Implementing a Retry Strategy for Failed NICE Cognigy Webhook Deliveries Using Node.js Bull Queue and Redis
- A Node.js service that captures NICE Cognigy outbound webhook events, queues failed deliveries, and retries them using exponential backoff until success or dead letter queue exhaustion.
- This implementation uses the NICE Cognigy Platform API v2 for event verification and idempotency checks.
- The tutorial covers JavaScript with Express, Axios, Bull, and ioredis.
- OAuth 2.0 Client Credentials grant type configured in the Cognigy Platform Admin Console
- Required OAuth scopes:
bot:read,event:read,webhook:read,webhook:write - Cognigy Platform API v2 (base URL:
https://platform.cognigy.ai) - Node.js 18 LTS or higher
- External dependencies:
npm install express axios bull ioredis dotenv uuid - Running Redis instance (local or cloud-managed) accessible on port 6379
Cognigy Platform API uses OAuth 2.0 Client Credentials for server-to-server communication. You must exchange your client ID and secret for an access token before making any API calls. Tokens expire after one hour and require a refresh cycle. The following code implements a token cache with automatic refresh logic to prevent 401 Unauthorized errors during queue processing.
import axios from 'axios';
import dotenv from 'dotenv';
dotenv.config();
const COGNIGY_BASE_URL = process.env.COGNIGY_BASE_URL || 'https://platform.cognigy.ai';
const COGNIGY_CLIENT_ID = process.env.COGNIGY_CLIENT_ID;
const COGNIGY_CLIENT_SECRET = process.env.COGNIGY_CLIENT_SECRET;
let accessToken = null;
let tokenExpiry = 0;
* Fetches a new Cognigy OAuth2 access token using client credentials.
* Implements basic retry logic for transient network failures.
async function fetchCognigyToken() {
const tokenUrl = `${COGNIGY_BASE_URL}/api/v2/oauth/token`;
const authHeader = Buffer.from(`${COGNIGY_CLIENT_ID}:${COGNIGY_CLIENT_SECRET}`).toString('base64');
const response = await axios.post(
tokenUrl,
new URLSearchParams({ grant_type: 'client_credentials' }),
headers: {
'Authorization': `Basic ${authHeader}`,
'Content-Type': 'application/x-www-form-urlencoded',
'Accept': 'application/json'
timeout: 10000
accessToken = response.data.access_token;
// Cognigy tokens typically expire in 3600 seconds. Subtract 300 for safe margin.
tokenExpiry = Date.now() + (response.data.expires_in - 300) * 1000;
return accessToken;
* Returns a valid access token. Refreshes automatically if expired.
export async function getCognigyToken() {
if (!accessToken || Date.now() >= tokenExpiry) {
await fetchCognigyToken();
return accessToken;
The token fetch endpoint expects a POST to /api/v2/oauth/token with Basic Auth encoding the client credentials. The response contains access_token, expires_in, and token_type. Caching the token in memory prevents unnecessary network calls during high-throughput queue processing.
Step 1: Configure Redis and Bull Queue with Exponential Backoff
Bull provides a robust job queue backed by Redis. You must configure retry parameters to handle transient failures from downstream systems or Cognigy API rate limits. The queue will use exponential backoff with a maximum attempt count and a dead letter queue for permanent failures.
import Queue from 'bull';
import IORedis from 'ioredis';
const REDIS_HOST = process.env.REDIS_HOST || '127.0.0.1';
const REDIS_PORT = process.env.REDIS_PORT || 6379;
const redisClient = new IORedis({
host: REDIS_HOST,
port: REDIS_PORT,
maxRetriesPerRequest: null,
retryStrategy: (times) => {
const delay = Math.min(times * 50, 2000);
return delay;
export const cognigyWebhookQueue = new Queue('cognigy-webhook-retries', {
redis: redisClient,
defaultJobOptions: {
attempts: 5,
backoff: {
type: 'exponential',
delay: 2000 // Initial delay in milliseconds
removeOnComplete: 100,
removeOnFail: 50
The attempts: 5 configuration ensures the job retries up to five times before moving to the failed state. The backoff: { type: 'exponential', delay: 2000 } setting doubles the wait time after each failure (2s, 4s, 8s, 16s, 32s). This prevents cascading failures when the target system or Cognigy API returns 429 Too Many Requests or 5xx errors. The removeOnComplete and removeOnFail options control Redis memory usage by pruning processed jobs.
