Implementing Authorization Code with PKCE for Single-Page Applications
- A client-side JavaScript module that authenticates a user against Genesys Cloud or NICE CXone using the Authorization Code flow with Proof Key for Code Exchange (PKCE).
- The code handles the redirect to the identity provider, processes the authorization code callback, and exchanges the code for an access token without a backend server.
- The implementation uses modern vanilla JavaScript (ES6+) and the
cryptoWeb API, making it suitable for any single-page application (SPA) framework like React, Angular, or Vue.
- OAuth Client Type: Public Client (SPA). The client must be registered in the Genesys Cloud Admin Portal or NICE CXone Admin Console as a “Public” or “SPA” client type. Secret-based flows are insecure in browsers and must not be used.
- Required Scopes:
openid,offline_access(if refresh tokens are needed), and application-specific scopes (e.g.,user:read,analytics:read). - Runtime Requirements: A modern browser supporting the Web Crypto API (
window.crypto). - External Dependencies: None. This tutorial uses standard browser APIs. No external libraries like
oidc-client-jsare required, though they are recommended for production complexity.
The Authorization Code flow with PKCE is the standard for SPAs because it eliminates the need to store a client secret in the browser bundle. Instead, it uses a cryptographic verifier/challenge pair to prove that the token request comes from the same entity that initiated the authorization request.
Generate the PKCE Code Verifier and Challenge
The first step is generating a random string (the code verifier) and deriving a challenge from it. The challenge is sent to the authorization server during the redirect, and the verifier is sent when exchanging the code for a token.
// utils/oauth-pkce.js
* Generates a random string of bytes and encodes it as Base64URL.
* @param {number} length - The number of random bytes to generate.
* @returns {Promise<string>} The Base64URL encoded string.
async function generateRandomString(length) {
const array = new Uint8Array(length);
window.crypto.getRandomValues(array);
return Array.from(array, byte => byte.toString(16).padStart(2, '0')).join('');
* Encodes a string to Base64URL.
* @param {string} input - The string to encode.
* @returns {string} The Base64URL encoded string.
function base64URLEncode(str) {
return btoa(str)
.replace(/\+/g, '-')
.replace(/\//g, '_')
.replace(/=/g, '');
* Creates the PKCE code verifier and challenge.
* @returns {Promise<{ codeVerifier: string, codeChallenge: string }>}
async function generatePKCEParams() {
// Generate a random 32-byte string for the verifier
const codeVerifier = await generateRandomString(32);
// Hash the verifier using SHA-256 and encode to Base64URL for the challenge
const encoder = new TextEncoder();
const data = encoder.encode(codeVerifier);
const hashBuffer = await window.crypto.subtle.digest('SHA-256', data);
const codeChallenge = base64URLEncode(String.fromCharCode(...new Uint8Array(hashBuffer)));
return { codeVerifier, codeChallenge };
Constructing the Authorization Request
You must redirect the user to the identity provider’s authorization endpoint. The URL must include the client ID, redirect URI, response type, scopes, state, and the PKCE code challenge.
Genesys Cloud Endpoint: https://login.mypurecloud.com/as/authorization
NICE CXone Endpoint: https://platform.us.niceincontact.com/oauth2/v2/authorize
// auth/login.js
const GENESYS_CONFIG = {
clientId: 'YOUR_CLIENT_ID',
redirectUri: 'http://localhost:3000/callback',
scope: 'openid offline_access user:read',
authorizationEndpoint: 'https://login.mypurecloud.com/as/authorization'
const CXONE_CONFIG = {
scope: 'openid offline_access',
authorizationEndpoint: 'https://platform.us.niceincontact.com/oauth2/v2/authorize'
* Initiates the OAuth login flow.
* @param {Object} config - The platform configuration object.
async function initiateLogin(config) {
const { codeVerifier, codeChallenge } = await generatePKCEParams();
// Store the verifier securely. In a real app, use sessionStorage or a secure cookie.
// Do NOT store in localStorage due to XSS risks if possible, but for SPAs it is often the only option
// if HttpOnly cookies are not managed by a backend.
sessionStorage.setItem('oauth_code_verifier', codeVerifier);
sessionStorage.setItem('oauth_state', crypto.randomUUID()); // Generate a unique state
const params = new URLSearchParams({
response_type: 'code',
client_id: config.clientId,
redirect_uri: config.redirectUri,
scope: config.scope,
code_challenge: codeChallenge,
code_challenge_method: 'S256',
state: sessionStorage.getItem('oauth_state')
const authUrl = `${config.authorizationEndpoint}?${params.toString()}`;
// Redirect the user
window.location.href = authUrl;
Step 1: Handling the Callback and Exchanging the Code
When the user grants permission, the identity provider redirects back to your redirectUri with an authorization code and the state. You must exchange this code for an access token by posting to the token endpoint.
