Implementing a Daily Analytics Export Job to S3 Using Python and Genesys Cloud
You will build a Python script that queries the Genesys Cloud Analytics API for the previous day’s conversation details and streams that data directly into an Amazon S3 bucket as a compressed CSV file.
This tutorial utilizes the Genesys Cloud analytics/conversations/details/query endpoint and the Python boto3 library for S3 operations.
The implementation covers asynchronous pagination, error handling for rate limits, and efficient memory management for large datasets.
Before writing code, ensure the following environment requirements are met.
OAuth Client Configuration
- You need a Genesys Cloud OAuth Client ID and Client Secret.
- The client must be configured with the Confidential access type (Authorization Code or Client Credentials flow). For this server-to-server job, Client Credentials is preferred.
- Required Scope:
analytics:queryis mandatory. If you need to filter by specific users or queues, you may also needuser:readorrouting:queue:readdepending on your filtering logic, but for raw data extraction,analytics:queryis sufficient.
AWS Configuration
- An AWS Account with an active S3 bucket.
- An IAM User or Role with
s3:PutObjectpermissions on the target bucket. - AWS credentials configured in your environment variables (
AWS_ACCESS_KEY_ID,AWS_SECRET_ACCESS_KEY,AWS_DEFAULT_REGION) or via a credentials file.
Software Dependencies
- Python 3.9+
pip install requests boto3 pandasrequests: For making HTTP calls to the Genesys Cloud API.boto3: The AWS SDK for Python.pandas: For efficient CSV serialization and memory management.
Genesys Cloud uses OAuth 2.0 for authentication. For a background job, the Client Credentials grant type is the standard approach. This flow exchanges your Client ID and Secret for an access token without user interaction.
The token expires after one hour. A robust job should cache this token or re-fetch it if the API returns a 401 Unauthorized error. In this tutorial, we will implement a simple token fetch function.
import requests
import os
# Configuration
GENESYS_CLOUD_CLIENT_ID = os.getenv("GENESYS_CLIENT_ID")
GENESYS_CLOUD_CLIENT_SECRET = os.getenv("GENESYS_CLIENT_SECRET")
GENESYS_CLOUD_BASE_URL = "https://api.mypurecloud.com" # Use your specific region URL, e.g., api.us-gov-pure.cloud
def get_access_token() -> str:
Retrieves an OAuth 2.0 access token using Client Credentials flow.
token_url = f"{GENESYS_CLOUD_BASE_URL}/oauth/token"
payload = {
"client_id": GENESYS_CLOUD_CLIENT_ID,
"client_secret": GENESYS_CLOUD_CLIENT_SECRET,
"scope": "analytics:query"
response = requests.post(token_url, data=payload)
if response.status_code != 200:
raise Exception(f"Failed to retrieve token: {response.status_code} - {response.text}")
token_data = response.json()
return token_data["access_token"]
Note on Regions: Replace api.mypurecloud.com with your specific region endpoint if you are operating in a non-default region (e.g., api.au-pure.cloud for Australia).
Step 1: Define the Analytics Query Payload
The Genesys Cloud Analytics API requires a specific JSON structure to define what data you want. We are targeting Conversation Details. This endpoint provides row-level data for every interaction (call, chat, email, etc.).
To export the previous day’s data, we must construct a date range. We will calculate the start and end times for the previous day in UTC.
import json
def get_previous_day_query_payload() -> dict:
Constructs the query payload for the previous day's conversation details.
# Calculate yesterday's date range in UTC
now = datetime.utcnow()
yesterday_start = (now - timedelta(days=1)).replace(hour=0, minute=0, second=0, microsecond=0)
yesterday_end = (now - timedelta(days=1)).replace(hour=23, minute=59, second=59, microsecond=999999)
# Format as ISO 8601 with timezone offset (UTC is +00:00)
start_time = yesterday_start.strftime("%Y-%m-%dT%H:%M:%S+00:00")
end_time = yesterday_end.strftime("%Y-%m-%dT%H:%M:%S+00:00")
query = {
"dateFrom": start_time,
"dateTo": end_time,
"interval": "PT1H", # Hourly intervals are standard for detail queries
"view": "conversationDetails", # Specific view for row-level data
"groupBy": [], # No grouping for raw details
"metrics": [
"talkDuration",
"holdDuration",
"workDuration"
"filters": {
"type": "AND",
"filters": [
"type": "EQUALS",
"dimension": "channel",
"value": "voice" # Example: Filter only voice calls. Remove to get all channels.
return query
Why conversationDetails?
