Implementing Automated QA Scorecards using Custom LLM Evaluations
This guide details the architecture and implementation of an automated Quality Assurance pipeline that ingests contact center transcripts, routes them through a custom Large Language Model evaluation endpoint, and writes structured scores directly into the platform QA system. When complete, your organization will have a fully programmatic QA workflow that generates consistent, rubric-driven scorecards without manual agent review.
- Licensing Tiers: Genesys Cloud CX 2 (or CX 3) with the AI Assistant add-on, plus the Genesys Cloud Quality (QA) module. For NICE CXone deployments, you require CXone 360 with CXone Analytics and CXone Quality.
- Permission Strings:
Quality > Evaluate > Edit,Quality > Scorecard > Edit,Integrations > API > Create,Telephony > Recording > Access,Architect > Flow > Edit. - OAuth Scopes:
quality:evaluate:write,quality:scorecard:read,interaction:read,recording:read,transcript:read. - External Dependencies: Access to a hosted LLM inference endpoint (AWS Bedrock, Azure OpenAI, or self-hosted vLLM), object storage for transcript archival, and a serverless orchestrator (AWS Lambda, Azure Functions, or Genesys Cloud Architect webhook flow). You also require a dedicated QA scorecard template with numeric scoring sections.
1. Architecting the Transcript Ingestion & Routing Pipeline
The foundation of automated QA is reliable transcript acquisition. You must decouple transcription completion from evaluation execution to prevent pipeline backpressure. The platform generates transcription events asynchronously. You will configure a webhook listener that triggers only when transcript status transitions to COMPLETE. This guarantees that the LLM receives a finalized dialogue structure rather than a partial stream.
Configure the webhook to filter on transcriptionStatus and exclude DRAFT or PROCESSING states. The payload will contain the interactionId, transcriptId, and media metadata. Your middleware must validate the interaction type (voice, digital, or callback) and route accordingly. Voice interactions require ASR confidence filtering, while digital interactions already contain structured text.
The Trap: Polling the transcription API synchronously or processing transcripts before the platform finalizes speaker diarization. When you ingest partial transcripts, the LLM receives truncated customer statements and agent responses. This causes hallucinated compliance violations, inflated sentiment scores, and wasted inference budget. The platform continues to append transcript segments for up to 90 seconds after call disconnect to resolve overlapping speech.
Architectural Reasoning: Event-driven ingestion via webhook guarantees state consistency. We place a message queue (SQS, RabbitMQ, or platform-native queue) between the webhook and the LLM invocation layer. This queue absorbs traffic spikes during peak call volumes and allows you to implement dead-letter routing for malformed transcripts. We also attach an idempotency key derived from the interactionId to prevent duplicate evaluations if the webhook fires multiple times due to network retries.
2. Designing the LLM Evaluation Rubric & Prompt Contract
The LLM does not understand platform QA nomenclature. You must translate your operational scorecard into a deterministic prompt contract. The prompt must enforce strict JSON output, specify exact scoring ranges, and require evidence extraction for every scored item. Free-form evaluation output breaks downstream parsing and introduces score drift across model versions.
Construct a system prompt that defines the evaluator role, the rubric sections, and the scoring scale. Bind the prompt to a JSON Schema validator at the API gateway level. The schema must match your QA scorecard structure exactly. Below is a production-ready prompt template and the corresponding JSON schema constraint.
"system_prompt": "You are a Quality Assurance evaluator for a contact center. Evaluate the provided transcript against the following rubric. Return ONLY valid JSON. Do not include markdown formatting. Score each item on a scale of 0 to 5. Provide a direct quote as evidence for every score. If evidence is missing, score 0.",
"rubric": {
"greeting": "Agent verifies customer identity and states full name.",
"active_listening": "Agent paraphrases customer issue before proposing resolution.",
"compliance": "Agent reads mandatory disclosure script verbatim.",
"resolution": "Agent confirms customer satisfaction before closing."
"json_schema": {
"type": "object",
"properties": {
"greeting": { "type": "object", "properties": { "score": { "type": "integer", "minimum": 0, "maximum": 5 }, "evidence": { "type": "string" } } },
"active_listening": { "type": "object", "properties": { "score": { "type": "integer", "minimum": 0, "maximum": 5 }, "evidence": { "type": "string" } } },
"compliance": { "type": "object", "properties": { "score": { "type": "integer", "minimum": 0, "maximum": 5 }, "evidence": { "type": "string" } } },
"resolution": { "type": "object", "properties": { "score": { "type": "integer", "minimum": 0, "maximum": 5 }, "evidence": { "type": "string" } } }
"required": ["greeting", "active_listening", "compliance", "resolution"],
"additionalProperties": false
The Trap: Relying on temperature values above 0.0 for scoring, or omitting the additionalProperties: false constraint in the JSON schema. A temperature of 0.2 introduces lexical variation in field names and score formatting. The QA API will reject payloads with unexpected keys, and score normalization logic will fail when integers arrive as strings.
Architectural Reasoning: Deterministic evaluation requires strict schema enforcement, temperature set to 0, and explicit rubric definitions with evidence extraction. We use JSON Schema validation at the API layer to reject malformed responses before scoring. This prevents corrupted data from entering the QA database. We also implement a fallback scoring routine that assigns a neutral score and flags the interaction for manual review when the LLM fails schema validation three times.