Genesys Cloud Token Endpoint: https://api.mypurecloud.com/api/v2/oauth/token
NICE CXone Token Endpoint: https://platform.us.niceincontact.com/oauth2/v2/token
// auth/callback.js
* Exchanges the authorization code for an access token.
* @param {string} code - The authorization code from the query string.
* @returns {Promise<Object>} The token response object.
async function exchangeCodeForToken(code, config) {
const codeVerifier = sessionStorage.getItem('oauth_code_verifier');
const expectedState = sessionStorage.getItem('oauth_state');
// Clear sensitive session data immediately after retrieval
sessionStorage.removeItem('oauth_code_verifier');
sessionStorage.removeItem('oauth_state');
if (!codeVerifier) {
throw new Error('PKCE Code Verifier not found. Session may have expired.');
const tokenEndpoint = config.tokenEndpoint ||
(config.provider === 'genesys'
? 'https://api.mypurecloud.com/api/v2/oauth/token'
: 'https://platform.us.niceincontact.com/oauth2/v2/token');
const formData = new URLSearchParams({
grant_type: 'authorization_code',
code: code,
code_verifier: codeVerifier
const response = await fetch(tokenEndpoint, {
method: 'POST',
headers: {
'Content-Type': 'application/x-www-form-urlencoded'
body: formData
if (!response.ok) {
const errorBody = await response.json();
throw new Error(`Token exchange failed: ${errorBody.error_description || response.statusText}`);
const tokens = await response.json();
// Validate state if provided in the initial request to prevent CSRF
// Note: The state is usually returned in the callback URL query params,
// not in the token response. You must validate it before calling this function.
return tokens;
} catch (error) {
console.error('OAuth Token Exchange Error:', error);
throw error;
Step 2: Parsing the Callback URL
Your application must detect when it is on the callback page, parse the query parameters, validate the state, and trigger the token exchange.
// app/main.js
* Main entry point for handling the OAuth callback.
async function handleCallback(config) {
const urlParams = new URLSearchParams(window.location.search);
const code = urlParams.get('code');
const state = urlParams.get('state');
const error = urlParams.get('error');
// Handle user denial or other errors from the IdP
if (error) {
console.error('Authorization failed:', urlParams.get('error_description'));
window.location.href = '/login?error=denied';
return;
if (!code) {
console.error('No authorization code found in URL.');
return;
// Validate State to prevent CSRF
const storedState = sessionStorage.getItem('oauth_state');
if (state !== storedState) {
console.error('State mismatch. Potential CSRF attack detected.');
sessionStorage.clear();
return;
const tokens = await exchangeCodeForToken(code, config);
// Store tokens securely
localStorage.setItem('genesys_access_token', tokens.access_token);
localStorage.setItem('genesys_refresh_token', tokens.refresh_token);
localStorage.setItem('genesys_token_expiry', Date.now() + (tokens.expires_in * 1000));
// Redirect to the main app dashboard
window.location.href = '/dashboard';
} catch (err) {
console.error('Failed to exchange code:', err);
window.location.href = '/login?error=token_exchange';
// Usage in your app's entry point
if (window.location.pathname === '/callback') {
handleCallback(GENESYS_CONFIG);
Step 3: Making Authenticated API Requests
Once you have the access token, you include it in the Authorization header of subsequent API requests.
// api/client.js
* Makes an authenticated GET request to a Genesys Cloud endpoint.
* @param {string} endpoint - The API endpoint path (e.g., '/api/v2/users/me').
* @param {string} token - The access token.
* @returns {Promise<Object>} The JSON response data.
async function getAuthenticatedData(endpoint, token) {
if (!token) {
throw new Error('No access token available. Please log in.');
const baseUrl = 'https://api.mypurecloud.com';
const url = `${baseUrl}${endpoint}`;
const response = await fetch(url, {
method: 'GET',
headers: {
'Accept': 'application/json'
if (response.status === 401) {
// Token expired or invalid. Trigger refresh flow.
console.warn('Token expired. Refresh required.');
await refreshAccessToken();
// Retry logic would go here
if (!response.ok) {
const errorData = await response.json();
throw new Error(`API Error ${response.status}: ${errorData.message || response.statusText}`);
return await response.json();
} catch (error) {
console.error('API Request Failed:', error);
throw error;
// Example usage
async function loadUserProfile() {
const token = localStorage.getItem('genesys_access_token');
const profile = await getAuthenticatedData('/api/v2/users/me', token);
console.log('User Profile:', profile);
return profile;
Below is a consolidated, minimal HTML file that demonstrates the entire flow. This can be saved as index.html and opened in a browser (note: for fetch to work correctly with CORS and local storage, it is best served via a local server like python -m http.server or npx serve).
