Implementing a Dead Letter Queue for Failed Genesys Cloud Webhook Deliveries
  • A Python-based webhook receiver that detects 5xx server errors from downstream services and moves failed payloads to a persistent dead letter queue (DLQ) using Amazon SQS.
  • This solution uses the Genesys Cloud Webhook API for configuration and the AWS SDK (boto3) for queue management.
  • The implementation is written in Python 3.9+ using FastAPI for the HTTP server and boto3 for AWS integration.
  • Genesys Cloud OAuth Client: A client credential flow application with the scope webhook:read (for verification) and webhook:write (if configuring via API).
  • AWS Account: An active Amazon SQS queue configured for the DLQ.
  • Python Runtime: Python 3.9 or higher.
  • Dependencies:
    • fastapi (for the webhook endpoint)
    • uvicorn (ASGI server)
    • boto3 (AWS SDK)
    • pydantic (for data validation)
    • requests (for testing)
Install the dependencies via pip:
pip install fastapi uvicorn boto3 pydantic requests
Genesys Cloud uses OAuth 2.0 for API access. While webhook delivery itself does not require an access token (the payload is POSTed to your URL), you may need to authenticate to verify webhook configurations or programmatically create them.
The following code demonstrates how to obtain an access token using the Client Credentials Grant. This token is required if you are using the SDK to inspect webhook definitions.
import requests
import os
from typing import Optional
class GenesysAuth:
    def __init__(self, client_id: str, client_secret: str, env: str = "us-east-1"):
        self.client_id = client_id
        self.base_url = f"https://{env}.mygen.com"
        self.token_url = f"{self.base_url}/oauth/token"
    def get_access_token(self) -> Optional[str]:
        Retrieves an OAuth 2.0 access token using Client Credentials.
        Required Scope: webhook:read webhook:write
        headers = {
        data = {
            "client_id": self.client_id,
            "scope": "webhook:read webhook:write"
            response = requests.post(self.token_url, headers=headers, data=data)
            response.raise_for_status()
            token_data = response.json()
            return token_data.get("access_token")
            print(f"Authentication failed: {e.response.status_code} - {e.response.text}")
            return None
            print(f"Error fetching token: {e}")
            return None
Store your credentials in environment variables to avoid hardcoding secrets.
export GENESYS_CLIENT_ID="your_client_id"
export GENESYS_CLIENT_SECRET="your_client_secret"
export AWS_ACCESS_KEY_ID="your_aws_key"
export AWS_SECRET_ACCESS_KEY="your_aws_secret"
export AWS_REGION="us-east-1"
export DLQ_URL="https://sqs.us-east-1.amazonaws.com/123456789012/webhook-dlq"
Step 1: Define the Webhook Payload Structure
Genesys Cloud webhooks send JSON payloads. The structure depends on the trigger (e.g., routing:queue:member:added). You must define a Pydantic model to validate incoming requests. This ensures that malformed data is rejected before processing, preventing downstream errors.
from typing import Any, Dict, List, Optional
from datetime import datetime
class GenesysWebhookPayload(BaseModel):
    Generic structure for Genesys Cloud Webhook payloads.
    Actual fields vary by trigger, but 'id', 'type', and 'data' are common.
    type: str
    timestamp: Optional[str] = None
    data: Dict[str, Any] = Field(default_factory=dict)
    metadata: Optional[Dict[str, Any]] = None
    class Config:
        # Allow extra fields for flexibility as Genesys payload schemas evolve
        extra = "allow"
Step 2: Configure the Dead Letter Queue Client
We use boto3 to interact with Amazon SQS. The DLQ stores messages that failed to process due to 5xx errors from your downstream service. We implement exponential backoff logic locally before sending to the DLQ to avoid flooding the queue with transient errors.
import boto3
from botocore.exceptions import ClientError
import json
import logging
class DeadLetterQueueManager:
    def __init__(self, sqs_url: str, region_name: str = "us-east-1"):
        self.sqs = boto3.client("sqs", region_name=region_name)
        self.queue_url = sqs_url
    def send_to_dlq(self, payload: GenesysWebhookPayload, error_context: str) -> bool:
        Sends a failed webhook payload to the SQS Dead Letter Queue.
        Args:
            payload: The original Genesys webhook payload.
            error_context: Details about why the downstream service failed.
