Implementing After-Call Work (ACW) Auto-Timeout Enforcement with Configurable Grace Periods
This guide details the configuration and API-driven enforcement of After-Call Work (ACW) duration limits within Genesys Cloud CX, specifically implementing a dynamic grace period mechanism that overrides standard static settings. Upon completion, you will possess a production-ready architecture where agents are automatically transitioned from ACW to Ready state after a configurable window, including an optional buffer period before enforcement triggers. The solution utilizes the Users API for duration configuration and Architect flows for state management logic to ensure compliance without manual supervision.
To implement this architecture, you require specific licensing tiers and permission sets that are often overlooked during initial deployment phases.
Licensing Requirements:
  • Genesys Cloud CX License: Users must hold a standard Contact Center license (License Tier 1 or higher). ACW customization features are available across all paid tiers but require Admin access for configuration.
  • Architect Add-on: Access to the Architect flow editor is mandatory for implementing the logic that triggers the grace period enforcement. Standard ACW timeouts can be managed via UI, but configurable grace periods require flow-based intervention.
  • API Access: The implementation relies on the v2 REST API. You must have a valid OAuth 2.0 access token generated from an application with appropriate scopes.
Granular Permissions:
The following permissions are required for the accounts executing this configuration:
  • User > Edit: Allows modification of user-specific ACW duration properties via API.
  • Architect > Run: Permits execution of flows that manipulate agent states.
  • API Client > Read/Write: Required for any external orchestration scripts managing the enforcement loop.
  • Admin > Settings > Telephony: Needed to verify global timeout policies if they conflict with user settings.
OAuth Scopes:
When generating tokens for the API integration, ensure the following scopes are included in the token request payload:
  • genesys-cloud:user (read/write)
  • genesys-cloud:architect (run)
External Dependencies:
This solution assumes an external orchestration layer (e.g., a Python script, Node.js service, or integration middleware) is available to poll agent states or trigger API calls. Native Genesys Cloud does not allow external scripts to push state changes without this bridge.
1. Configuring Base ACW Duration via User Settings
The foundational layer of this solution involves establishing the standard After-Call Work duration for each user. In Genesys Cloud, every user has a property named acwDuration which defines the time in seconds they remain in the ACW state after a call disconnects before being forced back to Ready.
To implement a configurable grace period, you must first define the “Hard Limit” (the maximum time an agent can stay in ACW) and then layer logic on top of it. You cannot configure a “grace period” directly within the standard UI settings; the UI only accepts a single duration value. Therefore, the architecture requires setting the Hard Limit via API and using Architect to manage the Grace Period logic.
Configuration Steps:
  1. Retrieve the current user configuration using the GET endpoint.
  2. Update the acwDuration field to reflect the maximum allowable time (Hard Limit).
  3. Ensure the statusId is set to a valid state ID representing ACW if custom states are used, though standard ACW states apply by default.
Production-Ready API Request:
The following JSON payload demonstrates updating a user’s ACW duration to 180 seconds (3 minutes) via the PATCH endpoint. This serves as the Hard Limit enforcement baseline.
PATCH https://api.mypurecloud.com/api/v2/users/{userId}
Authorization: Bearer {accessToken}
    "acwDuration": 180,
    "statusId": "5d3c7f4a-9b2e-4f1a-8c3d-6e5f4a3b2c1d"
The Trap:
A common misconfiguration occurs when administrators attempt to set the acwDuration via the UI and then expect the API to override it dynamically. The UI settings are static snapshots. If you modify a user’s ACW duration in the UI, any subsequent API calls that do not include the updated value will revert the setting to the previous state upon save.
Architectural Reasoning:
We set the Hard Limit via API because it allows programmatic control based on business rules (e.g., different durations for VIP queues). The UI does not support conditional duration logic. By using the API, we decouple the enforcement logic from the user profile, allowing a single orchestration service to manage thousands of agents with varying grace periods without logging into the Admin UI.
2. Implementing Grace Period Logic via Architect Flow
The standard acwDuration setting forces an agent back to Ready immediately upon expiration. To introduce a “Grace Period,” we must intercept the state transition and allow a buffer before the final enforcement occurs. This is achieved by creating a custom flow that runs during the ACW period or by utilizing the Force ACW Timeout endpoint logic in conjunction with Architect.
The most robust method involves using an Architect flow triggered at the end of a call (Post-Call Flow) to manage the state transition. However, since agents are technically “off-call” during ACW, we utilize the State Management capabilities within Architect to check elapsed time and force the agent back if they exceed the grace threshold.
Implementation Steps:
  1. Create a new flow named ACW_Grace_Enforcement.
  2. Add a Wait node set to the Grace Period duration (e.g., 30 seconds).
  3. Connect the Wait node to a decision node that checks the user’s current state via API or variable check.
  4. If the agent remains in ACW after the wait, trigger a flow action that forces the state change.
Architect Flow Logic:
The following logic must be embedded in the flow entry point for the specific queue or user group requiring grace period enforcement:
  • Trigger: Call End (Post-Call)
  • Action: Set User Variable Grace_Period_Start_Time to CurrentTimestamp.
  • Wait Node: Duration = Grace_Duration_Seconds (e.g., 30).
  • API Action: Check current user state.
  • Decision Node: If User_Status == ACW, then Force Transition to Ready.
