Implementing Absence Pattern Detection Algorithms for Identifying Attendance Trend Anomalies
This guide details the architectural design and implementation of a statistical absence pattern detection pipeline that ingests Workforce Management (WFM/WEM) attendance data, computes rolling baseline deviations, and classifies attendance trend anomalies. When complete, you will have a production-ready service that outputs scored anomaly events, integrates them back into your CCaaS platform via custom attributes or webhooks, and triggers targeted supervisory alerts without degrading native WEM performance.
- Platform Licensing: Genesys Cloud CX 3 or higher with the WEM (Workforce Engagement Management) Add-on. For NICE CXone, Enterprise WFM license with Data Hub access.
- User Permissions (Genesys Cloud):
analytics:report:view,wfm:user:view,wfm:absence:view,user:custom-attribute:view,user:custom-attribute:update - OAuth Scopes:
wfm:absence:view,analytics:report:read,user:custom-attribute:write - External Dependencies:
- Time-series storage (PostgreSQL with TimescaleDB extension or InfluxDB) for baseline persistence
- Compute environment capable of executing scheduled Python/Node.js workers (AWS Lambda, Azure Functions, or dedicated container orchestrator)
- Authentication proxy to handle OAuth 2.0 token rotation and refresh logic
- Cross-Platform Note: The algorithmic logic applies identically to NICE CXone, but data ingestion relies on the NICE CXone Data Hub REST API (
/api/v2/wfm/attendance) instead of Genesys WEM endpoints. Reference the WFM Data Export guide for schema mapping differences.
1. Data Ingestion & Temporal Normalization
Raw WEM absence records are transactional, not analytical. They contain status transitions, shift boundaries, and platform-level overrides that fragment attendance signals. Your pipeline must aggregate these into consistent temporal windows before any statistical computation occurs.
Begin by querying the WEM absence API with a rolling 90-day lookback. This window provides sufficient historical depth to establish individual agent baselines while excluding stale seasonal patterns. Use server-side pagination to avoid memory exhaustion during bulk pulls.
API Request Structure:
GET /api/v2/analytics/wfm/users/absences?dateFrom=2024-01-01T00:00:00Z&dateTo=2024-03-31T23:59:59Z&pageSize=200&page=1
Authorization: Bearer <ACCESS_TOKEN>
Accept: application/json
Response Payload Fragment:
"page": 1,
"pageSize": 200,
"totalCount": 4820,
"entities": [
"userId": "a1b2c3d4-e5f6-7890-abcd-ef1234567890",
"userEmail": "agent.name@example.com",
"absenceId": "abs-98765432",
"status": "SICK",
"startTime": "2024-02-14T08:00:00Z",
"endTime": "2024-02-14T16:30:00Z",
"durationSeconds": 30600,
"shiftId": "shift-112233",
"shiftStartTime": "2024-02-14T07:45:00Z",
"shiftEndTime": "2024-02-14T17:00:00Z"
Normalize each record to a daily granularity per user. Calculate the absence ratio as durationSeconds / shiftDurationSeconds. Store the normalized record in your time-series database with the following schema:
user_id(UUID)record_date(DATE)absence_ratio(FLOAT)absence_category(VARCHAR)shift_pattern_id(VARCHAR)ingested_at(TIMESTAMPTZ)
The Trap: Ingesting absence data without aligning to the agent’s native shift start time. WEM exports timestamps in UTC, but attendance patterns are biologically and operationally tied to local shift boundaries. An agent working 22:00 to 06:00 local time will have their absence split across two calendar days in UTC. If you aggregate by UTC calendar day, a single 8-hour absence becomes two 4-hour fragments. The algorithm interprets this as two separate partial absences, destroying pattern continuity and inflating false positive rates by 34 to 47 percent in shift-work environments.
Architectural Reasoning: We normalize to the shift boundary before aggregation. The pipeline converts startTime and endTime to the agent’s timezone, calculates overlap with the scheduled shift window, and attributes the entire absence ratio to the calendar day containing the shift start. This preserves the operational reality of attendance tracking. WFM systems measure adherence against scheduled blocks, not atomic timezones. Aligning to shift boundaries ensures the statistical engine evaluates actual work commitments rather than arbitrary calendar slices.
2. Rolling Baseline & Statistical Deviation Engine
Pattern detection requires a dynamic reference frame. Static thresholds fail because attendance baselines drift with seasonality, role changes, and macroeconomic factors. Implement a double-layer rolling baseline using an Exponential Moving Average (EMA) combined with a Modified Z-Score calculation.
The EMA tracks the agent’s individual attendance trend, while the Modified Z-Score measures deviation from the median of the recent window. This approach resists outlier contamination better than standard deviation methods.
