=2.15.0 - Python runtime: 3.9 or higher
- External dependencies:
genesyscloud,python-dotenv(for credential management)
The Genesys Cloud Python SDK handles silent token refresh automatically when you provide both an access token and a refresh token during configuration. The initial token exchange must include the offline_access scope. The SDK stores the refresh token in memory and uses it to request new access tokens when the current token expires (default TTL: 1 hour).
The following code demonstrates the initial token exchange and SDK configuration. This runs once before the batch job begins.
import os
import json
import httpx
from genesyscloud import Configuration, AnalyticsApi
load_dotenv()
def get_initial_tokens() -> tuple[str, str]:
"""Exchange client credentials for access and refresh tokens."""
url = "https://api.mypurecloud.com/oauth/token"
payload = {
"client_id": os.getenv("GENESYS_CLIENT_ID"),
"client_secret": os.getenv("GENESYS_CLIENT_SECRET"),
"scope": "analytics:query offline_access"
with httpx.Client() as client:
response = client.post(url, headers=headers, data=payload)
response.raise_for_status()
token_data = response.json()
access_token = token_data["access_token"]
refresh_token = token_data["refresh_token"]
return access_token, refresh_token
def initialize_sdk_config() -> Configuration:
"""Configure the Genesys Cloud SDK with automatic refresh support."""
access_token, refresh_token = get_initial_tokens()
config = Configuration()
config.host = "https://api.mypurecloud.com"
config.set_access_token(access_token)
config.set_refresh_token(refresh_token)
# Persist refresh token to disk for job restarts
token_cache = {"refresh_token": refresh_token}
with open("token_cache.json", "w") as f:
json.dump(token_cache, f)
return config
The SDK intercepts outgoing requests, checks token expiration, and performs a silent POST /oauth/token call with grant_type=refresh_token when needed. No application code changes are required after initialization.
Step 1: Configure Retry Logic for 401 and 429 Responses
Long-running batch jobs frequently encounter transient 401 errors (token expiry mid-request) and 429 errors (analytics API rate limits). The SDK does not automatically retry 429 responses. You must implement a retry wrapper that catches genesyscloud.rest.ApiException, applies exponential backoff, and respects Retry-After headers.
import random
def retry_on_auth_or_rate_limit(max_retries: int = 5, base_delay: float = 1.0):
"""Decorator that retries API calls on 401 or 429 status codes."""
def decorator(func):
def wrapper(*args, **kwargs):
attempt = 0
while attempt < max_retries:
return func(*args, **kwargs)
except ApiException as e:
if e.status == 429:
# Extract Retry-After header if present
retry_after = int(e.headers.get("Retry-After", base_delay * (2 ** attempt)))
wait_time = max(retry_after, base_delay * (2 ** attempt) + random.uniform(0, 1))
print(f"Rate limited (429). Retrying in {wait_time:.2f}s (attempt {attempt + 1})")
time.sleep(wait_time)
attempt += 1
elif e.status == 401:
# Token expired mid-request. Force SDK to refresh and retry once.
print("Access token expired (401). Triggering silent refresh...")
attempt += 1
if attempt == max_retries:
raise RuntimeError("Max retries reached on 401. Refresh token may be invalid.")
else:
raise
raise RuntimeError(f"Operation failed after {max_retries} retries.")
return wrapper
return decorator
This decorator applies to any SDK method that queries the analytics endpoint. It ensures the job continues without manual intervention when rate limits or token boundaries are crossed.
Step 2: Execute Batch Analytics Query with Pagination
The /api/v2/analytics/conversations/details/query endpoint returns conversation details in pages. The response includes a next_page_uri when additional data exists. You must loop through pages until next_page_uri is null.
Below is the exact HTTP request/response cycle that the SDK translates. This mapping is critical for debugging proxy configurations and firewall rules.
POST /api/v2/analytics/conversations/details/query HTTP/1.1
Host: api.mypurecloud.com
Authorization: Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9...
Accept: application/json
"query": {
"dateRange": {
"from": "2024-01-01T00:00:00.000Z",
"to": "2024-01-02T00:00:00.000Z"
"filters": {
"type": "AND",
"clauses": [
"type": "EQ",
"field": "conversation.type",
"values": ["voice"]
"groupBy": ["conversation.type"],
"size": 100
HTTP/1.1 200 OK
"total": 2450,
"count": 100,
"nextPageUri": "/api/v2/analytics/conversations/details/query?cursor=eyJwYWdlIjoyfQ==",
"entities": [
"id": "conv-uuid-1",
"type": "voice",
"wrapUpCode": {
"id": "wrap-uuid",
"name": "Call Resolved"
"queue": {
"id": "queue-uuid",
"name": "Sales Support"
"duration": 142.5
The SDK method post_analytics_conversations_details_query sends this exact payload. You must parse next_page_uri and continue fetching until pagination completes.
from genesyscloud.analytics import AnalyticsApi
from genesyscloud.analytics.models import AnalyticsConversationDetailsQueryRequest
@retry_on_auth_or_rate_limit(max_retries=5)
def fetch_analytics_page(api_client: AnalyticsApi, query_body: dict, page_uri: str | None = None) -> dict:
"""Fetch a single page of analytics data."""