The conversationDetails view returns individual records for each interaction. This is distinct from summary views which aggregate data. For an S3 export intended for downstream BI tools (like Snowflake or Redshift), raw details are usually preferred.
Step 2: Implement Pagination and Rate Limit Handling
The Genesys Cloud API paginates results. The analytics/conversations/details/query endpoint returns a maximum of 10,000 records per page. If your daily volume exceeds this, you must iterate through pages.
Additionally, Genesys Cloud enforces strict rate limits (typically 30 requests per second for most analytics endpoints). You must implement a backoff strategy when you encounter a 429 Too Many Requests response.
import requests
import logging
def fetch_analytics_page(token: str, query: dict, next_page_token: str = None) -> tuple:
Fetches a single page of analytics data.
Returns (data_list, next_page_token, success_bool)
url = f"{GENESYS_CLOUD_BASE_URL}/api/v2/analytics/conversations/details/query"
headers = {
"Accept": "application/json"
# If we have a next page token, we use a POST with the body including the token
# The first request is a POST. Subsequent requests can also be POSTs with the body.
payload = query.copy()
if next_page_token:
payload["nextPageToken"] = next_page_token
# Retry logic for 429 and 5xx errors
max_retries = 5
response = requests.post(url, headers=headers, json=payload, timeout=30)
if response.status_code == 200:
return data.get("entities", []), data.get("nextPageToken"), True
elif response.status_code == 429:
# Rate limited. Wait and retry.
retry_after = int(response.headers.get("Retry-After", 2 ** attempt))
logger.warning(f"Rate limited (429). Waiting {retry_after} seconds...")
time.sleep(retry_after)
elif response.status_code == 401:
raise Exception("Token expired. Refresh required.")
elif response.status_code >= 500:
# Server error. Wait and retry.
logger.warning(f"Server error {response.status_code}. Retrying in {2 ** attempt} seconds...")
time.sleep(2 ** attempt)
else:
raise Exception(f"API Error: {response.status_code} - {response.text}")
logger.error(f"Network error: {e}")
raise Exception("Max retries exceeded for API call.")
def fetch_all_analytics_data(token: str, query: dict) -> list:
Iterates through all pages of analytics data until no nextPageToken is returned.
all_records = []
next_token = None
page_count = 0
while True:
page_count += 1
logger.info(f"Fetching page {page_count}...")
records, next_token, success = fetch_analytics_page(token, query, next_token)
if not success:
raise Exception("Failed to fetch analytics data.")
all_records.extend(records)
logger.info(f"Retrieved {len(records)} records. Total so far: {len(all_records)}")
# If no next page token, we are done
if not next_token:
break
# Small delay to be respectful of rate limits even if not 429'd
time.sleep(0.5)
return all_records
Step 3: Process and Upload to S3
Loading all records into memory (all_records in Step 2) works for small-to-medium volumes (e.g., < 50,000 records). For very high volumes, this approach will consume significant RAM.
For this tutorial, we will use Pandas to convert the list of dictionaries into a DataFrame and then write it to a CSV buffer. This buffer is then uploaded to S3 using boto3.
import boto3
import pandas as pd
import io
def upload_to_s3(records: list, bucket_name: str, file_key: str) -> None:
Converts records to CSV and uploads to S3.
if not records:
logger.warning("No records to upload.")
return
logger.info(f"Processing {len(records)} records into CSV...")
