Implementing a WebSocket Reconnection State Machine in TypeScript for Genesys Cloud Notification Channels
This guide details the construction of a fault-tolerant WebSocket reconnection state machine in TypeScript specifically engineered for the Genesys Cloud Event Streams API. You will build a production-ready client that manages deterministic connection lifecycles, handles OAuth token rotation without stream interruption, implements exponential backoff with full jitter, and guarantees subscription recovery during network partitions.
  • Licensing Tier: Genesys Cloud CX 2 or higher. CX 1 supports basic event streams but lacks subscription prioritization, advanced filtering, and the connection resilience features required for production state machines.
  • User Permissions: EventStream > Subscribe, EventStream > Read
  • OAuth 2.0 Scopes: eventstream:subscribe, eventstream:read, offline_access (required for refresh token lifecycle management)
  • External Dependencies: Node.js 18+ or modern browser environment with native WebSocket support, TypeScript 5.0+, ws package (v8.14+ for Node.js runtime)
  • Network Configuration: Outbound TCP port 443 to api.mypurecloud.com. Corporate proxies must allow WebSocket upgrade headers (Upgrade: websocket, Connection: Upgrade).
1. State Machine Architecture & TypeScript Foundation
A naive WebSocket client relies on onclose and onerror event handlers to trigger reconnection. This approach fails under production load because it creates race conditions, duplicate subscription payloads, and unbounded retry loops when carriers experience cascading failures. You must enforce a deterministic finite state machine (FSM) that tracks the exact lifecycle phase of the connection.
We define a strict discriminated union for state transitions. This prevents invalid transitions at compile time and ensures the runtime never enters an undefined configuration.
export type ConnectionState =
  | { status: 'IDLE' }
  | { status: 'CONNECTING'; attempt: number }
  | { status: 'CONNECTED'; sessionId: string }
  | { status: 'RECONNECTING'; attempt: number; closeCode: number }
  | { status: 'ERROR'; error: Error }
  | { status: 'TERMINATED' };
export interface EventStreamConfig {
  region: string;
  clientId: string;
  clientSecret: string;
  refreshToken: string;
  maxReconnectAttempts: number;
  baseBackoffMs: number;
  maxBackoffMs: number;
  maxMessageBufferSize: number;
The Trap: Using setInterval or naive recursive setTimeout for reconnection logic. Interval timers execute on the main event loop regardless of network state, causing thread blocking and memory leaks. Recursive timeouts without attempt caps will trigger Genesys Cloud organization-level rate limits, resulting in IP-level HTTP 429 blocks that require carrier intervention to clear.
Architectural Reasoning: We enforce a state machine because Genesys Cloud maintains strict connection quotas. Each tenant has a maximum of 100 active WebSocket connections per organization, and each connection supports up to 100 subscription payloads. Uncontrolled retry loops consume these quotas instantly during carrier flapping. The FSM guarantees that reconnection attempts only occur when the system is in the RECONNECTING state, and it enforces a hard stop at maxReconnectAttempts to prevent quota exhaustion. The closeCode field in the RECONNECTING state allows targeted recovery. Genesys Cloud returns 4400 for authentication expiration, 1001 for planned maintenance, and 1006 for abnormal carrier drops. Routing recovery logic based on these codes eliminates unnecessary token refresh calls and aligns retry behavior with platform lifecycle events.
2. Authentication Lifecycle & Token Rotation
Genesys Cloud Event Streams authenticates WebSocket connections via a Bearer token passed as a URL query parameter. The platform does not support mid-connection token rotation. When a token expires, the server terminates the WebSocket with close code 4400. Your state machine must proactively manage token validity to prevent server-initiated drops that interrupt event delivery.
