Implementing Answering Machine Detection (AMD) Tuning for Reduced False Positive Rates
This guide details the configuration of Answering Machine Detection (AMD) thresholds within Genesys Cloud Outbound Campaigns and Voice Routing logic to minimize false positive rates. The end result is a production-ready deployment where automated systems distinguish between human responses, answering machines, and fax lines with high precision, reducing wasted agent interactions and improving customer experience metrics. You will configure static thresholds for baseline operations and implement dynamic API-driven adjustments for load-dependent scenarios.
To execute this configuration successfully, the following environment requirements must be met before proceeding:
- Licensing Tier: Genesys Cloud CX Premium or Enterprise tier with Outbound capabilities enabled. Standard tiers do not support advanced AMD threshold tuning via API.
- Granular Permissions: The user account executing these changes requires
outbound_campaign_editandanalytics_viewpermissions. For Voice Routing adjustments,telephony_routing_rules_editis mandatory. - OAuth Scopes: If utilizing API-driven dynamic tuning, the service account must hold
outbound:write,analytics:view, andcallcenter:readscopes in the OAuth client configuration. - External Dependencies: A stable SIP trunk with carrier support for call metadata (e.g., ANI/DNIS pass-through) is recommended to correlate AMD events with carrier-level signaling.
1. Baseline Threshold Configuration via UI
The foundational step involves establishing the static parameters for Answering Machine Detection within the Outbound Campaign interface. This configuration dictates the algorithmic behavior of the detection engine during live calls.
Navigate to Admin > Outbound > Campaigns and select the specific campaign requiring tuning. Locate the Answering Machine Detection section in the configuration panel. The primary control here is the Threshold Score, which ranges from 0 to 100. A score of 0 indicates a machine, while 100 indicates a human.
The default platform setting typically sits at 65. This represents a balance where the system requires moderate confidence before classifying a response as human. To reduce false positives (where a human is incorrectly identified as a machine), you must lower this threshold. However, lowering it increases the risk of false negatives (where a machine is treated as a human).
Configuration Parameters:
- Threshold Score: Adjust from default 65 to 50 for high-volume campaigns requiring maximum human contact.
- Silence Duration: Set to 2 seconds minimum. This prevents the system from hanging up on callers who pause during speech processing.
- Tone Detection: Enable detection of standard beep tones associated with voicemail systems (e.g., 440Hz or 1300Hz continuous tones).
The Trap: The most common misconfiguration occurs when engineers lower the threshold to 25 or 30 to ensure no human is missed. This results in a catastrophic increase in agent time spent listening to voicemail greetings, effectively negating the efficiency gains of automation. If you reduce the threshold below 45, you must implement a secondary validation layer, such as a CRM skip logic check, to prevent agents from engaging with non-human endpoints.
Architectural Reasoning:
The detection algorithm relies on acoustic signature analysis rather than simple silence detection. It analyzes the frequency spectrum of the audio stream for characteristics common to answering machines (compressed audio artifacts, lack of background noise, distinct beep sequences). Reducing the threshold increases sensitivity to these artifacts but reduces specificity. The decision to lower the threshold must be correlated with campaign volume and cost-per-contact constraints. In high-volume telemarketing scenarios, a false positive is costly in terms of reputation; in support callback scenarios, it is merely an operational inefficiency.
2. Dynamic Tuning via API for Variable Load Conditions
Static thresholds fail under variable network conditions. Carrier latency and jitter can alter the acoustic signature of a call, causing the AMD engine to misclassify responses during peak load times or when connected through specific PSTN gateways. To address this, implement dynamic threshold adjustments using the Genesys Cloud Outbound API.
This approach allows the system to adjust sensitivity based on real-time performance metrics. For example, if the false positive rate exceeds 2% over a rolling 15-minute window, the system automatically lowers the threshold for subsequent dialing attempts within that campaign.
API Endpoint:
PATCH /api/v2/outbound/campaigns/{campaignId}
Request Payload:
"name": "Dynamic AMD Campaign",
"status": "ACTIVE",
"answerMachineDetectionSettings": {
"thresholdScore": 55,
"enabled": true,
"dynamicAdjustment": {
"enabled": true,
"metricWindowMinutes": 15,
"triggerThreshold": 2.0,
"adjustmentStep": -5,
"minThresholdScore": 40,
"maxThresholdScore": 70
"routingMethod": "LINE"
Execution Logic:
The dynamicAdjustment object defines the logic for runtime changes. The system monitors the falsePositiveRate metric derived from post-call analytics. If the rate exceeds triggerThreshold, the adjustmentStep is applied to the current threshold score, capped by minThresholdScore and maxThresholdScore. This prevents oscillation where the system flips back and forth between high and low sensitivity settings rapidly.
The Trap: A critical failure mode in this configuration is the lack of hysteresis. If the API logic lowers the threshold to 40 because of a spike, but does not raise it back to 55 once the rate drops below 1%, the campaign remains in a suboptimal state indefinitely. You must ensure the adjustment logic includes both a downward trigger and an upward reset condition. Without hysteresis, the campaign will experience instability where agents are subjected to varying call types within the same shift, leading to confusion and inconsistent reporting data.
