Implementing Automated Genesys Cloud CX System Health Checks Using Synthetic Transactions and Prometheus-Based Monitoring
This guide details the implementation of automated system health checks for Genesys Cloud CX using synthetic transactions executed via the Genesys Cloud CX Digital channel and monitored via a Prometheus-based alerting system. The end result is a proactive alerting system that identifies performance degradations or outages before they impact live agent or customer interactions. This provides a faster mean time to resolution (MTTR) and reduces the impact of incidents.
  • Licensing: Genesys Cloud CX Digital (required for Digital channel), Genesys Cloud CX Architect (required for building the synthetic transaction flow), Genesys Cloud CX Data Action (required for sending synthetic transaction results to external storage), and a Prometheus server with Grafana for visualization and alerting. CX 2.0 or higher is recommended for enhanced Data Action capabilities and reliability.
  • Permissions: Architect > Flows > View/Edit, Data Actions > Configurations > View/Edit, Administration > Integrations > View/Edit, Reporting > Historical Reporting > View, Reporting > Real-Time Reporting > View.
  • OAuth Scopes: The Data Action integration will require an OAuth client with the data_action scope. This scope allows the Data Action to access and send data to your configured external storage.
  • External Dependencies: A functioning Prometheus server with a configured Grafana instance. An external storage system accessible via HTTPS, such as AWS S3, Azure Blob Storage, or Google Cloud Storage (GCS). A method for sending data to Prometheus (e.g., Prometheus Pushgateway, Telegraf).
1. Designing the Synthetic Transaction Flow
The core of this solution is a Genesys Cloud CX Architect flow triggered via the Digital channel. This flow simulates a customer interaction, testing key system components. We will design a flow that:
  1. Receives a request via a dedicated Digital media type (e.g., SMS, Web Chat).
  2. Authenticates the request (to prevent unauthorized usage – crucial!). We’ll use a static keyword check for simplicity, but API-based authentication is more secure in production.
  3. Simulates a simple IVR interaction (e.g., a menu selection).
  4. Attempts to connect to a queue and measure connection time.
  5. Records key metrics (connection time, IVR response time, queue connection success/failure) as JSON data.
  6. Sends the JSON data to a Data Action configured to POST to your external storage.
The Trap: Failing to authenticate the requests. Anyone can trigger your synthetic transactions and potentially flood your system with false positives, obscuring genuine issues and generating unnecessary alerts.
Here’s an example Architect expression to extract a secret keyword:
${Channel.Parameters.secret_keyword}
This assumes the Digital request includes a parameter named secret_keyword. The flow then compares this to a predefined value. If it doesn’t match, the flow terminates immediately.
2. Configuring the Data Action
The Data Action will be responsible for taking the JSON payload generated by the Architect flow and sending it to your external storage. We will configure a Data Action with the following settings:
  • Name: Synthetic Transaction Data Action
  • Type: HTTP POST
  • URL: The HTTPS endpoint of your chosen storage system (e.g., https://s3.amazonaws.com/your-bucket-name/synthetic-transactions).
  • Content Type: application/json
  • Authentication: Configure appropriate authentication (e.g., AWS IAM role, Azure SAS token, Google Cloud Service Account).
  • Request Body: ${flow.data} – This variable contains the JSON payload generated by the Architect flow.
The Trap: Incorrectly configuring the authentication for the Data Action. The Data Action will fail silently, and you won’t receive any alerts regarding the failure, leading you to believe your system is healthy when it is not. Thoroughly test the Data Action independently before integrating it into the flow.
The JSON payload sent will look similar to this:
  "timestamp": "${DateTime.Now()}",
  "transaction_id": "${flow.uuid}",
  "queue_connection_time": "${flow.queue_connection_time}",
  "ivr_response_time": "${flow.ivr_response_time}",
  "queue_connection_success": "${flow.queue_connection_success}"
3. Setting up the Digital Channel Trigger
Configure a dedicated Digital media type (e.g., SMS or Web Chat) to trigger the synthetic transaction flow. This will require:
  • Creating a unique Digital media type identifier.
  • Configuring the trigger to route incoming messages to the Architect flow.
  • Ensuring the Digital trigger passes the secret_keyword parameter as part of the request.
The Trap: Using a production Digital media type for synthetic transactions. This could interfere with legitimate customer interactions. Always dedicate a specific, isolated Digital media type for this purpose.
4. Integrating with Prometheus
Now, we need to ingest the data from your external storage into Prometheus. The specific method depends on your storage solution. Options include:
  • Prometheus Pushgateway: The Data Action POSTs to the Pushgateway, which Prometheus scrapes. This requires careful security considerations.
  • Telegraf: A lightweight agent that monitors your storage system and pushes data to Prometheus. This is generally preferred for security and reliability.
  • Custom Script: A script that periodically pulls data from your storage and exposes it as Prometheus metrics.
Once the data is in Prometheus, define metrics based on the JSON payload. For example:
queue_connection_time_seconds{queue_name="YourQueue"} = queue_connection_time
ivr_response_time_seconds = ivr_response_time
queue_connection_success{queue_name="YourQueue"} = queue_connection_success
5. Configuring Alerts in Grafana
Finally, configure alerts in Grafana based on the Prometheus metrics. For example, you could create an alert that triggers when the queue_connection_time_seconds exceeds a threshold (e.g., 5 seconds). Configure appropriate notification channels (e.g., email, Slack, PagerDuty).
The Trap: Setting overly sensitive alert thresholds. Frequent false positives will lead to alert fatigue, and teams will start ignoring alerts. Carefully tune the thresholds based on historical data and your specific service level objectives (SLOs).
Edge Case 1: Data Action Failing Due to Network Issues
Failure Condition: The Data Action fails to POST the data to your external storage due to a network outage or firewall issue.
Root Cause: Intermittent network connectivity between Genesys Cloud CX and your external storage.
Solution: Implement retry logic within the Data Action configuration. Monitor the Data Action’s execution logs in Genesys Cloud CX for errors.
Edge Case 2: Incorrect JSON Format
Failure Condition: The Architect flow generates a JSON payload with an invalid format, causing the Data Action to fail.
Root Cause: An error in the Architect expression or data mapping.
Solution: Thoroughly test the Architect flow and validate the JSON payload before deploying to production. Use a JSON validator to verify the format. Enable logging within the Architect flow to capture the generated JSON.
Edge Case 3: Prometheus Not Scraping Metrics
Failure Condition: Prometheus is not scraping the metrics exposed by your chosen integration method.
Root Cause: Incorrect Prometheus configuration, firewall rules, or authentication issues.
Solution: Verify that Prometheus is correctly configured to scrape the endpoint where metrics are exposed. Check firewall rules and authentication settings. Review Prometheus logs for errors.