if page_uri:
# SDK supports direct URI pagination via the underlying ApiClient
# We use the raw request method for cursor-based pagination
response = api_client.api_client.call_api(
resource_path=page_uri,
method="GET",
header_params={"Authorization": f"Bearer {api_client.configuration.access_token}"},
response_type="dict"
return response
else:
request_obj = AnalyticsConversationDetailsQueryRequest.from_dict(query_body)
response = api_client.post_analytics_conversations_details_query(body=request_obj)
return response.to_dict()
Step 3: Process Results and Handle Long-Running Execution
Batch jobs must stream results to avoid memory exhaustion. The following loop processes pages, writes records to a CSV file, and respects pagination boundaries. It also implements a checkpoint mechanism to survive process crashes.
import csv
def run_batch_analytics_job(config: Configuration, output_file: str = "analytics_export.csv"):
api_client = AnalyticsApi(configuration=config)
query_body = {
"query": {
"dateRange": {
"to": "2024-01-31T23:59:59.999Z"
"filters": {
"type": "AND",
"clauses": [
{"type": "EQ", "field": "conversation.type", "values": ["voice"]}
"size": 200
page_uri = None
total_records = 0
with open(output_file, "w", newline="", encoding="utf-8") as csvfile:
writer = csv.writer(csvfile)
writer.writerow(["id", "type", "queue_name", "duration_seconds", "wrap_up_code"])
while True:
print(f"Fetching page at {datetime.now(timezone.utc).isoformat()}...")
response = fetch_analytics_page(api_client, query_body, page_uri)
entities = response.get("entities", [])
if not entities:
print("No more entities returned. Job complete.")
break
for entity in entities:
writer.writerow([
entity.get("id", ""),
entity.get("type", ""),
entity.get("queue", {}).get("name", ""),
entity.get("duration", 0),
entity.get("wrapUpCode", {}).get("name", "")
total_records += 1
page_uri = response.get("nextPageUri")
if not page_uri:
print("Pagination complete.")
break
# Brief pause to respect rate limits between pages
time.sleep(0.5)
print(f"Job finished. Exported {total_records} records to {output_file}")
The following script combines authentication, retry logic, pagination, and result streaming into a single production-ready module. Replace the environment variables with your Genesys Cloud credentials before execution.
import os
import json
import csv
import random
import httpx
load_dotenv()
payload = {
return token_data["access_token"], token_data["refresh_token"]
attempt = 0
if e.status == 429:
attempt += 1
attempt += 1
else:
raise
return wrapper
return decorator
if page_uri:
method="GET",
return response
else:
def run_batch_analytics_job():
# Load cached refresh token if available
if os.path.exists("token_cache.json"):
with open("token_cache.json", "r") as f:
cache = json.load(f)
config.set_refresh_token(cache["refresh_token"])
config.set_access_token("") # Empty access token forces immediate refresh on first call
else:
json.dump({"refresh_token": refresh_token}, f)
query_body = {
"query": {
"dateRange": {
"filters": {
"type": "AND",
"clauses": [
"size": 200
page_uri = None
total_records = 0
output_file = "analytics_export.csv"
while True:
if not entities:
break
writer.writerow([
total_records += 1
if not page_uri:
break
time.sleep(0.5)
Error: 401 Unauthorized (Refresh Token Expired)
- Cause: The refresh token itself expired (default TTL: 10 days for client credentials) or was revoked in the Genesys Cloud admin console.
- Fix: Delete
token_cache.json, regenerate tokens usingget_initial_tokens(), and restart the job. Ensure the OAuth client hasoffline_accessenabled. - Code showing the fix:
os.remove("token_cache.json")
Error: 429 Too Many Requests (Analytics Rate Limit)
- Cause: The analytics API enforces a strict request quota per organization. Batch jobs that fetch pages too quickly trigger throttling.
- Fix: Implement exponential backoff with jitter. Read the
Retry-Afterheader and wait at least that duration before resuming. - Code showing the fix: Already implemented in
retry_on_auth_or_rate_limit. The decorator parsesRetry-Afterand appliesbase_delay * (2 ** attempt) + random.uniform(0, 1).
Error: 500 Internal Server Error (Query Timeout)
- Cause: The date range is too large or the filter complexity exceeds the analytics engine timeout threshold.
- Fix: Split the date range into smaller chunks (e.g., 7-day intervals). Increase the
sizeparameter cautiously but keep it under 200 to reduce payload parsing time. - Code showing the fix:
# Split date range into weekly chunks
from datetime import timedelta
start = datetime(2024, 1, 1, tzinfo=timezone.utc)
end = datetime(2024, 1, 31, tzinfo=timezone.utc)
current = start
while current < end:
chunk_end = min(current + timedelta(days=7), end)
query_body["query"]["dateRange"]["from"] = current.isoformat()
query_body["query"]["dateRange"]["to"] = chunk_end.isoformat()
# Run fetch loop for this chunk
current = chunk_end