        Returns:
            True if successfully sent, False otherwise.
        dlq_message = {
            "original_payload": payload.dict(),
            "error_context": error_context,
            "dlq_timestamp": datetime.utcnow().isoformat(),
            "retry_count": 0  # Indicates this is the first entry in DLQ
            response = self.sqs.send_message(
                QueueUrl=self.queue_url,
                MessageBody=json.dumps(dlq_message),
                MessageAttributes={
                    "WebhookType": {
                        "DataType": "String",
                        "StringValue": payload.type
            logger.info(f"Message sent to DLQ. Id: {response.get('MessageId')}")
            return True
        except ClientError as e:
            logger.error(f"Failed to send to DLQ: {e}")
            return False
Step 3: Implement the Webhook Receiver with Retry Logic
This is the core component. The FastAPI endpoint receives the POST request. It attempts to process the data against a downstream service (simulated here). If the downstream service returns a 5xx error, the receiver implements local retries with exponential backoff. If all retries fail, the payload is moved to the DLQ.
from fastapi import FastAPI, Request, HTTPException
from fastapi.responses import JSONResponse
import httpx
import asyncio
app = FastAPI(title="Genesys Webhook Receiver with DLQ")
dlq_manager = DeadLetterQueueManager(
    sqs_url=os.getenv("DLQ_URL"),
    region_name=os.getenv("AWS_REGION", "us-east-1")
# Simulated downstream service URL
DOWNSTREAM_SERVICE_URL = "https://your-downstream-service.com/api/process"
async def process_downstream(payload: GenesysWebhookPayload) -> bool:
    Simulates processing the webhook in a downstream microservice.
    Returns True on success, False on 5xx error.
            response = await client.post(
                DOWNSTREAM_SERVICE_URL,
                json=payload.dict(),
                headers={"Content-Type": "application/json"}
            # Genesys expects a 2xx response to stop retries.
            # If downstream returns 5xx, we treat it as a failure.
            if response.status_code >= 500:
                logger.warning(f"Downstream service returned 5xx: {response.status_code}")
                return False
            # Treat 4xx as client errors (bad data), which should not be retried
            if response.status_code >= 400:
                logger.error(f"Downstream service returned 4xx: {response.status_code}")
                # Do not retry 4xx errors. Send directly to DLQ or log.
                raise Exception(f"Client error: {response.status_code}")
            return True
            logger.error(f"HTTP Error calling downstream: {e}")
            if e.response.status_code >= 500:
                return False
            raise
            logger.error(f"Unexpected error calling downstream: {e}")
            # Network errors or timeouts are transient; return False to trigger retry
            return False
@app.post("/webhook/genesys")
async def receive_webhook(request: Request):
    Endpoint to receive Genesys Cloud Webhook POST requests.
    Genesys Cloud will retry delivery if it does not receive a 2xx response.
    This handler ensures that only transient 5xx errors are retried locally
    before moving to the DLQ.
        body = await request.json()
        payload = GenesysWebhookPayload(**body)
        # Malformed JSON or missing required fields
        logger.error(f"Invalid payload: {e}")
        return JSONResponse(
            status_code=400,
            content={"error": "Invalid payload format"}
    # Configuration for local retries
    max_retries = 3
    base_delay = 1.0  # seconds
            success = await process_downstream(payload)
            if success:
                # Return 200 OK to Genesys to stop its own retries
                    status_code=200,
                    content={"status": "processed"}
            # If we reach here, process_downstream returned False (5xx or transient error)
            if attempt < max_retries - 1:
                delay = base_delay * (2 ** attempt)
                logger.info(f"Retry {attempt + 1}/{max_retries} after {delay}s due to 5xx error")
                await asyncio.sleep(delay)
            else:
                # All retries exhausted
                logger.error("Max retries reached. Sending to DLQ.")
                dlq_manager.send_to_dlq(
                    payload=payload,
                    error_context=f"Max retries ({max_retries}) exhausted for type: {payload.type}"
                # Return 200 to Genesys to acknowledge receipt and stop Genesys retries
                # The message is now in the DLQ for manual inspection/replay
                    status_code=200,
                    content={"status": "moved_to_dlq"}
            # Non-transient error (e.g., 4xx from downstream)
            logger.error(f"Non-retryable error: {e}")
                payload=payload,
                error_context=f"Non-retryable error: {str(e)}"
                status_code=200,
                content={"status": "moved_to_dlq_due_to_client_error"}
Step 4: Verify Webhook Configuration in Genesys Cloud
To ensure this endpoint is called, you must configure a webhook in Genesys Cloud. The following script uses the Genesys Cloud Python SDK to create a webhook that triggers when a conversation is created.
from purecloudplatformclientv2 import (
    ApiClient,
    Configuration,
    WebhooksApi,
    Webhook,
    WebhookDestination,
    WebhookTrigger,
    WebhookFilter
def create_webhook(auth: GenesysAuth, endpoint_url: str) -> Webhook:
    Creates a webhook in Genesys Cloud using the SDK.
