Implementing Authorization Code Flow with PKCE for SPAs in Genesys Cloud
- You will build a serverless, client-side authentication module that securely authenticates a user against Genesys Cloud without exposing client secrets.
- You will utilize the Genesys Cloud OAuth 2.0 Authorization Code flow with Proof Key for Code Exchange (PKCE) to mitigate authorization code interception attacks.
- You will implement the solution using modern JavaScript (ES Modules) and the Fetch API, ensuring compatibility with any frontend framework (React, Vue, Angular, or vanilla HTML/JS).
- OAuth Client Type: A Genesys Cloud OAuth 2.0 client configured as “Public” or “Confidential” (PKCE works for both, but is mandatory for Public clients).
- Required Scopes:
agent:login(to retrieve the user identity) andanalytics:events:read(example scope for subsequent API calls). - SDK Version: No specific SDK is required for the auth flow itself as it uses standard HTTP endpoints. Subsequent API calls may use
genesys-cloud-purecloud-platform-client-v2(JS). - Runtime: Any modern web browser (Chrome, Firefox, Safari, Edge) supporting ES6+ and the Fetch API.
- Dependencies: None. This implementation relies on native browser APIs.
The Authorization Code flow with PKCE is the industry standard for Single-Page Applications (SPAs). Unlike the Implicit flow (which is deprecated), this flow exchanges a short-lived authorization code for an access token. The PKCE mechanism ensures that even if the authorization code is intercepted during the redirect, it cannot be used by an attacker without the corresponding verifier.
Step 1: Generate PKCE Parameters
Before redirecting the user to Genesys Cloud, you must generate a cryptographic challenge. This consists of a code_verifier (kept secret in the browser memory) and a code_challenge (sent to Genesys Cloud).
The code_challenge is derived from the code_verifier using SHA-256 hashing and Base64 URL encoding.
// authUtils.js
* Generates a cryptographically random string of bytes.
* @param {number} length - The length of the string.
* @returns {string} A random ASCII string.
async function generateRandomString(length = 64) {
const array = new Uint8Array(length);
window.crypto.getRandomValues(array);
return Array.from(array, byte => byte.toString(16).padStart(2, '0')).join('');
* Encodes a string using Base64 URL encoding.
* @param {string} input - The string to encode.
* @returns {string} The Base64 URL encoded string.
function base64URLEncode(str) {
return btoa(str)
.replace(/\+/g, '-')
.replace(/\//g, '_')
.replace(/=/g, '');
* Creates the PKCE code challenge from a code verifier.
* @param {string} verifier - The code verifier.
* @returns {Promise<string>} The SHA-256 hashed and Base64URL encoded challenge.
async function createCodeChallenge(verifier) {
const encoder = new TextEncoder();
const data = encoder.encode(verifier);
const hashBuffer = await window.crypto.subtle.digest('SHA-256', data);
const hashArray = Array.from(new Uint8Array(hashBuffer));
const hashBase64 = hashArray.map(byte => String.fromCharCode(byte)).join('');
return base64URLEncode(hashBase64);
* Generates both the code_verifier and code_challenge.
* @returns {Promise<{ codeVerifier: string, codeChallenge: string }>}
export async function generatePKCEParams() {
const codeVerifier = await generateRandomString(128);
const codeChallenge = await createCodeChallenge(codeVerifier);
return { codeVerifier, codeChallenge };
Why this matters: If you skip PKCE, an attacker intercepting the redirect URL could steal the authorization code. With PKCE, the attacker possesses the code but lacks the code_verifier generated in the user’s browser, making the code useless.
Step 2: Initiate the Authorization Request
Construct the Genesys Cloud authorization URL. You must store the codeVerifier in a secure location (such as sessionStorage or a memory variable) because you will need it later to exchange the code for tokens.
// authFlow.js
import { generatePKCEParams } from './authUtils.js';
const GENESYS_CLOUD_URL = 'https://api.mypurecloud.com'; // Change to your environment
const CLIENT_ID = 'YOUR_CLIENT_ID_HERE';
const REDIRECT_URI = 'http://localhost:3000/callback'; // Must match exactly in Genesys Admin
const SCOPES = 'agent:login analytics:events:read';
export async function initiateLogin() {
const { codeVerifier, codeChallenge } = await generatePKCEParams();
// Store the verifier securely. In a real app, use sessionStorage or a secure in-memory store.