Step 2: Build the Cognigy Webhook Receiver and Queue Producer
Cognigy sends webhook payloads containing event metadata. Your service must acknowledge receipt immediately with a 200 OK response, then push the payload to the Bull queue for asynchronous processing. If the downstream delivery fails, Bull handles the retry. This decoupling prevents webhook timeouts and ensures event durability.
import express from 'express';
import { cognigyWebhookQueue } from './queue.js';
const router = express.Router();
router.post('/webhook/cognigy', express.json(), async (req, res) => {
const { botId, eventId, type, payload, timestamp } = req.body;
if (!botId || !eventId || !type) {
return res.status(400).json({ error: 'Missing required Cognigy webhook fields' });
const jobId = uuidv4();
await cognigyWebhookQueue.add(
'deliver-event',
jobId,
botId,
eventId,
type,
payload,
timestamp,
source: 'cognigy-webhook'
jobId,
removeOnComplete: true,
removeOnFail: false
// Acknowledge receipt immediately to Cognigy
res.status(200).json({ status: 'accepted', jobId });
} catch (error) {
console.error('Failed to enqueue Cognigy webhook:', error.message);
res.status(503).json({ error: 'Queue unavailable' });
export default router;
The endpoint validates the incoming payload structure, generates a unique jobId, and pushes the event to the queue. Returning 200 OK immediately prevents Cognigy from triggering its own retry mechanism, which would cause duplicate events. The queue producer configuration explicitly sets removeOnFail: false so failed jobs remain in Redis for inspection and manual replay.
Step 3: Implement the Bull Worker with Idempotent Delivery and Pagination Support
The worker processes queued events, verifies them against the Cognigy API for idempotency, and delivers the payload to the target endpoint. You must handle HTTP errors explicitly, distinguish between retryable and permanent failures, and support pagination when fetching event details for audit trails.
import { getCognigyToken } from './auth.js';
const TARGET_ENDPOINT = process.env.TARGET_ENDPOINT || 'https://internal-api.example.com/events';
cognigyWebhookQueue.process('deliver-event', async (job) => {
const { botId, eventId, type, payload, timestamp } = job.data;
const attempt = job.attemptsMade;
console.log(`Processing event ${eventId} (attempt ${attempt})`);
// Step 1: Verify event exists in Cognigy API for idempotency
const token = await getCognigyToken();
const cognigyEventUrl = `${process.env.COGNIGY_BASE_URL || 'https://platform.cognigy.ai'}/api/v2/bots/${botId}/events/${eventId}`;
const cognigyResponse = await axios.get(cognigyEventUrl, {
headers: {
timeout: 8000
// Realistic Cognigy API response structure
// "id": "evt_abc123",
// "botId": "bot_xyz789",
// "type": "conversation.message.received",
// "timestamp": "2024-06-15T10:30:00Z",
// "data": { ... }
if (cognigyResponse.status !== 200) {
throw new Error(`Cognigy API returned ${cognigyResponse.status} for event ${eventId}`);
// Step 2: Deliver payload to target system
const deliveryResponse = await axios.post(TARGET_ENDPOINT, payload, {
headers: {
'X-Event-Id': eventId,
'X-Source': 'cognigy-webhook-relay',
'Idempotency-Key': `cognigy-${botId}-${eventId}`
timeout: 15000
if (deliveryResponse.status >= 200 && deliveryResponse.status < 300) {
console.log(`Successfully delivered event ${eventId}`);
return deliveryResponse.data;
// Step 3: Handle non-retryable errors
if (deliveryResponse.status === 400 || deliveryResponse.status === 422) {
const permanentError = new Error(`Target system rejected payload: ${deliveryResponse.status}`);
permanentError.retryable = false;
throw permanentError;
// Step 4: Handle retryable errors
if (deliveryResponse.status === 429) {
const retryAfter = deliveryResponse.headers['retry-after'] || 5;
throw new Error(`Rate limited. Retry after ${retryAfter}s`);
if (deliveryResponse.status >= 500) {
throw new Error(`Server error from target: ${deliveryResponse.status}`);
The worker performs three critical operations. First, it calls GET /api/v2/bots/{botId}/events/{eventId} to verify the event exists and matches the webhook payload. This prevents processing stale or duplicated events. Second, it POSTs the payload to the target endpoint with an Idempotency-Key header to prevent duplicate processing. Third, it categorizes HTTP responses: 4xx errors like 400 and 422 are marked as non-retryable, while 429 and 5xx errors trigger Bull’s exponential backoff. The retryable: false flag on custom errors ensures Bull moves the job directly to the failed state without wasting attempts.
Step 4: Handle Dead Letter Queue Events and Circuit Breaking
Jobs that exhaust all retry attempts move to the failed state. You must implement event listeners to log failures, trigger alerts, and optionally retry via a manual reconciliation process. Pagination support applies when querying failed jobs for bulk reprocessing.
cognigyWebhookQueue.on('failed', async (job, error) => {
console.error(`Job ${job.id} failed permanently: ${error.message}`);
// Log to external monitoring system
console.error({
eventId: job.data.eventId,
botId: job.data.botId,
attempts: job.attemptsMade,
error: error.message,
// Optional: Push to a separate DLQ for manual review
'dlq-review',
{ ...job.data, failureReason: error.message },
{ removeOnComplete: true, attempts: 1 }
cognigyWebhookQueue.on('error', (error) => {
console.error('Queue system error:', error.message);
* Fetches failed jobs with pagination for audit and replay.
export async function getFailedJobs(limit = 50, offset = 0) {
const jobs = await cognigyWebhookQueue.getJobs(['failed'], offset, offset + limit, true);
return jobs.map(job => ({
failedReason: job.failedReason,
timestamp: job.finishedOn
The failed event listener captures jobs that exhausted all retries. It logs structured data for monitoring systems and optionally pushes the job to a dedicated DLQ for manual inspection. The getFailedJobs function demonstrates pagination using Bull’s getJobs method with the ['failed'] state filter. This allows administrators to review and manually replay events without losing audit trails.
