Implementing Agentless Campaign Notification Delivery for Payment Reminders and Alerts
This guide details the configuration of Genesys Cloud CX Notification Service to automate payment reminders and transaction alerts without human agent intervention. The end result is a secure, PCI-DSS compliant channel capable of delivering SMS, email, or push notifications triggered by external ledger events or scheduled campaigns. You will configure the Notification Service channels, establish API-driven triggers for real-time alerts, and implement scheduling logic for recurring payment reminders.
To execute this architecture, you require specific licensing tiers and granular permissions within the Genesys Cloud organization.
- Licensing Tier: Genesys Cloud CX Premium or Enterprise license is mandatory. Notification Service requires the Cloud Messaging add-on for SMS capabilities. For email delivery via Genesys, standard Cloud CX licensing applies, but outbound email domain verification must be completed.
- Granular Permissions: The user account performing the configuration must hold the following permission sets:
Notifications > Notification Service > EditNotifications > Notification Service > CreateCampaigns > Outbound > Edit(For scheduled reminders)API Access Management > OAuth > Edit(For integration setup)
- OAuth Scopes: Integration applications require the following scopes to trigger notifications programmatically:
notification_service:readnotification_service:writecontactcenter:read(To resolve customer identifiers if needed)
- External Dependencies: You must have a verified SMS gateway provider integrated via Genesys Carrier Management. For email, the domain MX records must be authenticated to prevent spoofing. A backend system (e.g., Payment Gateway, ERP) must expose a webhook endpoint or API to trigger notifications based on payment status changes.
1. Configure Notification Service Channels and Templates
The foundation of any agentless notification strategy is the definition of the channel itself and the template payload structure. In Genesys Cloud, you do not create generic messages; you define templates that map to specific channels like SMS or Email. This ensures type safety and compliance validation before a message leaves the platform.
Navigate to Notifications > Notification Service in the admin UI. Select Create Channel. Choose SMS for payment alerts or Email for detailed invoices. For SMS, select the appropriate carrier profile (e.g., Twilio, MessageBird) previously configured in Telephony settings.
You must define a template that supports dynamic variable substitution. Payment reminders require specific data points such as AccountID, DueDate, and Amount. Do not hardcode currency symbols or text strings inside the channel configuration; use template variables instead to allow for localization later.
Configuration Example:
"name": "PaymentReminder_SMS_Template",
"channelType": "SMS",
"content": "Hello ${CustomerName}, your payment of $${Amount} is due on ${DueDate}. Pay now at ${PaymentLink}. Reply STOP to opt out.",
"variables": [
"name": "CustomerName",
"type": "STRING",
"required": true
"name": "Amount",
"type": "NUMBER",
"required": true
"name": "DueDate",
"type": "DATETIME",
"required": true,
"format": "MM/dd/yyyy"
"name": "PaymentLink",
"type": "STRING",
"required": true
The Trap: The most common failure mode occurs when developers include sensitive payment data directly in the message body, such as full credit card numbers or CVV codes. Even if tokenized, sending partial PANs (Primary Account Numbers) in unencrypted SMS text violates PCI-DSS Requirement 3.2.
Architectural Reasoning:
You must implement a masking strategy at the backend application level before calling the Genesys API. The Amount variable should be masked or represented as a token if the message requires verification of identity beyond the phone number itself. Furthermore, you must ensure the PaymentLink points to an HTTPS endpoint with valid SSL certificates and does not rely on URL parameters that contain PII (Personally Identifiable Information).
2. Establish API-Driven Triggers for Real-Time Alerts
For transactional alerts (e.g., “Payment Received,” “Payment Failed”), a scheduled campaign is inefficient because the event occurs asynchronously in your payment gateway. You must use the Notification Service REST API to trigger messages immediately upon webhook reception.
Create an Integration Application in Admin > Security & Compliance > OAuth. Generate a Client ID and Client Secret. Use these credentials to obtain an access token via the /oauth/token endpoint before attempting any notification delivery calls. This ensures that only authorized backend systems can initiate outbound notifications.
API Endpoint:
POST https://api.mypurecloud.com/api/v2/notificationService/notifications
Authorization: Bearer <ACCESS_TOKEN>
Request Payload:
"templateName": "PaymentReminder_SMS_Template",
"recipient": {
"phoneNumber": "+15550001234"
"variables": {
"CustomerName": "John Doe",
"Amount": "150.00",
"DueDate": "2023-11-15T17:00:00Z",
"PaymentLink": "https://pay.example.com/link/secure_token_abc"
The Trap: Developers often attempt to use the customer’s raw phone number stored in their CRM as the phoneNumber field directly. If this number is not E.164 formatted (e.g., +15550001234), the delivery will fail silently or result in routing errors with international carriers.
Implement a normalization layer in your middleware before calling the API. Do not trust incoming data formats from legacy systems. Validate the E.164 format using a regex library within the integration code. Additionally, you must handle rate limiting. Genesys Cloud enforces soft limits on outbound notifications per second. If your payment gateway spikes during a billing cycle, exceeding these limits will result in HTTP 429 responses. Implement exponential backoff logic in your integration script to queue and retry failed requests without overwhelming the platform.