// Do NOT use localStorage for sensitive auth data if possible, due to XSS risks.
sessionStorage.setItem('pkce_code_verifier', codeVerifier);
const params = new URLSearchParams({
response_type: 'code',
client_id: CLIENT_ID,
redirect_uri: REDIRECT_URI,
scope: SCOPES,
state: generateRandomString(16), // Anti-CSRF token
code_challenge: codeChallenge,
code_challenge_method: 'S256'
const authUrl = `${GENESYS_CLOUD_URL}/oauth/authorize?${params.toString()}`;
// Redirect the user to Genesys Cloud
window.location.href = authUrl;
Critical Parameter Details:
response_type: Must becode. Never usetoken(Implicit flow).code_challenge_method: Must beS256. This tells Genesys Cloud that the challenge was hashed using SHA-256.state: A random string to prevent Cross-Site Request Forgery (CSRF). You must validate this state parameter upon return.
Step 3: Handle the Callback and Exchange Code for Tokens
When Genesys Cloud redirects the user back to your REDIRECT_URI, the URL will contain a code parameter and the state. You must now send this code to the /oauth/token endpoint to get the actual access token.
// tokenExchange.js
* Exchanges the authorization code for an access token.
* @param {string} code - The authorization code from the URL.
* @param {string} state - The state parameter for CSRF validation.
* @returns {Promise<Object>} The token response containing access_token, refresh_token, etc.
export async function exchangeCodeForToken(code, state) {
// 1. Retrieve the stored code verifier
const codeVerifier = sessionStorage.getItem('pkce_code_verifier');
if (!codeVerifier) {
throw new Error('PKCE code verifier not found. Authentication session expired or tampered.');
// 2. Clear the verifier from storage as it is no longer needed
sessionStorage.removeItem('pkce_code_verifier');
const body = new URLSearchParams({
grant_type: 'authorization_code',
code: code,
code_verifier: codeVerifier
const response = await fetch(`${GENESYS_CLOUD_URL}/oauth/token`, {
method: 'POST',
headers: {
'Content-Type': 'application/x-www-form-urlencoded'
body: body
if (!response.ok) {
const errorData = await response.json();
throw new Error(`OAuth Token Exchange Failed: ${response.status} - ${errorData.error_description || errorData.error}`);
const tokenData = await response.json();
// Store tokens securely (preferably in memory or httpOnly cookies if backend proxy is used)
// For this SPA example, we use sessionStorage, but be aware of XSS risks.
sessionStorage.setItem('genesys_access_token', tokenData.access_token);
sessionStorage.setItem('genesys_refresh_token', tokenData.refresh_token);
sessionStorage.setItem('genesys_token_expiry', Date.now() + (tokenData.expires_in * 1000));
return tokenData;
} catch (error) {
console.error('Token exchange error:', error);
throw error;
* Handles the callback URL parsing.
export function handleCallback() {
const urlParams = new URLSearchParams(window.location.search);
const code = urlParams.get('code');
const state = urlParams.get('state');
const error = urlParams.get('error');
if (error) {
console.error('Authorization Error:', urlParams.get('error_description'));
return;
if (!code || !state) {
console.error('Invalid callback: missing code or state.');
return;
// Validate state if you stored it in Step 2
// if (state !== sessionStorage.getItem('pkce_state')) { throw new Error('State mismatch'); }
.then(() => {
// Redirect to the main application dashboard
window.location.href = '/dashboard';
.catch(err => {
console.error('Login failed:', err);
alert('Authentication failed. Please try again.');
Expected Response Body:
"access_token": "eyJraWQiOiIxNjQ5MjM...",
"token_type": "Bearer",
"expires_in": 3600,
"refresh_token": "dGhpcyBpcyBhIHJlZnJlc2ggdG9rZW4...",
"scope": "agent:login analytics:events:read"
Step 4: Using the Access Token for API Calls
Once you have the access token, you can make authenticated requests to Genesys Cloud APIs. The token should be included in the Authorization header as a Bearer token.