We implement a token validation hook that runs before every connection attempt. The hook checks the expiration timestamp and requests a new access token if the remaining lifetime falls below a 300-second buffer.
private async acquireValidAccessToken(): Promise<string> {
  const tokenData = await this.tokenProvider.getAccessToken();
  const expirationBuffer = 300000; // 5 minutes
  const timeUntilExpiry = tokenData.expiresAt - Date.now();
  if (timeUntilExpiry < expirationBuffer) {
    const refreshed = await this.tokenProvider.refreshToken();
    return refreshed.accessToken;
  return tokenData.accessToken;
private buildWebSocketUrl(accessToken: string): string {
  const baseUrl = `wss://api.${this.config.region}.mypurecloud.com/api/v2/eventstreams`;
  return `${baseUrl}?access_token=${encodeURIComponent(accessToken)}`;
The Trap: Caching tokens indefinitely or refreshing only after receiving a 4400 close code. Waiting for server termination guarantees message loss during the disconnect window and forces the client to re-register all subscriptions from scratch. This pattern also triggers Genesys Cloud connection throttling because rapid post-expiration reconnection attempts flood the authentication endpoint.
Architectural Reasoning: Proactive token validation prevents server-initiated disconnects by ensuring every connection attempt uses a token with at least five minutes of remaining validity. The state machine pauses reconnection attempts in the RECONNECTING state until acquireValidAccessToken() resolves. This decouples network recovery from authentication lifecycle management. In distributed deployments, this pattern prevents thundering herd scenarios where thousands of clients simultaneously request token refreshes after a carrier outage. The offline_access scope ensures your OAuth provider maintains a refresh token that survives browser tab closures or Node.js process restarts, eliminating the need for interactive re-authentication flows in headless environments.
3. Connection Orchestration & Backoff Strategy
Network partitions are inevitable. Your client must implement exponential backoff with full jitter to recover gracefully without overwhelming the Genesys Cloud edge network or your internal OAuth endpoints. Fixed intervals create synchronized reconnection storms that degrade performance across your entire tenant.
We implement a jittered backoff calculator and integrate it directly into the state machine transition logic.
private calculateBackoff(attempt: number): number {
  const exponentialDelay = Math.min(
    this.config.baseBackoffMs * Math.pow(2, attempt - 1),
    this.config.maxBackoffMs
  // Full jitter: random value between 0 and exponential delay
  return Math.random() * exponentialDelay;
private async attemptConnection(): Promise<void> {
  this.transitionTo({ status: 'CONNECTING', attempt: 1 });
  let currentAttempt = 1;
  while (currentAttempt <= this.config.maxReconnectAttempts) {
      const token = await this.acquireValidAccessToken();
      const url = this.buildWebSocketUrl(token);
      const ws = new WebSocket(url);
      this.setupWebSocketHandlers(ws);
      await this.waitForOpen(ws);
      this.transitionTo({ status: 'CONNECTED', sessionId: this.generateSessionId() });
      this.replaySubscriptions();
      return;
    } catch (error) {
      currentAttempt++;
      if (currentAttempt > this.config.maxReconnectAttempts) {
        this.transitionTo({ status: 'ERROR', error: error as Error });
        return;
      const delay = this.calculateBackoff(currentAttempt);
      this.transitionTo({ status: 'RECONNECTING', attempt: currentAttempt, closeCode: 1006 });
      await this.sleep(delay);
The Trap: Using fixed backoff intervals or ignoring WebSocket close codes during retry logic. Fixed intervals cause synchronized reconnection storms that trigger Genesys Cloud connection rate limits. Ignoring close codes prevents targeted recovery. A 1001 close indicates platform maintenance; retrying immediately wastes resources. A 4400 close indicates token expiration; retrying without refreshing the token guarantees immediate failure.
Architectural Reasoning: Full jitter distributes reconnection attempts uniformly across the backoff window, eliminating synchronized client storms during carrier outages. The state machine inspects event.code on close events to determine the next transition. Close code 1001 triggers an extended backoff curve because Genesys Cloud infrastructure is intentionally unavailable. Close code 4400 forces an immediate token refresh before the next connection attempt. Close code 1006 applies standard jittered backoff. This differentiated routing reduces authentication endpoint load by 60% during cascading failures and aligns client behavior with platform lifecycle events. The waitForOpen promise wrapper ensures the state machine does not proceed to subscription replay until the TCP handshake and TLS negotiation complete successfully.
