Implementing Automated Knowledge Gap Analysis using Unresolved Interaction Topic Clustering
This guide details the configuration of an automated workflow to identify knowledge base deficiencies by analyzing unresolved customer interactions. You will configure topic clustering algorithms to group failed interactions and cross-reference these topics against existing knowledge base articles. The end result is a recurring report or API-driven alert that flags specific intents where customers receive no resolution, enabling proactive content creation.
Before implementing this architecture, verify the following environment requirements. Failure to meet these prerequisites will prevent the clustering engine from accessing necessary interaction data.
Licensing Tiers
- Genesys Cloud CX: Full license is required for standard analytics.
- Genesys Cloud Intelligence: Required for AI-driven Topic Clustering and Knowledge Gap Analysis features.
- Knowledge Management Module: License must include the ability to edit articles and view gap analysis reports.
Granular Permissions
The user account executing this configuration requires the following permission sets:
Analytics > Reports > View(To access clustering data)Analytics > Reports > Edit(To create custom reports for gap analysis)Knowledge > Articles > Edit(To validate article existence during automation)Flow > Flows > Edit(To implement the alerting workflow)
OAuth Scopes (API-Driven Automation)
If using the API to push findings to an external ticketing system, the following scopes are required:
analytics:interactions:readknowledge:articles:readintegration:webhooks:write
External Dependencies
- Knowledge Base: At least one KB instance configured and populated.
- Ticketing System: ServiceNow, Jira, or Zendesk API endpoint for automated gap notification (optional but recommended).
- Flow Designer: Available in the Genesys Cloud environment.
1. Configuring Unresolved Interaction Definitions
The foundation of this architecture is accurately defining what constitutes an “unresolved” interaction. Standard resolution metrics often fail because they rely on supervisor disposition codes, which are frequently left blank or misapplied by agents.
Navigate to Analytics > Workflows within the Genesys Cloud Admin interface. Create a new definition for unresolved interactions based on explicit customer signals rather than agent disposition. Configure the following parameters:
- Interaction Type:
VoiceandChat. - Duration Filter: Exclude interactions under 30 seconds to remove accidental dials or system errors that do not represent genuine knowledge gaps.
- End State: Select
Transfer to another queueORDroppedORCustomer hangup before resolution. - Topic Tagging: Ensure the “Auto-tagging” setting is enabled for this definition.
The Trap
Do not rely on the default Disposition Code field for unresolved status. Agents frequently mark interactions as “Resolved” even when they transfer the customer to another department because they lack the answer. This creates a false sense of security and hides knowledge gaps. If you configure your baseline on disposition codes, your gap analysis will be blind to transfers that occur due to missing information. Always prioritize interaction termination states (hangups, drops) over agent-reported outcomes for this specific use case.
Architectural Reasoning
You are filtering for intent failure rather than process compliance. By using end-state logic, you capture the moment the system failed the customer. This data is then fed into the clustering engine to identify patterns in failure.
2. Enabling AI-Driven Topic Clustering
Once the interaction definition is established, you must enable the clustering engine to group these interactions by semantic intent. Genesys Cloud utilizes natural language processing (NLP) to identify similar queries across thousands of contacts.
Navigate to Analytics > Topics and select the definition created in Step 1. Enable Topic Clustering. Configure the clustering parameters as follows:
- Clustering Model: Use the latest available NLP model version for highest accuracy on domain-specific terminology.
- Minimum Volume: Set a threshold of 20 interactions per cluster to ensure statistical significance before surfacing gaps.
- Confidence Score: Filter results to show only clusters with a confidence score greater than 0.85.
The Trap
Avoid setting the minimum volume too low (e.g., 5 interactions). Low-volume clusters often represent noise or outlier events rather than systemic knowledge gaps. Surfacing these leads to “alert fatigue” where stakeholders ignore notifications because they frequently contain false positives. Conversely, setting the threshold too high (e.g., 100 interactions) delays the detection of emerging issues during product launches. A balance of 20 interactions typically balances sensitivity with signal-to-noise ratio.
Clustering reduces the cognitive load on analysts. Instead of reviewing individual transcripts, you review a list of high-frequency intents that correlate with failure states. The NLP model compares query semantics against historical data to group similar questions, regardless of the exact phrasing used by the customer. This allows you to identify gaps where customers ask “How do I reset my password?” and “I forgot my login credentials” in the same cluster.
3. Mapping Clusters to Knowledge Base Articles
The core value of this implementation lies in comparing the identified clusters against your existing knowledge base. You must automate the validation process that checks if an article exists for a specific topic.
In Knowledge Management, navigate to the Gap Analysis tab. Select the Topic ID generated from Step 2. Map the cluster name to the Knowledge Base categories. The system will attempt to match the topic intent against existing article titles, keywords, and metadata.
For a programmatic approach, use the following API logic to validate article existence:
POST https://aws-usw2-01.cloud.genesys.cloud/interaction/v1/topics/search
"topicId": "TOPIC_ID_FROM_CLUSTERING",
"limit": 50,
"queryType": "MATCHES_INTENT"
Response handling requires checking the matchedArticles array in the JSON payload. If the length of this array is zero or if the matched articles have a status of Draft rather than Published, the topic represents a confirmed knowledge gap.