Dynamic tuning relies on telemetry data latency. The 15-minute window in the payload represents a balance between responsiveness and statistical significance. A 1-minute window is too noisy due to random variance; a 60-minute window reacts too slowly to network degradation events. The API approach decouples configuration from the UI, allowing for version-controlled infrastructure-as-code deployments of campaign settings. This ensures that environment changes (e.g., moving from a staging to production carrier) can be synchronized automatically without manual intervention.
3. Integration with CRM Skip Logic and Data Enrichment
AMD is not a standalone solution; it functions best when integrated with Customer Relationship Management (CRM) data to pre-qualify contact attempts. If the system detects an answering machine, it should not immediately mark the lead as dead. Instead, it should trigger a logic branch that checks historical interaction data.
This involves configuring Voice Routing Rules to pass AMD metadata into the CRM via a custom API callback upon call termination. The payload must include the amdScore and amdClassification fields.
CRM Integration Logic:
- Call Termination Event: The system captures the AMD classification (Human, Machine, Fax).
- Metadata Payload: Send a JSON payload to the CRM webhook endpoint containing:
{ "callId": "uuid-1234-5678", "contactId": "uuid-9012-3456", "amdClassification": "MACHINE", "amdScore": 32, "timestamp": "2023-10-27T14:30:00Z" } - Skip Logic: The CRM evaluates the
contactIdagainst a history of successful human contacts. If the contact has been successfully reached via human voice in the last 30 days, the system queues a retry regardless of the AMD classification.
The Trap: Engineers often treat the AMD result as a binary “stop” signal. If the CRM logic does not account for false negatives (machines misclassified as humans), the campaign will continue dialing known machines indefinitely. You must implement a maximum retry cap per contact ID in the CRM layer. If a contact returns an AMD classification of “MACHINE” three consecutive times, the system must suppress that number from the dialer list for at least 7 days. Failure to implement this suppression logic results in repeated harassment calls, which creates compliance risks under TCPA regulations and damages brand reputation.
This integration decouples detection from action. The telephony platform detects the state; the CRM determines the business rule. This separation of concerns allows you to change business rules (e.g., “retry once more after 24 hours”) without modifying the telephony infrastructure or campaign settings. It also allows for data enrichment where the AMD score can be used as a predictive variable in future AI models, improving overall contact center efficiency over time.
Edge Case 1: High Latency and Jitter Environments
The Failure Condition: In regions with poor network connectivity (e.g., rural areas or certain international gateways), call audio suffers from latency exceeding 200ms or jitter causing packet loss. The AMD algorithm interprets these audio gaps as silence, triggering a false positive classification of “Machine.”
The Root Cause: The default silence duration threshold is calibrated for low-latency environments (sub-150ms). When network conditions degrade, the detection window expands effectively, causing the system to wait too long before classifying the signal.
The Solution: Implement network-aware configuration profiles. Use the Genesys Cloud Voice Routing feature to map specific carrier trunks to different AMD sensitivity settings. For routes experiencing high latency, increase the Silence Duration parameter from 2 seconds to 4 seconds. This provides a buffer for delayed audio packets without compromising detection accuracy. Monitor this via the Call Quality dashboard and correlate latency spikes with AMD false positive rates.
Edge Case 2: Voicemail Greetings vs. Answering Machines
The Failure Condition: Human voicemails (personalized greetings) are frequently misclassified as live humans because they contain speech patterns similar to answering machines but lack the specific beep tones.
The Root Cause: The tone detection logic relies heavily on detecting standard machine beeps. Personalized voicemails do not emit these beeps, causing the system to default to a “Human” classification based on audio entropy.
The Solution: Adjust the Tone Detection sensitivity to be more aggressive for beep sequences. Additionally, implement a post-call logic check where any call classified as “Machine” is checked against a database of known voicemail patterns. If the audio contains distinct speech without background noise but no beep tone, flag it for manual review or route to a secondary SMS verification flow. This hybrid approach reduces false positives on personalized voicemails while maintaining detection on standard machine greetings.
Edge Case 3: Robocall Filtering Interference
The Failure Condition: Third-party call filtering services (e.g., Hiya, Nomorobo) often inject metadata or modify SIP headers that interfere with the native AMD engine.
The Root Cause: These services may strip certain audio frequencies or insert silent intervals to prevent fraud detection. The Genesys Cloud AMD engine may interpret these modifications as silence or machine artifacts incorrectly.
The Solution: Whitelist known carrier filtering services in the Voice Routing configuration. Ensure that SIP headers indicating filtering service involvement (e.g., X-Filtering-Service: Hiya) are passed through to the analytics layer. If a call comes from a filtered trunk, temporarily disable AMD and rely on the external filter’s classification data instead of native detection. This prevents the internal engine from fighting against external security layers.
- Genesys Cloud Outbound Campaigns Documentation: Outbound Campaign Settings
- Genesys Cloud API Reference (Outbound): PATCH /api/v2/outbound/campaigns/{campaignId}
- Genesys Cloud Voice Routing: Voice Routing Rules Configuration
- TCPA Compliance Guidelines (FCC): Telemarketing Sales Rule