Production-Ready Flow Snippet (JSON Representation):
While Architect flows are visual, the underlying logic corresponds to the following node configuration structure used in programmatic flow creation or debugging:
    "type": "WAIT",
    "waitTimeSeconds": 30,
    "label": "Grace_Period_Wait",
    "exitOnDisconnect": false,
    "interruptable": true
The Trap:
The most critical failure mode in this step is the Interruptible Flag. If the Wait node is not marked as interruptible, the agent cannot be forced out of the wait state by an external API call if a supervisor needs to intervene. Conversely, if it is interruptible but lacks the proper permission scopes for flow execution, the system will silently fail to transition the user back to Ready during enforcement.
We use a Wait node instead of a simple Timer because the Agent state must be verified before forcing a transition. Simply waiting 30 seconds does not guarantee the agent is still in ACW; they might have already returned to Ready manually. The flow logic ensures we only enforce the timeout if the agent remains unresponsive, preserving manual control for valid reasons (e.g., complex notes entry). This prevents unnecessary interruptions that could degrade quality scores or cause data loss in CRM integrations.
3. API-Driven Enforcement Loop
For environments requiring strict compliance where Architect flows might not be sufficient or when managing users across multiple queues, a dedicated enforcement loop via the REST API is necessary. This component polls agent states and triggers the transition if the threshold is exceeded.
This requires an external service that runs periodically (e.g., every 10 seconds) to query active agents in ACW state. If an agent’s ACW duration exceeds the configured Hard Limit plus Grace Period, the service issues a PATCH request to force the status change.
API Enforcement Endpoint:
The endpoint used to update user states programmatically is PATCH /api/v2/users/{userId}. To force a transition out of ACW, you must set the statusId to the ID of the Ready state.
Production-Ready Enforcement Payload:
This payload is sent by your orchestration service when an agent violates the grace period policy.
    "statusId": "5d3c7f4a-9b2e-4f1a-8c3d-6e5f4a3b2c1d",
    "statusName": "Ready",
    "acwDuration": 0,
    "notes": "Force Transited via Grace Period Enforcement API"
The Trap:
A frequent error in enforcement loops is the Race Condition. If the orchestration service and the Genesys Cloud backend process state changes simultaneously, you may encounter a 409 Conflict error or an HTTP 500 Internal Server Error. This occurs when the agent manually changes their own status while the API is attempting to force it.
We implement a retry logic with exponential backoff in the orchestration service to handle these race conditions gracefully. If a 409 is returned, the service logs the event and does not increment the violation counter for that specific user, as this indicates manual compliance rather than policy violation. Additionally, we set acwDuration to 0 during the force transition to prevent the timer from restarting immediately after the status change, ensuring a clean state reset.
Edge Case 1: Agent Manual Override During Grace Period
The Failure Condition: An agent manually transitions themselves to Ready before the grace period expires. The enforcement logic subsequently detects this and logs a false positive violation because it assumes the agent was still in ACW.
The Root Cause: The enforcement loop relies on polling data that may have a slight latency (up to 5 seconds) compared to the real-time state change. When the API poll queries the user status, it sees Ready, but the logic assumes the timer has not expired yet based on the start timestamp.
The Solution: Implement a state verification step before logging violations. The orchestration service must query GET /api/v2/users/{userId}/status immediately before forcing the transition. If the status is already Ready or Not-Ready, abort the enforcement action and log it as “Already Compliant.” This ensures that manual overrides do not trigger false alarms in your compliance dashboard.
Edge Case 2: API Rate Limiting During Peak Load
The Failure Condition: The enforcement loop hits Genesys Cloud API rate limits during high-volume periods, causing delayed state transitions. Agents remain in ACW longer than the configured Hard Limit because the enforcement call is throttled.
The Root Cause: The default rate limit for User Management endpoints is 100 requests per second per organization. In a large contact center with thousands of agents, polling every 10 seconds can easily exceed this threshold during peak traffic times.
The Solution: Implement request batching or queuing in the orchestration service. Instead of hitting the API for every user individually, group state queries into batches where possible (using the GET /api/v2/users endpoint with pagination) to reduce overhead. Additionally, implement a dynamic polling interval that increases during high-load periods to stay within the 90th percentile of the rate limit, ensuring enforcement does not degrade the API performance for other critical operations like call routing.
Edge Case 3: Flow Execution Failure Due to State Lock
The Failure Condition: The Architect flow intended to manage the grace period fails to execute because the user state is locked by a concurrent operation (e.g., a supervisor changing the agent’s status or a system maintenance task).
The Root Cause: Genesys Cloud prevents flow execution if the user is in a transition state. If the Agent moves from ACW to Ready while the flow is waiting, the flow context may be invalidated before it can check the condition.
The Solution: Add a Try/Catch mechanism within the flow logic that handles interruption exceptions. In Architect, configure the Flow Execution settings to allow asynchronous execution where possible. If using API-based enforcement, add a statusId validation step in the payload to ensure the user is currently in the expected state before attempting the transition. If the status does not match, ignore the request and wait for the next polling cycle.
Appendix: Compliance Checklist
Before deploying this solution to production, verify the following items:
  • All user accounts targeted have valid OAuth scopes (User > Edit).
  • Architect flows are tested in a sandbox environment with no impact on live traffic.
  • Orchestration service has sufficient retry logic for API rate limits (minimum 3 retries).
  • Grace Period duration is validated against business SLA requirements to ensure customer experience is not degraded by forced disconnections.
  • Audit logs are configured to capture all enforcement actions for compliance reporting.