# Convert list of dicts to DataFrame
df = pd.DataFrame(records)
# Flatten nested structures if necessary.
# Genesys often returns nested objects (e.g., 'routing.queue.name').
# Pandas explode or manual flattening might be needed for complex BI ingestion.
# For this example, we assume a flat structure or acceptable nested JSON in CSV cells.
# Create an in-memory bytes buffer for the CSV
csv_buffer = io.StringIO()
df.to_csv(csv_buffer, index=False, quoting=1) # quoting=1 ensures all fields are quoted
csv_content = csv_buffer.getvalue()
# Upload to S3
s3_client = boto3.client('s3')
s3_client.put_object(
Bucket=bucket_name,
Key=file_key,
Body=csv_content.encode('utf-8'),
ContentType='text/csv'
logger.info(f"Successfully uploaded {file_key} to {bucket_name}")
logger.error(f"Failed to upload to S3: {e}")
raise e
Below is the complete, runnable Python script. Save this as genesys_s3_export.py.
import os
import requests
import boto3
import pandas as pd
import io
import logging
# Configure Logging
level=logging.INFO,
format='%(asctime)s - %(levelname)s - %(message)s'
# --- Configuration ---
GENESYS_CLOUD_BASE_URL = os.getenv("GENESYS_CLOUD_BASE_URL", "https://api.mypurecloud.com")
S3_BUCKET_NAME = os.getenv("S3_BUCKET_NAME")
S3_PREFIX = "analytics/conversations/" # e.g., analytics/conversations/2023-10-27.csv
# --- Authentication ---
payload = {
# --- Data Querying ---
query = {
"dateTo": end_time,
"interval": "PT1H",
"groupBy": [],
"metrics": [
"talkDuration",
"holdDuration",
"workDuration"
"filters": {
"type": "AND",
"filters": [
"type": "EQUALS",
"value": "voice"
return query
Fetches a single page of analytics data with retry logic for 429/5xx.
headers = {
if next_page_token:
max_retries = 5
else:
Iterates through all pages of analytics data.
all_records = []
next_token = None
page_count = 0
while True:
page_count += 1
if not success:
if not next_token:
break
time.sleep(0.5) # Respect rate limits
return all_records
# --- S3 Upload ---
if not records:
return
logger.error(f"Failed to convert data to DataFrame: {e}")
raise e
Bucket=bucket_name,
Key=file_key,
raise e
# --- Main Execution ---
def main():
if not all([GENESYS_CLOUD_CLIENT_ID, GENESYS_CLOUD_CLIENT_SECRET, S3_BUCKET_NAME]):
raise ValueError("Missing required environment variables.")
logger.info("Starting Genesys Cloud Analytics Export Job...")
# 1. Authenticate
token = get_access_token()
logger.info("Authenticated successfully.")
# 2. Build Query
query = get_previous_day_query_payload()
logger.info(f"Query Date Range: {query['dateFrom']} to {query['dateTo']}")
# 3. Fetch Data
records = fetch_all_analytics_data(token, query)
logger.info(f"Total records fetched: {len(records)}")
# 4. Upload to S3
yesterday_str = (datetime.utcnow() - timedelta(days=1)).strftime("%Y-%m-%d")
file_key = f"{S3_PREFIX}{yesterday_str}.csv"
upload_to_s3(records, S3_BUCKET_NAME, file_key)
logger.info("Job completed successfully.")
logger.error(f"Job failed: {e}")
raise e
main()
Cause: The OAuth token has expired or was invalid.
Fix: Ensure your Client ID and Secret are correct. In a production scheduler, wrap the token fetch in a try-catch block that retries the token acquisition if the API returns 401. The code above raises an exception, which should trigger your scheduler (e.g., Airflow, Cron) to retry or alert.
Cause: You have exceeded the Genesys Cloud API rate limit.
Fix: The fetch_analytics_page function includes retry logic with exponential backoff. If you are still hitting 429s, increase the time.sleep(0.5) delay between pages. For very high-volume accounts, consider staggering requests or using the Genesys Cloud Data Export feature if available, though the API provides more granular control.
Error: MemoryError or High RAM Usage
Cause: The all_records list grows too large in memory.
Fix: For volumes exceeding 100,000 records, modify fetch_all_analytics_data to yield records or write chunks directly to S3 instead of aggregating them in a single list. You can use boto3’s upload_fileobj with a generator or write multiple part files and merge them.
Error: KeyError in Pandas DataFrame
Cause: Inconsistent data structures in the API response. Some records may have optional fields missing.
Fix: The pd.DataFrame() constructor handles missing keys by filling them with NaN. If you need specific columns, explicitly select them: df = pd.DataFrame(records)[['id', 'startTime', 'talkDuration']].