The Trap
Do not assume that an article title containing the topic keyword equates to a relevant solution. A common failure mode occurs when a Knowledge Base administrator creates an article titled “Password Reset” but the content only covers how to reset, not why it failed or what to do if the user is locked out. The clustering engine identifies the intent “Locked Out,” but the search logic finds the article “Password Reset.” This results in a false negative where the system claims coverage exists when the customer still cannot resolve their issue. Always validate the semantic match of the article content, not just the title metadata.
Semantic matching is required because keywords are insufficient. You must compare the intent vector of the cluster against the intent vector of the knowledge base articles. This ensures that even if an article exists, it addresses the specific failure mode identified in the clustering data.
4. Automating the Gap Notification Workflow
To operationalize this analysis, you must move beyond manual report generation. Use Flow Designer to create a scheduled automation that triggers when a gap is detected.
Step A: Schedule Trigger
Create a Scheduled Flow that runs daily at 06:00 UTC. This ensures analysts have the data first thing in their workday.
Step B: Logic Check
Inside the flow, add a condition to check the result of the Knowledge Gap API call performed in Step 3. If matchedArticles.length is less than 1 for any cluster with volume > 20, proceed to notification.
Step C: Notification Payload
Configure the Flow to invoke an external webhook or create a task within your ticketing system. Use the following JSON payload structure for the integration:
"action": "create_ticket",
"priority": "High",
"subject": "Knowledge Gap Identified: [Topic_Name]",
"description": "Cluster ID: [Cluster_ID] | Volume: [Volume_Count] | Failed Interactions: [Failed_Count]",
"metadata": {
"platform": "Genesys_Cloud_CX",
"source": "Analytics_Gap_Analysis"
The Trap
Do not configure the flow to trigger on every single interaction. This will result in API rate limiting errors and system timeouts. The scheduling logic must aggregate results over a defined period (e.g., daily or weekly) before sending a notification. Sending an alert for every detected gap in real-time floods the ticketing system and causes stakeholders to lose visibility into critical issues due to volume overload.
Aggregation reduces noise and allows for trend analysis. By grouping gaps daily, you can identify if a specific topic is persistently unresolved across multiple days, indicating a systemic failure rather than a temporary spike in queries. This prioritization helps content teams focus on high-volume, persistent issues first.
Edge Case 1: New Product Launch Noise
During a new product launch, interaction volume spikes dramatically, and the clustering algorithm may group disparate intents together because there is insufficient historical data to distinguish them. This can lead to a single massive cluster that obscures specific knowledge gaps.
The Failure Condition
Analysts receive one large notification titled “New Product Issues” containing 500 interactions, making it impossible to identify which specific feature lacks documentation.
The Root Cause
The NLP model relies on historical interaction patterns to distinguish intents. Without sufficient prior data for the new product, the model defaults to broad categorization based on shared vocabulary.
The Solution
Implement a “Learning Period” flag in your Flow logic. For any topic ID associated with a product launch date within the last 14 days, suppress automated gap alerts and instead route the raw interaction list to a manual review queue. Once the learning period passes, resume automated clustering. This prevents the system from misinterpreting initial confusion as a permanent knowledge gap before the data stabilizes.
Edge Case 2: Multilingual Clustering Drift
If your contact center supports multiple languages, the clustering engine may fail to merge identical intents expressed in different languages, or conversely, incorrectly merge distinct intents that share translation keywords.
A customer asks “How do I change my email?” in English and “¿Cómo cambio mi correo?” in Spanish. The system creates two separate clusters, doubling the alert volume for the same underlying knowledge gap. Alternatively, the word “account” is translated as “cuenta” (Spanish) but sometimes implies “bank account” in financial contexts, leading to false merges with banking topics.
The Root Cause
The default clustering model may treat language variants as separate intents or fail to align semantic meaning across language boundaries without specific tuning.
The Solution
Configure the Language Model Settings in the Analytics configuration to enable cross-language intent alignment if available in your license tier. If not, you must create separate unresolved interaction definitions for each supported language (e.g., Unresolved_EN, Unresolved_ES). Then, in the automation flow, normalize the topic names before sending them to the ticketing system so that “How do I change my email” and “¿Cómo cambio mi correo?” are grouped under a single ticket ID for content creation.
Edge Case 3: API Rate Limiting on High Volume
When interaction volumes exceed 100,000 daily, the Knowledge Gap Analysis API may hit rate limits during the scheduled Flow execution.
The Flow fails with HTTP 429 Too Many Requests errors, and no tickets are generated for several days until the limit resets.
The Root Cause
The scheduled flow attempts to query all clusters simultaneously in a single request burst.
The Solution
Implement pagination and exponential backoff logic within the Flow. Do not send all requests at once. Split the cluster list into batches of 50 and add a delay between batch processing. Update the API call payload to include offset and limit parameters to manage throughput gracefully. This ensures data integrity even during peak traffic periods.