// apiClient.js
* Makes an authenticated GET request to a Genesys Cloud API.
* @param {string} endpoint - The API endpoint (e.g., '/api/v2/users/me').
* @returns {Promise<Object>} The JSON response.
export async function getAuthenticatedData(endpoint) {
const accessToken = sessionStorage.getItem('genesys_access_token');
if (!accessToken) {
throw new Error('No access token found. Please log in.');
// Check if token is expired
const expiry = parseInt(sessionStorage.getItem('genesys_token_expiry') || '0');
if (Date.now() > expiry) {
// In a real app, trigger a refresh token flow here
throw new Error('Access token expired. Refresh required.');
const response = await fetch(`${GENESYS_CLOUD_URL}${endpoint}`, {
method: 'GET',
headers: {
'Authorization': `Bearer ${accessToken}`,
'Content-Type': 'application/json'
if (!response.ok) {
if (response.status === 401) {
// Token might be invalid or expired
sessionStorage.removeItem('genesys_access_token');
sessionStorage.removeItem('genesys_refresh_token');
throw new Error('Unauthorized: Token invalid or expired.');
throw new Error(`API Error: ${response.status} - ${JSON.stringify(errorData)}`);
return await response.json();
} catch (error) {
console.error('API Request Failed:', error);
throw error;
// Example Usage: Get current user profile
export async function getCurrentUser() {
return await getAuthenticatedData('/api/v2/users/me');
OAuth Scope Requirement: The endpoint /api/v2/users/me requires the agent:login scope. If you attempt to call an endpoint requiring a different scope (e.g., analytics:events:read) without including it in the initial authorization request, Genesys Cloud will return a 403 Forbidden error.
Step 5: Refreshing Tokens
Access tokens expire (default 1 hour). You must use the refresh_token to obtain a new access token without requiring the user to log in again.
// refreshToken.js
* Refreshes the access token using the refresh token.
* @returns {Promise<Object>} New token data.
export async function refreshAccessToken() {
const refreshToken = sessionStorage.getItem('genesys_refresh_token');
if (!refreshToken) {
throw new Error('No refresh token available.');
grant_type: 'refresh_token',
refresh_token: refreshToken
method: 'POST',
headers: {
body: body
if (!response.ok) {
throw new Error(`Token Refresh Failed: ${response.status} - ${errorData.error_description}`);
// Update stored tokens
if (tokenData.refresh_token) {
return tokenData;
} catch (error) {
console.error('Refresh error:', error);
// If refresh fails, the user session is likely dead. Clear tokens and redirect to login.
throw error;
Below is a single-file HTML implementation combining all steps for testing purposes. Save this as index.html and open it in a browser. Ensure you replace YOUR_CLIENT_ID_HERE and REDIRECT_URI with your actual Genesys Cloud OAuth application settings.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Genesys Cloud PKCE Auth Demo</title>
<style>
body { font-family: sans-serif; padding: 20px; max-width: 800px; margin: 0 auto; }
.btn { padding: 10px 20px; background: #007bff; color: white; border: none; cursor: pointer; border-radius: 4px; }
.btn:hover { background: #0056b3; }
.hidden { display: none; }
pre { background: #f4f4f4; padding: 10px; overflow-x: auto; }
.error { color: red; }
.success { color: green; }
</style>
</head>
<body>
<h1>Genesys Cloud PKCE Authentication</h1>
<div id="login-screen">
<p>Click below to log in to Genesys Cloud.</p>
<button id="login-btn" class="btn">Login with Genesys</button>
</div>
<div id="dashboard-screen" class="hidden">
<h2>User Profile</h2>
<pre id="user-profile">Loading...</pre>
<button id="logout-btn" class="btn" style="background: #dc3545;">Logout</button>
</div>
<div id="error-screen" class="hidden">
<h2 class="error">Authentication Error</h2>
<p id="error-message"></p>
<button id="retry-btn" class="btn">Retry</button>
</div>
<script type="module">
const CLIENT_ID = 'YOUR_CLIENT_ID_HERE'; // REPLACE THIS
const REDIRECT_URI = window.location.origin + window.location.pathname; // Current page as callback
// --- PKCE Utilities ---
