Implementing Automated Knowledge Article Expiry and Archive Workflows Based on Age Policies
This guide details the architecture and implementation of a scheduled automation that evaluates published knowledge articles against configurable age thresholds and transitions expired articles to the Archived state. Upon completion, you will have a production-ready orchestration pipeline that queries the Knowledge API, applies business rules to article metadata, executes batch status transitions with optimistic concurrency control, and maintains revision integrity without disrupting agent assist or customer self-service search.
  • Licensing Tier: Genesys Cloud CX 1 or higher with the Knowledge module enabled. NICE CXone requires the Content Management add-on with Lifecycle Management entitlements.
  • Granular Permissions: knowledge:article:read, knowledge:article:write, knowledge:space:read, knowledge:space:write, knowledge:revision:read.
  • OAuth Scopes: knowledge:article:read, knowledge:article:write, knowledge:space:read.
  • External Dependencies: A scheduled execution environment capable of HTTP/2.0 and retry logic. Enterprise deployments typically use Azure Functions, AWS Step Functions, or a dedicated middleware platform. Genesys Cloud Architect flows with Scheduled Triggers are acceptable for small-scale implementations but lack native bulk pagination handling and execution time limits that cause failures at scale.
  • Network Requirements: Outbound HTTPS traffic to api.mypurecloud.com (or your region-specific endpoint) on port 443. If operating behind a corporate proxy, ensure the orchestrator supports proxy authentication and TLS 1.2+.
1. Query Strategy and Metadata Filtering
The foundation of any age-based expiry workflow is a deterministic query that isolates articles eligible for archival. The Knowledge API does not provide a native createdBefore or publishedBefore filter parameter. You must retrieve articles and evaluate their timestamps client-side. The recommended approach uses the /api/v2/knowledge/articles endpoint with explicit pagination and status filtering.
API Request Configuration
GET /api/v2/knowledge/articles?status=Published&pageSize=200&expand=metadata HTTP/1.1
Host: api.mypurecloud.com
Accept: application/json
The response payload includes the publishedDate field, which represents the authoritative release timestamp. You must compare this field against your expiry policy threshold. A standard threshold is 90 days, but healthcare and financial verticals often enforce 180-day or 365-day retention windows based on compliance requirements.
Client-Side Evaluation Logic
  "title": "PCI-DSS Payment Processing Guidelines",
  "status": "Published",
  "publishedDate": "2023-06-15T14:30:00.000Z",
  "lastModified": "2024-01-10T09:15:00.000Z",
  "revision": 4,
  "spaceId": "space-12345",
  "metadata": {
    "expiryPolicy": "standard",
    "ownerId": "user-67890"
You calculate the age by subtracting publishedDate from the current UTC timestamp. If the difference exceeds the configured threshold, the article enters the archival queue. You must store the id, revision, and spaceId for each candidate. Never rely on lastModified for age calculations.
The Trap
Relying on lastModified instead of publishedDate causes articles to reset their age clock on every minor editorial change. A subject matter expert updates a single paragraph, and the article survives another full retention cycle. This defeats the purpose of the expiry policy and creates compliance audit failures. Additionally, failing to implement server-side pagination tracking causes the orchestrator to drop articles after the first 200 results when the knowledge base exceeds the default page size.
Architectural Reasoning
We use publishedDate because it represents the business release event, not the editorial history. Knowledge bases operate on a revision model where minor updates do not change the publication lifecycle. Pagination must be handled by tracking the nextPage token returned in the paging object. Each subsequent request replaces the initial query with GET /api/v2/knowledge/articles?status=Published&pageSize=200&pageToken=<token>. This pattern guarantees deterministic traversal regardless of concurrent article creation or deletion during the job execution window.
2. Batch Status Transition and Revision Management
Once the eligible articles are identified, the orchestrator must transition their status from Published to Archived. The Knowledge API enforces optimistic concurrency control through the revision field. Every status change requires the current revision number to prevent race conditions where two processes modify the same article simultaneously.
PATCH /api/v2/knowledge/articles/{articleId} HTTP/1.1
Request Payload
  "status": "Archived",
  "revision": 4,
  "language": "en-us"
The payload must include the exact revision value retrieved during the query phase. The API returns a 200 OK with the updated article object if the revision matches. If another process incremented the revision between the query and the patch, the API returns a 409 Conflict. Your orchestrator must implement a retry loop with exponential backoff, re-fetching the article to capture the new revision before retrying the status transition.
The Trap
Sending a raw status change without including the revision field or using an outdated revision number triggers 409 Conflict responses. Many developers attempt to bypass this by omitting the revision field, which causes the API to silently reject the update or apply it to the wrong revision branch. Another common failure is executing PATCH operations in parallel without rate limit awareness. The Knowledge API enforces a strict quota of approximately 100 writes per second per tenant. Bursting past this threshold triggers 429 Too Many Requests responses and cascades into job timeouts.
We enforce strict revision matching because knowledge articles often serve as single sources of truth for agent assist, chatbot training, and customer self-service. A race condition during archival could overwrite a critical status change made by a compliance officer or a content manager. The retry loop with exponential backoff (base delay of 500ms, max attempts of 3) absorbs transient conflicts without corrupting data. Rate limiting is handled by implementing a token bucket algorithm or a fixed-window throttler that caps PATCH requests at 80 per second. This leaves headroom for human editors and other automation pipelines sharing the same tenant quota.