3. Implementing the Scoring API & QA Scorecard Mapping
Once the LLM returns a validated JSON payload, you must map it to the platform QA scorecard structure. The QA engine enforces strict section weighting, point allocation, and evaluator attribution. You cannot write raw LLM scores directly into the evaluation record. You must normalize the scores, attach the evidence as comments, and reference the correct scorecard version.
Use the platform QA API to create the evaluation. The payload must include the interactionId, scorecardId, evaluatorId (typically a system service account), and an array of sections containing items. Each item requires the id matching the scorecard question, the normalized score, and the comment field populated with the LLM evidence.
POST /api/v2/quality/evaluations
"interactionId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"scorecardId": "sc-qa-rubric-v2",
"evaluatorId": "svc-qa-automation",
"date": "2024-06-15T14:30:00Z",
"sections": [
"id": "sec-01",
"items": [
"id": "q-greeting",
"score": 4,
"comment": "Evidence: Agent stated full name but skipped identity verification step. Quote: 'Hi, this is Marcus. How can I help?'"
"id": "q-active-listening",
"score": 5,
"comment": "Evidence: Agent paraphrased billing dispute accurately. Quote: 'So you are seeing an unexpected charge from the March renewal, correct?'"
"id": "q-compliance",
"score": 5,
"comment": "Evidence: Mandatory disclosure read verbatim. Quote: 'Please be advised this call may be recorded for quality assurance purposes.'"
"id": "q-resolution",
"score": 3,
"comment": "Evidence: Agent confirmed resolution but did not ask for satisfaction rating. Quote: 'I have processed the refund. Is there anything else?'"
The Trap: Mapping LLM scores directly to platform scorecard sections without normalization or threshold rounding. The QA engine calculates weighted averages based on section configuration. If your LLM returns a 4.2 and the scorecard expects integers, the API returns a 400 validation error. Additionally, writing evidence directly into the comment field without length truncation causes database truncation and audit log corruption.
Architectural Reasoning: The QA engine enforces strict section weighting and point allocation. We implement a normalization layer that converts LLM confidence scores into platform-compatible point values using floor rounding. We preserve audit trails by storing the raw LLM JSON in an external document store and writing only the truncated evidence and normalized score into the QA comment field. This maintains API compatibility while preserving full evaluation context for compliance audits.
4. Orchestrating the End-to-End Automation Flow
The final layer ties ingestion, evaluation, and scoring into a resilient execution pipeline. You will deploy a serverless function that consumes the transcript queue, invokes the LLM, validates the response, and submits the QA evaluation. The function must handle rate limiting, implement exponential backoff, and log evaluation metadata for observability.
Configure the orchestrator to batch transcript processing during off-peak hours if your LLM provider enforces strict token quotas. Use platform-specific routing rules to exclude internal test calls, supervisor coaching sessions, and abandoned interactions. Tag evaluations with automated metadata to filter them from manual QA reporting views.
The Trap: Synchronous blocking of the ingestion pipeline during LLM inference timeouts. When the LLM provider experiences latency spikes, the message queue accumulates unprocessed messages. If your function lacks timeout configuration or retry logic, the pipeline stalls and evaluations fall behind real-time requirements.
Architectural Reasoning: Asynchronous queue-based processing with retry logic and dead-letter queues ensures pipeline resilience. We configure a maximum retry count of three with exponential backoff (5s, 30s, 120s). Failed evaluations route to a dead-letter queue where a daily reconciliation job attempts reprocessing. We also implement idempotency keys to prevent duplicate evaluations if the function retries after a transient network failure. This architecture guarantees exactly-once evaluation semantics under production load.
Edge Case 1: Transcript Redaction Mismatches
- The failure condition: The LLM returns compliance violations for redacted PII segments, or assigns zero scores to sections where customer data was masked.
- The root cause: Platform-native PII redaction replaces sensitive tokens with
[REDACTED]placeholders before transcript completion. The LLM interprets these placeholders as missing information and penalizes the agent for gaps in dialogue. - The solution: Inject a preprocessing step that replaces
[REDACTED]with a neutral context token like[CUSTOMER_DATA]before LLM ingestion. Update the system prompt to explicitly instruct the model to ignore redaction tokens during scoring. Validate the transcript against a redaction whitelist to ensure mandatory compliance scripts remain unmasked.
Edge Case 2: Scorecard Version Drift
- The failure condition: The QA API returns
404 Not Foundor422 Unprocessable Entitywhen submitting evaluations. - The root cause: The QA scorecard template was updated by an administrator, changing section IDs or question IDs. The LLM prompt and API payload still reference the deprecated schema.
- The solution: Implement a schema registry that versions the LLM prompt alongside the QA scorecard. Trigger a webhook on scorecard modification that invalidates the current prompt cache and deploys an updated prompt contract. Add a pre-submission validation step that queries the scorecard definition API and verifies field parity before sending the evaluation payload.
Edge Case 3: LLM Refusal and Content Filtering
- The failure condition: The LLM returns a safety refusal message instead of a JSON scorecard, causing the orchestrator to crash or drop the evaluation.
- The root cause: Customer transcripts contain profanity, threats, or sensitive medical/financial language. The LLM provider safety filters intercept the prompt and block evaluation.
- The solution: Route transcripts through a content classification filter before LLM ingestion. If the classification score exceeds a risk threshold, bypass the LLM and assign a default neutral score with a
FLAG_REVIEWtag. Configure the LLM provider to disable content filtering for enterprise workloads where compliance requires full transcript analysis. Document the bypass logic in your data processing agreement to maintain regulatory compliance.