    token = auth.get_access_token()
    if not token:
        raise Exception("Failed to authenticate")
    configuration = Configuration()
    configuration.access_token = token
    configuration.host = f"https://{auth.base_url}/api/v2"
    client = ApiClient(configuration)
    webhooks_api = WebhooksApi(client)
    # Define the destination (your FastAPI endpoint)
    destination = WebhookDestination(
        name="DLQ Webhook Receiver",
        url=endpoint_url,
        headers={
    # Define the trigger (e.g., Conversation Created)
    trigger = WebhookTrigger(
        event="routing:conversation:created"
    # Define the webhook
    webhook = Webhook(
        name="DLQ Test Webhook",
        description="Webhook for DLQ tutorial",
        destinations=[destination],
        trigger=trigger,
        enabled=True,
        delivery_policy={
            "retry_delay": 5000, # 5 seconds
            "max_retries": 3
        created_webhook = webhooks_api.post_webhooks(body=webhook)
        logger.info(f"Webhook created: {created_webhook.id}")
        return created_webhook
        logger.error(f"Failed to create webhook: {e}")
        raise
The following script combines authentication, DLQ setup, and the FastAPI application. Save this as main.py.
import os
import uvicorn
import httpx
import asyncio
import boto3
import json
import logging
from typing import Any, Dict, Optional
# --- Configuration ---
DLQ_URL = os.getenv("DLQ_URL", "https://sqs.us-east-1.amazonaws.com/123456789012/webhook-dlq")
AWS_REGION = os.getenv("AWS_REGION", "us-east-1")
DOWNSTREAM_URL = os.getenv("DOWNSTREAM_URL", "https://httpbin.org/post") # Use httpbin for testing
# --- Data Models ---
    type: str
    class Config:
        extra = "allow"
# --- DLQ Manager ---
    def __init__(self, sqs_url: str, region_name: str):
        dlq_message = {
            "source": "genesys-webhook-receiver"
            return True
            logger.error(f"DLQ Send Failed: {e}")
            return False
# --- Application Logic ---
app = FastAPI(title="Genesys Webhook DLQ Receiver")
dlq_manager = DeadLetterQueueManager(DLQ_URL, AWS_REGION)
            # Simulate a 500 error if a specific header is present for testing
            headers = {}
            if payload.metadata and payload.metadata.get("force_error"):
                headers["X-Force-Error"] = "true"
                DOWNSTREAM_URL,
                headers=headers
                return False
                raise Exception(f"Client Error: {response.status_code}")
            return True
            # Transient errors
            if "timeout" in str(e).lower() or "connection" in str(e).lower():
                return False
            raise
        return JSONResponse(status_code=400, content={"error": "Invalid payload"})
    max_retries = 3
    base_delay = 1.0
            if success:
                return JSONResponse(status_code=200, content={"status": "success"})
                await asyncio.sleep(base_delay * (2 ** attempt))
            else:
                dlq_manager.send_to_dlq(payload, "Max retries exhausted")
                return JSONResponse(status_code=200, content={"status": "dlq"})
            dlq_manager.send_to_dlq(payload, f"Non-retryable: {str(e)}")
    uvicorn.run(app, host="0.0.0.0", port=8000)
Error: botocore.exceptions.ClientError: An error occurred (403) when calling the SendMessage operation
  • Cause: The IAM role or user associated with your AWS credentials does not have permission to send messages to the specified SQS queue.
  • Fix: Ensure your AWS_ACCESS_KEY_ID and AWS_SECRET_ACCESS_KEY have the SQS:SendMessage permission for the target queue ARN.
  • Code Fix: Verify environment variables are loaded correctly before initializing DeadLetterQueueManager.
Error: 429 Too Many Requests from Genesys Cloud
  • Cause: Your webhook receiver is responding too slowly, or Genesys Cloud is retrying because you are not returning a 2xx status code within the timeout window.
  • Fix: Ensure your FastAPI endpoint returns a 200 OK immediately after deciding to retry locally or send to DLQ. Do not block the Genesys HTTP connection while waiting for retries. The code above returns 200 after local retries are exhausted, which stops Genesys from retrying.
Error: Pydantic ValidationError
  • Cause: The incoming JSON from Genesys Cloud does not match the GenesysWebhookPayload model.
  • Fix: Genesys Cloud payloads vary by trigger. Ensure your Pydantic model allows extra fields (extra = "allow") and makes optional fields optional. Inspect the raw request body in logs to adjust the model.