3. Configure Scheduled Campaigns for Recurring Reminders
While API triggers handle transactional events, scheduled campaigns are required for recurring reminders (e.g., “Payment Due in 7 days”). Genesys Cloud allows you to create Outbound Campaigns that utilize Notification Service templates rather than voice dialing.
Navigate to Campaigns > Create Campaign. Select Notification as the campaign type. Define a schedule using the cron expression syntax supported by the platform. You must map the external data source (CSV or Database) containing customer records to the template variables defined in Step 1.
For payment reminders, you should implement a “Staggered” approach. Do not send all reminders at midnight UTC. This causes unnecessary load on your payment gateway link and creates a spike in user engagement that may confuse analytics. Instead, configure the campaign to distribute deliveries over an 8-hour window aligned with the recipient’s local time zone.
Configuration Logic:
- Data Source: Upload a CSV containing
ContactID,PhoneNumber, andPaymentStatus. - Filtering: Use Expression Builder to exclude customers who have already paid. Example expression:
{{contact.PaymentStatus}} != 'PAID'. - Scheduling: Set the start time to 08:00 local time for each region.
The Trap: A frequent error is configuring the campaign to run daily without a “throttle” or “max attempts” limit. If a customer has an outstanding balance, you do not want to bombard them with SMS messages every day until they pay. This leads to high opt-out rates and potential carrier blocklisting.
Implement a logic gate in the campaign configuration that checks for “Last Contacted Date.” If a reminder was sent within the last 24 hours, do not schedule another attempt. This requires a data join operation between your external billing system and the Genesys contact database. Alternatively, use the Campaign > Contact API to update the Contact object with a flag like LastReminderSent after each successful delivery. This prevents duplicate messaging loops and respects carrier frequency caps.
Edge Case 1: Time Zone Discrepancies in Recipient Delivery
The Failure Condition: A payment reminder is scheduled for 09:00 UTC. The recipient resides in New York (EST/EDT). The message arrives at 04:00 EST, which is outside of reasonable communication hours. This leads to customer complaints and lower engagement rates.
The Root Cause: Genesys Cloud Campaigns often default to the organization’s configured time zone or UTC for scheduling logic unless explicitly overridden by contact attributes. If the PhoneNumber attribute does not carry a TimeZone value, the platform cannot calculate local delivery windows accurately.
The Solution:
Ensure your data ingestion pipeline maps the user’s location to a Genesys Contact attribute named preferred_timezone. During Campaign configuration, enable the “Use Local Time Zone for Delivery” option and map it to this attribute. Validate that the phone number lookup returns the correct region code associated with the time zone. If you are using API triggers, pass the timestamp in UTC but instruct the notification engine to schedule delivery based on the recipient’s TimeZone metadata if available.
Edge Case 2: Opt-Out Synchronization Across Channels
The Failure Condition: A customer replies “STOP” to an SMS payment reminder. They subsequently receive an Email payment alert because the SMS opt-out status was not propagated to the Email channel configuration.
The Root Cause: Genesys Cloud treats SMS and Email as distinct channels under the Notification Service umbrella, but compliance mandates a unified opt-out state for a specific contact regarding marketing or transactional notifications depending on jurisdiction. If your system manages opt-outs in an external CRM without syncing back to Genesys, you risk regulatory fines under TCPA (USA) or GDPR (EU).
The Solution:
Implement a webhook listener on the Genesys Cloud side that captures optout events from the Notification Service logs. When an SMS opt-out is received, immediately trigger a backend function that updates the global “Do Not Contact” flag for that customer in your CRM and Genesys Contact Center. Ensure your Email campaign logic queries this flag before executing. The API payload should include a field to check isOptedOut prior to sending.
API Check Logic:
"endpoint": "/api/v1/contact/status",
"method": "GET",
"params": {
"response_validation": {
"field": "globalOptOutStatus",
"condition": "equals",
"value": "FALSE"
Edge Case 3: Delivery Latency During High Load
The Failure Condition: During a billing cycle, the payment gateway sends thousands of transaction webhooks simultaneously. The Notification Service queue backs up, and customers receive payment confirmations hours after the transaction occurred. This erodes trust in the automated system.
The Root Cause: Genesys Cloud processes notifications asynchronously by default to ensure platform stability during peak loads. If the integration does not handle asynchronous responses correctly, the backend application may treat a “200 OK” as final delivery confirmation before the message actually leaves the gateway.
The Solution:
Implement an idempotent retry mechanism in your integration layer. When you receive a 202 Accepted status from the Notification Service API, do not mark the transaction as “Complete.” Instead, poll the notification status endpoint /notificationService/notifications/{notificationId} with a timeout window of 60 seconds. If the status remains pending, trigger a retry with exponential backoff. Monitor the deliveryStatus field in the response payload. If it returns DELIVERED, then close the transaction log entry. This ensures that your payment reconciliation system only considers a notification successful once the carrier confirms receipt.