The following script combines authentication, queue configuration, webhook receiver, and worker processing into a single runnable module. Save this as index.js, install dependencies, and set the required environment variables.
import webhookRouter from './webhook.js';
dotenv.config();
const app = express();
app.use(express.json());
app.use('/api', webhookRouter);
const redisClient = new IORedis({ host: REDIS_HOST, port: REDIS_PORT, maxRetriesPerRequest: null });
redis: redisClient,
defaultJobOptions: { attempts: 5, backoff: { type: 'exponential', delay: 2000 }, removeOnComplete: 100, removeOnFail: 50 }
const authHeader = Buffer.from(`${process.env.COGNIGY_CLIENT_ID}:${process.env.COGNIGY_CLIENT_SECRET}`).toString('base64');
const response = await axios.post(tokenUrl, new URLSearchParams({ grant_type: 'client_credentials' }), {
headers: { 'Authorization': `Basic ${authHeader}`, 'Content-Type': 'application/x-www-form-urlencoded', 'Accept': 'application/json' },
timeout: 10000
if (!accessToken || Date.now() >= tokenExpiry) await fetchCognigyToken();
return accessToken;
const { botId, eventId, payload } = job.data;
const cognigyEventUrl = `${COGNIGY_BASE_URL}/api/v2/bots/${botId}/events/${eventId}`;
headers: { 'Authorization': `Bearer ${token}`, 'Accept': 'application/json' },
timeout: 8000
if (cognigyResponse.status !== 200) throw new Error(`Cognigy API returned ${cognigyResponse.status}`);
headers: { 'Content-Type': 'application/json', 'X-Event-Id': eventId, 'Idempotency-Key': `cognigy-${botId}-${eventId}` },
timeout: 15000
if (deliveryResponse.status >= 200 && deliveryResponse.status < 300) return deliveryResponse.data;
if ([400, 422].includes(deliveryResponse.status)) {
const err = new Error(`Target rejected: ${deliveryResponse.status}`);
err.retryable = false;
throw err;
throw new Error(`Delivery failed: ${deliveryResponse.status}`);
cognigyWebhookQueue.on('failed', (job, error) => {
app.listen(process.env.PORT || 3000, () => {
console.log('Cognigy webhook relay running on port 3000');
Run the service with node index.js. The application starts an Express server on port 3000, initializes the Bull queue with Redis, and begins processing queued events. Replace environment variables with your Cognigy client credentials and target endpoint URL.
Error: 401 Unauthorized from Cognigy API
- Cause: The OAuth token expired or was never cached correctly. Client credentials are invalid or scopes are missing.
- Fix: Verify
COGNIGY_CLIENT_IDandCOGNIGY_CLIENT_SECRETenvironment variables. Ensure the OAuth client hasbot:readandevent:readscopes assigned in the Cognigy Admin Console. Check the token refresh logic ingetCognigyTokento confirm the expiry margin calculation. - Code showing the fix: Add explicit scope validation during token fetch:
const response = await axios.post(tokenUrl, new URLSearchParams({ grant_type: 'client_credentials', scope: 'bot:read event:read webhook:read' }), {
headers: { 'Authorization': `Basic ${authHeader}`, 'Content-Type': 'application/x-www-form-urlencoded' }
Error: 403 Forbidden on Event Retrieval
- Cause: The OAuth client lacks permission to access the specified bot or event. The bot ID in the webhook payload does not match an accessible resource.
- Fix: Assign the OAuth client to the specific bot environment in Cognigy. Verify the
botIdmatches the exact identifier returned byGET /api/v2/bots. Add logging to capture the full Cognigy API response for scope mismatch details. - Code showing the fix:
if (cognigyResponse.status === 403) {
console.error('Scope mismatch or bot access denied:', cognigyResponse.data);
throw new Error('Cognigy bot access forbidden');
Error: 429 Too Many Requests on Target Endpoint
- Cause: The downstream system enforces rate limits that exceed Bull’s default backoff interval.
- Fix: Parse the
Retry-Afterheader from the target response and dynamically adjust the job delay. Bull supports custom backoff functions that read headers and calculate precise wait times. - Code showing the fix:
const retryAfter = parseInt(deliveryResponse.headers['retry-after'] || '5', 10);
job.moveToDelayed(Date.now() + retryAfter * 1000);
return;
Error: Bull Queue Stalls or Jobs Remain in Delayed State
- Cause: Redis connection drops, memory exhaustion, or worker process crashes without graceful shutdown.
- Fix: Implement Redis reconnection logic, monitor queue length metrics, and add process signal handlers to complete in-flight jobs before exit. Use
queue.close()during shutdown to flush pending acknowledgments. - Code showing the fix:
process.on('SIGTERM', async () => {
console.log('Shutting down gracefully...');
await cognigyWebhookQueue.close();
await redisClient.quit();
process.exit(0);