3. Orchestration Scheduling and Idempotency
The final architectural component is the execution schedule and state tracking mechanism. Knowledge expiry workflows run on a cadence that balances compliance requirements against API consumption. Daily execution during off-peak hours (02:00 to 04:00 UTC) minimizes impact on agent assist latency and search indexing cycles.
State Tracking Pattern
You must maintain an external state store (Redis, DynamoDB, or a relational database) that records the articleId, lastProcessedTimestamp, and finalStatus. Before transitioning an article, the orchestrator checks the state store. If the article was already processed within the current execution window, the orchestrator skips the PATCH operation. This idempotent design prevents duplicate archival attempts when the job restarts due to infrastructure failures or network partitions.
Execution Flow
  1. Initialize execution window and clear stale state records older than 24 hours.
  2. Query published articles with pagination until pageToken is null.
  3. Filter articles where publishedDate exceeds the retention threshold.
  4. Validate space permissions and article locks.
  5. Execute PATCH with revision matching and exponential backoff.
  6. Record successful transitions in the state store.
  7. Generate an execution report containing success counts, conflict retries, and skipped articles.
The Trap
Re-running the job without tracking processed article IDs causes duplicate archive attempts. The Knowledge API accepts the status transition, but the redundant calls consume write quotas and generate unnecessary audit log entries. A more severe failure occurs when the orchestrator lacks idempotency and processes the same article across multiple scheduled runs due to overlapping execution windows. This creates audit noise and can trigger false positive alerts in your compliance monitoring stack.
We implement idempotency through a deterministic execution key composed of articleId and executionDate. The state store acts as a distributed lock that survives orchestrator restarts. This pattern aligns with event sourcing principles where every state transition is recorded exactly once. The execution report provides observability into policy enforcement drift. If success rates drop below 95 percent, the pipeline triggers a fallback alert to the knowledge governance team. This approach scales to 500,000+ articles without degrading API performance or introducing data inconsistency.
Edge Case 1: Locked Articles and Concurrent Edits
The Failure Condition
The orchestrator attempts to archive an article but receives a 409 Conflict with a payload indicating the article is locked for editing. The job logs a failure and moves to the next article, leaving the expired article in the Published state indefinitely.
The Root Cause
Subject matter editors or content managers have an active editing session open in the Genesys Cloud UI or an integrated authoring tool. The Knowledge API enforces a write lock during active sessions to prevent data corruption. The orchestrator does not check the locked flag or lockedBy metadata before attempting the status transition.
The Solution
Implement a pre-flight validation step that inspects the locked boolean and lockedBy object in the article payload. If the article is locked, defer the archival attempt to the next execution window. Add a configurable grace period (default 48 hours) after which the orchestrator sends a notification to the content governance queue. The notification includes the article ID, title, lock owner, and expiry policy violation details. This preserves editorial workflow continuity while ensuring eventual compliance.
Edge Case 2: Cross-Space Permission Boundaries
The orchestrator successfully archives articles in three knowledge spaces but fails with 403 Forbidden responses for two additional spaces. The job reports partial success, and expired articles remain published in the restricted spaces.
The Root Cause
The OAuth service account used by the orchestrator lacks the knowledge:space:write permission for specific knowledge spaces. Genesys Cloud enforces space-level access controls that override tenant-wide permissions. Content managers frequently create restricted spaces for sensitive verticals (HIPAA, PCI-DSS, executive communications) and explicitly deny write access to automation service accounts.
The Solution
Audit space permissions before deployment using the GET /api/v2/knowledge/spaces endpoint. Map each space ID to its access control list and verify that the orchestrator service account holds knowledge:space:write and knowledge:article:write privileges. If policy dictates that the automation account cannot hold direct write access, implement a delegation pattern. The orchestrator queries eligible articles and publishes events to a message bus. A secondary process with elevated space permissions consumes the events and executes the archival transitions. This separation of concerns aligns with least-privilege security models.
Edge Case 3: Search Index Lag After Archival
Agents and customers continue to retrieve archived articles in search results for 15 to 45 minutes after the orchestrator reports successful transitions. Compliance auditors flag this as a data retention violation.
The Root Cause
The Knowledge API updates the article status synchronously, but the search index operates asynchronously. Genesys Cloud uses a distributed search cluster that processes indexing jobs in batches. The propagation delay varies based on tenant size, index queue depth, and regional infrastructure load. The orchestrator completes its execution before the search cluster finishes reindexing.
The Solution
Do not rely on API response timestamps for search consistency validation. Implement a post-execution verification step that queries the search endpoint with a known archived article ID. The orchestrator polls the search API at 5-minute intervals until the article returns a zero-match result or exceeds a 60-minute timeout. If the timeout is reached, the orchestrator triggers a manual index refresh via the POST /api/v2/knowledge/indexing/refresh endpoint (available on CX 3 and higher). Document this propagation window in your compliance runbooks to prevent false positive audit findings.