return btoa(str).replace(/\+/g, '-').replace(/\//g, '_').replace(/=/g, '');
// --- Auth Flow ---
scope: 'agent:login',
state: await generateRandomString(16),
window.location.href = `${GENESYS_CLOUD_URL}/oauth/authorize?${params.toString()}`;
async function exchangeCodeForToken(code) {
if (!codeVerifier) throw new Error('PKCE verifier missing');
code: code,
method: 'POST',
body: body
if (!response.ok) {
const err = await response.json();
throw new Error(err.error_description || 'Token exchange failed');
const data = await response.json();
sessionStorage.setItem('genesys_access_token', data.access_token);
sessionStorage.setItem('genesys_refresh_token', data.refresh_token);
sessionStorage.setItem('genesys_token_expiry', Date.now() + (data.expires_in * 1000));
return data;
async function fetchUserProfile() {
const token = sessionStorage.getItem('genesys_access_token');
if (!token) return null;
const response = await fetch(`${GENESYS_CLOUD_URL}/api/v2/users/me`, {
headers: { 'Authorization': `Bearer ${token}` }
sessionStorage.clear();
return null;
if (!response.ok) throw new Error('Failed to fetch user profile');
// --- UI Logic ---
const loginScreen = document.getElementById('login-screen');
const dashboardScreen = document.getElementById('dashboard-screen');
const errorScreen = document.getElementById('error-screen');
const loginBtn = document.getElementById('login-btn');
const logoutBtn = document.getElementById('logout-btn');
const retryBtn = document.getElementById('retry-btn');
const userProfilePre = document.getElementById('user-profile');
const errorMessage = document.getElementById('error-message');
function showScreen(screen) {
loginScreen.classList.add('hidden');
dashboardScreen.classList.add('hidden');
errorScreen.classList.add('hidden');
screen.classList.remove('hidden');
async function checkAuthState() {
if (error) {
errorMessage.textContent = urlParams.get('error_description');
showScreen(errorScreen);
return;
if (code) {
await exchangeCodeForToken(code);
// Clean URL
window.history.replaceState({}, document.title, window.location.pathname);
await loadDashboard();
} catch (err) {
errorMessage.textContent = err.message;
return;
// Check for existing session
if (token && Date.now() < expiry) {
} else {
showScreen(loginScreen);
async function loadDashboard() {
const user = await fetchUserProfile();
if (!user) {
return;
userProfilePre.textContent = JSON.stringify(user, null, 2);
showScreen(dashboardScreen);
} catch (err) {
loginBtn.addEventListener('click', initiateLogin);
logoutBtn.addEventListener('click', () => {
retryBtn.addEventListener('click', () => {
window.location.href = window.location.pathname;
// Initialize
checkAuthState();
</script>
</body>
</html>
Error: invalid_grant
- What causes it: The authorization code has already been used, expired, or the
code_verifierdoes not match thecode_challengesent during the initial request. - How to fix it: Ensure you are not reusing the authorization code. Verify that the
code_verifierstored insessionStorageexactly matches the one used to generate thecode_challenge. Check that theredirect_uriin the token exchange matches the one used in the authorization request exactly (including trailing slashes).
Error: invalid_client
client_idprovided is invalid, not found, or the client is not configured to allow theredirect_urispecified. - How to fix it: Go to Genesys Cloud Admin > Platform > OAuth 2.0. Verify the Client ID. Ensure the
redirect_uriis explicitly listed in the “Allowed Redirect URIs” list for that client.
Error: access_denied
- What causes it: The user denied the authorization request, or the scope requested is not permitted for the client or the user’s role.
- How to fix it: Check the browser console for any JavaScript errors during the redirect. Verify that the OAuth client has the necessary permissions for the requested scopes.
- What causes it: You have exceeded the rate limit for the
/oauth/tokenendpoint. - How to fix it: Implement exponential backoff logic. Do not retry immediately. Wait 1 second, then 2, then 4, etc., before retrying the token exchange.
