Implementing Advanced SAML JIT Provisioning with Conditional Custom Attribute Mapping
- Architecting a JIT (Just-In-Time) provisioning strategy for Genesys Cloud CX.
- Implementing Custom SAML Attribute Mapping to populate secondary user fields (e.g., Department, Title, Employee ID).
- Designing conditional logic to ensure data integrity during the “Auto-Provisioning” lifecycle.
- Licensing: Genesys Cloud CX 1/2/3.
- Identity Provider: Any SAML 2.0 compliant IdP (Okta, Azure AD, PingIdentity).
- Permissions:
Integrations > Single Sign-On > Add/EditDirectory > User > Add/View
1. The Strategy: The “Zero-Effort” Onboarding
JIT Provisioning allows users to be created in Genesys Cloud automatically the first time they log in via SSO. This eliminates the need for manual CSV imports or separate SCIM syncs for non-agent staff.
The Strategy:
- The Policy: All “Casual Users” (non-agents) are provisioned via JIT. Agents are provisioned via SCIM for immediate skill assignment.
- The Mechanism: Enable the “Provision users on their first login” toggle in the SSO configuration.
- The Workflow:
- User navigates to Genesys Cloud Login → Redirect to IdP.
- IdP authenticates and sends SAML Assertion.
- Genesys Cloud sees the user doesn’t exist → Creates account using SAML data.
2. Implementing Custom Attribute Mapping
The standard SAML assertion only provides the email and name. To make the Directory useful, you need custom fields.
The Implementation:
- IdP Config: Configure your IdP to send additional attributes:
department:SalesemployeeID:EMP-12345location:Chicago
- Genesys Mapping: In Admin > Integrations > Single Sign-On, go to Attribute Mapping.
- The Mapping:
- Map
departmentto the GenesysDepartmentfield. - Map
employeeIDto theEmployee IDfield.
- Map
- The Benefit: The user’s profile is fully populated and searchable in the internal directory from the moment they first arrive.
3. Conditional Custom Attribute Logic
In some scenarios, you only want to update certain fields during the initial provisioning, while other fields should be updated on every login.
The Strategy:
- The Trap: If you map a field like
title, and a user manually changes it in Genesys, it will be overwritten by the IdP value at the next login. - The Solution: Use the “Update user attributes on each login” setting strategically.
- If Enabled: IdP is the source of truth for all mapped fields.
- If Disabled: IdP only sets the fields during the first creation.
- Architectural Reasoning: For organizations where supervisors manage skills manually in Genesys, disabling “Update on each login” is essential to prevent the IdP from stripping skills it doesn’t know about.
4. Handling JIT Provisioning for External Partners
If you allow BPO partners to log in via their own IdP (Federation), JIT is critical.
The Implementation:
- External Org Trust: Set up a separate SSO integration for the Partner Org.
- The Division Lock: Use the Default Division setting in the SSO configuration to ensure all JIT-provisioned users from this specific IdP are placed into a “Partner Division.”
- The Safety Net: This ensures that external partners cannot see internal employees or sensitive queues, even if they are auto-provisioned.
Edge Case 1: Name Format Mismatches
Failure Condition: The IdP sends givenName and sn separately, but Genesys expects displayName.
Solution: Most IdPs (like Okta or Azure AD) allow you to create a Computed Attribute in the SAML statement. Create a new attribute full_name that concatenates the two fields before sending it to Genesys.
Edge Case 2: The “Duplicate Identifier” 409 Error
Failure Condition: A user attempts to log in, but JIT fails because another user already has the same Employee ID.
Solution: Audit your IdP data for uniqueness. JIT will fail if it violates any database constraints in Genesys Cloud. Use the SSO Diagnostic Logs in Genesys to find the specific field causing the conflict.
Edge Case 3: Auto-Provisioning Role Caps
Failure Condition: JIT creates 500 users, but you only have 100 licenses.
Solution: Genesys will stop creating users once the license limit is reached. Implement Group Filtering in your IdP so only authorized users are even allowed to attempt the login, preventing the “accidental” consumption of licenses by unauthorized staff.