Algorithm Implementation (Python):
import numpy as np
from scipy import stats
from datetime import timedelta
class AbsencePatternDetector:
def __init__(self, window_size: int = 30, ema_alpha: float = 0.3, anomaly_threshold: float = 2.5):
self.window_size = window_size
self.ema_alpha = ema_alpha
self.anomaly_threshold = anomaly_threshold
def compute_ema(self, values: list[float]) -> list[float]:
ema = [values[0]]
for val in values[1:]:
ema.append(self.ema_alpha * val + (1 - self.ema_alpha) * ema[-1])
return ema
def modified_z_score(self, values: list[float]) -> float:
median = np.median(values)
mad = np.median(np.abs(np.array(values) - median))
if mad == 0:
return 0.0
return 0.6745 * (values[-1] - median) / mad
def evaluate_user_pattern(self, daily_ratios: list[float]) -> dict:
if len(daily_ratios) < self.window_size:
return {"anomaly_score": 0.0, "classification": "INSUFFICIENT_DATA"}
recent_window = daily_ratios[-self.window_size:]
ema_trend = self.compute_ema(recent_window)
trend_direction = ema_trend[-1] - ema_trend[0]
deviation = self.modified_z_score(recent_window)
is_anomalous = abs(deviation) > self.anomaly_threshold
"anomaly_score": round(abs(deviation), 3),
"trend_direction": "INCREASING" if trend_direction > 0.05 else ("DECREASING" if trend_direction < -0.05 else "STABLE"),
"classification": "ANOMALY" if is_anomalous else "NORMAL",
"baseline_ema": round(ema_trend[-1], 3),
"window_median": round(np.median(recent_window), 3)
Schedule this engine to execute daily after WEM data sync completes. Feed each agent’s normalized daily absence ratios into evaluate_user_pattern. The function returns an anomaly score, trend direction, and classification. Agents scoring above the threshold trigger downstream actions.
The Trap: Applying a global threshold across all user segments. A 2.5 Modified Z-Score means different things for a high-volume contact center agent versus a specialized technical support engineer. High-turnover roles naturally exhibit higher baseline variance. Using a single threshold forces you to either flood supervisors with noise (low threshold) or miss genuine deterioration patterns in stable roles (high threshold).
Architectural Reasoning: We segment thresholds by role family and tenure bracket before evaluation. The pipeline queries the user metadata API to classify agents into buckets (e.g., Tier1_0to6mo, Tier2_6to24mo, Specialist_24mo+). Each bucket maintains its own anomaly threshold derived from historical 95th percentile deviations. This stratification ensures the algorithm evaluates agents against peers with identical operational constraints. Pattern detection must account for structural variance, not just mathematical variance.
3. Anomaly Classification & Platform Feedback Loop
Detected anomalies require actionable feedback without disrupting native WEM workflows. Direct writes to WEM absence records are prohibited and architecturally unsound. Instead, use custom user attributes for scoring and a webhook dispatcher for real-time alerting.
Create three custom user attributes in the platform:
wfm_anomaly_score(Number)wfm_attendance_trend(Text)wfm_last_pattern_eval(Date)
Push results via the User Custom Attribute API. This preserves WEM data integrity while making pattern metrics available for routing, reporting, and coaching workflows.
PATCH /api/v2/users/{userId}/custom-attributes
Request Payload:
"attributes": [
"name": "wfm_anomaly_score",
"value": "3.842"
"name": "wfm_attendance_trend",
"value": "INCREASING"
"name": "wfm_last_pattern_eval",
"value": "2024-03-15"
Configure a webhook endpoint to receive anomaly events. The dispatcher should batch events by supervisor queue to prevent notification fatigue. Include the anomaly_score, trend_direction, and window_median in the webhook payload so supervisors can contextualize the alert before initiating a coaching conversation.
The Trap: Creating a synchronous write loop between the anomaly engine and the platform. If your webhook triggers a platform action that modifies user status, and that status change feeds back into the WEM absence stream, you generate recursive data mutations. The algorithm re-evaluates the mutated data, flags a new anomaly, and triggers another webhook. This cascade consumes API rate limits and corrupts baseline history.
Architectural Reasoning: We enforce a unidirectional data flow. The pattern detection engine operates in read-only mode regarding WEM absence records. All outputs write exclusively to custom attributes or external alerting systems. Custom attributes are excluded from WEM adherence calculations by design. This isolation guarantees that pattern scoring never influences the raw attendance data it analyzes. You can reference the WFM Data Governance guide for attribute isolation best practices.
Edge Case 1: Shift Rotation Baseline Contamination
The Failure Condition: An agent transitions from a day shift pattern to a night shift pattern. The algorithm flags a sudden attendance anomaly despite the agent maintaining identical attendance behavior.
The Root Cause: The rolling baseline retains the previous shift’s historical absence ratios. Night shift patterns often exhibit different absence categories (e.g., higher fatigue-related partial absences). The algorithm interprets the category shift as a deterioration trend rather than a structural pattern change.
The Solution: Implement a baseline reset trigger. Query the schedule change API to detect shift pattern modifications. When a pattern change exceeds a threshold (e.g., shift start time delta > 4 hours), flush the EMA window and initialize a cold-start baseline using the new pattern’s first 14 days. Tag the user with a WARMING_UP classification to suppress anomaly alerts during the stabilization period.
Edge Case 2: WEM Data Sync Latency & Stale Window Calculations
The Failure Condition: The pattern engine executes before WEM finishes processing end-of-day adherence reconciliations. The algorithm evaluates incomplete absence records, producing artificially low baseline medians and triggering false anomaly classifications.
The Root Cause: WEM performs asynchronous post-processing for status overrides, manual corrections, and carrier-level sync adjustments. These operations can delay final absence record commits by 15 to 45 minutes past shift end.
The Solution: Implement a dependency check before engine execution. Poll the WEM data freshness API endpoint (GET /api/v2/wfm/data/freshness) to verify lastSyncTimestamp matches the expected cutoff. If the timestamp lags beyond a 30-minute tolerance, defer execution and queue the run for the next interval. Cache previous day’s results to prevent dashboard staleness. This approach aligns with the recommended WEM data pipeline timing documented in the platform integration standards.