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>PKCE OAuth Demo</title>
<style>
body { font-family: sans-serif; padding: 2rem; }
button { padding: 10px 20px; cursor: pointer; }
.hidden { display: none; }
</style>
</head>
<body>
<h1>Genesys Cloud PKCE Login Demo</h1>
<div id="login-view">
<p>Click below to authenticate via Genesys Cloud.</p>
<button id="login-btn">Login with Genesys Cloud</button>
</div>
<div id="app-view" class="hidden">
<h2>Welcome, <span id="user-name">User</span></h2>
<p>Access Token: <code id="token-preview"></code></p>
<button id="logout-btn">Logout</button>
</div>
<script>
// Configuration
const CONFIG = {
clientId: 'YOUR_CLIENT_ID_HERE',
redirectUri: window.location.origin + window.location.pathname,
authEndpoint: 'https://login.mypurecloud.com/as/authorization',
tokenEndpoint: 'https://api.mypurecloud.com/api/v2/oauth/token'
// DOM Elements
const loginView = document.getElementById('login-view');
const appView = document.getElementById('app-view');
const loginBtn = document.getElementById('login-btn');
const logoutBtn = document.getElementById('logout-btn');
const userNameSpan = document.getElementById('user-name');
const tokenPreview = document.getElementById('token-preview');
// PKCE Utilities
return btoa(str)
.replace(/=/g, '');
// Login Flow
loginBtn.addEventListener('click', async () => {
const state = crypto.randomUUID();
sessionStorage.setItem('oauth_state', state);
client_id: CONFIG.clientId,
redirect_uri: CONFIG.redirectUri,
scope: CONFIG.scope,
state: state
window.location.href = `${CONFIG.authEndpoint}?${params.toString()}`;
// Callback Handling
async function handleCallback() {
if (error) {
alert('Login failed: ' + urlParams.get('error_description'));
return;
if (!code) return;
alert('State mismatch');
return;
sessionStorage.clear(); // Clean up
code: code,
const response = await fetch(CONFIG.tokenEndpoint, {
method: 'POST',
body: formData
if (!response.ok) throw new Error('Token exchange failed');
// Fetch User Profile
const userResponse = await fetch('https://api.mypurecloud.com/api/v2/users/me', {
headers: { 'Authorization': `Bearer ${tokens.access_token}` }
const user = await userResponse.json();
showApp(user.name, tokens.access_token);
} catch (err) {
console.error(err);
alert('Failed to authenticate');
function showApp(name, token) {
loginView.classList.add('hidden');
appView.classList.remove('hidden');
userNameSpan.textContent = name;
tokenPreview.textContent = token.substring(0, 20) + '...';
// Logout
logoutBtn.addEventListener('click', () => {
localStorage.removeItem('genesys_access_token');
window.location.reload();
// Init
if (window.location.search.includes('code=')) {
handleCallback();
} else if (localStorage.getItem('genesys_access_token')) {
// Optional: Auto-login if token exists and is valid
// For this demo, we just show the login button
</script>
</body>
</html>
Error: invalid_grant during token exchange
Cause: The authorization code has expired (they are short-lived, typically 5-10 minutes) or the PKCE code verifier does not match the code challenge.
Fix: Ensure you are using the exact codeVerifier generated before the redirect. Do not regenerate it on the callback page. Check that you are encoding the challenge using SHA-256 and Base64URL correctly.
// Debugging PKCE Mismatch
async function verifyPKCE() {
const verifier = "test_verifier_string"; // Replace with actual
const data = encoder.encode(verifier);
const challenge = btoa(String.fromCharCode(...new Uint8Array(hashBuffer)))
.replace(/=/g, '');
console.log('Verifier:', verifier);
console.log('Challenge:', challenge);
Error: 401 Unauthorized on API calls
Cause: The access token is expired or missing scopes.
Fix: Check the expires_in field from the token response. Implement a refresh token flow before making API calls if the token is near expiration. Ensure the scope requested in the authorization step includes the permissions required for the API endpoint.
Error: CORS Policy Blocked
Cause: The browser blocks the request because the redirect_uri in your code does not exactly match the redirect_uri registered in the Genesys Cloud/CXone admin portal.
Fix: Check the Admin Portal. If you registered http://localhost:3000/callback, you cannot use http://localhost:3000/. The paths must match exactly.