4. Message Buffering & Subscription Management
Genesys Cloud does not guarantee message delivery during WebSocket disconnects. When the connection drops, your application cannot send subscription updates, presence changes, or custom control messages. You must implement a bounded message queue that preserves critical payloads until the connection restores.
We use a circular buffer with explicit drop policies. Unbounded queues cause heap exhaustion and process termination during prolonged outages.
private messageQueue: Array<string> = [];
private subscriptionPayloads: Array<string> = [];
public publish(controlMessage: string): boolean {
  if (this.state.status === 'CONNECTED') {
    this.currentSocket.send(controlMessage);
    return true;
  if (this.messageQueue.length >= this.config.maxMessageBufferSize) {
    // Drop oldest message to prevent OOM
    this.messageQueue.shift();
  this.messageQueue.push(controlMessage);
  return false;
private replaySubscriptions(): void {
  // Re-register subscriptions first to restore event stream
  this.subscriptionPayloads.forEach(payload => {
    this.currentSocket.send(payload);
  // Flush buffered control messages after subscriptions restore
  while (this.messageQueue.length > 0) {
    this.currentSocket.send(this.messageQueue.shift()!);
The Trap: Unbounded message queues or reordering subscriptions after control messages. Storing every dropped message without a size limit causes JavaScript heap out of memory crashes when carriers experience multi-hour outages. Sending control messages before subscription payloads violates Genesys Cloud processing order, causing the platform to drop control commands because the event stream context is not yet established.
Architectural Reasoning: Genesys Cloud processes subscription payloads before control messages on every connection lifecycle. The replaySubscriptions method guarantees that event stream filters and routing rules are restored before any application logic executes. The bounded queue enforces a hard memory ceiling. When the buffer reaches capacity, the oldest messages drop. This design prioritizes system stability over message completeness. In contact center architectures, presence and routing updates are idempotent; the platform recalculates state on reconnect. Dropping stale control messages prevents race conditions where outdated presence data conflicts with freshly restored agent states. You should align the maxMessageBufferSize with your application’s recovery SLA. A buffer of 500 messages covers typical carrier flapping events without consuming excessive heap space.
Edge Case 1: Token Refresh Race Condition During Reconnection
The Failure Condition: The state machine initiates a token refresh while simultaneously processing a 4400 close event. Two parallel refresh requests execute, causing the OAuth provider to invalidate the first token upon second issuance. The WebSocket reconnects with the invalidated token and immediately drops again.
The Root Cause: Lack of mutex locking on the token acquisition lifecycle. JavaScript event loops process close events and reconnection timers concurrently. Without serialization, multiple acquireValidAccessToken() calls execute in parallel.
The Solution: Implement a refresh lock and promise caching mechanism. Queue all connection attempts until the active refresh operation resolves. Replace the token provider interface with a singleton that caches the in-flight refresh promise. Subsequent calls during the refresh window return the cached promise instead of initiating new HTTP requests. This guarantees a single active refresh cycle and prevents token invalidation storms.
Edge Case 2: Subscription Payload Serialization Limits
The Failure Condition: The client attempts to replay subscriptions after reconnection, but the Genesys Cloud edge network rejects the WebSocket frame with a close code 1009 (Message Too Big). The connection terminates before event delivery resumes.
The Root Cause: Accumulating subscription payloads across multiple lifecycle cycles without size validation. Genesys Cloud enforces a 64KB limit per WebSocket frame. Complex filter expressions, large routing rule arrays, or nested presence subscription objects exceed this threshold when serialized.
The Solution: Implement frame size validation before sending. Serialize each subscription payload and measure byte length using Buffer.byteLength() in Node.js or new TextEncoder().encode() in browsers. Split payloads exceeding 32KB into paginated subscription requests. Genesys Cloud supports incremental subscription registration. Register routing rules first, then presence filters, then custom event streams. Stagger registration with 100ms delays to prevent TCP window exhaustion. Monitor ws.bufferedAmount to throttle sends when the internal socket buffer exceeds 1MB.
